    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      searcher57 @Ahnungsbefreit last edited by
      Ok, ich versuch es später nochmal. Danke!😊
      <broadlink2.0
      	12333	2021-06-17 16:07:29.617	info	found macs:
      broadlink2.0
      	12333	2021-06-17 16:07:29.616	info	broadlink2.0 started and found 0 devices named
      broadlink2.0
      	12333	2021-06-17 16:07:29.615	info	Poll every 30 secods.
      broadlink2.0
      	12333	2021-06-17 16:07:25.364	info	discover [ '192.168.178.57' ] from 0.0.0.0:56876
      broadlink2.0
      	12333	2021-06-17 16:07:25.362	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:25.361	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:20.842	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'RM4', name: '0x653c_a0:43:b0:b9:e4:d0', devhex: '0x653c', devname: 'rm4'}
      broadlink2.0
      	12333	2021-06-17 16:07:20.840	warn	Failed to authenticate device RM4, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	12333	2021-06-17 16:07:20.139	info	discover [ '192.168.178.255', '192.168.178.255', '255.255.255.255', '224.0.0.251'] from 0.0.0.0:58551
      broadlink2.0
      	12333	2021-06-17 16:07:20.137	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:20.136	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:20.118	info	Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0
      	12333	2021-06-17 16:07:20.050	info	macObjects: []
      broadlink2.0
      	12333	2021-06-17 16:07:20.049	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:20.048	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	12333	2021-06-17 16:07:20.044	info	broadlink2 has 0 old devices!
      broadlink2.0
      	12333	2021-06-17 16:07:20.043	info	Devices to rename: LB:hostName-aa-bb-cc=LB:SmartBulb
      broadlink2.0
      	12333	2021-06-17 16:07:20.043	info	Devices to add: 25916=RM4
      broadlink2.0
      	12333	2021-06-17 16:07:20.042	info	Scanning additional IP's: 192.168.178.57
      broadlink2.0
      	12333	2021-06-17 16:07:20.038	info	broadlink2 initialization started...
      broadlink2.0
      	12333	2021-06-17 16:07:19.929	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.22.1, js-controller: 3.3.12
      broadlink2.0
      	11325	2021-06-17 16:07:15.599	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      broadlink2.0
      	11325	2021-06-17 16:07:15.597	info	terminating
      broadlink2.0
      	11325	2021-06-17 16:07:15.595	info	Adapter disconnected and stopped with dostop(null) and callback(true)
      broadlink2.0
      	11325	2021-06-17 16:07:15.589	info	Close all connections...
      broadlink2.0
      	11325	2021-06-17 16:07:15.586	info	Got terminate signal TERMINATE_YOURSELF
      broadlink2.0
      	11325	2021-06-17 15:33:41.227	info	found macs:
      broadlink2.0
      	11325	2021-06-17 15:33:41.227	info	broadlink2.0 started and found 0 devices named
      broadlink2.0
      	11325	2021-06-17 15:33:41.226	info	Poll every 30 secods.
      broadlink2.0
      	11325	2021-06-17 15:33:38.018	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:38.017	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:37.918	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:37.917	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:37.819	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:37.818	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:37.717	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:37.716	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:37.637	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:37.636	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:36.946	info	discover [ '192.168.178.57' ] from 0.0.0.0:48698
      broadlink2.0
      	11325	2021-06-17 15:33:36.943	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:36.942	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:33.520	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.518	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.463	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.461	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.448	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.447	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.309	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.308	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.229	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.228	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.164	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.163	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:33.018	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:33.017	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.965	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.964	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.934	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.933	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.773	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.772	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.706	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.704	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.656	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.655	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.495	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.494	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.455	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.454	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:32.406	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11325	2021-06-17 15:33:32.405	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11325	2021-06-17 15:33:31.720	info	discover [ '192.168.178.255', '192.168.178.255', '255.255.255.255', '224.0.0.251'] from 0.0.0.0:58180
      broadlink2.0
      	11325	2021-06-17 15:33:31.718	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:31.717	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:31.699	info	Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0
      	11325	2021-06-17 15:33:31.671	info	macObjects: []
      broadlink2.0
      	11325	2021-06-17 15:33:31.670	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:31.669	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11325	2021-06-17 15:33:31.665	info	broadlink2 has 0 old devices!
