    4. Test ViessmannAPI v2.0.0
      BlackTigga @BlackTigga last edited by BlackTigga
      @tombox sagte in Test ViessmannAPI v2.0.0:
      Bitte nochmal installieren und ein paar debug zeilen schicken
      Anbei meine weiteren Beobachtungen:
      Nachdem gestern im Laufe des Tages das Request-Limit erreicht wurde, erschien bis kurz vor 02:00 Uhr folgende Meldung:
      2021-08-11 01:59:38.751 - info: viessmannapi.0 (19325) Rate limit reached. Will be reseted next day 02:00
      2021-08-11 01:59:38.752 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
      2021-08-11 01:59:38.752 - error: viessmannapi.0 (19325) Error: Request failed with status code 429
      Der nächste (und einzige) Logeintrag war dann um 02:40 Uhr:
      2021-08-11 02:40:38.929 - info: viessmannapi.0 (19325) {"viErrorId":"req-a8064f7bb16d4e2997deb18e4d760b82","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
      2021-08-11 02:40:38.940 - info: viessmannapi.0 (19325) Please check the connection of your gateway
      2021-08-11 02:40:38.941 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
      2021-08-11 02:40:38.942 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
      2021-08-11 02:40:38.954 - info: viessmannapi.0 (19325) {"viErrorId":"req-2ee6cfab343b4c3a9d175fc79c7af20a","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
      2021-08-11 02:40:38.955 - info: viessmannapi.0 (19325) Please check the connection of your gateway
      2021-08-11 02:40:38.956 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
      2021-08-11 02:40:38.957 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
      2021-08-11 02:40:39.004 - info: viessmannapi.0 (19325) {"viErrorId":"req-9534206120014dc5a58a3f6809c10b10","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
      2021-08-11 02:40:39.005 - info: viessmannapi.0 (19325) Please check the connection of your gateway
      2021-08-11 02:40:39.006 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
      2021-08-11 02:40:39.007 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
      Um 07:19 habe ich den Adapter neu gestartet, seitdem laufen die Daten wieder rein:
      2021-08-11 07:20:57.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
      2021-08-11 07:20:57.408 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
      2021-08-11 07:20:58.558 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
      2021-08-11 07:21:59.559 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
      2021-08-11 07:22:57.085 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
      2021-08-11 07:22:57.351 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
      2021-08-11 07:22:59.194 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
      2021-08-11 07:23:56.993 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
      2021-08-11 07:23:57.181 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
      2021-08-11 07:23:58.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
      2021-08-11 07:24:56.996 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
      2021-08-11 07:24:57.460 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
        LaBamba @LaBamba last edited by
        @tombox
        Danke, ich hatte sie zwar installiert aber anscheinend wurde die installation abgebrochen. Nach der Neuinstallation funktioniert es wieder.
          tombox @BlackTigga last edited by tombox
          @blacktigga DAs ist sehr hilfreich
          was sind die Geräte
          RoomControl-1 und HeatDemandControl
          Haben die irgendwelche Sensoren oder braucht man davon Informationen?
            Ich sehe in beiden Datensätzen im Log keinerlei Informationen die ich benötigen würde und ich habe auch keine gesonderten Sensoren verbaut.
            Und die Logeinträge zu HeatDemandControl sehen ja auch immer so aus (ungekürzt):
            2021-08-11 07:20:57.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/763741501xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
            Sieht für mich als Laie so aus, als wenn da sowieso gar keinerlei Daten abgeholt werden?!
              @blacktigga Ich habe dir dazu eine PN geschrieben
                amgxda @tombox last edited by
                Der Viessmann Developer Portal Changelog-Eintrag vom Juli 2021 ist auch bezeichnend. Da wird schon angekündigt, dass Datenpunkte und Funktionen hinter der Paywall verschwinden sollen. Warmwasser starten, nur gegen Gebühr, toll ausgedacht, Viessmann!
                "Hinweis: Die Funktionen der Basis (freien) Variante der API sind ein temporäres Angebot und der Umfang kann sich mit der Zeit gegenenfalls ändern."
                  A Former User last edited by
                  @amgxda Das war klar, denn die Entwicklungs- und Betriebskosten der Server kann man kaum mit dem einmaligen Kauf einer Anlage abdecken, denke ich ...
                  Wenn's n paar Euro sind im Jahr.. wir werden sehen..
                  Wenn's zu teuer wird, ist VControlD dann die Alternative.
                    amgxda last edited by
                    @ilovegym
                    Ja, sollte Viessmann hier zu restriktiv vorgehen, werde ich die vcontrold-Lösung nutzen. Die Cloud-Lösung nutze ich hauptsächlich wegen der versprochenen 5-Jahre-Garantie. Wenn ich es richtig sehe, muss bei vcontrold nur das USB-Kabel an den RPi, der vcontrold laufen und mit iobroker.viessmann bekommt man auch noch die Datenpunkte. Das komplizierteste scheint die Erstellung der Konfigurationsdateien zu sein.
