    4. JavaScript
    5. Hilfe bei RSS-feed benötigt !
    • dslraser
      dslraser Forum Testing Most Active @sigi234 last edited by
      @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
      Als Option E-Mail senden ja/nein wäre noch ideal. Ich sehen das sogar wichtiger als die Ansage.
      Das ginge dann auch. Mir ging es erstmal um das Grundsätzliche.
        sigi234 Forum Testing Most Active @dslraser last edited by
        @dslraser sagte in Hilfe bei RSS-feed benötigt !:
        Natürlich.
        • Negalein
          Negalein Global Moderator @dslraser last edited by
          kleine Änderung
          2021-08-14 00:22:40.339 - warn: javascript.0 (6878) getState "0_userdata.0.Feuerwehr.RSS_Meldung" not found (3)
          2021-08-14 00:22:40.340 - warn: javascript.0 (6878) at FeedParser. (script.js.Feuerwehr.Einsaetze:61:14)
          2021-08-14 00:22:40.340 - warn: javascript.0 (6878) at FeedParser.emit (events.js:375:28)
          2021-08-14 00:22:40.340 - warn: javascript.0 (6878) at FeedParser.emit (domain.js:470:12)
          2021-08-14 00:22:40.340 - warn: javascript.0 (6878) at emitReadable_ (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:504:10)
          2021-08-14 00:22:40.341 - warn: javascript.0 (6878) at emitReadable (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:498:62)
          2021-08-14 00:22:40.341 - warn: javascript.0 (6878) at addChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:298:29)
          2021-08-14 00:22:40.341 - warn: javascript.0 (6878) at readableAddChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:278:11)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.Readable.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:245:10)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.Transform.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:148:32)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.handleCloseTag (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:327:10)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at SAXStream.emit (events.js:375:28)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at SAXStream.emit (domain.js:470:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at SAXParser.me._parser. [as onclosetag] (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:258:17)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at emit (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:624:35)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at emitNode (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:629:5)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at closeTag (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:889:7)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at SAXParser.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:1436:13)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at SAXStream.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:239:18)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser._transform (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:1117:17)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.Transform._read (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:184:10)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.Transform._write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:172:83)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at doWrite (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at writeOrBuffer (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at FeedParser.Writable.write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Request.ondata (internal/streams/legacy.js:20:31)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Request.emit (events.js:375:28)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Request.emit (domain.js:470:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1073:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at IncomingMessage.emit (events.js:375:28)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at IncomingMessage.emit (domain.js:470:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at IncomingMessage.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at HTTPParser.parserOnBody (_http_common.js:139:24)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Socket.socketOnData (_http_client.js:515:22)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Socket.emit (events.js:375:28)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Socket.emit (domain.js:470:12)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at Socket.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.342 - warn: javascript.0 (6878) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          2021-08-14 00:22:40.343 - warn: javascript.0 (6878) getState "0_userdata.0.Feuerwehr.RSS_Meldung" not found (3)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser. (script.js.Feuerwehr.Einsaetze:61:14)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.emit (events.js:375:28)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.emit (domain.js:470:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at emitReadable_ (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:504:10)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at emitReadable (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:498:62)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at addChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:298:29)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at readableAddChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:278:11)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.Readable.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:245:10)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.Transform.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:148:32)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.handleCloseTag (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:327:10)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at SAXStream.emit (events.js:375:28)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at SAXStream.emit (domain.js:470:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at SAXParser.me._parser. [as onclosetag] (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:258:17)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at emit (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:624:35)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at emitNode (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:629:5)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at closeTag (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:889:7)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at SAXParser.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:1436:13)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at SAXStream.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:239:18)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser._transform (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:1117:17)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.Transform._read (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:184:10)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.Transform._write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:172:83)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at doWrite (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at writeOrBuffer (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at FeedParser.Writable.write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at Request.ondata (internal/streams/legacy.js:20:31)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at Request.emit (events.js:375:28)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at Request.emit (domain.js:470:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1073:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at IncomingMessage.emit (events.js:375:28)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at IncomingMessage.emit (domain.js:470:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.344 - warn: javascript.0 (6878) at IncomingMessage.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at HTTPParser.parserOnBody (_http_common.js:139:24)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at Socket.socketOnData (_http_client.js:515:22)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at Socket.emit (events.js:375:28)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at Socket.emit (domain.js:470:12)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at Socket.