    4. [gelöst]Benötige Hilfe, Adapter lassen sich nicht mehr updaten
      SigiMOE last edited by
      Hier mal noch was, was nicht funktioniert hat : npm install iobroker.js-controller –production
      pi@raspberrypi:/opt/iobroker $ npm cache clean
      pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller --production
      npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
      ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
      node-gyp rebuild
      ! make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      /usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1plus: symbol lookup error: /usr/lib/arm-linux-gnueabihf/libmpfr.so.4: undefined symbol: __g?rfR_one
      unix_dgram.target.mk:92: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:106:13)
      gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp ERR! System Linux 4.4.21-v7+
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! node -v v6.9.4
      gyp ERR! node-gyp -v v3.5.0
      gyp ERR! not ok
      ! > iobroker.js-controller@0.15.3 install /opt/iobroker/node_modules/iobroker.js-controller
      node lib/setup.js setup first
      ! array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/array-flatten -> node_modules/array-flatten
      base64-url@1.3.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/base64-url -> node_modules/base64-url
      bytes@2.4.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/bytes -> node_modules/bytes
      connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash -> node_modules/connect-flash
      content-type@1.0.2 node_modules/iobroker.admin/node_modules/body-parser/node_modules/content-type -> node_modules/content-type
      cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie-signature -> node_modules/cookie-signature
      cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser -> node_modules/cookie-parser
      depd@1.1.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/depd -> node_modules/depd
      destroy@1.0.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/destroy -> node_modules/destroy
      ee-first@1.1.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished/node_modules/ee-first -> node_modules/ee-first
      encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/encodeurl -> node_modules/encodeurl
      escape-html@1.0.3 node_modules/iobroker.admin/node_modules/express/node_modules/escape-html -> node_modules/escape-html
      etag@1.7.0 node_modules/iobroker.admin/node_modules/express/node_modules/etag -> node_modules/etag
      ms@0.7.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug/node_modules/ms -> node_modules/express/node_modules/ms
      debug@2.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug -> node_modules/express/node_modules/debug
      qs@6.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/qs -> node_modules/express/node_modules/qs
      ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/debug/node_modules/ms -> node_modules/finalhandler/node_modules/ms
      debug@2.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/debug -> node_modules/finalhandler/node_modules/debug
      forwarded@0.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/forwarded -> node_modules/forwarded
      fresh@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/fresh -> node_modules/fresh
      • isarray@0.0.1 node_modules/has-binary/node_modules/isarray
      • inherits@2.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/inherits
      • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/setprototypeof
      • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors
      • iconv-lite@0.4.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/iconv-lite
      • raw-body@2.1.7 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body
      • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
      • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types
      • type-is@1.6.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is
      • body-parser@1.15.2 node_modules/iobroker.admin/node_modules/body-parser
      • cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie
      • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie
      • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie-signature
      • crc@3.4.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/crc
      • ms@0.7.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug/node_modules/ms
      • depd@1.1.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
      • parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/parseurl
      • utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/utils-merge
      • express-session@1.14.2 node_modules/iobroker.admin/node_modules/express-session
      • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
      • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types
      • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/negotiator
      • accepts@1.3.3 node_modules/iobroker.admin/node_modules/express/node_modules/accepts
      • content-disposition@0.5.1 node_modules/iobroker.admin/node_modules/express/node_modules/content-disposition
      • content-type@1.0.2 node_modules/iobroker.admin/node_modules/express/node_modules/content-type
      • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/cookie
      • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express/node_modules/cookie-signature
      • depd@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/depd
      • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/statuses
      • unpipe@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/unpipe
      • ee-first@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished/node_modules/ee-first
      • on-finished@2.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished
      • finalhandler@0.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler
      • ipaddr.js@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js
      • proxy-addr@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr
      • qs@6.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/qs
      • inherits@2.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/inherits
      • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/setprototypeof
      • mime@1.3.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/mime
      • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/statuses
      • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors
      • send@0.14.1 node_modules/iobroker.admin/node_modules/express/node_modules/send
      • serve-static@1.11.1 node_modules/iobroker.admin/node_modules/express/node_modules/serve-static
      • media-typer@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/media-typer
      • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
      • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types
