    4. Rega Fehler
    Rega Fehler
      Homoran Global Moderator Administrators @Chris-D 0 last edited by
      @chris-d-0 iobroker list instances
        Chris-D 0 @Homoran last edited by
        @homoran said in Rega Fehler:
          system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0              : backitup              -  enabled
        + system.adapter.discovery.0             : discovery             -  enabled
        + system.adapter.echarts.0               : echarts               -  enabled
          system.adapter.email.0                 : email                 - disabled
          system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
          system.adapter.fritzdect.0             : fritzdect             - disabled
          system.adapter.habpanel.0              : habpanel              -  enabled
        + system.adapter.history.0               : history               -  enabled
        + system.adapter.hm-rega.0               : hm-rega               -  enabled
        + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
        + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
          system.adapter.ical.0                  : ical                  -  enabled
        + system.adapter.info.0                  : info                  -  enabled
        + system.adapter.iot.0                   : iot                   -  enabled
        + system.adapter.javascript.0            : javascript            -  enabled
          system.adapter.material.0              : material              -  enabled
          system.adapter.mobile.0                : mobile                - disabled
          system.adapter.openweathermap.0        : openweathermap        -  enabled
        + system.adapter.ping.0                  : ping                  -  enabled
        + system.adapter.samsung.0               : samsung               -  enabled
        + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonos.0                 : sonos                 -  enabled
          system.adapter.synology.0              : synology              - disabled, port: 5000
        + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                : tr-064                -  enabled
        + system.adapter.tr-064.1                : tr-064                -  enabled
          system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
          system.adapter.vis.0                   : vis                   - disabled
          system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
          Homoran Global Moderator Administrators @Chris-D 0 last edited by Homoran
          @chris-d-0 sagte in Rega Fehler:
          + instance is alive
          iobroker start admin
            keine Verbesserung
              keine Verbesserung
              Das steht dann in der Konsole?
                @homoran hehe nein - weiterhin 057711a8-514f-4ed4-8e2c-ee4b881926e5-image.png
                  willst du mich veräppeln?
                  du sollst den genannten Befehl in die Konsole hämmern und die gesamte Ein- und Ausgabe posten!
                  in Code-tags!
                    @homoran Nein, ich will dich nicht veräppeln. Es kam nix in der Konsole danach
                    C Homoran 2 Replies Last reply Reply Quote 0
                      Chris-D 0 @Chris-D 0 last edited by
                      @chris-d-0
                      pi@raspberrypi:~ $ iobroker start admin
                      pi@raspberrypi:~ $
                        also nochmal:
                        @homoran sagte in Rega Fehler:
                        in Code-tags!
                            pi@raspberrypi:~ $ iobroker list instances
                            + instance is alive
                              der admin läuft immer noch nicht
                              iobroker update -i
                              C 1 Reply Last reply Reply Quote 1
                                iobroker update -i
                                pi@raspberrypi:~ $ iobroker update -i
                                Used repository: Stable (default)
                                hash unchanged, use cached sources
                                update done
                                Adapter    "admin"         : 5.1.23   , installed 5.1.23
                                Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                                Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                                Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                                Adapter    "echarts"       : 0.4.13   , installed 0.4.13
                                Adapter    "email"         : 1.0.10   , installed 1.0.10
                                Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                                Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                                Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                                Adapter    "history"       : 1.9.13   , installed 1.9.13
                                Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                                Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                                Adapter    "ical"          : 1.11.2   , installed 1.11.2
                                Adapter    "info"          : 1.9.8    , installed 1.9.8
                                Adapter    "iot"           : 1.8.22   , installed 1.8.22
                                Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                                Controller "js-controller" : 3.3.15   , installed 2.2.8 [Updateable]
                                Adapter    "material"      : 1.0.4    , installed 1.0.4
                                Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                                Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                                Adapter    "ping"          : 1.5.0    , installed 1.5.0
                                Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                                Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                                Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                                Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                                Adapter    "synology"      : 1.0.0    , installed 1.0.0
                                Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                                Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                                Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
                                Adapter    "vis"           : 1.4.3    , installed 1.4.3
                                Adapter    "web"           : 3.4.7    , installed 3.4.7
                                Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                                haselchen Homoran 2 Replies Last reply Reply Quote 0
                                • haselchen
                                  haselchen Most Active @Chris-D 0 last edited by haselchen
                                  @Homoran
                                  Jetzt wissen wir warum 🙂
                                  Admin V5 und JS 2.2.8
                                    du hast admin v5 und eine uralte Version des Controllers. Das passt nicht zsammen
                                    Bitte Controller auf v3.3 bringen
                                      @homoran jaaa und wie mache ich das am besten?^^
                                        https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
                                          @homoran Ich danke euch!
                                          • haselchen
                                            @chris-d-0
                                            So leicht kommste uns nicht davon 😉
                                            Erst die funktionierende Admin Seite posten mit JS Controller Version 😉
                                            Und natürlich die Info ob mit der CCU wieder alles läuft.
                                            C 2 Replies Last reply Reply Quote 1
                                            10329
