    4. Node-Red
    5. zweimal einen Datenpunkt Button schalten
    • Aphofis
      Aphofis @mickym last edited by
      @mickym
      Die Info ist schon super! Danke
      Aphofis 1 Reply Last reply Reply Quote 0
      • Aphofis
        Aphofis @Aphofis last edited by
        Wie mache ich es denn mit den Programmnummern 4-9 kann ich die dann einfach zur liste erweitern !?
        • mickym
          mickym Most Active @Aphofis last edited by
          @aphofis Klar ich habe nur aus Faulheit nicht alle gemacht, wenn Du mit der Maus auf den Ausgang fährst dann siehst Du ja welcher Ausgang welche Ziffer ist:
          • Aphofis
            Aphofis @mickym last edited by Aphofis
            @mickym
            Könntest du das mal Checken !? ob das so korrekt ist.
                    "id": "9ba6d862.87def",
                    "type": "tab",
                    "label": "Flow 1",
                    "disabled": false,
                    "info": ""
                    "id": "41550327.2bf39c",
                    "type": "split",
                    "z": "9ba6d862.87def",
                    "name": "",
                    "splt": "1",
                    "spltType": "len",
                    "arraySplt": 1,
                    "arraySpltType": "len",
                    "stream": false,
                    "addname": "",
                    "x": 810,
                    "y": 780,
                    "wires": [
                            "717ffa37.5bf7e4"
                    "id": "717ffa37.5bf7e4",
                    "type": "switch",
                    "name": "",
                    "property": "payload",
                    "propertyType": "msg",
                    "rules": [
                            "t": "eq",
                            "v": "0",
                            "vt": "str"
                            "t": "eq",
                            "v": "1",
                            "vt": "str"
                            "t": "eq",
                            "v": "2",
                            "vt": "str"
                            "t": "eq",
                            "v": "3",
                            "vt": "str"
                            "t": "eq",
                            "v": "4",
                            "vt": "str"
                            "t": "eq",
                            "v": "5",
                            "vt": "str"
                            "t": "eq",
                            "v": "6",
                            "vt": "str"
                            "t": "eq",
                            "v": "7",
                            "vt": "str"
                            "t": "eq",
                            "v": "8",
                            "vt": "str"
                            "t": "eq",
                            "v": "9",
                            "vt": "str"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 10,
                    "x": 950,
                    "y": 780,
                    "wires": [
                            "ac8cd608.ff2d78"
                            "81031c96.e4e03"
                            "6dc90375.86eebc"
                            "a9da448a.767fd8"
                            "af9bfd6c.63bba8"
                            "4f06297a.1e6c58"
                            "4b809e4c.07f8a8"
                            "a8ad7493.6d4248"
                            "c484b7dc.c24b4"
                            "4730dff6.8708d8"
                    "id": "ac8cd608.ff2d78",
                    "type": "change",
                    "name": "Setze 1 für Tastendruck",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 580,
                    "wires": [
                            "180a64a9.60d013"
                    "id": "710e3c6d.11f0b4",
                    "type": "change",
                    "name": "Programmplatz 1",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 220,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "b1042862.fb3ba8",
                    "type": "change",
                    "name": "Programmplatz 2",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "2",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 260,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "81031c96.e4e03",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 620,
                    "wires": [
                            "8d4f5879.10bf5"
                    "id": "6dc90375.86eebc",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 660,
                    "wires": [
                            "66e15519.1f0f7c"
                    "id": "a9da448a.767fd8",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 700,
                    "wires": [
                            "ad008a78.901388"
                    "id": "180a64a9.60d013",
                    "type": "ioBroker out",
                    "name": "Philips_TV:Number0",
                    "topic": "harmony.0.Homi.Philips_TV.Number0",
                    "ack": "false",
                    "autoCreate": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 580,
                    "wires": []
                    "id": "54babf1b.651a38",
                    "type": "alexa-home-controller",
                    "controllername": "Channel 01",
                    "port": "60030",
                    "maxItems": 25,
                    "x": 170,
                    "y": 220,
                    "wires": []
                    "id": "99132697.c16468",
                    "type": "alexa-home",
                    "devicename": "ARD",
