    4. dyson Air purifier Adapter - Tester gesucht
      cactus-online @dtp last edited by
      nach einen Neustart des ioBroker bleibt die Instanz gelb. Neuanfordern des 2FA Codes geht nicht.
      dysonairpurifier.0	2021-06-25 09:40:45.139	error	(2740) getDyson2faMailError: Request failed with status code 401
      Username und Passwort habe ich explizit noch einmal neu eingegeben. Wo könnte ich weiter suchen ?
      Grizzelbee 1 Reply Last reply Reply Quote 0
      • Grizzelbee
        Grizzelbee Developer @cactus-online last edited by
        @cactus-online
        Was steht denn so im (Debug-) Log?
          cactus-online @Grizzelbee last edited by
          @grizzelbee ```
          dysonairpurifier.0 2021-06-25 13:22:14.007 info (67728) NN2-EU-KEA4278A - MQTT disconnected.
          dysonairpurifier.0 2021-06-25 13:22:05.513 debug (67728) sendTo "send" to system.adapter.admin.0 from system.adapter.dysonairpurifier.0: getDyson2faMail
          dysonairpurifier.0 2021-06-25 13:22:05.512 error (67728) getDyson2faMailError: Request failed with status code 401
          dysonairpurifier.0 2021-06-25 13:22:05.129 debug (67728) Utils: getDyson2faMail!
          dysonairpurifier.0 2021-06-25 13:22:05.128 debug (67728) OnMessage: locale: de-DE
          dysonairpurifier.0 2021-06-25 13:22:05.128 debug (67728) OnMessage: country: DE
          dysonairpurifier.0 2021-06-25 13:22:05.128 debug (67728) OnMessage: Mail: <email removed>
          dysonairpurifier.0 2021-06-25 13:21:44.007 debug (67728) Updating existing object [NN2-EU-KEA4278A.Online] with value: [false]
          dysonairpurifier.0 2021-06-25 13:21:44.006 info (67728) NN2-EU-KEA4278A - MQTT reconnecting.
          dysonairpurifier.0 2021-06-25 13:21:43.007 debug (67728) Updating existing object [NN2-EU-KEA4278A.Online] with value: [false]
          dysonairpurifier.0 2021-06-25 13:21:43.005 info (67728) NN2-EU-KEA4278A - MQTT disconnected.
          dysonairpurifier.0 2021-06-25 13:21:13.004 debug (67728) Updating existing object [NN2-EU-KEA4278A.Online] with value: [false]
          dysonairpurifier.0 2021-06-25 13:21:13.003 info (67728) NN2-EU-KEA4278A - MQTT reconnecting.
          dysonairpurifier.0 2021-06-25 13:21:12.003 debug (67728) Updating existing object [NN2-EU-KEA4278A.Online] with value: [false]
          dysonairpurifier.0 2021-06-25 13:21:12.002 info (67728) NN2-EU-KEA4278A - MQTT disconnected.
          dysonairpurifier.0 2021-06-25 13:20:42.001 debug (67728) Updating existing object [NN2-EU-KEA4278A.Online] with value: [false]
          dysonairpurifier.0 2021-06-25 13:20:41.999 info (67728) NN2-EU-KEA4278A - MQTT reconnecting.
            dtp @cactus-online last edited by
            die dyson App zeigt ja unter anderem auch die Außenwerte für PM2.5, PM10, NO und Pollen an. Könnte sich der Adapter diese Werte ggf. auch holen, damit man sie in seine Visualisierung einbinden kann?
            • Grizzelbee
              Grizzelbee Developer @dtp last edited by
              @cactus-online
              Tut mir leid, aber außer dem "Not authorized (401)" kann ich da auch nichts sehen.
              Keine Ahnung wo das bei dir herkommen könnte.
              @dtp
              Tut mir leid, aber der Adapter holt (abgesehen von ein paar Basisinfos beim Start) nur die Infos, die er lokal vom dyson selbst bekommt. Für zusätzliche Wetter-, Pollen- und Luftqualitätsdaten gibt es andere Adapter, die darauf spezialisiert sind.
                dtp @Grizzelbee last edited by dtp
                @grizzelbee Alles klar. Hätte mir halt die Installation weiterer Adapter erspart. Trotzdem danke für die Info.
                Bisher läuft der Adapter übrigens reibungslos bei mir.
                  bjoernson @dtp last edited by
                  Hallo @Grizzelbee, ich habe leider auch das gleiche Problem wie @cactus-online . Nach dem Update auf Admin 5 bekomme ich den Adapter leider nicht mehr grün. Es liegt aber wahrscheinlich nicht direkt an Admin 5, da nach dem einspielen vom Backup der Adapter ebenfalls nicht grün wird. Die 2-Faktor-Authentifizierung scheint auch nicht mehr zu funktionieren. Zumindest passiert nichts, wenn ich einen neuen Code anfordere.
                    bvol @Grizzelbee last edited by
                    @grizzelbee würd gern testen fühle mich ausgegrenzt, da ich in ch sitze 😞
                    • Grizzelbee
                      Grizzelbee Developer @bjoernson last edited by Grizzelbee
                      @bjoernson und @cactus-online
                      Ich gucke mir das mal in den nächsten Tagen an.
