    4. Node-Red
    5. zweimal einen Datenpunkt Button schalten
    • mickym
      mickym Most Active @Aphofis last edited by
      @aphofis Also wenn wie bei mir ein String "10" in die Split Node kommt, dann siehst Du hier anhand der Debug Nodes, die Du halt gegen die Tastenpunkte Deiner Harmony ersetzen musst:
      hier mal dieser Beispielflow:
              "id": "41550327.2bf39c",
              "type": "split",
              "z": "e8c5c56.e220438",
              "name": "",
              "splt": "1",
              "spltType": "len",
              "arraySplt": 1,
              "arraySpltType": "len",
              "stream": false,
              "addname": "",
              "x": 610,
              "y": 180,
              "wires": [
                      "717ffa37.5bf7e4"
              "id": "8a918032.ba379",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "10",
              "payloadType": "str",
              "x": 430,
              "y": 180,
              "wires": [
                      "41550327.2bf39c"
              "id": "6af7e799.ee3168",
              "type": "debug",
              "name": "Phillips Nr. 0",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 970,
              "y": 40,
              "wires": []
              "id": "717ffa37.5bf7e4",
              "type": "switch",
              "name": "",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "0",
                      "vt": "str"
                      "t": "eq",
                      "v": "1",
                      "vt": "str"
                      "t": "eq",
                      "v": "2",
                      "vt": "str"
                      "t": "eq",
                      "v": "3",
                      "vt": "str"
                      "t": "eq",
                      "v": "4",
                      "vt": "str"
                      "t": "eq",
                      "v": "5",
                      "vt": "str"
                      "t": "eq",
                      "v": "6",
                      "vt": "str"
                      "t": "eq",
                      "v": "7",
                      "vt": "str"
                      "t": "eq",
                      "v": "8",
                      "vt": "str"
                      "t": "eq",
                      "v": "9",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 10,
              "x": 770,
              "y": 180,
              "wires": [
                      "6af7e799.ee3168"
                      "d6f4657d.bcc268"
                      "fc1a91f1.e1c14"
                      "113e7478.8fecec"
              "id": "d6f4657d.bcc268",
              "type": "debug",
              "name": "Phillips Nr. 1",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 970,
              "y": 80,
              "wires": []
              "id": "fc1a91f1.e1c14",
              "type": "debug",
              "name": "Phillips Nr. 2",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 970,
              "y": 120,
              "wires": []
              "id": "113e7478.8fecec",
              "type": "debug",
              "name": "Phillips Nr. 3",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 970,
              "y": 160,
              "wires": []
      Die switch Node braucht natürlich für jede Taste einen eigenen Ausgang:
      Aphofis 1 Reply Last reply Reply Quote 0
      • Aphofis
        Aphofis @mickym last edited by
        @mickym
        Das verstehe ich aber noch nicht so ganz
        • mickym
          mickym Most Active @Aphofis last edited by mickym
          @aphofis Also ich habe mal mit meiner Inject Node angenommen es kommt ein String "10" raus. Importiere halt mal den Flow.
          Also kommt 10 in die split Node rein.
          Die Zerlegt nun den String in 2 Nachrichten mit jeweils EINER Ziffer. Also kommt erst eine Nachricht mit "1" gefolgt von einer Nachricht mit "0".
          Diese werden nun in der Switch Node auf die Eingänge 0 - 9 verteilt und dort hängt dann der Zifferndatenpunkte Deiner Fernbedienung dran. Also als ob Du in Deiner Fernbedienung erst die 1 und dann die 0 drückst.
          • Aphofis
            Aphofis @mickym last edited by Aphofis
            @mickym
            Ah OK cool jetzt verstehe ich
            ok moment
            (Node-Red Fehler gefunden, hatte zweimal den selben Port bei zwei verschiedenen Geräten für Alexa)
            • mickym
              @aphofis Im Prinzip wirst Du in Deinem harmony Adapter bei Deinem Fernseher (bei mir halt Pioneer) für jede Ziffer einen eigenen Datenpunkt haben:
              Es kann zwar sein, dass der keine Zahlen sondern lieber true oder immer eine 1 haben will, aber dann setzt Du das mit einer Change Node entsprechend.
              • Aphofis
                @mickym
                und wie implementiere ich dann alexa dazu???
                • mickym
                  @aphofis Na Deine Alexa gibt doch den String aus oder nicht?
                  Also was kommt den raus, wenn Du ARD oben sagst?
                  • mickym
                    mickym Most Active @mickym last edited by mickym
                    @mickym Wenn da nur true aus der Alexa Node oben rauskommt, dann hängst Du halt eine Change Node dahinter, um Dir den entsprechenden Programmplatz zu übersetzen. Irgendwie musst Du ja in Deinen Sendeplatz übersetzen.