      • type-is@1.6.13 node_modules/iobroker.admin/node_modules/express/node_modules/type-is
      • express@4.14.0 node_modules/iobroker.admin/node_modules/express
      • passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-local/node_modules/passport-strategy
      • aws-sign2@0.6.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws-sign2
      • aws4@1.5.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws4
      • caseless@0.11.0 node_modules/iobroker.admin/node_modules/request/node_modules/caseless
      • delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
      • combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream
      • extend@3.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/extend
      • forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/request/node_modules/forever-agent
      • asynckit@0.4.0 node_modules/iobroker.admin/node_modules/request/node_modules/form-data/node_modules/asynckit
      • ansi-styles@2.2.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
      • escape-string-regexp@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
      • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
      • has-ansi@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
      • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
      • strip-ansi@3.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
      • supports-color@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
      • chalk@1.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk
      • graceful-readlink@1.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
      • commander@2.9.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander
      • generate-function@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
      • is-property@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
      • generate-object-property@1.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
      • jsonpointer@4.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
      • pinkie@2.0.4 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
      • pinkie-promise@2.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
      • hoek@2.16.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/hoek
      • boom@2.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom
      • cryptiles@2.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/cryptiles
      • sntp@1.0.9 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/sntp
      • hawk@3.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk
      • assert-plus@0.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/assert-plus
      • extsprintf@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf
      • json-schema@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/json-schema
      • verror@1.3.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror
      • jsprim@1.3.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim
      • asn1@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/asn1
      • assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/assert-plus
      • dashdash@1.14.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/dashdash
      • getpass@0.1.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/getpass
      • jsbn@0.1.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jsbn
      • ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/ecc-jsbn
      • jodid25519@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jodid25519
      • tweetnacl@0.14.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/tweetnacl
      • bcrypt-pbkdf@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/bcrypt-pbkdf
      • sshpk@1.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk
      • http-signature@1.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature
      • is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/is-typedarray
      • isstream@0.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/isstream
      • json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/json-stringify-safe
      • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types/node_modules/mime-db
      • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types
      • form-data@2.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/form-data
      • node-uuid@1.4.7 node_modules/iobroker.admin/node_modules/request/node_modules/node-uuid
      • oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/request/node_modules/oauth-sign
      • stringstream@0.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/stringstream
      • punycode@1.4.1 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/node_modules/punycode
      • tough-cookie@2.3.2 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie
      • tunnel-agent@0.4.3 node_modules/iobroker.admin/node_modules/request/node_modules/tunnel-agent
      • ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug/node_modules/ms
      • debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug
      • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
      • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types
      • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/negotiator
      • accepts@1.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts
      • base64id@0.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/base64id
      • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after
      • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice
      • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer
      • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob
      • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
      • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary
      • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/wtf-8
      • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser
      • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/options
      • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/ultron
      • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      • engine.io@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io
      • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary/node_modules/isarray
      • has-binary@0.1.7 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary
      • benchmark@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/benchmark
      • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/component-emitter
      • debug@0.7.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/debug
      • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/isarray
      • json3@3.2.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/json3
      • socket.io-parser@2.2.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser
      • socket.io-adapter@0.4.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter
      • backo2@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/backo2