                    Aber bis zum Garantie-Ende bin ich froh, dass es den viessmannapi-Adapter gibt 🙂
                      @blacktigga Ich habe eingebaut das die virtuelle Geräte nicht aktualisiert werden nochmal neu installieren und testen ob das limit jetzt reicht
                      • Tiger VI
                        Tiger VI @tombox last edited by
                        @tombox Danke für die Rückmeldung nach langen Probieren denke ich, dass es hier noch einen Fehler in der API von Viessmann gibt
                        "mon":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
                        "sun":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
                        Liefert Fehler 500
                        {"code":"500","reason":"COMMAND_EXECUTION_FAILURE","details":"Invalid schedule entry mode: standard."}}
                        Wenn man aber unter /features/ventilation.schedule/ die momentan konfigurieren Modes anschaut, heißen sie dort: "levelThree" für Standard und "levelFour" für Intensive Lüftungsstufe.
                        Wenn man "levelThree" nutzt kommt aber auch ein Fehler:
                        {"code":"400","reason":"VALIDATION_ERROR","details":"The parameter newSchedule ... does not meet the constraints {"type":"Schedule","modes":["reduced","standard","intensive"],
                        "maxEntries":8,"resolution":10,"defaultMode":"basic","overlapAllowed":true}:
                        Entry 'mon' has invalid mode."}}
                        Hab die Frage mal ins Viessmann Developer Forum gepostet
                          BlackTigga @tombox last edited by
                          Läuft seit heute morgen anstandslos durch 👍
                          viessmannapi.0 2021-08-12 16:22:25.665	debug	ignore type:virtual
                          viessmannapi.0 2021-08-12 16:22:25.664	debug	ignore type:virtual
                          viessmannapi.0 2021-08-12 16:22:25.650	debug	ignore type:gateway
                          viessmannapi.0 2021-08-12 16:21:26.324	debug	https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data"
                          Stefan Epunkt B 2 Replies Last reply Reply Quote 0
                          • Stefan Epunkt
                            Stefan Epunkt @BlackTigga last edited by
                            Moin an Alle,
                            ich hab nun schon gesucht und gesucht. Kann mir jemand sagen ob der Systemdruck bei den Datenpunkten dabei ist?
                            • Palm_Maniac
                              Palm_Maniac last edited by
                              ich bin heute endlich dazu gekommen den neuen Adapter zu testen.
                              Zunächst hatte ich einfach, ohne den alten zu löschen, den neuen installiert und bekam folgende Fehler im Log:
                              viessmannapi.0
                              2021-08-13 14:50:48.768	error	{"error":"internal server error"}
                              viessmannapi.0
                              2021-08-13 14:50:48.768	error	Error: Request failed with status code 500
                              viessmannapi.0
                              2021-08-13 14:50:48.533	info	starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v14.17.2, js-controller: 3.3.15
                              Dann habe ich ihn gelöscht und neu installiert mit dem gleichen Ergebnis, der Adapter bleibt auf Gelb mit diesen Einträgen im Log. Liegt das an mir oder an Viessmann?
                                tombox @Palm_Maniac last edited by
                                @palm_maniac 500 ist ein Fehler bei viessmann einfach abwarten und später probieren
                                R Palm_Maniac 2 Replies Last reply Reply Quote 1
                                  Ritschy2000 @tombox last edited by
                                  konnte eventuell schon jemand mit Wärmepumpe inkl. Kühlfunktion (NC) den entsprechenden Datenpunkt finden, woran man erkennt, dass die Kühlung gerade aktiv ist.
                                  Ich finde viele Punkte zum Thema "Cooling", allerdings wird kein Datenpunkt auf "true" gesetzt,
                                  obwohl gerade die Kühlung läuft...
                                  Tiger VI 1 Reply Last reply Reply Quote 0
                                  • Palm_Maniac
                                    Palm_Maniac @tombox last edited by Palm_Maniac
                                    @tombox also bei mir wird der Adapter auch nach fast 3 Tagen nicht grün, weiterhin Fehler 500. Da die App funktioniert und es wohl bei anderen auch funktioniert, verstehe ich nicht wieso es bei mir nicht will. So viel falsch machen kann man doch nicht...
                                    PS: Oh mann, bin ich ein Honk.... Ich hatte Recaptcha noch an... 🙄 Jetzt läufts. 😁
                                      schueli86 @tombox last edited by schueli86
                                      ich schaffe es nicht die Zeitprogramme für Wasser oder für die Heizung zu ändern. Wenn ich setValue aufrufe, dann erhalte ich nachfolgenden Fehler:
                                      statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"500","reason":"INTERNAL_SERVER_ERROR","details":"entries[cur].map is not a function"}}
                                      Ich habe bei zum Beispiel folgenden Wert bei viessmannapi.0.XXX.0.features.heating.dhw.schedule.commands.setSchedule.setValue verwendet:
                                        "mon": [
                                            "start": "05:30",
                                            "end": "19:30",
                                            "mode": "on",
                                            "position": 0
                                      Wenn ich das Heizprogramm verändere, dann erhalte ich den gleichen Fehler.
                                      T Tiger VI 2 Replies Last reply Reply Quote 0
                                        tombox @schueli86 last edited by
                                        @schueli86 Hast du mal hier gefragt
                                        https://www.viessmann-community.com/t5/Getting-started-programming-with/bd-p/dev-viessmann-api-getting-started
                                        ob sie helfen können wie der request korrekt aussehen soll
                                          @tombox bis jetzt noch nicht. Werde ich heute Abend mal machen. Ich hatte die Hoffnung, dass es hier schon jemand geschafft hat.
                                            @schueli86 Ich habe in die github version die error message verbessert dann hilft es die frage zu stellen
                                            795
                                            216791