                    Sprich wenn Du ARD sagst und die obige Node triggerst - und es soll auf der Fernbedienung 1 und 0 gedrückt werden, dann setzt Du hinter die Alexa Node einfach ein Change Node mit dem String 10.
                    Hier mal der ganze Flow - Du musst nun einfach nur die Inject Nodes gegen Alexa Nodes ersetzen und hinten die Debug Nodes gegen Dein iobroker out Nodes mit den Tastenpunkten:
                    Hier wieder der gesamte Flow zum Import:
                           "type": "split",
                           "name": "",
                           "splt": "1",
                           "spltType": "len",
                           "arraySplt": 1,
                           "stream": false,
                           "addname": "",
                           "x": 610,
                           "y": 180,
                           "wires": [
                                   "717ffa37.5bf7e4"
                           "type": "inject",
                           "name": "ARD",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "10",
                           "x": 250,
                           "y": 140,
                           "wires": [
                                   "710e3c6d.11f0b4"
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1230,
                           "y": 40,
                           "wires": []
                           "type": "switch",
                           "name": "",
                           "rules": [
                                   "t": "eq",
                                   "v": "0",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "1",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "2",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "3",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "4",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "5",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "6",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "7",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "8",
                                   "vt": "str"
                                   "t": "eq",
                                   "v": "9",
                                   "vt": "str"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 10,
                           "x": 770,
                           "y": 180,
                           "wires": [
                                   "ac8cd608.ff2d78"
                                   "81031c96.e4e03"
                                   "6dc90375.86eebc"
                                   "a9da448a.767fd8"
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1230,
                           "y": 80,
                           "wires": []
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1230,
                           "y": 120,
                           "wires": []
                           "type": "debug",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 1230,
                           "y": 160,
                           "wires": []
                           "id": "ac8cd608.ff2d78",
                           "type": "change",
                           "name": "Setze 1 für Tastendruck",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "1",
                                   "tot": "num"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 990,
                           "y": 40,
                           "wires": [
                                   "6af7e799.ee3168"
                           "id": "710e3c6d.11f0b4",
                           "type": "change",
                           "name": "Programmplatz 10",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "10",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 430,
                           "y": 140,
                           "wires": [
                                   "41550327.2bf39c"
                           "id": "f7c2bd16.233fd",
                           "type": "inject",
                           "name": "ZDF",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "11",
                           "x": 250,
                           "y": 180,
                           "wires": [
                                   "b1042862.fb3ba8"
                           "id": "b1042862.fb3ba8",
                           "type": "change",
                           "name": "Programmplatz 11",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "11",
                                   "tot": "str"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 430,
                           "y": 180,
                           "wires": [
                                   "41550327.2bf39c"
                           "id": "81031c96.e4e03",
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "1",
                                   "tot": "num"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 990,
                           "y": 80,
                           "wires": [
                                   "d6f4657d.bcc268"
                           "id": "6dc90375.86eebc",
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "1",
                                   "tot": "num"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 990,
                           "y": 120,
                           "wires": [
                                   "fc1a91f1.e1c14"
                           "id": "a9da448a.767fd8",
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "1",
                                   "tot": "num"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 990,
                           "y": 160,
                           "wires": [
                                   "113e7478.8fecec"
                    Im Moment siehst Du anhand der Debug Nodes - das die richtigen Tasten gedrückt werden - habe ich markiert über das Topic:
                    Aphofis 2 Replies Last reply Reply Quote 0
                    • Aphofis
                      @mickym
                      I will try
                      • Aphofis
                        @mickym
                        OK und wo ist dort Alexa und Harmony verknüpft!?
                        nihct böse sein aber Node-Red bin ich null konform
                        • mickym
                          @aphofis Nochmal hast Du den Flow importiert?
                          Wenn Du jetzt auf den Inject Node Klickst, (das entsprecht später Deiner Alexa Node). Die Debug Nodes - da kommen iobroker Out Nodes auf Deine Harmony Punkte - wie ich Sie Dir in meiner Objektstruktur gezeigt habe.
                          Ich habe mal die Nodes gruppiert - damit Du die Verbindung besser siehst:
                          In die orange Gruppe kommen Deine Alexa Nodes - in die grüne Gruppe die iobroker-Out Nodes zu Deinen Harmony Datenpunkten.
                          Und beides ist über den Flow miteinander verbunden (das sind die Verbindungslinien).
