    4. js-controller 3.3 jetzt im STABLE!
      Thomas Braun Most Active @peterfido last edited by Thomas Braun
      @peterfido
      Dann versuch jetzt nochmal dein Glück.
        peterfido @Thomas Braun last edited by
        Habe ich. Ein paar Warnungen kommen noch.
        peter@proxbroker:/opt/iobroker$ iobroker upgrade self
        Update js-controller from @3.2.16 to @3.3.15
        NPM version: 6.14.14
        npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        In file included from ../src/binding.cc:1:
        /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(cpufeatures, init)
        In file included from ../src/binding.cc:6:
        ../src/binding.cc:2013:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(sshcrypto, init)
        Starting node restart.js
          @peterfido
          Lösch den npm cache Mal
          cd /opt/iobroker
          npm cache clear --force
            @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
            Leider keine Änderung.
            cmake (3.13.4-1) wird eingerichtet ...
            Trigger für man-db (2.8.5-2) werden verarbeitet ...
            Trigger für libc-bin (2.28-10) werden verarbeitet ...
            peter@proxbroker:/opt/iobroker$ npm cache clear --force
            npm WARN using --force I sure hope you know what you are doing.
            Ich lasse es jetzt so.
              @peterfido
              Versuchs so:
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                Das Ergebnis:
                peter@proxbroker:/opt/iobroker$ iobroker stop
                peter@proxbroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                object _design/custom updated
                object _design/system updated
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                + iobroker.js-controller@3.3.15
                removed 88 packages and updated 1 package in 34.258s
                peter@proxbroker:/opt/iobroker$ iobroker start
                  @peterfido Dann sollte es ja jetzt passen.
                  iobroker version
                    Danke.
                    Die Version war nach dem Update um 12:14 auch schon die 3.3.15. Es traten halt die Warnungen während des Updates auf.
                    Mein erster Versuch ohne
                    iobroker fix
                    hatte die ioBroker "zerschossen". Er konnte ein paar Links nicht löschen. Danach lief kein Update mehr durch. Also im Snapshot zurück und erst den fix laufen lassen und nochmal aktualisieren.
                    Danach war die Version zwar aktuell, jedoch war ich mir wegen der Fehlermeldung mit dem cmake unsicher und habe daher hier angefragt.
                    Die (letzte) "manuelle" Installation hatte den positiven Nebeneffekt, dass ein paar Gigabyte freigeschaufelt wurden. 😊
                      @peterfido
                      Jetzt kann ich dem auch nicht entnehmen ob das wieder senkrecht läuft...
                      iobroker version
                      iobroker update
                      iobroker upgrade
                        peter@proxbroker:/opt/iobroker$ iobroker version
                        3.3.15
                        peter@proxbroker:/opt/iobroker$ iobroker update
                        Used repository: stable
                        hash unchanged, use cached sources
                        update done
                        Adapter    "admin"         : 5.1.23   , installed 5.1.23
                        Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                        Adapter    "asterisk"      : 1.0.6    , installed 1.0.6
                        Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                        Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                        Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                        Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                        Adapter    "doorio"        : 2.0.1    , installed 2.0.1
                        Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                        Adapter    "email"         : 1.0.10   , installed 1.0.10
                        Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                        Adapter    "flot"          : 1.10.6   , installed 1.10.6
                        Adapter    "fullcalendar"  : 1.1.0    , installed 1.1.0
                        Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.8
                        Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                        Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                        Adapter    "history"       : 1.9.13   , installed 1.9.13
                        Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                        Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                        Adapter    "hue"           : 3.5.19   , installed 3.5.19
                        Adapter    "hue-extended"  : 2.0.0    , installed 2.0.0
                        Adapter    "ical"          : 1.11.2   , installed 1.11.2
                        Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
                        Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                        Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                        Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                        Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                        Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                        Adapter    "info"          : 1.9.8    , installed 1.9.8
                        Adapter    "iot"           : 1.8.22   , installed 1.8.22
                        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                        Controller "js-controller" : 3.3.15   , installed 3.3.15