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.345 - warn: javascript.0 (6878) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          2021-08-14 00:22:40.366 - warn: javascript.0 (6878) getState "0_userdata.0.Feuerwehr.RSS_Meldung" not found (3)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser. (script.js.Feuerwehr.Einsaetze:61:14)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.emit (events.js:375:28)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.emit (domain.js:470:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at emitReadable_ (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:504:10)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at emitReadable (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:498:62)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at addChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:298:29)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at readableAddChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:278:11)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.Readable.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:245:10)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.Transform.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:148:32)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.handleCloseTag (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:327:10)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at SAXStream.emit (events.js:375:28)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at SAXStream.emit (domain.js:470:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at SAXParser.me._parser. [as onclosetag] (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:258:17)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at emit (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:624:35)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at emitNode (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:629:5)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at closeTag (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:889:7)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at SAXParser.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:1436:13)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at SAXStream.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:239:18)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser._transform (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:1117:17)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.Transform._read (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:184:10)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.Transform._write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:172:83)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at doWrite (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at writeOrBuffer (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at FeedParser.Writable.write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Request.ondata (internal/streams/legacy.js:20:31)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Request.emit (events.js:375:28)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Request.emit (domain.js:470:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1073:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at IncomingMessage.emit (events.js:375:28)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at IncomingMessage.emit (domain.js:470:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at IncomingMessage.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at HTTPParser.parserOnBody (_http_common.js:139:24)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Socket.socketOnData (_http_client.js:515:22)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Socket.emit (events.js:375:28)
          2021-08-14 00:22:40.367 - warn: javascript.0 (6878) at Socket.emit (domain.js:470:12)
          2021-08-14 00:22:40.368 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.368 - warn: javascript.0 (6878) at Socket.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.368 - warn: javascript.0 (6878) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
          2021-08-14 00:22:40.368 - warn: javascript.0 (6878) getState "0_userdata.0.Feuerwehr.RSS_Meldung" not found (3)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at FeedParser. (script.js.Feuerwehr.Einsaetze:61:14)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at FeedParser.emit (events.js:375:28)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at FeedParser.emit (domain.js:470:12)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at emitReadable_ (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:504:10)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at emitReadable (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:498:62)
          2021-08-14 00:22:40.369 - warn: javascript.0 (6878) at addChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:298:29)
          2021-08-14 00:22:40.370 - warn: javascript.0 (6878) at readableAddChunk (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:278:11)
          2021-08-14 00:22:40.370 - warn: javascript.0 (6878) at FeedParser.Readable.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_readable.js:245:10)
          2021-08-14 00:22:40.370 - warn: javascript.0 (6878) at FeedParser.Transform.push (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:148:32)
          2021-08-14 00:22:40.370 - warn: javascript.0 (6878) at FeedParser.handleCloseTag (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:327:10)
          2021-08-14 00:22:40.370 - warn: javascript.0 (6878) at SAXStream.emit (events.js:375:28)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at SAXStream.emit (domain.js:470:12)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at SAXParser.me._parser. [as onclosetag] (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:258:17)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at emit (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:624:35)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at emitNode (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:629:5)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at closeTag (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:889:7)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at SAXParser.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:1436:13)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at SAXStream.write (/opt/iobroker/node_modules/feedparser/node_modules/sax/lib/sax.js:239:18)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at FeedParser._transform (/opt/iobroker/node_modules/feedparser/lib/feedparser/index.js:1117:17)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at FeedParser.Transform._read (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:184:10)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at FeedParser.Transform._write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_transform.js:172:83)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at doWrite (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at writeOrBuffer (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at FeedParser.Writable.write (/opt/iobroker/node_modules/feedparser/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at Request.ondata (internal/streams/legacy.js:20:31)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at Request.emit (events.js:375:28)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at Request.emit (domain.js:470:12)
          2021-08-14 00:22:40.371 - warn: javascript.0 (6878) at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1073:12)
          2021-08-14 00:22:40.379 - warn: javascript.0 (6878) at IncomingMessage.emit (events.js:375:28)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at IncomingMessage.emit (domain.js:470:12)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at IncomingMessage.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at HTTPParser.parserOnBody (_http_common.js:139:24)
          2021-08-14 00:22:40.380 - warn: javascript.0 (6878) at Socket.socketOnData (_http_client.js:515:22)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at Socket.emit (events.js:375:28)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at Socket.emit (domain.js:470:12)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at addChunk (internal/streams/readable.js:290:12)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at readableAddChunk (internal/streams/readable.js:265:9)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at Socket.Readable.push (internal/streams/readable.js:204:10)
          2021-08-14 00:22:40.381 - warn: javascript.0 (6878) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
            sigi234 Forum Testing Most Active @dslraser last edited by sigi234
            kleine Änderung
            läuft.