                    "devicetype": "Extended color light",
                    "x": 390,
                    "y": 220,
                    "wires": [
                            "710e3c6d.11f0b4"
                    "id": "3c50a238.28d71e",
                    "devicename": "ZDF",
                    "x": 390,
                    "y": 260,
                    "wires": [
                            "b1042862.fb3ba8"
                    "id": "98045911.119328",
                    "controllername": "Channel  02",
                    "port": "60031",
                    "maxItems": 25,
                    "x": 170,
                    "y": 260,
                    "wires": []
                    "id": "8d4f5879.10bf5",
                    "name": "Philips_TV:Number1",
                    "topic": "harmony.0.Homi.Philips_TV.Number1",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 620,
                    "wires": []
                    "id": "66e15519.1f0f7c",
                    "name": "Philips_TV:Number2",
                    "topic": "harmony.0.Homi.Philips_TV.Number2",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 660,
                    "wires": []
                    "id": "ad008a78.901388",
                    "name": "Philips_TV:Number3",
                    "topic": "harmony.0.Homi.Philips_TV.Number3",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 700,
                    "wires": []
                    "id": "8436366c.b09238",
                    "name": "Philips_TV:Number4",
                    "topic": "harmony.0.Homi.Philips_TV.Number4",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 740,
                    "wires": []
                    "id": "2867fe19.eb641a",
                    "name": "Philips_TV:Number5",
                    "topic": "harmony.0.Homi.Philips_TV.Number5",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 780,
                    "wires": []
                    "id": "71a24f8a.9b7cc",
                    "name": "Philips_TV:Number6",
                    "topic": "harmony.0.Homi.Philips_TV.Number6",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 820,
                    "wires": []
                    "id": "92a659d2.68fd1",
                    "name": "Philips_TV:Number7",
                    "topic": "harmony.0.Homi.Philips_TV.Number7",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 860,
                    "wires": []
                    "id": "6b1ebcb.2d834c4",
                    "name": "Philips_TV:Number8",
                    "topic": "harmony.0.Homi.Philips_TV.Number8",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 900,
                    "wires": []
                    "id": "7a4af580.ceb9a4",
                    "name": "Philips_TV:Number9",
                    "topic": "harmony.0.Homi.Philips_TV.Number9",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1440,
                    "y": 940,
                    "wires": []
                    "id": "571e6564.0b072c",
                    "type": "change",
                    "name": "Programmplatz 3",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "3",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 300,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "416bcede.59b508",
                    "devicename": "SAT1",
                    "x": 390,
                    "y": 300,
                    "wires": [
                            "571e6564.0b072c"
                    "id": "ba86839a.00887",
                    "controllername": "Channel  03",
                    "port": "60032",
                    "maxItems": 25,
                    "x": 170,
                    "y": 300,
                    "wires": []
                    "id": "af9bfd6c.63bba8",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 740,
                    "wires": [
                            "8436366c.b09238"
                    "id": "4f06297a.1e6c58",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 780,
                    "wires": [
                            "2867fe19.eb641a"
                    "id": "4b809e4c.07f8a8",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 820,
                    "wires": [
                            "71a24f8a.9b7cc"
                    "id": "a8ad7493.6d4248",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 860,
                    "wires": [
                            "92a659d2.68fd1"
                    "id": "c484b7dc.c24b4",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 900,
                    "wires": [
                            "6b1ebcb.2d834c4"
                    "id": "4730dff6.8708d8",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "num"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1210,
                    "y": 940,
                    "wires": [
                            "7a4af580.ceb9a4"
                    "id": "12d08e90.46cfe9",
                    "controllername": "Channel  04",
                    "port": "60033",
                    "maxItems": 25,
                    "x": 170,
                    "y": 340,
                    "wires": []
                    "id": "c70f74d1.9d8178",
                    "devicename": "RTL",
                    "x": 390,
                    "y": 340,
                    "wires": [
                            "7c427be4.e1b90c"
                    "id": "fbad0259.fc8ec",
                    "devicename": "SRTL",
                    "x": 390,
                    "y": 380,
                    "wires": [
                            "c64fc917.ed9928"
