    4. Rega Fehler
    Rega Fehler
    • haselchen
      haselchen Most Active @Chris-D 0 last edited by haselchen
      @chris-d-0
      Gib mal in der Reihenfolge ein
      iobroker stop
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker start
      C 1 Reply Last reply Reply Quote 1
        Chris-D 0 @haselchen last edited by
        @haselchen
        pi@raspberrypi:~ $ iobroker stop
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /home/pi/node_modules/@iobroker
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'
        npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/home/pi/node_modules/@iobroker'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_20_19_283Z-debug.log
        Homoran haselchen 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Chris-D 0 last edited by Homoran
          @chris-d-0 sagte in Rega Fehler:
          was hast du da angestellt?
          den npm-Befehl in /home/pi ausgeführt???
          der muss in /opt/iobroker ausgeführt werden
          • haselchen
            @chris-d-0
            cd /opt/iobroker
            curl -sL https://iobroker.net/fix.sh | bash -
            Edit:
            sehe ich jetzt erst....wo zum Himmel hast du das alles hin installiert?
              Chris-D 0 @Homoran last edited by Chris-D 0
              @homoran @haselchen Nicht bewusst
                da bist du in deinem Home Verzeichnis
                Wie man da die Installation wieder rausbekommt weiß ich nicht.
                Du musst vorher ein cd /opt/iobroker machen bevor du den npm-Befehl absetzst
                  @homoran @haselchen Holy...
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                  > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  NPM version: 6.14.14
                  > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                  > node-gyp rebuild
                  make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  In file included from ../src/unix_dgram.cc:5:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  In file included from ../../nan/nan.h:56,
                  ../src/unix_dgram.cc: At global scope:
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(unix_dgram, Initialize)
                    SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                    COPY Release/unix_dgram.node
                  make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                  > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                  > node rebuild.js
                  ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                  > @serialport/bindings@9.2.0 install /opt/iobroker/node_modules/@serialport/bindings
                  > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                  prebuild-install WARN install No prebuilt binaries found (target=14.17.5 runtime=node arch=arm libc= platform=linux)
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                    CXX(target) Release/obj.target/bindings/src/serialport.o
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                  ../src/serialport.cpp: At global scope:
                  ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                   SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                  ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                   SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                  In file included from ../node_modules/nan/nan.h:58,
                                   from ../src/./serialport.h:13,
                                   from ../src/serialport.cpp:1:
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(serialport, init);
                    CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                  ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                  ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                  ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                  ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                    CXX(target) Release/obj.target/bindings/src/poller.o
                    CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                    SOLINK_MODULE(target) Release/obj.target/bindings.node
                    COPY Release/bindings.node
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
                  > sharp@0.28.1 install /opt/iobroker/node_modules/sharp
                  > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                  sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.10.6-linux-armv7.tar.br
                  prebuild-install WARN install No prebuilt binaries found (target=3 runtime=napi arch=arm libc= platform=linux)
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                    CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
                    AR(target) Release/obj.target/../node-addon-api/nothing.a
                    COPY Release/nothing.a
                    TOUCH Release/obj.target/libvips-cpp.stamp
                    CXX(target) Release/obj.target/sharp/src/common.o
                    CXX(target) Release/obj.target/sharp/src/metadata.o
                    CXX(target) Release/obj.target/sharp/src/stats.o
                    CXX(target) Release/obj.target/sharp/src/operations.o
                    CXX(target) Release/obj.target/sharp/src/pipeline.o
                    CXX(target) Release/obj.target/sharp/src/utilities.o
                    CXX(target) Release/obj.target/sharp/src/sharp.o
                    SOLINK_MODULE(target) Release/obj.target/sharp.node
                    COPY Release/sharp.node
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
                  > canvas@2.8.0 install /opt/iobroker/node_modules/canvas
                  > node-pre-gyp install --fallback-to-build
                  node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                  node-pre-gyp WARN Pre-built binaries not installable for canvas@2.8.0 and node@14.17.5 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                  node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                    COPY Release/canvas-postbuild.node
                    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                  ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                  ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                     E(ptr - data > imgdOffset, "image data overlaps with another structure");
                  ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                   #define E(cond, msg) if(cond) return setErr(msg)