            00:32:40.882	info	javascript.0 (2636) Stop script script.js.Sigi.dslraser_feuerwehr
            00:32:41.210	info	javascript.0 (2636) Start javascript script.js.Sigi.dslraser_feuerwehr
            00:32:41.232	info	javascript.0 (2636) script.js.Sigi.dslraser_feuerwehr: registered 0 subscriptions and 0 schedules
            00:32:44.331	info	javascript.0 (2636) script.js.Sigi.dslraser_feuerwehr: alt: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS,Vöcklabruck BERG IM ATTERGAU VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 1 , VERKEHRSUNFALL AUFRÄUMARBEITEN RAITH 6
            00:32:44.332	info	javascript.0 (2636) script.js.Sigi.dslraser_feuerwehr: neu: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS
            • Negalein
              kleine Änderung
              bei mir auch wieder 🙂
              00:33:26.722	info	javascript.1 (12500) Stop script script.js.Feuerwehr.Alarm-Alexa
              00:33:26.723	info	javascript.0 (12462) Stop script script.js.Feuerwehr.Alarm-Alexa
              00:33:27.504	info	javascript.0 (12462) Start javascript script.js.Feuerwehr.Alarm-Alexa
              00:33:27.513	info	javascript.0 (12462) script.js.Feuerwehr.Alarm-Alexa: registered 0 subscriptions and 0 schedules
              00:33:30.660	info	javascript.0 (12462) script.js.Feuerwehr.Alarm-Alexa: alt: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS
              00:33:30.660	info	javascript.0 (12462) script.js.Feuerwehr.Alarm-Alexa: neu:
              • dslraser
                dslraser Forum Testing Most Active @Negalein last edited by
                @negalein sagte in Hilfe bei RSS-feed benötigt !:
                Hattest Du den Pfad umbenannt, oder ist das andere Script noch an ?
                  Für eine Ansage passen die Daten nicht unbedingt ?
                  Beispiel:
                  Richtig, ich würde ev. eine Kurz/Lang Version für die Ansage als Option einbauen?
                  Kurzversion:
                  Achtung Feuewehreinsatz in TIMELKAM , VERKEHRSUNFALL EINGEKLEMMTE PERSON
                  • dslraser
                    Ich habe das Blockly mal über Nacht laufen lassen. Scheint zu funktionieren.