      broadlink2.0
      	11325	2021-06-17 15:33:31.664	info	Devices to rename: LB:hostName-aa-bb-cc=LB:SmartBulb
      broadlink2.0
      	11325	2021-06-17 15:33:31.664	info	Devices to add: 0xabcd=RM4
      broadlink2.0
      	11325	2021-06-17 15:33:31.663	info	Scanning additional IP's: 192.168.178.57
      broadlink2.0
      	11325	2021-06-17 15:33:31.659	info	broadlink2 initialization started...
      broadlink2.0
      	11325	2021-06-17 15:33:31.534	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.22.1, js-controller: 3.3.12
      broadlink2.0
      	11309	2021-06-17 15:33:27.237	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      broadlink2.0
      	11309	2021-06-17 15:33:27.235	info	terminating
      broadlink2.0
      	11309	2021-06-17 15:33:27.234	info	Adapter disconnected and stopped with dostop(null) and callback(true)
      broadlink2.0
      	11309	2021-06-17 15:33:27.230	info	Close all connections...
      broadlink2.0
      	11309	2021-06-17 15:33:27.227	info	Got terminate signal TERMINATE_YOURSELF
      broadlink2.0
      	11309	2021-06-17 15:32:31.734	info	found macs:
      broadlink2.0
      	11309	2021-06-17 15:32:31.733	info	broadlink2.0 started and found 0 devices named
      broadlink2.0
      	11309	2021-06-17 15:32:31.732	info	Poll every 30 secods.
      broadlink2.0
      	11309	2021-06-17 15:32:27.391	info	discover [ '192.168.1.199' ] from 0.0.0.0:54881
      broadlink2.0
      	11309	2021-06-17 15:32:27.390	info	interface to be used: { netmaskBits: 24, address: '192.168.178.58/24', addrs: [ 192, 168, 178, 58 ], cidr: '192.168.178.58/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11309	2021-06-17 15:32:27.389	info	interface to be used: { netmaskBits: 24, address: '192.168.178.54/24', addrs: [ 192, 168, 178, 54 ], cidr: '192.168.178.54/24', bcaddr: '192.168.178.255'}:
      broadlink2.0
      	11309	2021-06-17 15:32:23.962	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.960	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.908	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.907	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.863	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.861	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.704	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.703	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.660	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.659	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.614	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.613	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object Object]
      broadlink2.0
      	11309	2021-06-17 15:32:23.455	warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.178.57', port: 80, devtype: 25916, oname: '智能遥控', cloud: 1, maco: <Buffer d0 e4 b9 b0 43 a0>, mac: 'a0:43:b0:b9:e4:d0', type: 'unknown', name: '0x653c_a0:43:b0:b9:e4:d0', devname: 'UKN', devhex: '0x653c'}
      broadlink2.0
      	11309	2021-06-17 15:32:23.454	warn	Failed to authenticate device Unknown, undefined, a0:43:b0:b9:e4:d0, 192.168.178.57, 智能遥控cloud=true with err [object >```
      code_text127397
      A Knallochse 2 Replies Last reply Reply Quote 0
        aba320 @searcher57 last edited by
        @searcher57 hallo,
        wie @Ahnungsbefreit schon sagte das Gerät darf nicht in die Cloud von Broadlink kommen. steht auch in deinme Log Zeile 14 "warning.. device in cloud.........". ich hatte damals extra ne veraltete Broadlink app genutzt (weiß im moment aber nicht mehr welche, das war viel früher aber auch mal in diesem Thread.). nur in netz kein Name kein raum etc. wenn einfaches rauswerfen aus der smartphone app nicht hilft Werksrest und das ding nur wieder in netz bringen.
        • Knallochse
          Knallochse @searcher57 last edited by
          @searcher57 mit einem Apple Gerät wäre es diese App zum einrichten des RM pro
            searcher57 @Knallochse last edited by
            @knallochse
            Taraaa!!