                  ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                     E(ptr - data + imgdSize > len, "not enough image data");
                    CXX(target) Release/obj.target/canvas/src/Backends.o
                    CXX(target) Release/obj.target/canvas/src/Canvas.o
                    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                    CXX(target) Release/obj.target/canvas/src/closure.o
                    CXX(target) Release/obj.target/canvas/src/color.o
                    CXX(target) Release/obj.target/canvas/src/Image.o
                    CXX(target) Release/obj.target/canvas/src/ImageData.o
                    CXX(target) Release/obj.target/canvas/src/init.o
                    CXX(target) Release/obj.target/canvas/src/register_font.o
                    SOLINK_MODULE(target) Release/obj.target/canvas.node
                    COPY Release/canvas.node
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                  > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                  > node-gyp rebuild
                  make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                    CXX(target) Release/obj.target/diskusage/src/main.o
                  In file included from ../src/main.cpp:3:
                  ../src/main.cpp: At global scope:
                  ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(diskusage, Init)
                    CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                    SOLINK_MODULE(target) Release/obj.target/diskusage.node
                    COPY Release/diskusage.node
                  make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                  > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
                  > node lib/checkVersions.js
                  > iobroker.vis@1.4.3 install /opt/iobroker/node_modules/iobroker.vis
                  > node main.js --install
                  > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  The following notifications happened during sync:
                  - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                  > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                  > node scripts/postinstall
                  Greenlock and ACME.js v3 are on the way!
                  Watch for updates at https://indiegogo.com/at/greenlock
                  > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
                  > node lib/install.js
                  │ Manual installation of ioBroker is no longer supported  │
                  │ on Linux, OSX and FreeBSD!                              │
                  │ Please refer to the documentation on how to install it! │
                  │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 100
                  npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
                  npm ERR! Exit status 100
                  npm ERR!
                  npm ERR! Failed at the iobroker@2.0.3 postinstall script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_49_50_171Z-debug.log
                    oops - passt das irgendwie??
                    npm ERR! errno 100 npm ERR! iobroker@2.0.3 postinstall: node lib/install.js npm ERR! Exit status 100
                    was ist denn da jetzt faul?
                    iobroker stop
                    iobroker fix
                    iobroker start
                    C 2 Replies Last reply Reply Quote 0
                      @homoran said in Rega Fehler:
                      euhm keine Ahnung
                        iobroker stop
                        iobroker fix
                        mache ich
                        iobroker start
                          Chris-D 0 @Chris-D 0 last edited by
                          @Homoran
                          pi@raspberrypi:~ $ iobroker start
                          pi@raspberrypi:~ $ iobroker update -i
                          Used repository: Stable (default)
                          hash changed or no sources cached => force download of new sources
                          update done
                          Adapter    "admin"         : 5.1.23   , installed 5.1.23
                          Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                          Adapter    "echarts"       : 0.4.13   , installed 0.4.13
                          Adapter    "email"         : 1.0.10   , installed 1.0.10
                          Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                          Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                          Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                          Adapter    "history"       : 1.9.13   , installed 1.9.13
                          Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                          Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                          Adapter    "ical"          : 1.11.2   , installed 1.11.2
                          Adapter    "info"          : 1.9.8    , installed 1.9.8
                          Adapter    "iot"           : 1.8.22   , installed 1.8.22
                          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                          Controller "js-controller" : 3.3.15   , installed 2.2.10 [Updateable]
                          Adapter    "material"      : 1.0.4    , installed 1.0.4
                          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                          Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                          Adapter    "ping"          : 1.5.0    , installed 1.5.0
                          Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                          Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                          Adapter    "synology"      : 1.0.0    , installed 1.0.0
                          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                          Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
                          Adapter    "vis"           : 1.4.3    , installed 1.4.3
                          Adapter    "web"           : 3.4.7    , installed 3.4.7
                          Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                            Thomas Braun Most Active @Chris-D 0 last edited by Thomas Braun
                            @chris-d-0
                            iobroker stop
                            iobroker update
                            iobroker upgrade self
                            Komplette Ein- und Ausgaben posten.
