    4. Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen
      sigi234 Forum Testing Most Active @Dirk Peter last edited by
      @dirk-peter sagte in Test Adapter Sprinkle Control mit neuen Funktionen:
      @martybr - 0.2.4 ist on, - hoffe das ich nichts übersehen habe, Dirk Peter
      sprinklecontrol.0
      2021-08-15 18:00:36.206	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_6.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:36.206	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_5.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:36.204	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_4.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:36.203	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_3.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:36.202	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_2.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:36.201	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_1.triggerPoint" has to be type "string" but received type "boolean"
      sprinklecontrol.0
      2021-08-15 18:00:35.165	info	setSoilMoistPct - analog: Ventil_1 .pst: 100
      sprinklecontrol.0
      2021-08-15 18:00:35.165	warn	Ventil_1: analog soil moisture sensor at 100 % => The range of values has been exceeded
      sprinklecontrol.0
      2021-08-15 18:00:35.165	info	setSoilMoistPct, Ventil_1 => analog, newVal: 20
      sprinklecontrol.0
      2021-08-15 18:00:35.164	info	filter analog: Ventil_1, state: 20
      sprinklecontrol.0
      2021-08-15 18:00:33.223	info	#1.0 => Set ID: Ventil_6(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_6.autoOn","objectName":"Ventil_6","objectID":"sprinklecontrol.0.sprinkle.Ventil_6.runningTime","idState":"0_userdata.0.Garten.Ventil_6","updateStateTimerID":null,"sprinkleID":5,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.223	info	#1.0 => Set ID: Ventil_5(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_5.autoOn","objectName":"Ventil_5","objectID":"sprinklecontrol.0.sprinkle.Ventil_5.runningTime","idState":"0_userdata.0.Garten.Ventil_5","updateStateTimerID":null,"sprinkleID":4,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.222	info	#1.0 => Set ID: Ventil_4(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_4.autoOn","objectName":"Ventil_4","objectID":"sprinklecontrol.0.sprinkle.Ventil_4.runningTime","idState":"0_userdata.0.Garten.Ventil_4","updateStateTimerID":null,"sprinkleID":3,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.222	info	#1.0 => Set ID: Ventil_3(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_3.autoOn","objectName":"Ventil_3","objectID":"sprinklecontrol.0.sprinkle.Ventil_3.runningTime","idState":"0_userdata.0.Garten.Ventil_3","updateStateTimerID":null,"sprinkleID":2,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.221	info	#1.0 => Set ID: Ventil_2(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_2.autoOn","objectName":"Ventil_2","objectID":"sprinklecontrol.0.sprinkle.Ventil_2.runningTime","idState":"0_userdata.0.Garten.Ventil_2","updateStateTimerID":null,"sprinkleID":1,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"calculation","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":4,"pct":50,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.221	info	#1.0 => Set ID: Ventil_1(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_1.autoOn","objectName":"Ventil_1","objectID":"sprinklecontrol.0.sprinkle.Ventil_1.runningTime","idState":"0_userdata.0.Garten.Ventil_1","updateStateTimerID":null,"sprinkleID":0,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":1100,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor1","inGreenhouse":false,"analogZPct":2,"analogOHPct":5,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
      sprinklecontrol.0
      2021-08-15 18:00:33.143	info	starting. Version 0.2.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.sprinklecontrol, node: v12.22.5, js-controller: 3.3.15
      Dirk Peter 2 Replies Last reply Reply Quote 0
        MartyBr @Dirk Peter last edited by
        @dirk-peter
        Super, du bist ja "pfeilschnell!". 👍
        Liegt das Update auf GitHub? Ich werde es dann installieren und weiter testen.
          @dirk-peter
          Ich bin mit der 0.2.4 Online. Ich hoffe, bei mir funktionieren die Bodenfeuchtesensoren weiter. Wir hatten heute Freunde zum Grillen da. Der Hund hat mir die Bodenfeuchtesensoren aus dem Rasen gezogen und irgendwo im Garten fallengelassen. Einen habe ich nun wiedergefunden 😓
          Ich habe ihn eingebaut. Hoffentlich liefert er noch Werte.
            @dirk-peter
            Die Triggerpunkte sind da:
            • Dirk Peter
              Dirk Peter @sigi234 last edited by
              @sigi234 sagte in Test Adapter Sprinkle Control mit neuen Funktionen:
              Kann ich mir nicht erklären. Schreibe eindeutig in 'string', habe eine issues im js-controller eröffnet.