            Nachdem ich die dritte App zur Installation benutzt habe, kann ich endlich den Broadlink im ioBroker ansprechen. Nein ich habe ein Samsung S20! Hier hat nur folgende App Funktioniert:
            Danke für Eure Hilfe!!
            S K 2 Replies Last reply Reply Quote 0
              searcher57 @searcher57 last edited by
              @searcher57
              Ich muss jedoch einmal etwas los werden.
              Hier im Forum suchen sehr viele Laien (Anfänger) Hilfe. Diese wird auch schnell und kompetent gegeben. Wenn ich jedoch manche Ratschläge lese, kommt mir, wie auch vielen anderen Usern, der Gedanke, dass sich die IT-Spezialisten gerne präsentieren und die Hilfesuchenden blosstellen wollen! Es ist doch manchmal so einfach jemandem zu helfen, wie es wie BBTown bei mir gemacht hat!
              Trotzdem nochmal danke!😚 😚
                RainbowRun last edited by
                Hallo 🙂
                da ich mehr der leise Leser bin aber ich nun ein Problem habe wollte ich schauen ob mir vielleicht einer helfen kann.
                Ich habe einen neuen RM mini 3 mit der SN RM735 heute erhalten ich dachte wird schon funktionieren nur leider geht nicht viel
                Device RM:RM3-de-cf-44 detected: address=, mac= typ=RM, id=0x6508 devtype=RM Mini 3
                die Id hab ich schon versucht Einzupflegen nur leider passiert nicht viel iobroker
                broadlink2.0.RM:RM3-de-cf-44._notReachable das ist der einzige Eintrag der dabei steht.
                Vielleicht kennt ja schon einer dieses Model
                Liebe Grüße
                S A 2 Replies Last reply Reply Quote 0
                  searcher57 @RainbowRun last edited by searcher57
                  @rainbowrun
                  Tut mir leid, da ich selbst Anfänger bin und einen Broadlink RM4 Pro im Einsatz habe, kann ich Dir nicht weiterhelfen. Aus meiner Erfahrung kann ich Dir aber sagen, dass die Nutzung vom Broadlink im IO Broker nicht einfach zu nutzen ist.
                  Viel Erfolg!!
                    aba320 @RainbowRun last edited by
                    @rainbowrun Hallo, welche Adapterversion hast Du?
                    Das Protokoll für RM4 und neue RM3 minis ist erst ab version 2.1.0 enthalten. über insall von github sonst aktualisieren.
                    ich hab nur RM4 mini der läuft bei mir mit 2.1.4 reibungslos.
                      csp last edited by
                      Hallo!
                      Ich vervende den Adapter schon ziemlich lange und wollte mal wieder ein paar neue Funkfernbedingungssignale einlernen.
                      Das geht aber nicht mehr. Über LearnRF findet er zwar was, speichert es aber nicht ab.
                      Bei Learn passiert gar nichts.
                      Fehlermeldung im Protokoll:
                      learning makeState error: RM:RM4-pro-f1-2a-d7} TypeError: Cannot read property 'code' of undefined
                      Jemand ne Idee?
                      Gruß,
                      Thomas
                      padrino 1 Reply Last reply Reply Quote 0
                      • padrino
                        padrino Most Active @csp last edited by padrino
                        Ich weiß, es bringt vermutlich nix hier zu schreiben, da der Adapter/Thread wohl leider recht tot scheint... 😞
                        Aber ich versuch es mal.
                        Mein Broadlink beginnt auf einmal irgendwie sich sich selbst zu zerstören.
                        Vereinzelte Befehle, die über Jahre liefen veruschen auf einmal Fehler, ohne, dass am System etwas geändert wurd.
                        Z.B.
                        2021-08-17 10:42:16.101 - warn: broadlink2.0 (19141) Error in StateChange for broadlink2.0.RMPROPLUS-42-fb-44.L.Ecklampe_IR_an = TypeError: Cannot destructure property `always` of 'undefined' or 'null'.at Function.changeState (/opt/iobroker/node_modules/iobroker.broadlink2/fjadapter.js:1100:7)at setState (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:418:11)at A.stateChange (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:207:13)at process._tickCallback (internal/process/next_tick.js:68:7)
                        Kann damit jemand etwas anfangen?