                              Chris-D 0 @Thomas Braun last edited by
                              @thomas-braun said in Rega Fehler:
                              iobroker stop iobroker update iobroker upgrade self
                              update done
                              Adapter    "airconwithme"  : 0.0.3
                              Adapter    "airzone"       : 1.0.4
                              Adapter    "alarm"         : 2.0.2
                              Adapter    "alexa2"        : 3.9.3
                              Adapter    "alias-manager" : 1.2.3
                              Adapter    "alpha2"        : 1.0.0
                              Adapter    "amazon-dash"   : 1.1.0
                              Adapter    "artnet"        : 1.2.2
                              Adapter    "asterisk"      : 1.0.6
                              Adapter    "asuswrt"       : 1.0.1
                              Adapter    "b-control-em"  : 0.2.1
                              Adapter    "beckhoff"      : 1.4.1
                              Adapter    "benq"          : 0.2.4
                              Adapter    "binance"       : 1.1.3
                              Adapter    "ble"           : 0.12.0
                              Adapter    "bluelink"      : 1.0.7
                              Adapter    "bmw"           : 2.0.0
                              Adapter    "bosesoundtouch": 0.10.0
                              Adapter    "botvac"        : 1.0.0
                              Adapter    "bring"         : 1.7.7
                              Adapter    "broadlink2"    : 2.0.3
                              Adapter    "bsblan"        : 0.2.2
                              Adapter    "bshb"          : 0.1.13
                              Adapter    "bydbatt"       : 1.0.5
                              Adapter    "bydhvs"        : 1.2.3
                              Adapter    "chromecast"    : 2.3.1
                              Adapter    "comfoair"      : 1.1.3
                              Adapter    "contactid"     : 1.0.2
                              Adapter    "coronavirus-statistics": 0.6.3
                              Adapter    "countdown"     : 1.2.3
                              Adapter    "cul"           : 1.3.5
                              Adapter    "daikin"        : 1.3.3
                              Adapter    "daswetter"     : 3.0.7
                              Adapter    "deconz"        : 1.3.19
                              Adapter    "denon"         : 1.11.2
                              Adapter    "device-reminder": 1.2.9
                              Adapter    "devices"       : 1.0.9
                              Adapter    "digitalstrom"  : 2.2.1
                              Adapter    "discovergy"    : 0.5.4
                              Adapter    "divera247"     : 0.1.2
                              Adapter    "doorio"        : 2.0.1
                              Adapter    "ds18b20"       : 1.4.1
                              Adapter    "dwd"           : 2.7.7
                              Adapter    "dysonairpurifier": 0.9.2
                              Adapter    "easee"         : 1.0.2
                              Adapter    "ebus"          : 2.2.5
                              Adapter    "ecovacs-deebot": 1.2.1
                              Adapter    "egigeozone"    : 0.1.2
                              Adapter    "ekey"          : 1.1.0
                              Adapter    "emby"          : 1.0.2
                              Adapter    "energymanager" : 1.3.3
                              Adapter    "enet"          : 1.0.1
                              Adapter    "epson_ecotank_et_2750": 0.0.5
                              Adapter    "epson_stylus_px830": 0.2.1
                              Adapter    "epson_xp540"   : 1.0.6
                              Adapter    "exchangerates" : 0.0.14
                              Adapter    "fahrplan"      : 1.0.7
                              Adapter    "fakeroku"      : 0.2.1
                              Adapter    "feiertage"     : 1.0.17
                              Adapter    "fhem"          : 1.6.1
                              Adapter    "find-my-iphone": 0.2.15
                              Adapter    "firetv"        : 1.0.0
                              Adapter    "flot"          : 1.10.6
                              Adapter    "followthesun"  : 0.3.5
                              Adapter    "foobar2000"    : 2.0.4
                              Adapter    "fritzbox"      : 0.2.1
                              Adapter    "fronius"       : 1.0.5
                              Adapter    "frontier_silicon": 0.0.10
                              Adapter    "fuelpricemonitor": 0.2.6
                              Adapter    "fullcalendar"  : 1.1.0
                              Adapter    "fullybrowser"  : 2.0.8
                              Adapter    "g-homa"        : 0.5.3