              M sigi234 2 Replies Last reply Reply Quote 0
                @dirk-peter
                Das Log sieht bei mir sauber aus:
                sprinklecontrol.0
                2021-08-15 20:40:10.340	info	setSoilMoistPct - analog: Rasen_West .pst: 77
                sprinklecontrol.0
                2021-08-15 20:40:10.339	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
                sprinklecontrol.0
                2021-08-15 20:40:10.339	info	setSoilMoistPct - analog: Rasen_West .pst: 77
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                2021-08-15 20:40:10.338	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
                sprinklecontrol.0
                2021-08-15 20:40:10.338	info	setSoilMoistPct - analog: Rasen_West .pst: 77
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                2021-08-15 20:40:10.337	info	setSoilMoistPct, Rasen_West => analog, newVal: 77
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Hecke_und_Rosen .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct, Hecke_und_Rosen => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	filter analog: Hecke_und_Rosen, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Rasen_Ost .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct, Rasen_Ost => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	filter analog: Rasen_Ost, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct - analog: Rasen_Süd-Ost .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.667	info	setSoilMoistPct, Rasen_Süd-Ost => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.666	info	filter analog: Rasen_Süd-Ost, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.666	info	setSoilMoistPct - analog: Rasen_Süd .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.666	info	setSoilMoistPct, Rasen_Süd => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.666	info	filter analog: Rasen_Süd, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.664	info	setSoilMoistPct - analog: Rasen_Süd-West .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.663	info	setSoilMoistPct, Rasen_Süd-West => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.663	info	filter analog: Rasen_Süd-West, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.663	info	setSoilMoistPct - analog: Rasen_West .pst: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.663	info	setSoilMoistPct, Rasen_West => analog, newVal: 98
                sprinklecontrol.0
                2021-08-15 20:31:44.661	info	filter analog: Rasen_West, state: 98
                sprinklecontrol.0
                2021-08-15 20:31:42.668	info	#1.0 => Set ID: Hecke_und_Rosen(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Hecke_und_Rosen.autoOn","objectName":"Hecke_und_Rosen","objectID":"sprinklecontrol.0.sprinkle.Hecke_und_Rosen.runningTime","idState":"hm-rpc.1.OEQ0205713.6.STATE","updateStateTimerID":null,"sprinkleID":5,"wateringTime":40,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.668	info	#1.0 => Set ID: Rasen_Ost(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Ost.autoOn","objectName":"Rasen_Ost","objectID":"sprinklecontrol.0.sprinkle.Rasen_Ost.runningTime","idState":"hm-rpc.1.OEQ0205713.4.STATE","updateStateTimerID":null,"sprinkleID":4,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.667	info	#1.0 => Set ID: Rasen_Süd-Ost(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd-Ost.autoOn","objectName":"Rasen_Süd-Ost","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd-Ost.runningTime","idState":"hm-rpc.1.OEQ0205713.5.STATE","updateStateTimerID":null,"sprinkleID":3,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.666	info	#1.0 => Set ID: Rasen_Süd(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd.autoOn","objectName":"Rasen_Süd","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd.runningTime","idState":"hm-rpc.1.OEQ0205713.7.STATE","updateStateTimerID":null,"sprinkleID":2,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.666	info	#1.0 => Set ID: Rasen_Süd-West(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_Süd-West.autoOn","objectName":"Rasen_Süd-West","objectID":"sprinklecontrol.0.sprinkle.Rasen_Süd-West.runningTime","idState":"hm-rpc.1.OEQ0205713.2.STATE","updateStateTimerID":null,"sprinkleID":1,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.665	info	#1.0 => Set ID: Rasen_West(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Rasen_West.autoOn","objectName":"Rasen_West","objectID":"sprinklecontrol.0.sprinkle.Rasen_West.runningTime","idState":"hm-rpc.1.OEQ0205713.1.STATE","updateStateTimerID":null,"sprinkleID":0,"wateringTime":30,"wateringAdd":100,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"alias.0.Garten.Feuchtigkeitssensor.Rasen-Sensor1","inGreenhouse":false,"analogZPct":0,"analogOHPct":100,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":6.4,"pctTriggerIrrigation":80}}
                sprinklecontrol.0
                2021-08-15 20:31:42.638	info	starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v12.22.4, js-controller: 3.3.15
                sprinklecontrol.0
                2021-08-15 20:31:38.677	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                sprinklecontrol.0
                2021-08-15 20:31:38.677	info	terminating
                sprinklecontrol.0
                2021-08-15 20:31:38.676	info	cleaned everything up...
