    4. js-controller 3.3 jetzt im STABLE!
      peterfido @Slowman last edited by peterfido
      @apollon77
      Das Update ist durchgeführt. Vorher musste ich noch einen
      iobroker fix
      durchführen.
      Die Ausgabe des Updates:
      peter@proxbroker:/opt/iobroker$ iobroker upgrade self
      Update js-controller from @3.2.16 to @3.3.15
      NPM version: 6.14.14
      npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      /bin/sh: 1: cmake: not found
      make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Fehler 127
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      gyp ERR! System Linux 4.19.0-17-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
      gyp ERR! node -v v12.22.5
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      In file included from ../src/binding.cc:6:
      /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/binding.cc:2013:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(sshcrypto, init)
      Starting node restart.js
      Kann ich die Fehler ignorieren?
        Thomas Braun Most Active @peterfido last edited by
        @peterfido
        cmake würde ich mal nachinstallieren.
        apt policy cmake
        bringt?
          peterfido @Thomas Braun last edited by peterfido
          Danke.
          OK, habe ich installiert.
          cmake:
            Installiert:           (keine)
            Installationskandidat: 3.13.4-1
            Versionstabelle:
               3.13.4-1 500
                  500 http://deb.debian.org/debian buster/main amd64 Packages
                  500 http://ftp.de.debian.org/debian buster/main amd64 Packages
          peter@proxbroker:~$ sudo apt install cmake
          Die folgenden zusätzlichen Pakete werden installiert:
            cmake-data libjsoncpp1 librhash0
          Vorgeschlagene Pakete:
            cmake-doc ninja-build
          Die folgenden NEUEN Pakete werden installiert:
            cmake cmake-data libjsoncpp1 librhash0
          0 aktualisiert, 4 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 5.155 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 25,8 MB Plattenplatz zusätzlich benutzt.
          Möchten Sie fortfahren? [J/n]
          Holen:1 http://deb.debian.org/debian buster/main amd64 cmake-data all 3.13.4-1 [1.476 kB]
          Holen:2 http://deb.debian.org/debian buster/main amd64 libjsoncpp1 amd64 1.7.4-3 [75,6 kB]
          Holen:3 http://deb.debian.org/debian buster/main amd64 librhash0 amd64 1.3.8-1 [122 kB]
          Holen:4 http://deb.debian.org/debian buster/main amd64 cmake amd64 3.13.4-1 [3.480 kB]
          Es wurden 5.155 kB in 0 s geholt (19,2 MB/s).
          Vormals nicht ausgewähltes Paket cmake-data wird gewählt.
          (Lese Datenbank ... 123005 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../cmake-data_3.13.4-1_all.deb ...
          Entpacken von cmake-data (3.13.4-1) ...
          Vormals nicht ausgewähltes Paket libjsoncpp1:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../libjsoncpp1_1.7.4-3_amd64.deb ...
          Entpacken von libjsoncpp1:amd64 (1.7.4-3) ...
          Vormals nicht ausgewähltes Paket librhash0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../librhash0_1.3.8-1_amd64.deb ...
          Entpacken von librhash0:amd64 (1.3.8-1) ...
          Vormals nicht ausgewähltes Paket cmake wird gewählt.
          Vorbereitung zum Entpacken von .../cmake_3.13.4-1_amd64.deb ...
          Entpacken von cmake (3.13.4-1) ...
          librhash0:amd64 (1.3.8-1) wird eingerichtet ...
          cmake-data (3.13.4-1) wird eingerichtet ...
          libjsoncpp1:amd64 (1.7.4-3) wird eingerichtet ...
          cmake (3.13.4-1) wird eingerichtet ...
          Trigger für man-db (2.8.5-2) werden verarbeitet ...
          Trigger für libc-bin (2.28-10) werden verarbeitet ...
          peter@proxbroker:~$
          Sollte ich nochmal iobroker upgraden? << Also erst zurück zum Snapshot und dann nochmal mit cmake
            Thomas Braun Most Active @peterfido last edited by Thomas Braun
            @peterfido
            Dann versuch jetzt nochmal dein Glück.
              Habe ich. Ein paar Warnungen kommen noch.