                      @bvol
                      ja, ich weiß. 😞
                      Keine böse Absicht, aber es gibt leider keine vollständige Liste dessen, was da rein müsste. also baue ich es ein, wie es angefordert wird, oder ich die Vermutung habe, was gebraucht werden könnte.
                      Es gibt auch schon einen offenen Issue dafür:
                      https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/114
                      Edit:
                      Neues Release von heute:
                      V0.9.2 (2021-08-15) (Pearl in a world of dirt)
                      • (bvol) New: #114 Added Switzerland to country selection in config
                      • (grizzelbee) Fix: #119 Updated dyson certificate to enable connection again. Thanks @Krobipd for helping with the link
                      • (grizzelbee) Upd: Updated dependencies
                      Es muss KEIN neues 2FA durchgeführt werden! Der alte Code sollte weiterhin gültig sein und der Adapter sofort online gehen.
                      https://github.com/Grizzelbee/ioBroker.dysonairpurifier/issues/119
                      phifogg created this issue in Grizzelbee/ioBroker.dysonairpurifier
                      closed Country Code for Switzerland Missing #114
                      Phillipp83 created this issue in Grizzelbee/ioBroker.dysonairpurifier
                      closed Seit js-controller update lässt sich der Adapter nicht mehr Starten. #119
                        bjoernson @Grizzelbee last edited by
                        @grizzelbee said in dyson Air purifier Adapter - Tester gesucht:
                        Edit:
                        Perfekt, mit dieser Version funktioniert es wieder (getestet mit Admin 4). Der Adapter ist nun wieder grün. Danke!
                        • Grizzelbee
                          Huhu Leute,
                          ich brauche bitte mal eure Hilfe. Durch Erwerb eines Humidify & Cool ist mir aufgefallen, dass nicht alle Geräte dieselben OscillationAngles unterstützen.
                          Pure Cool (Product Type 438) kann: 45°, 90°, 180° und 350° sowie CUST
                          Humidify & Cool (Product Type 358) kann: 45°, 90° und BRZE (Briese)
                          Könnt ihr mir bitte mal den Gefallen tun und mir hier schreiben was die anderen Geräte (laut App) so können und ob die im Adapter den Datenpunkt OscillationAngle haben? Damit ich das möglichst sauber und vollständig abbilden kann?
                          Danke im Voraus!!
                            mameier1234 last edited by
                            toller Adapter ! ich habe meinen Dyson H+C Formaldehyd drin...
                            In der App werde ich auch schön dran erinnert, den Wassertank aufzufüllen ... Gibt es da auch einen Datenpunkt dafür ?, damit ich das visualisieren kann ?
                            • Grizzelbee
                              Grizzelbee Developer @mameier1234 last edited by
                              @mameier1234 sagte in dyson Air purifier Adapter - Tester gesucht:
                              Hallo Martin,
                              schön das dir der Adapter gefällt und nützt. 🙂
                              Leider aktuell noch nicht - nein. Ich würde das zwar gerne einbauen - und habe da letztens auch noch mal viel Zeit investiert, aber in der "normalen" Datennachricht scheint diese Information nicht enthalten zu sein - zumindest habe ich nichts gefunden. Es ist mir zwar im Laufe der Zeit gelungen die meisten Datenpunktkürzel zu entschlüsseln und zu dokumentieren, aber genau dafür finde ich keines. Keine Ahnung wie die das machen.
                              Falls hier jemand eine Idee hat - oder seinen dyson via Man-in-the-middle belauschen kann .. ich bin für jede Idee, jeden Hinweis und jede Hilfe dankbar!
                              Ach ja: Kommen die Formaldehyd-Werte korrekt und hat die App dafür auch einen Index, den ich einbauen kann/soll?
                                mameier1234 @Grizzelbee last edited by mameier1234
                                @grizzelbee
                                Ja.. der Formaldehyd Wert kommt ... ob er korrekt ist ? Das kann ich gar nicht sagen, da man ihn in der App NICHT sieht.... 🙂
                                • ice987
                                  ice987 @Grizzelbee last edited by ice987
                                  @grizzelbee
                                  Ich habe mir einen "Dyson Pure Humidify + Cool" gegönnt und direkt deinen Adapter "ioBroker.dysonairpurifier" in der stable - Version v2.2.0 installiert. Alles funktioniert soweit einwandfrei und ich möchte mich für diese Arbeit direkt Bedanken! Dennoch ich hätte folgende Fragen:
                                  1. welches ist der Unterschied zwischen den Datenpunkten PM10R und PM10 bzw. PM25R und PM25?