                                 "type": "split",
                                 "name": "",
                                 "splt": "1",
                                 "spltType": "len",
                                 "arraySplt": 1,
                                 "stream": false,
                                 "addname": "",
                                 "x": 590,
                                 "y": 260,
                                 "wires": [
                                         "717ffa37.5bf7e4"
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "eq",
                                         "v": "0",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "1",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "2",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "3",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "4",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "5",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "6",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "7",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "8",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "9",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 10,
                                 "x": 750,
                                 "y": 260,
                                 "wires": [
                                         "ac8cd608.ff2d78"
                                         "81031c96.e4e03"
                                         "6dc90375.86eebc"
                                         "a9da448a.767fd8"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "1",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 970,
                                 "y": 120,
                                 "wires": [
                                         "6af7e799.ee3168"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "10",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 220,
                                 "wires": [
                                         "41550327.2bf39c"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "11",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 260,
                                 "wires": [
                                         "41550327.2bf39c"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "1",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 970,
                                 "y": 160,
                                 "wires": [
                                         "d6f4657d.bcc268"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "1",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 970,
                                 "y": 200,
                                 "wires": [
                                         "fc1a91f1.e1c14"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "1",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 970,
                                 "y": 240,
                                 "wires": [
                                         "113e7478.8fecec"
                                 "id": "8fde9d8c.4f4fe",
                                 "type": "group",
                                 "name": "Iobroker Out Nodes zur Harmony ",
                                 "style": {
                                     "label": true,
                                     "fill": "#addb7b"
                                 "nodes": [
                                     "6af7e799.ee3168",
                                     "d6f4657d.bcc268",
                                     "fc1a91f1.e1c14",
                                     "113e7478.8fecec"
                                 "x": 1114,
                                 "y": 79,
                                 "w": 214,
                                 "h": 202
                                 "type": "debug",
                                 "g": "8fde9d8c.4f4fe",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1210,
                                 "y": 120,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1210,
                                 "y": 160,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1210,
                                 "y": 200,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1210,
                                 "y": 240,
                                 "wires": []
                                 "id": "f02a92ce.cc5d1",
                                 "type": "group",
                                 "name": "Alexa Nodes",
                                 "style": {
                                     "label": true,
                                     "fill": "#ffdf7f"
                                 "nodes": [
                                     "8a918032.ba379",
                                     "f7c2bd16.233fd"
                                 "x": 134,
                                 "y": 179,
                                 "w": 172,
                                 "h": 122
                                 "type": "inject",
                                 "g": "f02a92ce.cc5d1",
                                 "name": "ARD",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "10",
                                 "x": 230,
                                 "y": 220,
                                 "wires": [
                                         "710e3c6d.11f0b4"
                                 "type": "inject",
                                 "name": "ZDF",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "11",
                                 "x": 230,
                                 "y": 260,
                                 "wires": [
                                         "b1042862.fb3ba8"
                          • mickym
                            Falls das true aus der Alexa Node zum rausfiltern noch wichtig ist, dann musst das halt noch zwischen die Alexa Node und der Change Node indem Du in den Programmplatz übersetzt das dazwischen machen.
                            • Aphofis
                              @mickym
                              nicht zwingend notwendig.
                              Da die Alexa steuerung ja auf 1 und 0 reagiert kann das true/false raus.
                              war nur wichtig für normale Datenpunkte
                              wo integriere ich denn die Steuerung vom Harmony und wo packe ich die Alexa steuerung hin???
                              Was markiert ist.
                              • mickym
                                @aphofis Das Links lässt Du so wie es ist. Die WDR Node entspricht dem orangen Kasten und hängst ihn an einen der Change NOdes um in die Programm Speicherplätze zum Übersetzen.
                                Die Debug NOdes ersetzt Du durch Deine Phillips Tasten Nodes (iobroker out)
                                • Aphofis
                                  @mickym
                                  Das mal ne schöne Beschreibung Vielen dank!!!
                                  Das teste ich gleich mal
                                  • Aphofis
                                    Aphofis @Aphofis last edited by
                                    weißt du zufällig, ob es eine Alexa Node gibt wo man den Gerätetyp ändern kann da momentan alle Geräte aus iobroker als Lampe deklariert sind !?
                                    • mickym
                                      @aphofis Nein - da kenn ich mich nicht aus.
                                      @frankyboy73 ist da eher Spezialist - der war aber schon lange nicht mehr online. Hier mal ein Beitrag von ihm:
                                      https://forum.iobroker.net/topic/24069/temperaturen-über-node-red-und-alexa-abfragen/47?_=1629204642794
                                      Da erzählt er etwas von Routinen - dann kann man wohl statt schalte WDR ein -irgendwelche anderen Kommandos abgeben.
                                      Aber ich habe keine Alexa und kann Dir deshalb diesbezügl. nicht helfen.
                                      • Aphofis
                                        @mickym
                                        Die Info ist schon super! Danke
                                        • Aphofis
                                          Wie mache ich es denn mit den Programmnummern 4-9 kann ich die dann einfach zur liste erweitern !?
                                          • mickym
                                            @aphofis Klar ich habe nur aus Faulheit nicht alle gemacht, wenn Du mit der Maus auf den Ausgang fährst dann siehst Du ja welcher Ausgang welche Ziffer ist:
                                            1.0k
                                            1208