                        Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                        Adapter    "lovelace"      : 2.0.4    , installed 2.0.4
                        Adapter    "material"      : 1.0.4    , installed 1.0.4
                        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                        Adapter    "modbus"        : 3.4.11   , installed 3.4.11
                        Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                        Adapter    "node-red"      : 2.4.0    , installed 2.4.0
                        Adapter    "nut"           : 1.5.0    , installed 1.5.0
                        Adapter    "onkyo"         : 2.1.0    , installed 2.1.0
                        Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                        Adapter    "parser"        : 1.0.7    , installed 1.0.7
                        Adapter    "ping"          : 1.5.0    , installed 1.5.0
                        Adapter    "proxmox"       : 1.3.3    , installed 1.3.3
                        Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                        Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                        Adapter    "s7"            : 1.3.6    , installed 1.3.6
                        Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                        Adapter    "scenes"        : 2.3.6    , installed 2.3.6
                        Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                        Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                        Adapter    "sql"           : 1.15.7   , installed 1.15.7
                        Adapter    "statistics"    : 1.0.9    , installed 1.0.9
                        Adapter    "systeminfo"    : 0.3.1    , installed 0.3.1
                        Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                        Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                        Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                        Adapter    "unifi"         : 0.5.10   , installed 0.5.10
                        Adapter    "vis"           : 1.4.3    , installed 1.4.3
                        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                        Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                        Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                        Adapter    "vis-icontwo"   : 0.75.0   , installed 0.75.0
                        Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                        Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                        Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                        Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                        Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                        Adapter    "web"           : 3.4.7    , installed 3.4.7
                        Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
                        All adapters are up to date
                          @peterfido
                          Sollte jetzt passen.
                          Pedder007 1 Reply Last reply Reply Quote 1
                          • Pedder007
                            Pedder007 @Thomas Braun last edited by Pedder007
                            @die Beteiligten, wollte an der Stelle einfach einmal Danke sagen!
                            Nach einigem lesen hier im Forum und der ein oder anderen beantworteten Frage habe ich am letzten Sonntag alles ge-updated.
                            Also js-controller, javascript und zum Schluss noch Admin. Davor noch 3-4 andere Adapter inkl. deCONZ.
                            ... und was soll ich sagen, komplett unspektakulär, keinerlei Probleme, geradezu laaangweilig 😂 👍 👍 👍
                            Alles lüppt geschmeidig weiter 🤗
                            Einen klasse Job habt ihr da alle gemacht, danke!
                            PS.
                            Hatte extra 2 SD-Card Clone + Backitup + Kopie des iobroker-data Verzeichnisses angelegt.
                            Alles völlig umsonst 😉
                            F 1 Reply Last reply Reply Quote 2
                              fastfoot @Pedder007 last edited by
                              @pedder007 sagte in js-controller 3.3 jetzt im STABLE!:
                              Backups sind nie!!! umsonst 🙂
                              1 Reply Last reply Reply Quote 4
                                chhe last edited by
                                @apollon77 said in js-controller 3.3 jetzt im STABLE!:
                                Windows
                                Ausa der Community kommt von @sigi234 eine Anleitung für ein Windows Update Update_Windows_ioBroker.pdf
                                die Anleitung ist ja sehr ausführlich und auch hilfreich. Wie soll mal mit dem Windows installer aber updaten wenn die letzte zur Verfügung stehende Version vom 23.11.2019 ist?
                                https://www.iobroker.net/#de/download
                                  sigi234 Forum Testing Most Active @chhe last edited by
                                  @chhe sagte in js-controller 3.3 jetzt im STABLE!:
                                  Windows
                                  Na darum ist die Anleitung ja da, bis es eine neue Version vom Installer gibt.
                                    chhe @sigi234 last edited by
                                    @sigi234
                                    Die Anleitung gibt aber vor, eine Frische Installation mit dem Installer durchzuführen. Das erscheint mir aber ohne die neue Version des Installers nicht möglich.