                                  2. der Datenpunkt Sleeptimer ist read-only. Ist das das mit Absicht?
                                  3. der Datenpunkt NightModeMaxFan ist read-only. Ist das das mit Absicht?
                                  4. wird der Datenpunkt OscillationAngle mit einem eigenen oder einem vorgegebenen Wert befüllt, wird dieser entsprechend gesendet und ausgeführt. Der aktualisierte Wert im Datenpunkt ist anschliessend jedoch CUST °. Könnte dieser mit dem realen Wert aktualisiert werden?
                                  Sonst: alles TOP!
                                  vielen Dank! 👏 😊
                                  • Grizzelbee
                                    Grizzelbee Developer @ice987 last edited by
                                    Hallo @ice987
                                    Vielen dank für die Blumen. 🙂 Freue mich, wenn der Adapter hilft.
                                    @ice987 sagte in dyson Air purifier Adapter - Tester gesucht:
                                    Kann ich dir gar nicht genau sagen. Die Geräte liefern beide Werte unabhängig voneinandern und sie sind nicht immer identisch. Deshalb habe ich entschieden bis auf weiteres einfach beide anzuzeigen. Das mag sich in der Zukunft vielleicht ändern. Also um genauer zu sein: das die R-Datenpunkte wegfallen. Alktuell gibt es aber keine Pläne.
                                    Ja. Ich habe noch nichts im Zusammenhang mit den Timern programmiert. Primär weil ich den Timer selbst nicht nutze und auch keine Gewinn im Zusammenhang mit ioBroker sehe. "Wenn Timer, dann im Broker" ist meine aktuelle Meinung.
                                    Ja. Meines Wissens nach kann diese Einstellung nicht geändert werden. Spiel aber gerne damit rum um berichte mir von Erfolgen. Dann mache ich den gerne steuerbar.
                                    Nein. Das geht leider nicht. Die Geräte liefern tatsächlich bei jedem beliebigen Winkel nur "CUST". Daraus kann ich den richtigen Wert nicht zurückrechnen. Ich sah da allerdings bisher auch noch kein Problem drin. Ich bin bei allem aber immer für gute Argumente und eine gute Diskussion offen.
                                    ice987 1 Reply Last reply Reply Quote 0
                                    • ice987
                                      @grizzelbee sagte in dyson Air purifier Adapter - Tester gesucht:
                                      Hallo @ice987
                                      Super Arbeit, Vielen Dank!
                                      Dass diese nicht identisch sind, habe ich ebenfalls herausgefunden, deshalb meine Frage. Bei mir entspricht der R-Datenpunkt dem Wert in der Dyson-App. Somit bitte diesen nicht löschen 🙂
                                      Das geht für mich in Ordnung.
                                      So wichtig ist der nun auch wieder nicht...
                                      Wenn nichts schlaues zurückkommt, ist's so.
                                      • Alexoss T
                                        Alexoss T @Grizzelbee last edited by
                                        @grizzelbee Hi, ich habe Probleme mit dem Eintrag der IP Adresse. Sie wird beim Neustart sofort wieder überschrieben. Allerdings befindet sich das Gerät in einem anderen Subnetz. Was mache ich falsch? Grüße Alex
                                        • Grizzelbee
                                          Grizzelbee Developer @Alexoss T last edited by
                                          @alexoss-t
                                          Hmm. Das Verhalten kann ich bei mir mit der aktuellen Version nicht reproduzieren. Auf welcher Version bist du denn? In alten Versionen gab es immer mal wieder Probleme mit der Hostadresse. Das war keine besonders Ruhmreiche Geschichte. 😉 Das ist meines Wissens nach aber seit der V2.1.3 behoben.
                                          viele Grüße
                                          grizzelbee
                                          Alexoss T 1 Reply Last reply Reply Quote 0
                                            Rookman last edited by
                                            Hallo, ich habe den Adapter erfolgreich installiert und auch die Einrichtung mit 2FA etc. hat soweit funktioniert. Es werden unter den Objekten auch meinen beiden Geräte, ein HP03 und ein PH04 angezeigt aber nur mit ein paar Parametern wie Name und Typ aber es werden keinerlei Messwerte oder Betriebszustände angezeigt.
                                            Im Protokoll wird dieser Fehler ausgegeben:
                                            MQTT error: Error: getaddrinfo ENOTFOUND pt4-eu-pdaxxx
                                            Habe ich etwas übersehen oder nicht richtig konfiguriert?
                                            dyson hot pure cool humidifyer
                                            33
                                            247
                                            35417