                    javascript.0	2021-08-14 10:16:03.169	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Gmunden BRAND "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , BRAND KFZ A1 FAHRTR. SALZBURG ,Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Ala
                    javascript.0	2021-08-14 10:16:03.169	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9
                    javascript.0	2021-08-14 10:02:03.194	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9
                    javascript.0	2021-08-14 10:02:03.194	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9,Linz-Land LEONDING TECHNISC
                    javascript.0	2021-08-14 09:35:03.158	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9,Linz-Land LEONDING TECHNISC
                    javascript.0	2021-08-14 09:35:03.158	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9,Linz-Land LEONDING TECHNISC
                    javascript.0	2021-08-14 09:10:03.171	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Vöcklabruck TIMELKAM VERKEHRSUNFALL FEUERWEHREINSATZ Alarmstufe: 2 , VERKEHRSUNFALL EINGEKLEMMTE PERSON KALCHOFEN 9,Linz-Land LEONDING TECHNISC
                    javascript.0	2021-08-14 09:10:03.171	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land LEONDING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM POLOPLASTSTRAßE 1,Grieskirchen PEUERBACH TECHNISCH "K
                    javascript.0	2021-08-14 09:01:03.161	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land LEONDING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM POLOPLASTSTRAßE 1,Grieskirchen PEUERBACH TECHNISCH "K
                    javascript.0	2021-08-14 09:01:03.161	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land LEONDING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM POLOPLASTSTRAßE 1,Grieskirchen PEUERBACH TECHNISCH "K
                    javascript.0	2021-08-14 08:56:03.151	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land LEONDING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM POLOPLASTSTRAßE 1,Grieskirchen PEUERBACH TECHNISCH "K
                    javascript.0	2021-08-14 08:56:03.151	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Grieskirchen PEUERBACH TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , WASSERSCHADEN KIRCHENPLATZ 9,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERW
                    javascript.0	2021-08-14 08:43:03.194	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Grieskirchen PEUERBACH TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , WASSERSCHADEN KIRCHENPLATZ 9,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERW
                    javascript.0	2021-08-14 08:43:03.194	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Grieskirchen PEUERBACH TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , WASSERSCHADEN KIRCHENPLATZ 9,Ried im Innkreis RIED IM INNKREIS TECHNI
                    javascript.0	2021-08-14 08:33:03.184	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Grieskirchen PEUERBACH TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , WASSERSCHADEN KIRCHENPLATZ 9,Ried im Innkreis RIED IM INNKREIS TECHNI
                    javascript.0	2021-08-14 08:33:03.184	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Ried im Innkreis RIED IM INNKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT RIED IM INNKREIS,Linz-Land TRAUN TECHNI
                    javascript.0	2021-08-14 08:08:03.198	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Ried im Innkreis RIED IM INNKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT RIED IM INNKREIS,Linz-Land TRAUN TECHNI
                    javascript.0	2021-08-14 08:08:03.197	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 07:50:03.190	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 07:50:03.190	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land ENNS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG PFARRGASSE 11,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ A
                    javascript.0	2021-08-14 07:24:03.158	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land ENNS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG PFARRGASSE 11,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ A
                    javascript.0	2021-08-14 07:24:03.158	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 06:32:03.173	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 06:32:03.173	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land PASCHING TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT PASCHING,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREI
                    javascript.0	2021-08-14 05:46:03.160	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land PASCHING TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT PASCHING,Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREI
                    javascript.0	2021-08-14 05:46:03.159	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 02:59:03.164	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4
                    javascript.0	2021-08-14 02:59:03.163	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Linz-Land TRAUN TECHNISCH "KLE
                    javascript.0	2021-08-14 02:28:03.175	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Linz-Land TRAUN TECHNISCH "KLE
                    javascript.0	2021-08-14 02:28:03.174	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Braunau HELPFAU-UTTENDORF TECH