                              Adapter    "geofency"      : 1.0.3
                              Adapter    "go-e"          : 1.0.15
                              Adapter    "growatt"       : 1.0.1
                              Adapter    "gruenbeck"     : 0.0.30
                              Adapter    "haassohn"      : 1.0.4
                              Adapter    "haier"         : 1.0.4
                              Adapter    "ham"           : 4.0.2
                              Adapter    "ham-wemo"      : 2.0.0
                              Adapter    "harmony"       : 1.2.2
                              Adapter    "heatingcontrol": 2.4.3
                              Adapter    "heos"          : 1.8.6
                              Adapter    "heytech"       : 1.0.0
                              Adapter    "hid"           : 0.1.17
                              Adapter    "hmip"          : 1.13.0
                              Adapter    "homeconnect"   : 0.0.36
                              Adapter    "homee"         : 1.2.0
                              Adapter    "homepilot"     : 1.0.3
                              Adapter    "hp-ilo"        : 1.0.6
                              Adapter    "hs100"         : 2.0.6
                              Adapter    "hue"           : 3.5.19
                              Adapter    "hue-extended"  : 2.0.0
                              Adapter    "i2c"           : 1.2.0
                              Adapter    "icons-addictive-flavour-png": 0.1.0
                              Adapter    "icons-fatcow-hosting": 0.1.0
                              Adapter    "icons-icons8"  : 0.0.1
                              Adapter    "icons-material-png": 0.1.0
                              Adapter    "icons-material-svg": 0.1.0
                              Adapter    "icons-mfd-png" : 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.2
                              Adapter    "icons-ultimate-png": 1.0.1
                              Adapter    "influxdb"      : 1.9.5
                              Adapter    "innogy-smarthome": 0.3.7
                              Adapter    "iogo"          : 0.7.0
                              Adapter    "iqontrol"      : 1.8.2
                              Adapter    "jarvis"        : 2.2.1
                              Adapter    "jeelink"       : 0.1.0
                              Adapter    "kecontact"     : 1.2.3
                              Adapter    "klf200"        : 1.0.1
                              Adapter    "km200"         : 1.1.6
                              Adapter    "knmi-weather"  : 1.0.0
                              Adapter    "knx"           : 1.0.45
                              Adapter    "kodi"          : 2.0.5
                              Adapter    "kostal-piko-ba": 1.1.9
                              Adapter    "kress"         : 2.5.5
                              Adapter    "lametric"      : 1.3.2
                              Adapter    "landroid"      : 1.0.3
                              Adapter    "lcn"           : 1.0.2
                              Adapter    "legrand-ecocompteur": 1.0.0
                              Adapter    "letrika_comgw" : 0.0.5
                              Adapter    "lg-ess-home"   : 0.0.10
                              Adapter    "lgtv"          : 1.1.10
                              Adapter    "lgtv-rs"       : 0.1.1
                              Adapter    "lgtv11"        : 1.0.5
                              Adapter    "lifx"          : 0.1.0
                              Adapter    "lightify"      : 0.2.16
                              Adapter    "link"          : 0.5.10
                              Adapter    "linkeddevices" : 1.4.3
                              Adapter    "linktap"       : 0.1.8
                              Adapter    "linux-control" : 1.1.2
                              Adapter    "logparser"     : 1.1.0
                              Adapter    "lovelace"      : 2.0.4
                              Adapter    "loxone"        : 2.2.3
                              Adapter    "luftdaten"     : 1.0.3
                              Adapter    "lupusec"       : 1.3.5
                              Adapter    "luxtronik1"    : 0.3.1
                              Adapter    "maxcube"       : 1.0.4
                              Adapter    "maxcul"        : 1.3.1
                              Adapter    "mbus"          : 2.3.4
                              Adapter    "mclighting"    : 0.1.2
                              Adapter    "megad"         : 1.2.1
                              Adapter    "megadd"        : 0.2.0
                              Adapter    "megaesp"       : 0.1.0
                              Adapter    "melcloud"      : 1.1.4
                              Adapter    "mercedesme"    : 0.0.54
                              Adapter    "mercury"       : 0.1.4
                              Adapter    "meross"        : 1.6.3
                              Adapter    "meteoalarm"    : 2.0.2
