    4. Rega Fehler
    Rega Fehler
      Homoran Global Moderator Administrators @Chris-D 0 last edited by
      @chris-d-0 sagte in Rega Fehler:
      system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      der admin läuft immer noch nicht
      iobroker update -i
      C 1 Reply Last reply Reply Quote 1
        Chris-D 0 @Homoran last edited by
        @homoran said in Rega Fehler:
        iobroker update -i
        pi@raspberrypi:~ $ iobroker update -i
        Used repository: Stable (default)
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.1.23   , installed 5.1.23
        Adapter    "backitup"      : 2.1.13   , installed 2.1.13
        Adapter    "cloud"         : 4.1.0    , installed 4.1.0
        Adapter    "discovery"     : 2.7.0    , installed 2.7.0
        Adapter    "echarts"       : 0.4.13   , installed 0.4.13
        Adapter    "email"         : 1.0.10   , installed 1.0.10
        Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
        Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
        Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
        Adapter    "history"       : 1.9.13   , installed 1.9.13
        Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
        Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
        Adapter    "ical"          : 1.11.2   , installed 1.11.2
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "iot"           : 1.8.22   , installed 1.8.22
        Adapter    "javascript"    : 5.2.8    , installed 5.2.8
        Controller "js-controller" : 3.3.15   , installed 2.2.8 [Updateable]
        Adapter    "material"      : 1.0.4    , installed 1.0.4
        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
        Adapter    "openweathermap": 0.1.0    , installed 0.1.0
        Adapter    "ping"          : 1.5.0    , installed 1.5.0
        Adapter    "samsung"       : 0.2.9    , installed 0.2.9
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
        Adapter    "sonos"         : 2.1.1    , installed 2.1.1
        Adapter    "synology"      : 1.0.0    , installed 1.0.0
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
        Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
        Adapter    "vis"           : 1.4.3    , installed 1.4.3
        Adapter    "web"           : 3.4.7    , installed 3.4.7
        Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
        haselchen Homoran 2 Replies Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @Chris-D 0 last edited by haselchen
          @Homoran
          Jetzt wissen wir warum 🙂
          Admin V5 und JS 2.2.8
            du hast admin v5 und eine uralte Version des Controllers. Das passt nicht zsammen
            Bitte Controller auf v3.3 bringen
              @homoran jaaa und wie mache ich das am besten?^^
                https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
                  @homoran Ich danke euch!
                  • haselchen
                    @chris-d-0
                    So leicht kommste uns nicht davon 😉
                    Erst die funktionierende Admin Seite posten mit JS Controller Version 😉
                    Und natürlich die Info ob mit der CCU wieder alles läuft.
                    C 2 Replies Last reply Reply Quote 1
                      Chris-D 0 @haselchen last edited by
                      @haselchen hehe keine Angst, bevor es nicht läuft, lasse ich euch nicht vom Haken 😉
                      Installiert gerade
                        @haselchen Braucht relativ lange...
                        pi@raspberrypi:~ $ iobroker upgrade self
                        Update js-controller from @2.2.8 to @3.3.15
                        NPM version: 6.14.14
                        npm install iobroker.js-controller@3.3.15 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                        • haselchen
                          @chris-d-0
                          Hast du vorher iobroker stop eingegeben?
                            @haselchen yes
                            • haselchen
                              @chris-d-0
                              Auf keinen Fall unterbrechen oder Stromlos machen.
                              Warte einfach mal ab....
                                Chris-D 0 @haselchen last edited by Chris-D 0
                                @haselchen danach passierte lange nichts und danach kam einfach eine neue Eingabezeile
                                pi@raspberrypi:~ $
                                • haselchen
                                  @chris-d-0
                                  Gib mal in der Reihenfolge ein
                                  iobroker stop
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                  iobroker start
                                    @haselchen
                                    pi@raspberrypi:~ $ iobroker stop
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                    npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                    npm WARN pi No description
                                    npm WARN pi No repository field.
                                    npm WARN pi No README data
                                    npm WARN pi No license field.
                                    npm ERR! code EACCES
                                    npm ERR! syscall access
                                    npm ERR! path /home/pi/node_modules/@iobroker
                                    npm ERR! errno -13
                                    npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'
                                    npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'] {
                                    npm ERR!   errno: -13,
                                    npm ERR!   code: 'EACCES',
                                    npm ERR!   syscall: 'access',
                                    npm ERR!   path: '/home/pi/node_modules/@iobroker'
                                    npm ERR! }
                                    npm ERR!
                                    npm ERR! The operation was rejected by your operating system.
                                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                                    npm ERR!
                                    npm ERR! If you believe this might be a permissions issue, please double-check the
                                    npm ERR! permissions of the file and its containing directories, or try running
                                    npm ERR! the command again as root/Administrator.
                                    npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_20_19_283Z-debug.log
                                    Homoran haselchen 3 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @Chris-D 0 last edited by Homoran
                                      was hast du da angestellt?
                                      den npm-Befehl in /home/pi ausgeführt???
                                      der muss in /opt/iobroker ausgeführt werden
                                      • haselchen
                                        @chris-d-0
                                        cd /opt/iobroker
                                        curl -sL https://iobroker.net/fix.sh | bash -
                                        Edit:
                                        sehe ich jetzt erst....wo zum Himmel hast du das alles hin installiert?
                                          Chris-D 0 @Homoran last edited by Chris-D 0
                                          @homoran @haselchen Nicht bewusst
                                            da bist du in deinem Home Verzeichnis
                                            Wie man da die Installation wieder rausbekommt weiß ich nicht.
                                            Du musst vorher ein cd /opt/iobroker machen bevor du den npm-Befehl absetzst
                                            10338