      • component-bind@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind
      • component-emitter@1.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter
      • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter
      • component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-inherit
      • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after
      • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/arraybuffer.slice
      • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/base64-arraybuffer
      • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/blob
      • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
      • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary
      • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/wtf-8
      • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser
      • has-cors@1.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/has-cors
      • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert/node_modules/callsite
      • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert
      • parsejson@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson
      • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert/node_modules/callsite
      • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert
      • parseqs@0.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs
      • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/options
      • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/ultron
      • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      • xmlhttprequest-ssl@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/xmlhttprequest-ssl
      • yeast@0.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/yeast
      • indexof@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof
      • object-component@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component
      • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert/node_modules/callsite
      • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert
      • parseuri@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri
      • engine.io-client@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client
      • to-array@0.1.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array
      • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter
      • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray
      • json3@3.3.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3
      • socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser
      • socket.io-client@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client
      • socket.io@1.5.1 node_modules/iobroker.admin/node_modules/socket.io
      • xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend
      • is-my-json-valid@2.15.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
      • har-validator@2.0.6 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator
      • request@2.78.0 node_modules/iobroker.admin/node_modules/request
        media-typer@0.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/media-typer -> node_modules/media-typer
        merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/merge-descriptors -> node_modules/merge-descriptors
        methods@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/methods -> node_modules/methods
        on-finished@2.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished -> node_modules/on-finished
        on-headers@1.0.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/on-headers -> node_modules/on-headers
        parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/parseurl -> node_modules/parseurl
        passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport/node_modules/passport-strategy -> node_modules/passport-strategy
        passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local -> node_modules/passport-local
        passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio -> node_modules/passport.socketio
        path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/express/node_modules/path-to-regexp -> node_modules/path-to-regexp
        pause@0.0.1 node_modules/iobroker.admin/node_modules/passport/node_modules/pause -> node_modules/pause
        passport@0.3.2 node_modules/iobroker.admin/node_modules/passport -> node_modules/passport
        random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/random-bytes -> node_modules/random-bytes
        range-parser@1.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/range-parser -> node_modules/range-parser
        qs@6.3.0 node_modules/iobroker.admin/node_modules/request/node_modules/qs -> node_modules/request/node_modules/qs
        ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/ms -> node_modules/send/node_modules/debug/node_modules/ms
        debug@2.2.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug -> node_modules/send/node_modules/debug
      • isarray@0.0.1 node_modules/socket.io-parser/node_modules/isarray
        statuses@1.3.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/statuses -> node_modules/statuses
        uid-safe@2.1.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe -> node_modules/uid-safe
        unpipe@1.0.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body/node_modules/unpipe -> node_modules/unpipe
        utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/utils-merge -> node_modules/utils-merge
        vary@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/vary -> node_modules/vary
        iobroker.core@1.0.0 /opt/iobroker
        └─┬ iobroker.js-controller@0.15.3
        ├─┬ iobroker.admin@1.6.11
        │ ├─┬ body-parser@1.16.0
        │ │ ├── debug@2.6.0
        │ │ ├─┬ http-errors@1.5.1
        │ │ │ └── setprototypeof@1.0.2
        │ │ ├── iconv-lite@0.4.15
        │ │ ├── qs@6.2.1
        │ │ ├── raw-body@2.2.0
        │ │ └── type-is@1.6.14
        │ ├─┬ express@4.14.1
        │ │ ├── content-disposition@0.5.2
        │ │ ├── finalhandler@0.5.1
        │ │ ├─┬ proxy-addr@1.1.3
        │ │ │ └── ipaddr.js@1.2.0
        │ │ ├── send@0.14.2
        │ │ └── serve-static@1.11.2
        │ └─┬ express-session@1.15.0
        │ └── crc@3.4.4
        ├─┬ jszip@3.1.3
        │ └─┬ readable-stream@2.0.6
        │ └── isarray@1.0.0
        ├─┬ letsencrypt@2.1.8
        │ └─┬ rsa-compat@1.2.7
        │ └─┬ ursa@0.9.4
        │ └── nan@2.5.1
        ├─┬ socket.io@1.7.2
        │ ├── debug@2.3.3
        │ ├─┬ engine.io@1.8.2
        │ │ └── debug@2.3.3
        │ ├─┬ has-binary@0.1.7
        │ │ └── isarray@0.0.1
        │ └─┬ socket.io-adapter@0.5.0
        │ └── debug@2.3.3
        └─┬ socket.io-client@1.7.2
        ├── debug@2.3.3
        └─┬ engine.io-client@1.8.2
        └── debug@2.3.3
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      noch eine Idee was ich alles machen könnte ?