                              Adapter    "midea"         : 0.0.6
                              Adapter    "miele"         : 0.1.5
                              Adapter    "mielecloudservice": 4.2.0
                              Adapter    "mihome"        : 1.3.7
                              Adapter    "mihome-lamp"   : 1.1.0
                              Adapter    "mihome-plug"   : 0.2.1
                              Adapter    "mihome-vacuum" : 3.2.2
                              Adapter    "mikrotik"      : 1.0.16
                              Adapter    "milight"       : 0.3.6
                              Adapter    "milight-smart-light": 1.2.0
                              Adapter    "minuvis"       : 1.4.0
                              Adapter    "modbus"        : 3.4.11
                              Adapter    "moma"          : 1.2.8
                              Adapter    "mpd"           : 1.0.6
                              Adapter    "mqtt"          : 2.4.0
                              Adapter    "mqtt-client"   : 1.4.0
                              Adapter    "musiccast"     : 0.1.5
                              Adapter    "mydlink"       : 1.1.12
                              Adapter    "mysensors"     : 2.0.1
                              Adapter    "nanoleaf-lightpanels": 1.2.0
                              Adapter    "net-tools"     : 0.1.5
                              Adapter    "netatmo"       : 1.4.3
                              Adapter    "netatmo-crawler": 0.5.1
                              Adapter    "nibeuplink"    : 0.4.0
                              Adapter    "nina"          : 0.0.25
                              Adapter    "node-red"      : 2.4.0
                              Adapter    "nuki"          : 1.5.0
                              Adapter    "nuki-extended" : 2.3.1
                              Adapter    "nut"           : 1.5.0
                              Adapter    "octoprint"     : 1.1.1
                              Adapter    "odl"           : 1.1.4
                              Adapter    "oilfox"        : 0.0.5
                              Adapter    "omnicomm-lls"  : 0.0.7
                              Adapter    "onkyo"         : 2.1.0
                              Adapter    "onvif"         : 0.4.4
                              Adapter    "openhab"       : 1.1.0
                              Adapter    "openligadb"    : 1.1.0
                              Adapter    "opi"           : 0.1.1
                              Adapter    "oppoplayer"    : 0.2.4
                              Adapter    "owfs"          : 0.6.4
                              Adapter    "owntracks"     : 1.0.0
                              Adapter    "panasonic-viera": 1.0.2
                              Adapter    "parser"        : 1.0.7
                              Adapter    "paw"           : 0.0.7
                              Adapter    "pegelalarm"    : 1.2.0
                              Adapter    "ph803w"        : 1.0.1
                              Adapter    "phantomjs"     : 1.1.2
                              Adapter    "pi-hole"       : 1.3.2
                              Adapter    "piface"        : 1.0.0
                              Adapter    "pimatic"       : 0.3.0
                              Adapter    "places"        : 1.0.0
                              Adapter    "plenticore"    : 2.2.0
                              Adapter    "plex"          : 0.8.11
                              Adapter    "plexconnect"   : 0.0.7
                              Adapter    "pollenflug"    : 1.0.6
                              Adapter    "proxmox"       : 1.3.3
                              Adapter    "proxy"         : 1.2.2
                              Adapter    "pushbullet"    : 0.0.11
                              Adapter    "pushover"      : 2.0.5
                              Adapter    "pushsafer"     : 1.0.3
                              Adapter    "radar2"        : 1.0.9
                              Adapter    "radiohead"     : 1.1.1
                              Adapter    "rflink"        : 2.1.6
                              Adapter    "rickshaw"      : 1.0.0
                              Adapter    "ring"          : 1.2.3
                              Adapter    "robonect"      : 0.1.3
                              Adapter    "roomba"        : 1.1.1
                              Adapter    "rpi2"          : 1.3.1
                              Adapter    "s7"            : 1.3.6
                              Adapter    "sainlogic"     : 0.7.2
                              Adapter    "sanext"        : 0.0.5
                              Adapter    "sayit"         : 1.12.3
                              Adapter    "sbfspot"       : 4.0.5
                              Adapter    "scenes"        : 2.3.6
                              Adapter    "schoolfree"    : 1.0.0
                              Adapter    "schwoerer-ventcube": 1.4.2