                    "id": "9df8bfa4.c3ce6",
                    "controllername": "Channel  05",
                    "port": "60034",
                    "maxItems": 25,
                    "x": 170,
                    "y": 380,
                    "wires": []
                    "id": "8d08a264.f24f7",
                    "devicename": "NTV",
                    "x": 390,
                    "y": 420,
                    "wires": [
                            "5bb4468a.8e78b8"
                    "id": "1def56e3.948791",
                    "controllername": "Channel  06",
                    "port": "60035",
                    "maxItems": 25,
                    "x": 170,
                    "y": 420,
                    "wires": []
                    "id": "7c427be4.e1b90c",
                    "type": "change",
                    "name": "Programmplatz 4",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "4",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 340,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "c64fc917.ed9928",
                    "type": "change",
                    "name": "Programmplatz 5",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "5",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 380,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "5bb4468a.8e78b8",
                    "type": "change",
                    "name": "Programmplatz 6",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "6",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 420,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "f436a97.1799758",
                    "type": "change",
                    "name": "Programmplatz 7",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "7",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 460,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "8cc31771.1018",
                    "type": "change",
                    "name": "Programmplatz 8",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "8",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 500,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "282284b0.6c341c",
                    "type": "change",
                    "name": "Programmplatz 9",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "9",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 540,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "30b2467c.662f1a",
                    "controllername": "Channel  07",
                    "port": "60036",
                    "maxItems": 25,
                    "x": 170,
                    "y": 460,
                    "wires": []
                    "id": "62730099.aa952",
                    "devicename": "PRO7",
                    "x": 390,
                    "y": 460,
                    "wires": [
                            "f436a97.1799758"
                    "id": "6c4f968b.42537",
                    "devicename": "RTL2",
                    "x": 390,
                    "y": 500,
                    "wires": [
                            "8cc31771.1018"
                    "id": "52cd5d63.f7b5a4",
                    "controllername": "Channel  08",
                    "port": "60037",
                    "maxItems": 25,
                    "x": 170,
                    "y": 500,
                    "wires": []
                    "id": "2d5de55a.decbb2",
                    "devicename": "WDR",
                    "x": 390,
                    "y": 540,
                    "wires": [
                            "282284b0.6c341c"
                    "id": "c4efc595.c3f11",
                    "controllername": "Channel  09",
                    "port": "60038",
                    "maxItems": 25,
                    "x": 170,
                    "y": 540,
                    "wires": []
                    "id": "96115730.c32378",
                    "controllername": "Channel  10",
                    "port": "60039",
                    "maxItems": 25,
                    "x": 170,
                    "y": 580,
                    "wires": []
                    "id": "bd976fa9.7978a",
                    "devicename": "HRF",
                    "x": 390,
                    "y": 580,
                    "wires": [
                            "826fce9e.7a3ed8"
                    "id": "40d7b534.55f39c",
                    "devicename": "RBB",
                    "x": 390,
                    "y": 620,
                    "wires": [
                            "8fac3c63.c4f6c8"
                    "id": "b283fdc0.4302d8",
                    "controllername": "Channel  11",
                    "port": "60040",
                    "maxItems": 25,
                    "x": 170,
                    "y": 620,
                    "wires": []
                    "id": "5bc8e1d1.ce2d7",
                    "devicename": "ARTE",
                    "x": 390,
                    "y": 660,
                    "wires": [
                            "de4a5094.a881e8"
                    "id": "8a61bc65.1f9d5",
                    "controllername": "Channel  12",
                    "port": "60041",
                    "maxItems": 25,
                    "x": 170,
                    "y": 660,
                    "wires": []
                    "id": "57608ea9.0e8c68",
                    "controllername": "Channel  13",
                    "port": "60042",
                    "maxItems": 25,
                    "x": 170,
                    "y": 700,
                    "wires": []
                    "id": "fdda08ee.3c59e",