                sprinklecontrol.0
                2021-08-15 20:31:38.675	info	Got terminate signal TERMINATE_YOURSELF
                sprinklecontrol.0
                2021-08-15 20:30:17.969	info	getTelegramUser:{"1234567890":{"firstName":"mmmmm","userName":"xxxxxxx"}}
                sprinklecontrol.0
                2021-08-15 20:05:30.506	info	setSoilMoistPct - analog: Rasen_West .pst: 100
                sprinklecontrol.0
                2021-08-15 20:05:30.505	info	setSoilMoistPct - analog: Rasen_West .pst: 100
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                2021-08-15 20:05:30.505	info	setSoilMoistPct, Rasen_West => analog, newVal: 100
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                sprinklecontrol.0
                Dirk Peter 1 Reply Last reply Reply Quote 0
                • Dirk Peter
                  Dein Sensor ist nicht richtig konfiguriert, der Wert ist über 100% und wurde auf 100% zurück gesetzt. Daher die Warnung.
                  • Dirk Peter
                    Dirk Peter @MartyBr last edited by
                    @martybr schön, das freut mich. 🙂
                      sigi234 Forum Testing Most Active @Dirk Peter last edited by sigi234
                      Was ist Falsch eingestellt?
                      sprinklecontrol.0
                      2021-08-15 21:23:32.441	info	setSoilMoistPct - analog: Ventil_6 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.441	warn	Ventil_6: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.441	info	setSoilMoistPct, Ventil_6 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.440	info	filter analog: Ventil_6, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.440	info	setSoilMoistPct - analog: Ventil_5 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	warn	Ventil_5: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	info	setSoilMoistPct, Ventil_5 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	info	filter analog: Ventil_5, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	info	setSoilMoistPct - analog: Ventil_4 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	warn	Ventil_4: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.439	info	setSoilMoistPct, Ventil_4 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.438	info	filter analog: Ventil_4, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.438	info	setSoilMoistPct - analog: Ventil_3 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.438	warn	Ventil_3: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.438	info	setSoilMoistPct, Ventil_3 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.438	info	filter analog: Ventil_3, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.437	info	setSoilMoistPct - analog: Ventil_2 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.437	warn	Ventil_2: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.437	info	setSoilMoistPct, Ventil_2 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.437	info	filter analog: Ventil_2, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.436	info	setSoilMoistPct - analog: Ventil_1 .pst: 100
                      sprinklecontrol.0
                      2021-08-15 21:23:32.436	warn	Ventil_1: analog soil moisture sensor at 100 % => The range of values has been exceeded
                      sprinklecontrol.0
                      2021-08-15 21:23:32.435	info	setSoilMoistPct, Ventil_1 => analog, newVal: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:32.434	info	filter analog: Ventil_1, state: 20
                      sprinklecontrol.0
                      2021-08-15 21:23:30.316	info	#1.0 => Set ID: Ventil_6(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_6.autoOn","objectName":"Ventil_6","objectID":"sprinklecontrol.0.sprinkle.Ventil_6.runningTime","idState":"0_userdata.0.Garten.Ventil_6","updateStateTimerID":null,"sprinkleID":5,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor6","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.315	info	#1.0 => Set ID: Ventil_5(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_5.autoOn","objectName":"Ventil_5","objectID":"sprinklecontrol.0.sprinkle.Ventil_5.runningTime","idState":"0_userdata.0.Garten.Ventil_5","updateStateTimerID":null,"sprinkleID":4,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor5","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.315	info	#1.0 => Set ID: Ventil_4(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_4.autoOn","objectName":"Ventil_4","objectID":"sprinklecontrol.0.sprinkle.Ventil_4.runningTime","idState":"0_userdata.0.Garten.Ventil_4","updateStateTimerID":null,"sprinkleID":3,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor4","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.314	info	#1.0 => Set ID: Ventil_3(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_3.autoOn","objectName":"Ventil_3","objectID":"sprinklecontrol.0.sprinkle.Ventil_3.runningTime","idState":"0_userdata.0.Garten.Ventil_3","updateStateTimerID":null,"sprinkleID":2,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor3","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.314	info	#1.0 => Set ID: Ventil_2(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_2.autoOn","objectName":"Ventil_2","objectID":"sprinklecontrol.0.sprinkle.Ventil_2.runningTime","idState":"0_userdata.0.Garten.Ventil_2","updateStateTimerID":null,"sprinkleID":1,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":700,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor2","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.313	info	#1.0 => Set ID: Ventil_1(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Ventil_1.autoOn","objectName":"Ventil_1","objectID":"sprinklecontrol.0.sprinkle.Ventil_1.runningTime","idState":"0_userdata.0.Garten.Ventil_1","updateStateTimerID":null,"sprinkleID":0,"wateringTime":10,"wateringAdd":200,"wateringInterval":0,"pipeFlow":1100,"methodControlSM":"analog","triggerSM":"0_userdata.0.Bewaesserungssensor.Sensor1","inGreenhouse":false,"analogZPct":8,"analogOHPct":10,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":10,"triggersIrrigation":4,"pctTriggerIrrigation":50}}
                      sprinklecontrol.0
                      2021-08-15 21:23:30.287	info	starting. Version 0.2.4 in C:/Program Files/iobroker/Home/node_modules/iobroker.sprinklecontrol, node: v12.22.5, js-controller: 3.3.15
                      • Dirk Peter
                        sprinklecontrol.0
                        Du hast in deiner Konfiguration eine Bandbreite von 8 (Bodenfeuchte-Sensor bei 0%) bis 10 (Bodenfeuchte-Sensor bei 100%) eingestellt.
                        Sprinkle Control liest aber einen Wert von 20 (Ventil_6 => analog, newVal: 20) aus. Daher die Warn-Meldung.
                        MfG Dirk Peter
                          Neue Meldung:
                          web.0
                          2021-08-15 22:41:10.258	info	State value to set for "sprinklecontrol.0.sprinkle.Ventil_3.runningTime" has to be type "string" but received type "number"
                          • Dirk Peter
                            @sigi234 Wie ich schon geschrieben habe, wird diese Meldung vom js-controller erzeugt um die Entwickler daran zu erinnern im richtigen Datentyp zu schreiben. Dies ist bei mir aber meines Wissens der Fall. Weswegen ich eine issues beim js-controller auf GitHub eröffnet habe. Du kannst es ja hier auf GitHub verfolgen.
                            MfG Dirk Peter
                            • Dirk Peter
                              Dirk Peter @sigi234 last edited by Dirk Peter
                              @sigi234
                              web.0
                              Doch mein Fehler! Sollte mit dem nächsten update erledigt sein.
                              Dirk Peter
                                @dirk-peter
                                Da scheint noch ein Fehler in der Auswertung der Bodenfeuchtigssensoren zu sein. Alle Ventile sind auf den gleichen Sensor konfiguriert. Der Sensor zeigte heute Morgen nach dem Regen 98% an. Trotzdem ist die Beregnung mit Ventil 2 aufsteigend gestartet.
                                Die Bodenfeuchtigkeit der Sensoren ist bei Ventil 1 richtig, die anderen Ventile zeigen nur 1% an.
                                Hier dazu Telegram:
                                SprinkleControl:
                                Rasen_West 98% (78%)
                                Rasen_Süd-West 1% (78%)
                                   START => 30:00
                                Rasen_Süd 1% (78%)
                                   START => 30:00
                                Rasen_Süd-Ost 1% (78%)
                                   START => 30:00
                                Rasen_Ost 1% (78%)
                                   START => 30:00
                                Hecke_und_Rosen 1% (78%)
                                   START => 40:00
                                Hier das json der Konfiguration:
                                system.adapter.sprinklecontrol.0-5.json
                                • Dirk Peter
                                  @martybr Hallo Martin,
                                  jetzt habe ich den Fehler gefunden. Ich ging immer davon aus, dass man pro Bewässerungskreis einen separaten Bodenfeuchte-Sensor verwendet. Daher wurde beim 1. gefundenen Sensor die Suche abgebrochen. Du kannst es daran erkennen, das die Sensoren auf 1% stehen und die letzte Änderung ihres Wertes die Startzeit deines Adapters war. Ich schau mir mal an wie ich das umschreibe.