                        Auch wenn ich einen Befehl neu anlerne und ihn dann umbenenne, wird nur noch der "Name" umbenannt, die "ID" bleibt "Code...", das war vorher nicht so.
                          apollon77 @padrino last edited by
                          @padrino GitHub issue bitte anlegen
                          • padrino
                            padrino Most Active @apollon77 last edited by
                            @apollon77
                            Beim Broadlink adapter?
                            Da guckt doch auch keiner mehr rein, leider.
                            Außerdem wüsste ich gar nicht was ich da (be)schreiben soll, kann den Fehler ja nicht mal richtig benennen.
                            Habe nun festgestellt, betroffen sind wohl nur Befehle, die Teil eines "state" sind, aber auch auch, wenn ich diese nicht über den "state" sondern den Befehl direkt aufrufe.
                            Lösche ich den State funktioniert der Befehl auch wieder. Lege ich den State wieder an, läuft auch der Befehl nicht mehr.
                            Meine Lösung für jetzt: alle states rauswerfen und alles nur noch über eigene Datenpunkte von Hand machen...
                            Ok, das Problem, dass die ID nicht mit "Name" automatisch umbenannt wird, bleibt davon unberüht, aber das stört mich ich Moment nicht direkt, da ich eigentlich keine neuen Befehle im Moment anlernen will. O:)
                            apollon77 Olli_M 2 Replies Last reply Reply Quote 0
                              @padrino ich denke Frank schaut sich hier und da mal rein. Sonst ist es so das ohne GitHub issue keiner das Problem sieht weil nur hier im Forum reicht nicht. Am Ende auch schwierig wenn dunes nicht benennen kannst. Am besten issue und dort „reproduction steps“ …
                              • Olli_M
                                Olli_M @padrino last edited by
                                @padrino
                                funkioniert der Adapter noch?
                                Habe ihn gerade von Github installiert, aber finde kein learning Object 😞
                                Ip Adresse habe ich angegeben und der Adapter ist auf grün
                                  crunchip Forum Testing Most Active @Olli_M last edited by
                                  @olli_m an und für sich schon, dir fehlt aber der Broadlink, was hast du denn für einen?
                                    KPJ24 @searcher57 last edited by
                                    @searcher57
                                    Wie haben sie das in der APP gemacht?
                                    Ich verzweilfe daran den RM4 mini, mithilfe der app in WLAN zu bringen.
                                    • padrino
                                      padrino Most Active @KPJ24 last edited by
                                      Weiß jemand, ob man sich aus einem "an Code" den "off Code" errechnen kann?
                                      Bekomme für eine meine ELRO Funksteckdosen nur ein gültigen Code für "on" angelernt, "off" will der Broadlink nicht. 😞
                                      Müsste doch irgendwo im Code stehen, dass es on oder off ist und der Rest bleibt doch gleich, oder?