        @SigiMOE:
        noch eine Idee was ich alles machen könnte ? `
        Ja!
        Die gleichen Befehle mit sudo absetzen.
        Du bist als user pi angemeldet.
        Rainer
          bingo !!!!
          Jetzt geht es wieder….
          #PUHVIELENDANKHABICHECHTNOCHMALGLÜCKGEHABT
          Vielen Dank an alle, Die mir geholfen haben...
          CU bis zum nächsten SUPERGAU
            skorpil last edited by
            Brauche zum gleichen Thema Hilfe:
            Ich habe alle oben aufgeführten Schritte durchgeführt, nachdem auch bei mir das update fehlgeschlagen ist.
            Alle Schritte laufen durch, bis auf " sudo npm install iobroker –unsafe-perm "
            da kriege ich dann folgendes Fehlerlog. Kann mir jemand einen Rat geben, wie ich das löse?
            0 info it worked if it ends with ok
            1 verbose cli [ '/usr/bin/nodejs',
            1 verbose cli   '/usr/bin/npm',
            1 verbose cli   'install',
            1 verbose cli   'iobroker',
            1 verbose cli   '--unsafe-perm' ]
            2 info using npm@4.1.2
            3 info using node@v6.9.5
            4 silly loadCurrentTree Starting
            5 silly install loadCurrentTree
            6 silly install readLocalPackageData
            7 silly fetchPackageMetaData iobroker
            8 silly fetchOtherPackageData iobroker
            9 silly cache add args [ 'iobroker', null ]
            10 verbose cache add spec iobroker
            11 silly cache add parsed spec Result {
            11 silly cache add   raw: 'iobroker',
            11 silly cache add   scope: null,
            11 silly cache add   escapedName: 'iobroker',
            11 silly cache add   name: null,
            11 silly cache add   rawSpec: 'iobroker',
            11 silly cache add   spec: '/opt/iobroker/iobroker',
            11 silly cache add   type: 'local' }
            12 silly addLocalTarball shasum (computed) 172d89ea6df6ab508c7b69dc0540b583db07e40c
            13 verbose addTmpTarball /opt/iobroker/iobroker not in flight; adding
            14 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
            15 verbose addTmpTarball validating metadata from /opt/iobroker/iobroker
            16 verbose tar unpack /opt/iobroker/iobroker
            17 verbose tar unpacking to /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
            18 silly gentlyRm /tmp/npm-17981-2b62b2d6/unpack-0ba91d68 is being purged
            19 verbose gentlyRm don't care about contents; nuking /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
            20 silly gunzTarPerm modes [ '755', '644' ]
            21 error not a package /opt/iobroker/iobroker
            22 error addLocal Could not install /opt/iobroker/iobroker
            23 silly fetchPackageMetaData Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
            23 silly fetchPackageMetaData     at Error (native)
            23 silly fetchPackageMetaData  error for iobroker { Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
            23 silly fetchPackageMetaData   errno: -2,
            23 silly fetchPackageMetaData   code: 'ENOENT',
            23 silly fetchPackageMetaData   syscall: 'open',
            23 silly fetchPackageMetaData   path: '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' }
            24 silly rollbackFailedOptional Starting
            25 silly rollbackFailedOptional Finishing
            26 silly runTopLevelLifecycles Finishing
            27 silly install printInstalled
            28 verbose stack Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
            28 verbose stack     at Error (native)
            29 verbose cwd /opt/iobroker
            30 error Linux 4.4.38-v7+
            31 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
            32 error node v6.9.5
            33 error npm  v4.1.2
            34 error path /tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json
            35 error code ENOENT
            36 error errno -2
            37 error syscall open
            38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
            39 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
            39 error enoent This is most likely not a problem with npm itself
            39 error enoent and is related to npm not being able to find a file.
