    4. Kein restore mit backitup [gelöst]
    • ChrisNett
      ChrisNett @Thomas Braun last edited by
      nein das bleibt immer noch hängen auch ein älteres, ein neues erstellen ging aber.
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        ChrisNett @ChrisNett last edited by
        kann ich mit putty versuchen ein bestimmtes einzuspielen?
        • ChrisNett
          nach dem Neustart vom iobroker kommt dieser Fehler
          backitup.0
          2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
          der Adapter ist aber grün.
            Thomas Braun Most Active last edited by
            @christian-sandkaulen
            Installier den Adapter nochmal.
            • ChrisNett
              als zweite Instanz ?
                Thomas Braun Most Active @ChrisNett last edited by
                Nein, über den Adapter drüber.
                iobroker upgrade backitup@2.1.13
                • ChrisNett
                  @thomas-braun said in Kein restore mit backitup:
                  pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                  Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                  Update backitup from @2.1.13 to @2.1.13
                  host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                  NPM version: 6.14.14
                  npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                  müsste da nicht mehr passsieren?
                  • ChrisNett
                    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                    Adapter "backitup" updated
                    hat ewig gedauert.
                      Du bist zu ungeduldig.
                        Homoran Global Moderator Administrators @ChrisNett last edited by Homoran
                        @christian-sandkaulen sagte in Kein restore mit backitup:
                        hat ewig gedauert.
                        5 Minuten?
                        was ist dein Server?
                        • ChrisNett
                          ChrisNett @Homoran last edited by
                          backupt ist 6,3Mb
                          pi4 mit 4gb
                          • ChrisNett
                            ja da hast du recht, ich versuche noch mal einen restore nach dem update
                              pi4 mit 4gb
                              der sollte einen Install etwas schneller hinbekommen
                              @Thomas-Braun
                              Was kann denn da so bremsen, dann wird ein 6MB Backup möglicherweise in ein timeout laufen?
                              • ChrisNett
                                auf dem pi läuft noch motioneye das habe ich gerade mal gestoppt mal sehen ob das jetzt geht.
                                Thomas Braun ChrisNett 2 Replies Last reply Reply Quote 0
                                  @christian-sandkaulen @Homoran
                                  Motioneye ist ja auch für die Leichtigkeit bekannt.
                                  • ChrisNett
                                    pi@PI4:~ $ free
                                    Mem:        3930860       52152     3282432       16836      596276     3719800
                                    Swap:        102396
                                    pi@PI4:~ $ top
                                    top - 18:24:24 up  1:09,  1 user,  load average: 0,03, 0,55, 1,79
                                    Tasks: 118 total,   1 running, 117 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):   0,1/2,5     3[||        ]
                                    MiB Mem :   3838,7 total,   3205,0 free,     51,2 used,    582,5 buff/cache
                                    MiB Swap:    100,0 total,    100,0 free,      0,0 used.   3632,3 avail Mem
                                      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                      505 root      20   0       0      0      0 I   0,0   0,0   0:48.38 kworker/u8:3-events_unbound
                                    14545 root      20   0       0      0      0 I   4,3   0,0   0:27.40 kworker/u8:0-brcmf_wq/mmc1:0001:1
                                      134 root      20   0   37620  22608  21744 S   0,0   0,6   0:09.33 systemd-journal
                                    22629 root      20   0       0      0      0 I   0,0   0,0   0:09.32 kworker/0:2-events
                                     9386 root      20   0       0      0      0 I   0,3   0,0   0:09.27 kworker/u8:4-events_unbound
                                        1 root      20   0   32724   8132   6520 S   0,0   0,2   0:04.49 systemd
                                       12 root      20   0       0      0      0 I   0,0   0,0   0:04.20 rcu_sched
                                       62 root       0 -20       0      0      0 I   0,0   0,0   0:02.93 kworker/0:1H-kblockd
                                      363 root      20   0   25512   2728   2420 S   0,0   0,1   0:02.27 rsyslogd
                                      271 root      20   0       0      0      0 S   0,0   0,0   0:02.02 brcmf_wdog/mmc1
                                    22638 root      20   0       0      0      0 I   0,0   0,0   0:01.47 kworker/0:3-events
                                      380 avahi     20   0    5900   2612   2360 S   0,0   0,1   0:01.36 avahi-daemon
                                      da sieht man aber, dass es eben noch nicht so ruhig war.
                                      jetzt ist motioneye natürlich aus
                                        free -ht
                                        kann man besser lesen.
                                        • ChrisNett
                                          free -ht
                                          pi@PI4:~ $ free -ht
                                          Mem:          3,7Gi       1,1Gi       2,1Gi        16Mi       585Mi       2,7Gi
                                          Swap:          99Mi          0B        99Mi
                                          Total:        3,8Gi       1,1Gi       2,2Gi
                                          motion io ist aus und der ioBroker läuft.
                                          • ChrisNett
                                            er macht ein restore yes... lag es wirklich an MotionEye? soll das mal auf einen eigenen PI4?
                                            kann gerade keine code kopieren...
                                            906