              In file included from ../src/binding.cc:1:
              ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
               NODE_MODULE(cpufeatures, init)
                @peterfido
                Lösch den npm cache Mal
                cd /opt/iobroker
                npm cache clear --force
                  @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
                  Leider keine Änderung.
                  peter@proxbroker:/opt/iobroker$ npm cache clear --force
                  npm WARN using --force I sure hope you know what you are doing.
                  Ich lasse es jetzt so.
                    @peterfido
                    Versuchs so:
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                      Das Ergebnis:
                      peter@proxbroker:/opt/iobroker$ iobroker stop
                      peter@proxbroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                      > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                      > node lib/preinstallCheck.js
                      > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
                      > node iobroker.js setup first
                      object _design/custom updated
                      object _design/system updated
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                      + iobroker.js-controller@3.3.15
                      removed 88 packages and updated 1 package in 34.258s
                      peter@proxbroker:/opt/iobroker$ iobroker start
                        @peterfido Dann sollte es ja jetzt passen.
                        iobroker version
                          Danke.
                          Die Version war nach dem Update um 12:14 auch schon die 3.3.15. Es traten halt die Warnungen während des Updates auf.
                          Mein erster Versuch ohne
                          iobroker fix
                          hatte die ioBroker "zerschossen". Er konnte ein paar Links nicht löschen. Danach lief kein Update mehr durch. Also im Snapshot zurück und erst den fix laufen lassen und nochmal aktualisieren.
                          Danach war die Version zwar aktuell, jedoch war ich mir wegen der Fehlermeldung mit dem cmake unsicher und habe daher hier angefragt.
                          Die (letzte) "manuelle" Installation hatte den positiven Nebeneffekt, dass ein paar Gigabyte freigeschaufelt wurden. 😊
                            @peterfido
                            Jetzt kann ich dem auch nicht entnehmen ob das wieder senkrecht läuft...
                            iobroker version
                            iobroker update
                            iobroker upgrade
                              peter@proxbroker:/opt/iobroker$ iobroker version
                              3.3.15
                              peter@proxbroker:/opt/iobroker$ iobroker update
                              Used repository: stable
                              hash unchanged, use cached sources
                              update done
                              Adapter    "admin"         : 5.1.23   , installed 5.1.23
                              Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                              Adapter    "asterisk"      : 1.0.6    , installed 1.0.6
                              Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                              Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                              Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                              Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                              Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                              Adapter    "doorio"        : 2.0.1    , installed 2.0.1
                              Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                              Adapter    "email"         : 1.0.10   , installed 1.0.10
                              Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                              Adapter    "flot"          : 1.10.6   , installed 1.10.6
                              Adapter    "fullcalendar"  : 1.1.0    , installed 1.1.0
                              Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                              Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                              Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                              Adapter    "history"       : 1.9.13   , installed 1.9.13
                              Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                              Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                              Adapter    "hue"           : 3.5.19   , installed 3.5.19
                              Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
                              Adapter    "ical"          : 1.11.2   , installed 1.11.2
                              Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                              Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                              Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                              Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                              Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                              Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                              Adapter    "info"          : 1.9.8    , installed 1.9.8
                              Adapter    "iot"           : 1.8.22   , installed 1.8.22
                              Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                              Controller "js-controller" : 3.3.15   , installed 3.3.15
                              Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                              Adapter    "lovelace"      : 2.0.4    , installed 2.0.4
                              Adapter    "material"      : 1.0.4    , installed 1.0.4
                              Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                              Adapter    "modbus"        : 3.4.11   , installed 3.4.11
                              Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                              Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                              Adapter    "nut"           : 1.5.0    , installed 1.5.0
                              Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
                              Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                              Adapter    "parser"        : 1.0.7    , installed 1.0.7
                              Adapter    "ping"          : 1.5.0    , installed 1.5.0
                              Adapter    "proxmox"       : 1.3.3    , installed 1.3.3
                              Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                              Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                              Adapter    "s7"            : 1.3.6    , installed 1.3.6
                              Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                              Adapter    "scenes"        : 2.3.6    , installed 2.3.6
                              Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                              Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                              Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                              Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                              Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                              Adapter    "sql"           : 1.15.7   , installed 1.15.7
                              Adapter    "statistics"    : 1.0.9    , installed 1.0.9
                              Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
                              Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                              Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                              Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                              Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                              Adapter    "unifi"         : 0.5.10   , installed 0.5.10
                              Adapter    "vis"           : 1.4.3    , installed 1.4.3
                              Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                              Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                              Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                              Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                              Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                              Adapter    "vis-icontwo"   : 0.75.0   , installed 0.75.0
                              Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                              Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                              Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                              Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                              Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                              Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                              Adapter    "web"           : 3.4.7    , installed 3.4.7
                              Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
                              All adapters are up to date
                                @peterfido
                                Sollte jetzt passen.
