    4. Kein restore mit backitup [gelöst]
    • ChrisNett
      ChrisNett @ChrisNett last edited by
      kann ich mit putty versuchen ein bestimmtes einzuspielen?
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        nach dem Neustart vom iobroker kommt dieser Fehler
        backitup.0
        2021-08-16 17:45:56.923	warn	Cannot read log file: ReferenceError: config is not defined
        der Adapter ist aber grün.
          Thomas Braun Most Active last edited by
          @christian-sandkaulen
          Installier den Adapter nochmal.
          • ChrisNett
            ChrisNett @Thomas Braun last edited by
            als zweite Instanz ?
              Thomas Braun Most Active @ChrisNett last edited by
              Nein, über den Adapter drüber.
              iobroker upgrade backitup@2.1.13
              • ChrisNett
                @thomas-braun said in Kein restore mit backitup:
                pi@PI4:~ $ iobroker upgrade backitup@2.1.13
                Would you like to reinstall version 2.1.13 of backitup now? [(y)es, (n)o]: y
                Update backitup from @2.1.13 to @2.1.13
                host.PI4 Adapter "system.adapter.backitup.0" is stopped.
                NPM version: 6.14.14
                npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (        System call)
                müsste da nicht mehr passsieren?
                • ChrisNett
                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  Adapter "backitup" updated
                  hat ewig gedauert.
                    Du bist zu ungeduldig.
                      Homoran Global Moderator Administrators @ChrisNett last edited by Homoran
                      @christian-sandkaulen sagte in Kein restore mit backitup:
                      hat ewig gedauert.
                      5 Minuten?
                      was ist dein Server?
                      • ChrisNett
                        ChrisNett @Homoran last edited by
                        backupt ist 6,3Mb
                        pi4 mit 4gb
                        • ChrisNett
                          ja da hast du recht, ich versuche noch mal einen restore nach dem update
                            pi4 mit 4gb
                            der sollte einen Install etwas schneller hinbekommen
                            @Thomas-Braun
                            Was kann denn da so bremsen, dann wird ein 6MB Backup möglicherweise in ein timeout laufen?
                            • ChrisNett
                              auf dem pi läuft noch motioneye das habe ich gerade mal gestoppt mal sehen ob das jetzt geht.
                              Thomas Braun ChrisNett 2 Replies Last reply Reply Quote 0
                                @christian-sandkaulen @Homoran
                                Motioneye ist ja auch für die Leichtigkeit bekannt.
                                • ChrisNett
                                  pi@PI4:~ $ free
                                  Mem:        3930860       52152     3282432       16836      596276     3719800
                                  Swap:        102396
                                  pi@PI4:~ $ top
                                  top - 18:24:24 up  1:09,  1 user,  load average: 0,03, 0,55, 1,79
                                  Tasks: 118 total,   1 running, 117 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):   0,1/2,5     3[||        ]
                                  MiB Mem :   3838,7 total,   3205,0 free,     51,2 used,    582,5 buff/cache
                                  MiB Swap:    100,0 total,    100,0 free,      0,0 used.   3632,3 avail Mem
                                    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                    505 root      20   0       0      0      0 I   0,0   0,0   0:48.38 kworker/u8:3-events_unbound
                                  14545 root      20   0       0      0      0 I   4,3   0,0   0:27.40 kworker/u8:0-brcmf_wq/mmc1:0001:1
                                    134 root      20   0   37620  22608  21744 S   0,0   0,6   0:09.33 systemd-journal
                                  22629 root      20   0       0      0      0 I   0,0   0,0   0:09.32 kworker/0:2-events
                                   9386 root      20   0       0      0      0 I   0,3   0,0   0:09.27 kworker/u8:4-events_unbound
                                      1 root      20   0   32724   8132   6520 S   0,0   0,2   0:04.49 systemd
                                     12 root      20   0       0      0      0 I   0,0   0,0   0:04.20 rcu_sched
                                     62 root       0 -20       0      0      0 I   0,0   0,0   0:02.93 kworker/0:1H-kblockd
                                    363 root      20   0   25512   2728   2420 S   0,0   0,1   0:02.27 rsyslogd
                                    271 root      20   0       0      0      0 S   0,0   0,0   0:02.02 brcmf_wdog/mmc1
                                  22638 root      20   0       0      0      0 I   0,0   0,0   0:01.47 kworker/0:3-events
                                    380 avahi     20   0    5900   2612   2360 S   0,0   0,1   0:01.36 avahi-daemon
                                    da sieht man aber, dass es eben noch nicht so ruhig war.
                                    jetzt ist motioneye natürlich aus
                                      free -ht
                                      kann man besser lesen.
                                      • ChrisNett
                                        free -ht
                                        pi@PI4:~ $ free -ht
                                        Mem:          3,7Gi       1,1Gi       2,1Gi        16Mi       585Mi       2,7Gi
                                        Swap:          99Mi          0B        99Mi
                                        Total:        3,8Gi       1,1Gi       2,2Gi
                                        motion io ist aus und der ioBroker läuft.
                                        • ChrisNett
                                          er macht ein restore yes... lag es wirklich an MotionEye? soll das mal auf einen eigenen PI4?
                                          kann gerade keine code kopieren...
                                          • ChrisNett
                                            [DEBUG] [iobroker] Start ioBroker Restore ...
                                            [DEBUG] [iobroker] iobroker controller daemon is not running
                                            [DEBUG] [iobroker] host.PI4 OK.
                                            [DEBUG] [iobroker] host.PI4 Clear all objects and states...
                                            [DEBUG] [iobroker] clean 8767 objects...
                                            [DEBUG] [iobroker] Server Objects 127.0.0.1:52796 Error from InMemDB: Error: Object is marked as non deletable
                                            [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                                            [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                                            [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                                            [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                                            [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                                            [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                                            [DEBUG] [iobroker] clean 7218 states...
                                            [DEBUG] [iobroker] host.PI4 done.
                                            [DEBUG] [iobroker] System successfully restored!
                                            [DEBUG] [iobroker] ioBroker Restore completed successfully
                                            [EXIT] 0 **** Restore completed successfully!! ****
                                            The log can be closed ...
                                            also doch einen pi für motion eye? wisst ihr warum nach einem neustart (Stromausfall die vis weg sein kann?)
                                            906