                                      Mein Code:
                                      CODE_b100a0010b22210b0b220b210b21210c0b22210c0a220a220b22210b0b22210c0a22220b0b220a220b22210b0b220b210b22210c0b0001570a22210c0b210b220a22210c0b22210b0b220b220a22210c0b21220b0b22210c0b210b220b21220b0b220b210b22210c0b0001570b21220b0b220b220a22210c0b21220b0b220b210b22210c0b21210d0a22210c0b210b220b22210c0a220b220a22220b0b0001570b22210c0b210b220b21220b0b22210c0a230a220b21220b0b22210c0b22210b0b220b220a22220b0b220b210b22210c0b0001570b21220b0b220b210b22210c0a22210c0b220a220a22220b0b22210b0b22210c0b21210c0b21220b220b220b210c210c0b0001560b22210b0b220a220b21220b0b22210c0a220b210b22210c0a22210c0b21220b0b21220b0b22210c210c210b220b220b0b0001570a22210c0a220b220a22210c0a22210c0a220b210b22210c0a22210c0b21220b0b22210c0a22210c210c210c210b220b0b0001570a22210c0a220b220a22210c0a22210c0b210b220a22210c0a22210c0b21210c0b22210b0b22210c210c210c210c200c0b0005dc0000000000000000
                                        schubs2802 last edited by
                                        bin gerade auf dieses Forum hier gestoßen und hoffe es liest noch jemand mit, der etwas Ahnung hat oder zumindest einen Tipp für mich. Habe seit ein paar Wochen das Problem, dass der Broadlink aussteigt und die Scripte nicht mehr umsetzen mag. Ich nutze den Broadlink RM4 Pro für die Rollosteuerung im Wohnzimmer schon seit 3 Jahren und der hat immer gut funktioniert. Bis, ja das kann ich garnicht so genau sagen. Ich glaube es war nach dem "großen" Iobroker Update. Dann bekomme ich Fehlermeldungen und die Rollos bleiben unten (oder oben). Starte ich den Adapter neu, läuft es wieder. Spätestens am nächsten Tag das gleiche.
                                        Ich nutze den Broadlink2.0 V2.1.5. Vielleicht hat ja einer ne Idee.
                                        BG
                                        broadlink2.0
                                        2022-07-08 06:36:03.605	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59.L.CODE_b2002a030a130b120a130a130a130a130a130a13a61414090a1314090a130a130a13140914090a13140914080b1314080b1309130b130a120b120b1215080b131409140815081508150914080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a3a61415080a1314090a130a130a13140915080a13140915080a1314090a130a130a130a130a130a1314090a131508140914091409140914090a13140914080b1314090a1309140a13091414080a130a1409130b120a130a1409130a130b120b120a1409130b120a14091315080a14140815080a13150815091409140914091409140814a4a6131509091414080a130a130b13140815080a13150815080a1315080a130a130a130a130a130a1414080a141409140815081509140815080a13150815080a1414080a130a130a130a1414080b120a130b120a140a120a130a130a130b120a130a130a130b120a130a1315080a13150815080a13150815081508150815081509140715a4a51514080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131509140815081508150815080a13150914080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081508150715a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a13150815081508150815081509140814a4a51415080a1315080a130a130a14140815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150914080a13150815080a1315080a130a1409130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a131508150815081508150815081507150005dc0000000000000000000000000000=RM:RMPROPLUS-63-cc-59 {val: true,ack: false,ts: 1657254963114,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1656832699084}
                                        broadlink2.0
                                        2022-07-08 06:36:03.450	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59.L.CODE_b2002a030a13091409130b120b120b1309130a14a51414090a1315070b130a130a13140914080b13140914080b1314080a130b1309130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a120b130a130a1314090a13140914090a1314091409140914080a141409140815a3a61414080a1315080a130a130a14140815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13140915080a1314090a130a130a130a130a1314080b130a130a130a130a130a130a130a130a130914091409130b13091414080a13150914080b1215081508150815080b121508150814a4a51415080a1414080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150814091508150815080a13140915080a1314090a130a130a130a130a1314090a130a130a130a130a130a130a130a130a130a130a130a130a130a1314090a13140914090a1314091409140914090a131409140814a4a61414090a1314080b120a140914140914080a14140914080a1414080a130a130b120b120b120a1414080a131508150815091408150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a141408150814a4a51415080a1414080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081409140914090a131409150715a3a61415080a1315080a130a130a13150814090a13150815080a1314090a130a130a130a130a130a1314090a131409140914091508140914090a13140914080b1314090a130a130a130a120b1314090a130a120b120b120b130a13091409140a1309130a140a130914091414080b13140914080a1315091409140815080a1315091407150005dc0000000000000000000000000000=RM:RMPROPLUS-63-cc-59 {val: true,ack: false,ts: 1657254963114,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1656833239963}