                                Pedder007 1 Reply Last reply Reply Quote 1
                                • Pedder007
                                  Pedder007 @Thomas Braun last edited by Pedder007
                                  @die Beteiligten, wollte an der Stelle einfach einmal Danke sagen!
                                  Nach einigem lesen hier im Forum und der ein oder anderen beantworteten Frage habe ich am letzten Sonntag alles ge-updated.
                                  Also js-controller, javascript und zum Schluss noch Admin. Davor noch 3-4 andere Adapter inkl. deCONZ.
                                  ... und was soll ich sagen, komplett unspektakulär, keinerlei Probleme, geradezu laaangweilig 😂 👍 👍 👍
                                  Alles lüppt geschmeidig weiter 🤗
                                  Einen klasse Job habt ihr da alle gemacht, danke!
                                  PS.
                                  Hatte extra 2 SD-Card Clone + Backitup + Kopie des iobroker-data Verzeichnisses angelegt.
                                  Alles völlig umsonst 😉
                                  F 1 Reply Last reply Reply Quote 2
                                    fastfoot @Pedder007 last edited by
                                    @pedder007 sagte in js-controller 3.3 jetzt im STABLE!:
                                    Backups sind nie!!! umsonst 🙂
                                    1 Reply Last reply Reply Quote 4
                                      chhe last edited by
                                      @apollon77 said in js-controller 3.3 jetzt im STABLE!:
                                      Windows
                                      Ausa der Community kommt von @sigi234 eine Anleitung für ein Windows Update Update_Windows_ioBroker.pdf
                                      die Anleitung ist ja sehr ausführlich und auch hilfreich. Wie soll mal mit dem Windows installer aber updaten wenn die letzte zur Verfügung stehende Version vom 23.11.2019 ist?
                                      https://www.iobroker.net/#de/download
                                        sigi234 Forum Testing Most Active @chhe last edited by
                                        @chhe sagte in js-controller 3.3 jetzt im STABLE!:
                                        Windows
                                        Na darum ist die Anleitung ja da, bis es eine neue Version vom Installer gibt.
                                          chhe @sigi234 last edited by
                                          @sigi234
                                          Die Anleitung gibt aber vor, eine Frische Installation mit dem Installer durchzuführen. Das erscheint mir aber ohne die neue Version des Installers nicht möglich.
                                          Mein Problem ist eigtl. folgendes:
                                          Die bei mir installierten Versionen sind mittlerweile veraltet.
                                          Node.js ist 10.17.0
                                          js-controller ist 3.2.16
                                          Admin ist 4.0.10
                                          Ich möchte nun updaten, da ich auch nun den ersten Adapter habe der mit der Adminversion nicht mehr kompatibel ist. Wie soll ich nun vorgehen?
                                          1. Backup machen
                                          2. iobroker stop
                                            npm i iobroker.js-controller@stable --ignore-scripts
                                            iobroker start
                                          3. js-controller updaten (wie in der verlinkten Anleitung beschrieben)
                                          4. Node.js updaten (wie in der verlinkten Anleitung beschrieben)
                                          Ich bin davon ausgegangen, dass ich mit dem Installer und der frischen Installation den Admin update. An welcher Stelle soll ich das nun machen?
                                            sigi234 Forum Testing Most Active @chhe last edited by sigi234
                                            Nein
                                            1.Schritt
                                            In der GUI die Updates machen - falls nötig
                                            Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer
                                            einlesen.
                                            Migration kann Stunden dauern!
                                            Dann weiter mit Schritt 2+3
                                            344
                                            89917
