    4. Rega Fehler
    Rega Fehler
      Chris-D 0 @Homoran last edited by
      @homoran Ah Fehler erkannt...mom
        Chris-D 0 @Chris-D 0 last edited by
        @chris-d-0
        $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.17.5
        bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ node -v
        fast geklappt - was nun?
          Thomas Braun Most Active @Chris-D 0 last edited by
          @chris-d-0 Starte die Kiste Mal durch.
          sudo reboot
            Chris-D 0 @Thomas Braun last edited by
            @thomas-braun Klassiker^^ sieht jetzt gut aus
            • haselchen
              haselchen Most Active @Chris-D 0 last edited by
              @chris-d-0
              Was ergibt
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                Chris-D 0 @haselchen last edited by
                @haselchen
                pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.17.5
                v14.17.5
                6.14.14
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           14.17.5-1nodesource1
                  Installationskandidat: 14.17.5-1nodesource1
                  Versionstabelle:
                 *** 14.17.5-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Package
                  @chris-d-0 aber IOBroker lädt nicht trotz Fix
                    Homoran Global Moderator Administrators @Chris-D 0 last edited by
                    @chris-d-0 iobroker list instances
                      @homoran said in Rega Fehler:
                        system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0              : backitup              -  enabled
                      + system.adapter.discovery.0             : discovery             -  enabled
                      + system.adapter.echarts.0               : echarts               -  enabled
                        system.adapter.email.0                 : email                 - disabled
                        system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
                        system.adapter.fritzdect.0             : fritzdect             - disabled
                        system.adapter.habpanel.0              : habpanel              -  enabled
                      + system.adapter.history.0               : history               -  enabled
                      + system.adapter.hm-rega.0               : hm-rega               -  enabled
                      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                      + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
                        system.adapter.ical.0                  : ical                  -  enabled
                      + system.adapter.info.0                  : info                  -  enabled
                      + system.adapter.iot.0                   : iot                   -  enabled
                      + system.adapter.javascript.0            : javascript            -  enabled
                        system.adapter.material.0              : material              -  enabled
                        system.adapter.mobile.0                : mobile                - disabled
                        system.adapter.openweathermap.0        : openweathermap        -  enabled
                      + system.adapter.ping.0                  : ping                  -  enabled
                      + system.adapter.samsung.0               : samsung               -  enabled
                      + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonos.0                 : sonos                 -  enabled
                        system.adapter.synology.0              : synology              - disabled, port: 5000
                      + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.tr-064.0                : tr-064                -  enabled
                      + system.adapter.tr-064.1                : tr-064                -  enabled
                        system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
                        system.adapter.vis.0                   : vis                   - disabled
                        system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                        Homoran Global Moderator Administrators @Chris-D 0 last edited by Homoran
                        @chris-d-0 sagte in Rega Fehler:
                        + instance is alive
                        iobroker start admin
                          keine Verbesserung
                            keine Verbesserung
                            Das steht dann in der Konsole?
                              @homoran hehe nein - weiterhin 057711a8-514f-4ed4-8e2c-ee4b881926e5-image.png
                                willst du mich veräppeln?
                                du sollst den genannten Befehl in die Konsole hämmern und die gesamte Ein- und Ausgabe posten!
                                in Code-tags!
                                  @homoran Nein, ich will dich nicht veräppeln. Es kam nix in der Konsole danach
                                  C Homoran 2 Replies Last reply Reply Quote 0
                                    @chris-d-0
                                    pi@raspberrypi:~ $ iobroker start admin
                                    pi@raspberrypi:~ $
                                      also nochmal:
                                      @homoran sagte in Rega Fehler:
                                      in Code-tags!
                                          pi@raspberrypi:~ $ iobroker list instances
                                          + instance is alive
                                            der admin läuft immer noch nicht
                                            iobroker update -i
                                            C 1 Reply Last reply Reply Quote 1
                                            10328