                    "devicename": "PHOENIX",
                    "x": 380,
                    "y": 700,
                    "wires": [
                            "5b524890.1920b8"
                    "id": "53f3482e.0f2918",
                    "devicename": "3SAT",
                    "x": 390,
                    "y": 740,
                    "wires": [
                            "a6c6fa35.c1f638"
                    "id": "dd596bba.bf4ab",
                    "controllername": "Channel  14",
                    "port": "60043",
                    "maxItems": 25,
                    "x": 170,
                    "y": 740,
                    "wires": []
                    "id": "20c8d8eb.2951f8",
                    "devicename": "KIKA",
                    "x": 390,
                    "y": 780,
                    "wires": [
                            "954c44da.655b8"
                    "id": "2778e06f.54e73",
                    "controllername": "Channel  15",
                    "port": "60044",
                    "maxItems": 25,
                    "x": 170,
                    "y": 780,
                    "wires": []
                    "id": "8432b99d.65d99",
                    "controllername": "Channel  16",
                    "port": "60045",
                    "maxItems": 25,
                    "x": 170,
                    "y": 820,
                    "wires": []
                    "id": "26edfff9.6c1ad8",
                    "devicename": "TELE5",
                    "x": 390,
                    "y": 820,
                    "wires": [
                            "80925cd.275a02"
                    "id": "912399a5.2d7538",
                    "devicename": "NDR",
                    "x": 390,
                    "y": 860,
                    "wires": [
                            "d8216855.61e1d8"
                    "id": "6e0167b6.c07d7",
                    "controllername": "Channel  17",
                    "port": "60046",
                    "maxItems": 25,
                    "x": 170,
                    "y": 860,
                    "wires": []
                    "id": "2fe5291b.74865e",
                    "devicename": "MDR",
                    "x": 390,
                    "y": 900,
                    "wires": [
                            "acbdd84a.b98a28"
                    "id": "a5892a44.be7c68",
                    "controllername": "Channel  18",
                    "port": "60047",
                    "maxItems": 25,
                    "x": 170,
                    "y": 900,
                    "wires": []
                    "id": "826fce9e.7a3ed8",
                    "type": "change",
                    "name": "Programmplatz 10",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "10",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 580,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "8fac3c63.c4f6c8",
                    "type": "change",
                    "name": "Programmplatz 11",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "11",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 620,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "de4a5094.a881e8",
                    "type": "change",
                    "name": "Programmplatz 12",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "12",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 660,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "5b524890.1920b8",
                    "type": "change",
                    "name": "Programmplatz 13",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "13",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 700,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "a6c6fa35.c1f638",
                    "type": "change",
                    "name": "Programmplatz 14",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "14",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 740,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "954c44da.655b8",
                    "type": "change",
                    "name": "Programmplatz 15",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "15",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 780,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "80925cd.275a02",
                    "type": "change",
                    "name": "Programmplatz 16",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "16",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 820,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "d8216855.61e1d8",
                    "type": "change",
                    "name": "Programmplatz 17",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "17",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 860,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "acbdd84a.b98a28",
                    "type": "change",
                    "name": "Programmplatz 18",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "18",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 900,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "9a845b2b.b90948",
                    "type": "change",
                    "name": "Programmplatz 19",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "19",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 940,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "56cbe8b2.2542d",
                    "type": "change",
                    "name": "Programmplatz 20",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "20",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 980,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "d5dde41f.eedd18",
