    4. Kein restore mit backitup [gelöst]
      Thomas Braun Most Active @ChrisNett last edited by
      @christian-sandkaulen
      Node 12.22.5 ist aktuell. Das sollte dir bei sauberer Installation aber auch der Paketmanager verraten
        iobroker logs --watch
        zeigt den Fortgang im Log File.
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ChrisNett @Thomas Braun last edited by
          2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
          2021-08-16 15:43:23.987  - info: host.PI4 terminated
          2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
          2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
          2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
          2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
          2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
          2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
          2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
          2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
          2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
          2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
          2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
          2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
          2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
          2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          müsste da nicht mehr stehen?
            Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
            date && date -u
            • ChrisNett
              @thomas-braun said in Kein restore mit backitup:
              date && date -u
              ne seit einer stunde
              Mo 16. Aug 16:44:45 CEST 2021
              Mo 16. Aug 14:44:45 UTC 2021
                Das dürfte dann abgenippelt sein.
                iobroker start
                Iobroker status
                which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                • ChrisNett
                  Iobroker status
                  Objects type: file
                  States  type: file
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.1
                  v12.22.1
                  6.14.12
                  nodejs:
                    Installiert:           12.22.1-1nodesource1
                    Installationskandidat: 12.22.1-1nodesource1
                    Versionstabelle:
                   *** 12.22.1-1nodesource1 500
                          500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u1 500
                  Thomas Braun ChrisNett 2 Replies Last reply Reply Quote 0
                    Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
                    iobroker stop
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo reboot
                    • ChrisNett
                      ChrisNett @ChrisNett last edited by
                      im backitup adapter ist jetzt das aufgetaucht
                      Started restore ...
                      [DEBUG] [iobroker] Start ioBroker Restore ...
                      [EXIT] 0
                      • ChrisNett
                        nach einiger zeit hier der log
                        brauchst du den log?
                          Ist dein OS jetzt gepatcht?
                          • ChrisNett
                            pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.5
                            v12.22.5
                            6.14.14
                            nodejs:
                              Installiert:           12.22.5-1nodesource1
                              Installationskandidat: 12.22.5-1nodesource1
                              Versionstabelle:
                             *** 12.22.5-1nodesource1 500
                            pi@PI4:~ $
                            denke schon oder?
                              Und wie ist jetzt der Status? Backup drin?
                              • ChrisNett
                                nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                                • ChrisNett
                                  kann ich mit putty versuchen ein bestimmtes einzuspielen?
                                  • ChrisNett
                                    nach dem Neustart vom iobroker kommt dieser Fehler
                                    backitup.0
                                    2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                                    der Adapter ist aber grün.
                                      Thomas Braun Most Active last edited by
                                      Installier den Adapter nochmal.
                                      • ChrisNett
                                        als zweite Instanz ?
                                          Nein, über den Adapter drüber.
                                          iobroker upgrade backitup@2.1.13
                                          • ChrisNett
                                            pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                                            Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                                            Update backitup from @2.1.13 to @2.1.13
                                            host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                                            NPM version: 6.14.14
                                            npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                                            müsste da nicht mehr passsieren?
                                            906