                                        broadlink2.0
                                        2022-07-08 06:36:03.293	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59.L.CODE_b2002a030a130a130a130a130a130a130a130a13a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131409140914091409140914080b13140914090a1314080b130a120b120a140914091414080a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a13150715a4a51415080a1315080a130a130a13140914090a13140914090a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914080b1314080a140a130914091409130b1215080b120b120a130b120a130b120a130a130b120b120a130b120b1314090914140815080a1315081508150815080a130a13150715a4a51415080a1315080a130a130a13150914080a13150815080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a120b1314090a13140914090a1314091409140914080b130a13140815a3a61414090a1215080b130a120a14140815080a13150815080a1414080a130a130a130a1409130a1315080a131508150815081508150815080a13150815080a1414080a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508140915080a130a13150715a3a61414090a1315080a130a130a13140915080a13140914090a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914090a1314080a14091409130b120a130a1414080b120a130a130a130a140a120a130a130a130a130a130b120a1315080a13150815080b1215081508150815080a130a13150715a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1315080a131409150814091409140915080a13140914090a1314090a120b130a130a130a130a1314080b120b120b120b1309130b130a130a130a120b1309130b120b1215080b12150914080b1215091408150815080a130a131507150005dc0000000000000000000000000000=RM:RMPROPLUS-63-cc-59 {val: true,ack: false,ts: 1657254963114,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1656833229380}
                                        broadlink2.0
                                        2022-07-08 06:36:00.324	warn	stateChange error invalid id type: RM:RMPROPLUS-63-cc-59.L.CODE_b2002a0309130a130a130a130a130a130a130a13a61414080a1414080a1409140913150914080a14140914080a1315080a130a130a130a130a130a1315080a131508150815081508150815080a13150815080a1315080a130a130a130a130a130a130a1314090a130a130a130a130a130a1309130b120b120a130b13091414080a14140914080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1314090a131409140914091409140914090a13140914080a1414080b120b120b120b120b120a130b1215080b120a1409130b120b120a130b120a130b120a130a130a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13150815080a1315080a130a130a130a130a130a1314090a131409150814091409140914090a13140914090a1315080a120b120b120b130a130a120b1314080b120b130a130a130a120b120b130a120b120a130b13091414080a1315091409091414091409140914080a130b120a1315a3a61414080a1414080a130a130a13150815090913150815080a1414080a130b120a130a130a130a1414080b131409140815081508150815080a13150815080a1414080b120a130a130a130a130a130a1315080a130a130a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150814090a13140915080a1314080b130a130a130a130a130a1314080b131409140914091409140914080b1314091409091315080a140a1309140a120a130a140a1314090a120a130a130a130a130b120b120a130b120b120b120a1315080a13150815080a1315081508150815080a130a130a1215a4a51415080a1315080a130a130a13150815080a13140915080a1315080a130a130a130a130a130a1315070b131409140914091409140914080b1315081409091414080b120b120b120a130b120a130a1315080a130b120a130a130a130a130a130a130a130a130a130a1315080a13150815080a1315081508150815080a130a130a12150005dc0000000000000000000000000000=RM:RMPROPLUS-63-cc-59 {val: true,ack: false,ts: 1657254960112,q: 0,c: 'script.js.common.Steuerungen.Rollos_Wohnzimmer',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1656832224371}```
                                        code_text
                                        BananaJoe crunchip 2 Replies Last reply Reply Quote 0
                                        • BananaJoe
                                          BananaJoe Most Active @schubs2802 last edited by BananaJoe
                                          @schubs2802 ich nehme an du steuerst die Datenpunkte mit wahr an?
                                          Du kannst auch den _SendCode Datenpunkt nehmen, müsste folgender sein:
                                          broadlink2.0.RM:RMPROPLUS-63-cc-59._SendCode
                                          Und dort den Code reinschreiben, also den Namen des Datenpunktes des IR-Codes ohne den Pfad davor.
                                          Wobei deine schon extrem lang aussehen .... 1.661 Zeichen lang, wow. Meine sind so 180 bis 200 Zeichen lang
                                            schubs2802 @BananaJoe last edited by
                                            @bananajoe Danke für deine Hinweise. Werde es mal versuchen umzusetzen.
                                            Was die länge der Codes angeht, keine Ahnung warum die so lang sind.
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            618449