                                    Mein Problem ist eigtl. folgendes:
                                    Die bei mir installierten Versionen sind mittlerweile veraltet.
                                    Node.js ist 10.17.0
                                    js-controller ist 3.2.16
                                    Admin ist 4.0.10
                                    Ich möchte nun updaten, da ich auch nun den ersten Adapter habe der mit der Adminversion nicht mehr kompatibel ist. Wie soll ich nun vorgehen?
                                    1. Backup machen
                                    2. iobroker stop
                                      npm i iobroker.js-controller@stable --ignore-scripts
                                      iobroker start
                                    3. js-controller updaten (wie in der verlinkten Anleitung beschrieben)
                                    4. Node.js updaten (wie in der verlinkten Anleitung beschrieben)
                                    Ich bin davon ausgegangen, dass ich mit dem Installer und der frischen Installation den Admin update. An welcher Stelle soll ich das nun machen?
                                      sigi234 Forum Testing Most Active @chhe last edited by sigi234
                                      Nein
                                      1.Schritt
                                      In der GUI die Updates machen - falls nötig
                                      Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer
                                      einlesen.
                                      Migration kann Stunden dauern!
                                      Dann weiter mit Schritt 2+3
                                        crunchip Forum Testing Most Active last edited by crunchip
                                        @apollon77
                                        v3.3.15
                                        habe gerade meine Proxmox VM gestoppt und anschliessend neu gestartet, im log findet man zu sämtlichen Adaptern
                                        terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        des weiteren kam diese Meldung
                                        host.IoBroker
                                        	2021-08-19 21:43:41.306	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.306	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.305	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:169:15)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.305	error	Caught by controller[0]: at processEmit [as emit] (/opt/iobroker/node_modules/signal-exit/index.js:149:35)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.304	error	Caught by controller[0]: at process.emit (events.js:400:28)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.304	error	Caught by controller[0]: at Object.onceWrapper (events.js:520:26)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.303	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.303	error	Caught by controller[0]: at Adapter.emit (events.js:400:28)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.302	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                                        host.IoBroker
                                        	2021-08-19 21:43:41.300	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                                          apollon77 @crunchip last edited by
                                          @crunchip Hm ... Was heisst denn "gestoppt"? Hart ohne iobroker sauber zu beenden?
                                          Dann wären die "Already Running" Meldungen erstmal ok weil der Controller denkt das noch die alte Instanz-Prozesse laufen ... er sendet ihr dann nen Kill Befehl aber ist ja schon weg von daher egal ... und er startet dann einen neuen Prozess. Herauszufinden ob eine "andere" prozess-ID noch läuft ist nicht ganz so simpel.
                                          Immer Systeme sauber runterfahren 🙂
                                          Für den Chromecast Fehler würde ich da mal ein Issue anlegen. Interessant wäre noch zu wissen WANN das log kam?
                                            crunchip Forum Testing Most Active @apollon77 last edited by crunchip
                                            @apollon77 sagte in js-controller 3.3 jetzt im STABLE!:
                                            jep, VM direkt gestoppt, nicht dran gedacht, weil das gerade alles so nervt...die Fehlersuche
                                            jetzt, ist mir das nächste aufgefallen, nachdem ich das log durch gesehen habe
                                            zwei Browserfenster, ich verstehe das nicht, log Größe unterschiedlich und unterschiedliche Meldungen
                                            c00a8347-d3e1-455d-a167-8103cfe649cd-grafik.png b86c0e1f-2733-4805-9725-2903cd9964c7-grafik.png
                                            irgendwann mittendrin, nachdem schon ein paar Instanzen gestartet sind
                                            2021-08-19 21:42:51.416 - info: admin.0 (866) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.17.4, js-controller: 3.3.15
                                            2021-08-19 21:43:41.300 - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                                            344
                                            89927