            40 verbose exit [ -2, true ]
              @skorpil:
              Kann mir jemand einen Rat geben, wie ich das löse? `
              Leider nein 😞
              Ich habe auch in der letzten Woche drei Installationen zerschossen mit diesem Ergebnis.
              @skorpil:
              38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' `
              Bei zweien war ich definitiv selber schuld, beim dritten weiss ich es noch nicht warum.
              Leider scheint es so, dass bei dieser Fehlermeldung anscheinen keine Rettung mehr möglich ist.
              Ich habe die SD-Karten zur Seite gelegt und jeweils auf einer neuen Karte neu installiert.
              War für mich nicht lebenswichtig, da es eigentlich nur Testinstallationen waren. Ich wollte irgendwann einmal die iobroker.data aus den alten Installationen in die neuen kopieren, ob dann wieder alles da ist.
              Sorry for bad news 😞
              Aber vielleicht hat einer da mehr Glück gehabt.
              Rainer
                Homoran,
                erstmal Danke.
                –-um aber meine Verwirrung jetzt komplett zu machen: iobroker läuft, wenn ich ihn über den browser aufrufe. Allerdings mit js-controller 0.15.3. Und den wollte ich ja updaten.
                Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das?
                  @skorpil:
                  Homoran,
                  erstmal Danke.
                  Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das? `
                  Vielleicht kommen wir so sogar der Ursache auf die Spur, auch wenn ich mich immer noch als Linux-Noob einordne.
                  In allen Installationen lag (weil eben nur Testinstallation) eine tlw. uralte Controller-Version vor.
                  Bei einer Installation habe ich den Code, wie er im Admin unter Reiter Hosts angezeigt wird, wenn man auf das Update-Icon klickt, ungeprüft in die Konsole kopiert.
                  Leider sind dort Backslashs statt slashs gewesen (cd ****opt****iobroker, anstelle (cd ****/opt/****iobroker).
                  Dadurch wurde im Verzeichnis root erneut installiert.
                  Wenn da etwas ähnliches bei dir ist, hast du vielleicht auch zwei verschiedene Installationen.
                  Rainer
                    Rainer,
                    das habe ich mir auch gedacht. Es muß ja irgendwo ein iobroker laufen. Nur, wo resp. wie finde ich diese. Gerade lasse ich mein root Verzeichnis nach Dateien "iobroker" durchsuchen. Dauert etwas…
                    Den finde ich gar nicht. Bei mir steht unter hosts nur bei Plattform "Javascript/Node.js" und sonst nichts. oder ich bin zu dumm…
                      @skorpil:
                      oder ich bin zu dumm… `
                      nö, du hast ja jetzt die aktuelle Version.
                      Dieser Button erscheint nur, wenn es eine neuere Version als die installierte gibt.
                      Rainer
                        und die ist "0.15.3" (installiert) und "0.15.3" (verfügbar). Zumindest steht das so unter host.
                        Meine Installation des iobroker findet sich im Verzeichnis /opt/iobroker Sonst finde ich nur noch eine weitere Datei iobroker in user/bin.
                        Ich verstehe es nicht.
                          Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das?
                            @skorpil:
                            Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das? `
                            Hattest du das Upgrade des controllers als root durchgeführt?
                            Und die Suche nach ioBroker als pi?
                            Rainer
                              Ich weiß es nicht mehr, um ehrlich zu sein. Ich glaube, den Controller Update als pi. Die Suche habe ich sowohl als auch laufen lassen.
                              Ich versuche jetzt den Controller Update als Root…
                                So, habe jetzt folgendes als root ohn Fehlermeldung hinbekommen:
                                cd /opt/iobroker
                                sudo iobroker stop
                                sudo iobroker update
                                sudo iobroker upgrade.self
                                sudo iobroker start
                                und es läuft. Als root kann ich stoppen und starten.
                                Ich bin jetzt aber dennoch etwas verwirrt.
                                Ich habe die Versionen ich habe node v6.9.5 und npm v4.1.2 drauf. Und im iobroker wird angezeigt Javascript/Node.js in Version 0.15.3. Ist das alles so aktuell?
                                4583