                    javascript.0	2021-08-14 01:55:03.206	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Braunau HELPFAU-UTTENDORF TECH
                    javascript.0	2021-08-14 01:55:03.206	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Braunau HELPFAU-UTTENDORF TECH
                    javascript.0	2021-08-14 01:41:03.154	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land KIRCHBERG-THENING TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM TITANSTRAßE 2,Braunau HELPFAU-UTTENDORF TECH
                    javascript.0	2021-08-14 01:41:03.153	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Braunau HELPFAU-UTTENDORF TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT UTTENDORF 110,Linz-Land TRAUN TECHNISCH "KLEIN"
                    javascript.0	2021-08-14 01:33:03.186	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Braunau HELPFAU-UTTENDORF TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , ÖLSPUR, ÖLAUSTRITT UTTENDORF 110,Linz-Land TRAUN TECHNISCH "KLEIN"
                    javascript.0	2021-08-14 01:33:03.185	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4,Freistadt SCHOENAU IM MUEHLKREIS TECHNI
                    javascript.0	2021-08-14 01:28:03.150	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4,Freistadt SCHOENAU IM MUEHLKREIS TECHNI
                    javascript.0	2021-08-14 01:28:03.150	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Vöcklabruck PÖNDORF TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM LASCOSTRAßE 1,Linz-Land TRAUN TECHNISCH "KLEIN" FEUE
                    javascript.0	2021-08-14 00:41:03.166	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Vöcklabruck PÖNDORF TECHNISCHE PROBEN UND EINSATZKOMMANDOS Alarmstufe: 1 , BRANDMELDEALARM LASCOSTRAßE 1,Linz-Land TRAUN TECHNISCH "KLEIN" FEUE
                    javascript.0	2021-08-14 00:41:03.165	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4,Freistadt SCHOENAU IM MUEHLKREIS TECHNI
                    javascript.0	2021-08-14 00:38:03.191	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Linz-Land TRAUN TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , TÜRÖFFNUNG GUIDO HOLZKNECHT-STRAßE 4,Freistadt SCHOENAU IM MUEHLKREIS TECHNI
                    javascript.0	2021-08-14 00:38:03.191	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS
                    javascript.0	2021-08-14 00:32:03.181	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS
                    javascript.0	2021-08-14 00:32:03.181	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: alt: Freistadt SCHOENAU IM MUEHLKREIS TECHNISCH "KLEIN" FEUERWEHREINSATZ Alarmstufe: 1 , FAHRZEUGBERGUNG SCHOENAU IM MUEHLKREIS,Vöcklabruck BERG IM
                    javascript.0	2021-08-14 00:10:43.310	info	(4461) script.js.99_Test.Feuerwehr_alle_laufenden: registered 0 subscriptions and 0 schedules
                    javascript.0	2021-08-14 00:10:43.309	info	(4461) Start javascript script.js.99_Test.Feuerwehr_alle_laufenden
                    • dslraser
                      Kurzversion:
                      so in etwa ?
                      Sieht so aus (3 Meldungen)
                      javascript.0 (4461) script.js.99_Test.Feuerwehr_alle_laufenden: neu: Achtung, Feuerwehreinsatz in GILGENBERG AM WEILHART, BRAND KFZ,Achtung, Feuerwehreinsatz in MARCHTRENK, EINGESCHLOSSENE PERSON IN LIFT,Achtung, Feuerwehreinsatz in WEYREGG AM ATTERSEE, BRAND BAUM, FLUR, BÖSCHUNG
                      sigi234 Negalein 2 Replies Last reply Reply Quote 1
                        @dslraser
                        Ja, ev die Zeit bei sonst noch dazu
                        • Negalein
                          Ja, war leider noch aktiv.
                          Läuft sehr gut.
                          • Negalein
                            so in etwa ?
                            das wäre spitze
                            • dslraser
                              @negalein
                              Ich habe noch Besuch und konnte deshalb am WE nix weiter am Blockly machen. Ich habe nur eben mal kurz rein gesehen und habe echt gedacht das Blockly macht Mist, aber bei Euch gehts ja wirklich gerade ab.....
                              sigi234 Negalein 3 Replies Last reply Reply Quote 0
                                Jupp, und noch immer.
                                • Negalein
                                  kein Problem! Läuft ja nichts davon!
                                  Ja, war schon viel los. Aber das Meiste ist zum Sigi gezogen!
                                    sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                                    Vor 1 Stunde 30 °C aktuell 17°C
                                    • Negalein
                                      Negalein Global Moderator @sigi234 last edited by
                                      kommt mir bekannt vor 🙂
                                        @negalein
                                        Coole View. Grafana?
                                        • Negalein
                                          Coole View
                                          ist ursprünglich von Crunchip
                                          Grafana?
                                          Yes 🙂
                                            Und schon wieder.
                                            Aktuelle Einsätze : 208
                                            426
                                            67236