                              Adapter    "seq"           : 0.2.10
                              Adapter    "shelly"        : 4.0.7
                              Adapter    "shuttercontrol": 1.2.0
                              Adapter    "sia"           : 1.0.4
                              Adapter    "siegenia"      : 1.1.1
                              Adapter    "smappee"       : 0.2.5
                              Adapter    "smartcontrol"  : 1.2.1
                              Adapter    "smartgarden"   : 1.0.5
                              Adapter    "smartmeter"    : 3.2.1
                              Adapter    "snips"         : 1.5.1
                              Adapter    "snmp"          : 0.5.0
                              Adapter    "solarlog"      : 2.1.3
                              Adapter    "solarviewdatareader": 1.0.2
                              Adapter    "solarwetter"   : 1.0.0
                              Adapter    "sonnen"        : 1.9.4
                              Adapter    "sonoff"        : 2.4.5
                              Adapter    "sony-bravia"   : 1.0.1
                              Adapter    "spotify-premium": 1.0.0
                              Adapter    "sprinklecontrol": 0.1.7
                              Adapter    "sql"           : 1.15.7
                              Adapter    "squeezebox"    : 1.0.0
                              Adapter    "squeezeboxrpc" : 1.3.4
                              Adapter    "starline"      : 1.1.3
                              Adapter    "statistics"    : 1.0.9
                              Adapter    "stiebel-isg"   : 1.7.3
                              Adapter    "sunnyportal"   : 0.1.5
                              Adapter    "swiss-weather-api": 0.9.7
                              Adapter    "systeminfo"    : 0.3.1
                              Adapter    "tado"          : 0.3.4
                              Adapter    "tahoma"        : 0.4.3
                              Adapter    "tankerkoenig"  : 2.1.1
                              Adapter    "terminal"      : 0.1.2
                              Adapter    "tesla-motors"  : 0.5.2
                              Adapter    "text2command"  : 2.1.1
                              Adapter    "tinker"        : 1.1.0
                              Adapter    "traccar"       : 0.0.9
                              Adapter    "tradfri"       : 2.7.4
                              Adapter    "trashschedule" : 1.2.0
                              Adapter    "trivum"        : 0.0.4
                              Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                              Adapter    "tuya"          : 3.6.5
                              Adapter    "tvprogram"     : 1.1.0
                              Adapter    "tvspielfilm"   : 1.0.4
                              Adapter    "unifi"         : 0.5.10
                              Adapter    "upnp"          : 1.0.19
                              Adapter    "vaillant"      : 0.0.13
                              Adapter    "valloxmv"      : 1.1.3
                              Adapter    "vcard"         : 0.0.9
                              Adapter    "velux"         : 0.0.7
                              Adapter    "virtualpowermeter": 1.4.2
                              Adapter    "vis-bars"      : 0.1.4
                              Adapter    "vis-canvas-gauges": 0.1.5
                              Adapter    "vis-colorpicker": 1.2.0
                              Adapter    "vis-fancyswitch": 1.1.0
                              Adapter    "vis-google-fonts": 0.1.0
                              Adapter    "vis-history"   : 1.0.0
                              Adapter    "vis-hqwidgets" : 1.1.7
                              Adapter    "vis-icontwo"   : 0.77.0
                              Adapter    "vis-inventwo"  : 3.0.11
                              Adapter    "vis-jqui-mfd"  : 1.0.12
                              Adapter    "vis-justgage"  : 1.0.2
                              Adapter    "vis-keyboard"  : 0.0.2
                              Adapter    "vis-lcars"     : 1.0.4
                              Adapter    "vis-map"       : 1.0.4
                              Adapter    "vis-material-advanced": 1.7.0
                              Adapter    "vis-metro"     : 1.1.2
                              Adapter    "vis-players"   : 0.1.6
                              Adapter    "vis-plumb"     : 1.0.2
                              Adapter    "vis-rgraph"    : 0.0.2
                              Adapter    "vis-timeandweather": 1.1.7
                              Adapter    "vis-weather"   : 2.5.3
                              Adapter    "volumio"       : 0.1.2
                              Adapter    "volvo"         : 0.0.4
                              Adapter    "vr200"         : 1.0.0
                              Adapter    "vw-connect"    : 0.0.39
                              Adapter    "weatherflow_udp": 0.1.1
