    4. Rega Fehler
    Rega Fehler
      Chris-D 0 @Thomas Braun last edited by
      @thomas-braun said in Rega Fehler:
      cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ iobroker stop
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
      > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.14
      > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
      > node lib/checkVersions.js
      > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      The following notifications happened during sync:
      - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
      > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
      > node scripts/postinstall
      Greenlock and ACME.js v3 are on the way!
      Watch for updates at https://indiegogo.com/at/greenlock
      > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
      > node lib/install.js
      │ Manual installation of ioBroker is no longer supported  │
      │ on Linux, OSX and FreeBSD!                              │
      │ Please refer to the documentation on how to install it! │
      │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 100
      npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
      npm ERR! Exit status 100
      npm ERR!
      npm ERR! Failed at the iobroker@2.0.3 postinstall script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_29_16_679Z-debug.log
        apollon77 @Chris-D 0 last edited by
        @chris-d-0 hattest du mal npm 7 drauf? Da ist ein Mischmasch bei dir.
        Thomas Braun C 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @apollon77 last edited by
          @apollon77
          Offenbar.
          ist jedenfalls ein starker Indikator für npm7.
            @thomas-braun package-lock.json löschen
              Thomas Braun Most Active @Homoran last edited by Thomas Braun
              @homoran Keine Ahnung was man da machen kann. Musste das auf meinem System noch nie gerade biegen. Aber da sind ja auch die Versionssprünge nie so groß. Da am Ball bleiben zahlt sich halt aus.
                @thomas-braun sagte in Rega Fehler:
                das kann ein weiteres Problem sein.
                bin nicht mehr am PC.
                die package-lock.json sollte IMHO direkt in /opt/iobroker liegen.
                Nach löschen wird sie neu gebaut, dann in der richtigen Version wenn jetzt wieder npm v6 läuft
                  Chris-D 0 @apollon77 last edited by
                  @apollon77 ja genau hatte ich
                    Chris-D 0 @Homoran last edited by Chris-D 0
                    @homoran dann wäre die Frage wie das geht?
                      Chris-D 0 @Chris-D 0 last edited by
                      hat noch jemand eine Idee? der IoBroker geht jetzt nicht mehr. Vorher, bis auf den Rega Adapter, schon.
                        Thomas Braun Most Active @Chris-D 0 last edited by
                        @chris-d-0
                        iobroker stop
                        sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
                        iobroker start
                          @thomas-braun nicht viel passt
                          pi@raspberrypi:~ $ iobroker stop
                          pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
                          pi@raspberrypi:~ $ iobroker start
                            @chris-d-0
                            'Nicht viel passiert' ist gut. Keine Rückmeldung = alles wurde ausgeführt.
                            iobroker status
                              @thomas-braun sehr gut
                              pi@raspberrypi:~ $ iobroker status
                              At least one iobroker host is running.
                              Objects type: file
                              States  type: file
                              ABer IP Adresse kann nicht angezeigt werden
                                Thomas Braun Most Active @Chris-D 0 last edited by Thomas Braun
                                @chris-d-0
                                iobroker list adapters
                                iobroker list instances
                                  pi@raspberrypi:~ $ iobroker list instances
                                    system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0              : backitup              -  enabled
                                  + system.adapter.discovery.0             : discovery             -  enabled
                                  + system.adapter.echarts.0               : echarts               -  enabled
                                    system.adapter.email.0                 : email                 - disabled
                                    system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
                                    system.adapter.fritzdect.0             : fritzdect             - disabled
                                    system.adapter.habpanel.0              : habpanel              -  enabled
                                  + system.adapter.history.0               : history               -  enabled
                                  + system.adapter.hm-rega.0               : hm-rega               -  enabled
                                  + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
                                    system.adapter.ical.0                  : ical                  -  enabled
                                  + system.adapter.info.0                  : info                  -  enabled
                                  + system.adapter.iot.0                   : iot                   -  enabled
                                  + system.adapter.javascript.0            : javascript            -  enabled
                                    system.adapter.material.0              : material              -  enabled
                                    system.adapter.mobile.0                : mobile                - disabled
                                    system.adapter.openweathermap.0        : openweathermap        -  enabled
                                  + system.adapter.ping.0                  : ping                  -  enabled
                                  + system.adapter.samsung.0               : samsung               -  enabled
                                  + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.sonos.0                 : sonos                 -  enabled
                                    system.adapter.synology.0              : synology              - disabled, port: 5000
                                  + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.tr-064.0                : tr-064                -  enabled
                                  + system.adapter.tr-064.1                : tr-064                -  enabled
                                    system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
                                    system.adapter.vis.0                   : vis                   - disabled
                                    system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                    @chris-d-0
                                    iobroker start admin
                                    iobroker start web
                                      iobroker start admin iobroker start web
                                      pi@raspberrypi:~ $ iobroker start admin
                                      pi@raspberrypi:~ $ iobroker start web
                                      pi@raspberrypi:~ $
                                      keine Verbesserung
                                        @chris-d-0
                                          @chris-d-0
                                          iobroker stop
                                          sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
                                          iobroker start
                                            pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
                                            + instance is alive
                                            10329
