    4. Kein restore mit backitup [gelöst]
      Thomas Braun Most Active @ChrisNett last edited by
      @christian-sandkaulen
      Restore kann geraume Zeit dauern.
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        ChrisNett @Thomas Braun last edited by
        @thomas-braun said in Kein restore mit backitup:
        node
        v12.22.1 ist nicht aktuell?
        • ChrisNett
          sehe ich denn irgtwas am bildschirm? oder unter putty ?
            Node 12.22.5 ist aktuell. Das sollte dir bei sauberer Installation aber auch der Paketmanager verraten
              iobroker logs --watch
              zeigt den Fortgang im Log File.
              • ChrisNett
                2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
                2021-08-16 15:43:23.987  - info: host.PI4 terminated
                2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
                2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
                2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
                2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
                2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
                2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
                2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
                2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
                2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
                2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
                2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
                2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
                2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
                2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                müsste da nicht mehr stehen?
                  Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
                  date && date -u
                  • ChrisNett
                    date && date -u
                    ne seit einer stunde
                    Mo 16. Aug 16:44:45 CEST 2021
                    Mo 16. Aug 14:44:45 UTC 2021
                      Das dürfte dann abgenippelt sein.
                      iobroker start
                      Iobroker status
                      which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                      • ChrisNett
                        Iobroker status
                        Objects type: file
                        States  type: file
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v12.22.1
                        v12.22.1
                        6.14.12
                        nodejs:
                          Installiert:           12.22.1-1nodesource1
                          Installationskandidat: 12.22.1-1nodesource1
                          Versionstabelle:
                         *** 12.22.1-1nodesource1 500
                                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.24.0~dfsg-1~deb10u1 500
                        Thomas Braun ChrisNett 2 Replies Last reply Reply Quote 0
                          Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
                          iobroker stop
                          sudo apt update
                          sudo apt dist-upgrade
                          sudo reboot
                          • ChrisNett
                            ChrisNett @ChrisNett last edited by
                            im backitup adapter ist jetzt das aufgetaucht
                            Started restore ...
                            [DEBUG] [iobroker] Start ioBroker Restore ...
                            [EXIT] 0
                            • ChrisNett
                              nach einiger zeit hier der log
                              brauchst du den log?
                                Ist dein OS jetzt gepatcht?
                                • ChrisNett
                                  pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.22.5
                                  v12.22.5
                                  6.14.14
                                  nodejs:
                                    Installiert:           12.22.5-1nodesource1
                                    Installationskandidat: 12.22.5-1nodesource1
                                    Versionstabelle:
                                   *** 12.22.5-1nodesource1 500
                                  pi@PI4:~ $
                                  denke schon oder?
                                    Und wie ist jetzt der Status? Backup drin?
                                    • ChrisNett
                                      nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                                      • ChrisNett
                                        kann ich mit putty versuchen ein bestimmtes einzuspielen?
                                        • ChrisNett
                                          nach dem Neustart vom iobroker kommt dieser Fehler
                                          backitup.0
                                          2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                                          der Adapter ist aber grün.
                                            Thomas Braun Most Active last edited by
                                            Installier den Adapter nochmal.
                                            906
