    3. Entwicklung
    4. Adapterprobleme - FFMPEG
      Thomas Braun Most Active @Frank 1 last edited by
      @frank-1
      Welche Version?
      apt policy ffmpeg
        Frank 1 @Thomas Braun last edited by
        So sieht die Ausgabe aus
        ffmpeg:
          Installed: 7:4.1.6-1~deb10u1+rpt2
          Candidate: 7:4.1.6-1~deb10u1+rpt2
          Version table:
         *** 7:4.1.6-1~deb10u1+rpt2 500
                500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                100 /var/lib/dpkg/status
             7:4.1.6-1~deb10u1 500
        Vielen Danke für die Hilfe!
        Beste Grüße
        Frank
          Thomas Braun Most Active @Frank 1 last edited by Thomas Braun
          @frank-1
          sudo -u iobroker ffmpeg -version
          liefert? Da scheint mir was an apt vorbei installiert worden zu sein.
            @thomas-braun sagte in Adapterprobleme - FFMPEG:
            pi@cloud:~ $ sudo -u iobroker ffmpeg -version
            ffmpeg version 4.1.6-1~deb10u1+rpt2 Copyright (c) 2000-2020 the FFmpeg developers
            built with gcc 8 (Raspbian 8.3.0-6+rpi1)
            configuration: --prefix=/usr --extra-version='1~deb10u1+rpt2' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-vout-drm --enable-v4l2-request --enable-libudev --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
            libavutil      56. 22.100 / 56. 22.100
            libavcodec     58. 35.100 / 58. 35.100
            libavformat    58. 20.100 / 58. 20.100
            libavdevice    58.  5.100 / 58.  5.100
            libavfilter     7. 40.101 /  7. 40.101
            libavresample   4.  0.  0 /  4.  0.  0
            libswscale      5.  3.100 /  5.  3.100
            libswresample   3.  3.100 /  3.  3.100
            libpostproc    55.  3.100 / 55.  3.100
              @frank-1
              In der Fehlermeldung wird
              ffmpeg version 4.4-static https://johnvansickle.com/ffmpeg/  Copyright (c) 2000-2021 the FFmpeg developers
                built with gcc 6.3.0
              gemeldet. Das ist irgendwie statisch ins System gedrückt worden. Und mit einer alten Version von gcc gebaut. Da würde ich auch einen Fehler vermuten.
                Das ist mir auch aufgefallen, das kommt von hier.
                2021-08-14 10_48_51-_opt_iobroker_node_modules_ffmpeg-static - File Manager — Webmin 1.979 (Raspbian.png
                  @frank-1
                  Und wie kommt das da statisch hin?
                    Das kann ich leider nicht sagen, vielleicht hat es der Adapter "Eufy-Security" installiert, der wirft ja auch den Fehler.
                      @frank-1
                      Vielleicht ähnlich dazu:
                      https://github.com/bropat/ioBroker.eufy-security/issues/140
                      anarchocactus created this issue in bropat/ioBroker.eufy-security
                      closed ffmpeg fails on event video #140
                        Fixed in version 0.6.0
                        Habe heute morgen die Version 0.6.0 installiert ... behebt mein Problem leider nicht.
                        671
