    4. Kein restore mit backitup [gelöst]
    • ChrisNett
      ChrisNett @Thomas Braun last edited by
      2021-08-16 15:43:23.925  - info: host.PI4 All instances are stopped.
      2021-08-16 15:43:23.987  - info: host.PI4 terminated
      2021-08-16 15:43:23.446  - info: host.PI4 instance system.adapter.mqtt.0 terminated with code null ()
      2021-08-16 15:43:23.575  - warn: host.PI4 instance system.adapter.ping.0 terminated due to SIGTERM
      2021-08-16 15:43:23.576  - info: host.PI4 instance system.adapter.ping.0 terminated with code null ()
      2021-08-16 15:43:23.577  - warn: host.PI4 instance system.adapter.sonoff.0 terminated due to SIGTERM
      2021-08-16 15:43:23.577  - info: host.PI4 instance system.adapter.sonoff.0 terminated with code null ()
      2021-08-16 15:43:23.765  - warn: host.PI4 instance system.adapter.logparser.0 terminated due to SIGTERM
      2021-08-16 15:43:23.765  - info: host.PI4 instance system.adapter.logparser.0 terminated with code null ()
      2021-08-16 15:43:23.766  - warn: host.PI4 instance system.adapter.shelly.0 terminated due to SIGTERM
      2021-08-16 15:43:23.766  - info: host.PI4 instance system.adapter.shelly.0 terminated with code null ()
      2021-08-16 15:43:23.854  - warn: host.PI4 instance system.adapter.zigbee.0 terminated due to SIGTERM
      2021-08-16 15:43:23.855  - info: host.PI4 instance system.adapter.zigbee.0 terminated with code null ()
      2021-08-16 15:43:23.855  - warn: host.PI4 instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
      2021-08-16 15:43:23.856  - info: host.PI4 instance system.adapter.tankerkoenig.0 terminated with code null ()
      2021-08-16 15:43:23.924  - info: host.PI4 instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      müsste da nicht mehr stehen?
        Thomas Braun Most Active @ChrisNett last edited by
        @christian-sandkaulen
        Seit einer Stunde läuft das? Oder ist deine Zeitzone falsch?
        date && date -u
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          @thomas-braun said in Kein restore mit backitup:
          date && date -u
          ne seit einer stunde
          Mo 16. Aug 16:44:45 CEST 2021
          Mo 16. Aug 14:44:45 UTC 2021
            Das dürfte dann abgenippelt sein.
            iobroker start
            Iobroker status
            which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
            • ChrisNett
              Iobroker status
              Objects type: file
              States  type: file
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.1
              v12.22.1
              6.14.12
              nodejs:
                Installiert:           12.22.1-1nodesource1
                Installationskandidat: 12.22.1-1nodesource1
                Versionstabelle:
               *** 12.22.1-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u1 500
              Thomas Braun ChrisNett 2 Replies Last reply Reply Quote 0
                Damn bringst du jetzt erstmal dein Betriebssystem auf Stand:
                iobroker stop
                sudo apt update
                sudo apt dist-upgrade
                sudo reboot
                • ChrisNett
                  ChrisNett @ChrisNett last edited by
                  im backitup adapter ist jetzt das aufgetaucht
                  Started restore ...
                  [DEBUG] [iobroker] Start ioBroker Restore ...
                  [EXIT] 0
                  • ChrisNett
                    nach einiger zeit hier der log
                    brauchst du den log?
                      Ist dein OS jetzt gepatcht?
                      • ChrisNett
                        pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy        nodejs
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v12.22.5
                        v12.22.5
                        6.14.14
                        nodejs:
                          Installiert:           12.22.5-1nodesource1
                          Installationskandidat: 12.22.5-1nodesource1
                          Versionstabelle:
                         *** 12.22.5-1nodesource1 500
                        pi@PI4:~ $
                        denke schon oder?
                          Und wie ist jetzt der Status? Backup drin?
                          • ChrisNett
                            nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
                            • ChrisNett
                              kann ich mit putty versuchen ein bestimmtes einzuspielen?
                              • ChrisNett
                                nach dem Neustart vom iobroker kommt dieser Fehler
                                backitup.0
                                2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
                                der Adapter ist aber grün.
                                  Thomas Braun Most Active last edited by
                                  Installier den Adapter nochmal.
                                  • ChrisNett
                                    als zweite Instanz ?
                                      Nein, über den Adapter drüber.
                                      iobroker upgrade backitup@2.1.13
                                      • ChrisNett
                                        pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                                        Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                                        Update backitup from @2.1.13 to @2.1.13
                                        host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                                        NPM version: 6.14.14
                                        npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                                        müsste da nicht mehr passsieren?
                                        • ChrisNett
                                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                          Adapter "backitup" updated
                                          hat ewig gedauert.
                                            Du bist zu ungeduldig.
                                            906