                              Adapter    "weatherunderground": 3.3.1
                              Adapter    "weishaupt-wem" : 0.0.9
                              Adapter    "wiffi-wz"      : 2.2.0
                              Adapter    "wifilight"     : 1.1.0
                              Adapter    "windows-control": 0.1.5
                              Adapter    "wled"          : 0.5.6
                              Adapter    "wm-bus"        : 0.1.12
                              Adapter    "wolf"          : 1.2.1
                              Adapter    "wolf-smartset" : 1.0.0
                              Adapter    "worx"          : 1.4.3
                              Adapter    "xbox"          : 0.7.7
                              Adapter    "xs1"           : 1.0.2
                              Adapter    "yahka"         : 0.12.0
                              Adapter    "yamaha"        : 0.4.0
                              Adapter    "yeelight-2"    : 1.0.3
                              Adapter    "youtube"       : 1.1.1
                              Adapter    "yr"            : 3.0.5
                              Adapter    "zigbee"        : 1.5.6
                              Adapter    "zont"          : 0.5.3
                              Adapter    "zwave2"        : 1.10.2
                              pi@raspberrypi:~ $ iobroker upgrade self
                              Update js-controller from @2.2.10 to @3.3.15
                              npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              ACHTUNG: Die Fehlerberichterstattung über Sentry wird beim nächsten Start von ioBroker aktiviert
                              Wir von ioBroker wollen das stabilste Smart-Home-System bereitstellen.
                              Um dies zu ermöglichen, haben wir uns entschlossen, eine automatische Fehler- und Crash-Reporting-Lösung in den js-Controller und auch in Adapter zu implementieren.
                              DIESE BERICHTERSTATTUNG WIRD MIT DEM NÄCHSTEN START IHRES IOBROKERS AKTIVIERT!
                              Bei Fehlern, die zum Absturz des js-Controllers oder eines der relevanten Adapter führen, werden die Fehlerdetails an einen Server gesendet. Für den js-controller und die Haupt-Adapter befindet sich dieser Server in Deutschland. Informationen zu Community-Adaptern sind in der Github-Readme-Datei des betroffenen Adapters zu finden. Dort steht welcher Sentry-Server verwendet wird.
                              Die Fehlerberichterstattung kann, falls gewünscht, über den Befehl
                              'iobroker plugin disable sentry'
                              deaktiviert werden. Dieser Befehl stellt auch sicher, dass kein Adapter, der auf diesem Host ausgeführt wird, Absturzberichtsdaten an den Sentry-Server sendet.
                              npm ERR! errno 100
                              npm ERR!
                              npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_22_55_970Z-debug.log
                              host.raspberrypi Cannot install iobroker.js-controller@3.3.15: 100
                                @chris-d-0
                                cd /opt/iobroker
                                iobroker stop
                                  cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller
                                  pi@raspberrypi:/opt/iobroker $ iobroker stop
                                  > node lib/install.js
                                  npm ERR! errno 100
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_29_16_679Z-debug.log
                                    apollon77 @Chris-D 0 last edited by
                                    @chris-d-0 hattest du mal npm 7 drauf? Da ist ein Mischmasch bei dir.
                                    Thomas Braun C 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @apollon77 last edited by
                                      @apollon77
                                      Offenbar.
                                      ist jedenfalls ein starker Indikator für npm7.
                                        @thomas-braun package-lock.json löschen
                                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                          @homoran Keine Ahnung was man da machen kann. Musste das auf meinem System noch nie gerade biegen. Aber da sind ja auch die Versionssprünge nie so groß. Da am Ball bleiben zahlt sich halt aus.
                                            @thomas-braun sagte in Rega Fehler:
                                            das kann ein weiteres Problem sein.
                                            bin nicht mehr am PC.
                                            die package-lock.json sollte IMHO direkt in /opt/iobroker liegen.
                                            Nach löschen wird sie neu gebaut, dann in der richtigen Version wenn jetzt wieder npm v6 läuft
                                            10338