                    "devicename": "3SAT_HD",
                    "x": 380,
                    "y": 940,
                    "wires": [
                            "9a845b2b.b90948"
                    "id": "e74a9bd1.d7b04",
                    "controllername": "Channel  19",
                    "port": "60048",
                    "maxItems": 25,
                    "x": 170,
                    "y": 940,
                    "wires": []
                    "id": "307c58c.253baa8",
                    "devicename": "ARTE_HD",
                    "x": 370,
                    "y": 980,
                    "wires": [
                            "56cbe8b2.2542d"
                    "id": "307edeb4.2b91a2",
                    "controllername": "Channel  20",
                    "port": "60049",
                    "maxItems": 25,
                    "x": 170,
                    "y": 980,
                    "wires": []
                    "id": "c42b1e44.028e3",
                    "devicename": "ARD_ALPHA",
                    "x": 370,
                    "y": 1020,
                    "wires": [
                            "a01553ca.081a08"
                    "id": "1b874b34.c51edd",
                    "controllername": "Channel  21",
                    "port": "60050",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1020,
                    "wires": []
                    "id": "7855fac4.b2dd4c",
                    "devicename": "BRF_NORD",
                    "x": 370,
                    "y": 1060,
                    "wires": [
                            "68660b89.fb55a4"
                    "id": "b32926a5.3bdc38",
                    "controllername": "Channel  22",
                    "port": "60051",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1060,
                    "wires": []
                    "id": "5a4b98d6.77c1b",
                    "controllername": "Channel  23",
                    "port": "60052",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1100,
                    "wires": []
                    "id": "8b7677a0.9c1ea",
                    "devicename": "ONE",
                    "x": 390,
                    "y": 1100,
                    "wires": [
                            "b624a9ee.212f3"
                    "id": "9cb3f4ba.efba48",
                    "devicename": "PHOENIX_HD",
                    "x": 360,
                    "y": 1140,
                    "wires": [
                            "80f67e8b.86296"
                    "id": "2b93dda.940b522",
                    "controllername": "Channel  24",
                    "port": "60053",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1140,
                    "wires": []
                    "id": "9c271a3.a039ee8",
                    "devicename": "ZDF_NEO",
                    "x": 370,
                    "y": 1180,
                    "wires": [
                            "d51b201e.d26138"
                    "id": "2c1c7f21.69879",
                    "controllername": "Channel  25",
                    "port": "60054",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1180,
                    "wires": []
                    "id": "77741b1c.b402c4",
                    "controllername": "Channel  26",
                    "port": "60055",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1220,
                    "wires": []
                    "id": "dd15a44d.3028e",
                    "devicename": "ZDF_INFO",
                    "x": 370,
                    "y": 1220,
                    "wires": [
                            "1ecaadcc.458a5a"
                    "id": "f1ae1720.3b39c",
                    "devicename": "DMAX",
                    "x": 390,
                    "y": 1260,
                    "wires": [
                            "39775ee8.3fabfa"
                    "id": "4e07c19b.c1682",
                    "controllername": "Channel  27",
                    "port": "60056",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1260,
                    "wires": []
                    "id": "eca4dcc6.4869d8",
                    "devicename": "KABEL_1",
                    "x": 380,
                    "y": 1300,
                    "wires": [
                            "b95d6ff6.c1617"
                    "id": "6c838e99.eb2208",
                    "controllername": "Channel  28",
                    "port": "60057",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1300,
                    "wires": []
                    "id": "f4a70d6c.5f08d",
                    "devicename": "N24_DOKU",
                    "x": 370,
                    "y": 1340,
                    "wires": [
                            "eae43722.37082"
                    "id": "d4114cd4.11e028",
                    "controllername": "Channel  29",
                    "port": "60058",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1340,
                    "wires": []
                    "id": "d3cbc46d.38f978",
                    "devicename": "NICK",
                    "x": 390,
                    "y": 1380,
                    "wires": [
                            "3c6d7cb8.3dfa24"
                    "id": "a689dfa2.54f68",
                    "controllername": "Channel  30",
                    "port": "60059",
                    "maxItems": 25,
                    "x": 170,
                    "y": 1380,
                    "wires": []