                                  MfG Dirk Peter
                                  • dieckfr
                                    dieckfr @Dirk Peter last edited by
                                    @dirk-peter
                                    Hallo Dirk Peter, danke für Deine Antwort! Ich habe mich nun an der 2.4 versucht, aber scheitere immer noch kläglich...
                                    Ich habe wie von Dir vorgeschlagen 3 Kreise angelegt, den mittleren als Dummy zur Pause. Anzahl Max Ventile auf 1.
                                    Alle Kreise stehen auf festen Wochentagen.
                                    Folgendes passiert:
                                    1. Trotz On des Kreises in den Objekten, wird die Hardware nicht getriggert
                                    2. Es wird nicht mit dem ersten Kreis angefangen, sondern mit Kreis 2 und 1-3 stehen auf wait.
                                    Ich weiss echt nicht was ich falsch mache... Hier nochmal was ich gerne machen möchte 🙂
                                    Start der Bewässerung: Es soll jeden Tag zu einer festen Zeit Bewässert werden, unabhängig von irgendwas.
                                    Ablauf
                                    2.1 Ventil1 20 min ein
                                    2.2 5min Pause zum Druckaufbau der Pumpe
                                    2.3 Ventil2 20min ein
                                    Fertig 🙂
                                    Im 2ten Schritt
                                    Bewässerung abhängig von der Wettervorhersage
                                    1.1 Nicht Bewässern wenn am Tag genug Regen war
                                    1.2 Nicht Bewässern wenn am nächsten Tag genug Regen gemeldet ist
                                    INFO: Ich möchte Nachts gegen 2-3 Uhr Bewässern, da stört das nie 🙂
                                    Ist das irgendwie umsetzbar, also mit dem Adapter machbar? Hab ich nen Denkfehler?
                                    Vielen Dank im voraus!
                                    • Dirk Peter
                                      Dirk Peter @dieckfr last edited by
                                      @dieckfr
                                      Festlegen der Reihenfolge:
                                      • 1.) Anzahl Max Ventile auf 1
                                      • 2.) Reihenfolge der Ventile festlegen (über den Wasserverbrauch, es wird immer mit dem größter Verbrauch begonnen)
                                        z.B, Ventil 1 => 600 l/h; Ventil 2 => 500 l/h; Ventil 3 => 400 l/h
                                      • Wettervorhersage aktivieren, Schwellwert ab dem nicht bewässert werden soll festlegen
                                      Gruß Dirk Peter
                                      • Dirk Peter
                                        @martybr
                                        Habe auf GitHub eine Vorabversion 0.2.5, sollte damit funktionieren. Bitte testen.
                                        Info: Du brauchst nicht den nächsten Regen bzw. Sonnenschein abwarten! Du kannst es auch erkennen wenn alle Objekte "sprinklecontrol.0.*.actualSoilMoisture" die auf den gleichen Sensor zeigen, die identischen Werte aufweisen über eine gewisse Zeit mit Wertänderungen.
                                        MfG Dirk Peter
                                          @dirk-peter
                                          Ich habe die 0.2.5 installiert. Ich schaue mir die Werte und die Telegram Meldung morgen an und gebe dir dann Rückmeldung.
                                            @dirk-peter
                                            Das scheint nun zu funktionieren. Hier die Meldungen von SprinkleControl:
                                            Gestern:
                                            SprinkleControl:
                                            Rasen_West 92.5% (80%)
                                            Rasen_Süd-West 92.5% (80%)
                                            Rasen_Süd 92.5% (80%)
                                            Rasen_Süd-Ost 92.5% (80%)
                                            Rasen_Ost 92.5% (80%)
                                            Hecke_und_Rosen 92.5% (80%)
                                            Heute:
                                            SprinkleControl:
                                            Rasen_West 92% (80%)
                                            Rasen_Süd-West 92% (80%)
                                            Rasen_Süd 92% (80%)
                                            Rasen_Süd-Ost 92% (80%)
                                            Rasen_Ost 92% (80%)
                                            Hecke_und_Rosen 92% (80%)
                                            31.7k
                                            79.8k
                                            bodenfeuchte-sensoren gartenbewässerung sprinkle control wetterabhängig
                                            41
                                            295
                                            37855