                    "id": "a01553ca.081a08",
                    "type": "change",
                    "name": "Programmplatz 21",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "21",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1020,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "68660b89.fb55a4",
                    "type": "change",
                    "name": "Programmplatz 22",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "22",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1060,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "b624a9ee.212f3",
                    "type": "change",
                    "name": "Programmplatz 23",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "23",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1100,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "80f67e8b.86296",
                    "type": "change",
                    "name": "Programmplatz 24",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "24",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1140,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "d51b201e.d26138",
                    "type": "change",
                    "name": "Programmplatz 25",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "25",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1180,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "1ecaadcc.458a5a",
                    "type": "change",
                    "name": "Programmplatz 26",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "626",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1220,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "39775ee8.3fabfa",
                    "type": "change",
                    "name": "Programmplatz 27",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "27",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1260,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "b95d6ff6.c1617",
                    "type": "change",
                    "name": "Programmplatz 28",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "28",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1300,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "eae43722.37082",
                    "type": "change",
                    "name": "Programmplatz 29",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "29",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1340,
                    "wires": [
                            "41550327.2bf39c"
                    "id": "3c6d7cb8.3dfa24",
                    "type": "change",
                    "name": "Programmplatz 30",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "30",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 1380,
                    "wires": [
                            "41550327.2bf39c"
            • mickym
              @aphofis Ich kann den Flow halt nicht importieren, da ich keine Alexa Nodes habe und ich weiß auch nicht ob man diese ganzen Channelnodes braucht - ganz links - ich dachte eigentlich dass man das nur einmal braucht - aber da kenn ich mich nicht aus.
              Alles andere schaut gut aus.
              • Aphofis
                @mickym
                Du stellst Infos auf, die weiß ich auch nicht in der node steht MaxItems 25 vllt brauche ich auch nur zwei davon um bis 50 Sender hinzuzufügen.
                • mickym
                  @aphofis Das war keine Info - ich hab keine Alexa - nur ich war der Meinung die controller Node ist eine Verbindug zur Alexa und die unterstützt mehrere Geräte.
                  In dem Bild was Du mir geschickt hast - habe ich ja gesagt, dass ich das Teil nicht anrühren würde, wenn es vorher so geklappt hat - aber wie gesagt da muss Dir jemand anders helfen. Ich habe kann nur die Logik mit Dir zusammen implementieren.
                  • Aphofis
                    @mickym
                    Komisch das Alexa nur 20 Sender findet.
                    Sonst muss ich die die fehlen in eine neue flow nehmen damit die auch erkannt werden.
                    Nur die Logik ist auch toll um mein Verständnis zu Node-Red zu erweitern.
                    Die gefundenen 20 Sender funktionieren auch habe sie alle manuell getestet. Also deine Steuerung die du für mich erstellt hattest funktioniert.
                    • mickym
                      mickym Most Active @Aphofis last edited by mickym
                      @aphofis Na wenn es für 20 Sender funktioniert - dann bin ich ja aus dem Schneider. Puuh 😌
                      Und für den Rest brauchst einfach jemand der eine Alexa hat und sich damit auskennt und wie gesagt - ich kenne das bislang nur so, dass es einen Kanal gibt über die dann verschiedene Geräte Nodes geschaltet werden.
                      Welche Alexa Nodes hast Du denn installiert? Zeig doch mal Deinen Palettenmanager, wo man das sieht
                      • Aphofis
                        @mickym ich habe ja gut 37 Flows in denen jeweils einer der Alexa Nodes drin ist wo sich nur der port nicht wiederholen darf und die geräte funktionieren einwandfrei sind halt schaltbare Datenpunkte die entweder Geräte schalten oder Status informationen auslösen die dann je nach steuerung per alexa oder per telegram ausgegeben werden können. also Programm nummer 5 und 21-40 fehlen also ist es ja eigntl nur logisch das hlat die programm plätze für den einen Node voll sind dann ein neues Flow erstellen mit den programmen und gucken wie viele erkannt werden ansonsten eine dritte flow dann habe ich alle 40 meiner wichtigsten TV kanäle
                        1208
