    4. js-controller 3.3 jetzt im STABLE!
      crunchip Forum Testing Most Active last edited by crunchip
      @apollon77
      v3.3.15
      habe gerade meine Proxmox VM gestoppt und anschliessend neu gestartet, im log findet man zu sämtlichen Adaptern
      terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      des weiteren kam diese Meldung
      host.IoBroker
      	2021-08-19 21:43:41.306	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
      host.IoBroker
      	2021-08-19 21:43:41.306	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
      host.IoBroker
      	2021-08-19 21:43:41.305	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:169:15)
      host.IoBroker
      	2021-08-19 21:43:41.305	error	Caught by controller[0]: at processEmit [as emit] (/opt/iobroker/node_modules/signal-exit/index.js:149:35)
      host.IoBroker
      	2021-08-19 21:43:41.304	error	Caught by controller[0]: at process.emit (events.js:400:28)
      host.IoBroker
      	2021-08-19 21:43:41.304	error	Caught by controller[0]: at Object.onceWrapper (events.js:520:26)
      host.IoBroker
      	2021-08-19 21:43:41.303	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
      host.IoBroker
      	2021-08-19 21:43:41.303	error	Caught by controller[0]: at Adapter.emit (events.js:400:28)
      host.IoBroker
      	2021-08-19 21:43:41.302	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
      host.IoBroker
      	2021-08-19 21:43:41.300	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
        apollon77 @crunchip last edited by
        @crunchip Hm ... Was heisst denn "gestoppt"? Hart ohne iobroker sauber zu beenden?
        Dann wären die "Already Running" Meldungen erstmal ok weil der Controller denkt das noch die alte Instanz-Prozesse laufen ... er sendet ihr dann nen Kill Befehl aber ist ja schon weg von daher egal ... und er startet dann einen neuen Prozess. Herauszufinden ob eine "andere" prozess-ID noch läuft ist nicht ganz so simpel.
        Immer Systeme sauber runterfahren 🙂
        Für den Chromecast Fehler würde ich da mal ein Issue anlegen. Interessant wäre noch zu wissen WANN das log kam?
          crunchip Forum Testing Most Active @apollon77 last edited by crunchip
          @apollon77 sagte in js-controller 3.3 jetzt im STABLE!:
          jep, VM direkt gestoppt, nicht dran gedacht, weil das gerade alles so nervt...die Fehlersuche
          jetzt, ist mir das nächste aufgefallen, nachdem ich das log durch gesehen habe
          zwei Browserfenster, ich verstehe das nicht, log Größe unterschiedlich und unterschiedliche Meldungen
          c00a8347-d3e1-455d-a167-8103cfe649cd-grafik.png b86c0e1f-2733-4805-9725-2903cd9964c7-grafik.png
          irgendwann mittendrin, nachdem schon ein paar Instanzen gestartet sind
          2021-08-19 21:42:51.416 - info: admin.0 (866) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.17.4, js-controller: 3.3.15
          2021-08-19 21:43:41.300 - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
            @crunchip ich verstehe nicht was ich da sehe ... sorry. Aber ehrlich ... mach nen sauberen "iobroker stop" und "iobroker start" dann sollte alles ok sein wieder
              Mechy last edited by Negalein
              Hallo zusammen!
              Ich hab nun mal was abgewaret bevor ich der Anleitung folge. Nun hatte ich alles aktualisiert und mein IOBroker startet nicht mehr.
              pi@PI:~ $ iob start
              pi@PI:~ $ iobroker start
              pi@PI:~ $ cd /opt/iobroker
              pi@PI:/opt/iobroker $ iob start
              pi@PI:/opt/iobroker $ node -v
              v12.22.5
              pi@PI:/opt/iobroker $ npm -v
              6.14.14
              pi@PI:/opt/iobroker $ iobroker fix
              library: loaded
              Library version=2021-04-07
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              Was mich nun wundert das er sagt er sei nicht installiert obwohl ich ja im Verzeichnis bin, wie gehe ich nun am besten vor?
              Danke im Voraus!
                Thomas Braun Most Active @Mechy last edited by
                @mechy
                Bitte CodeTags verwenden.
                iobroker status
                sagt?
                  Mechy @Thomas Braun last edited by
                  Hallo, warum auch immer ich kann nicht sofort antworten, es kommt "Error fobidden"
                  Also dann neuer Versuch:
                  pi@PI:/opt/iobroker $ iobroker status
                  internal/modules/cjs/loader.js:818
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                      at internal/main/run_main_module.js:17:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                    @mechy
                    cd /opt/iobroker
                    iobroker stop
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iobroker start
                      @thomas-braun sagte in js-controller 3.3 jetzt im STABLE!:
                      Ich weiß das ich nichts weiß 🙂
                      Das hat nun etwas gedauert und die Adapter wachen so langsam auf. Scheint aber zu laufen.
                      Was war denn das Problem, oder hatte ich vorher irgendwas falsch gemacht? Ich lerne gerne dazu.
                      Danke schon mal!
                        Thomas Braun Most Active @Mechy last edited by Thomas Braun
                        @mechy sagte in js-controller 3.3 jetzt im STABLE!:
                        Keine Ahnung, ich weiß ja nicht was du da im Vorfeld gemacht oder nicht gemacht hast.
                        Übrigens: host names sollten keine Großbuchstaben enthalten. Nur Kleinbuchstaben und die Ziffern 0-9.
                          Hallo und danke für den Hinweis.
                          Ich hatte alle Adapter aktualisiert. Nachdem es durch war habe ich folgende Kommandos der Reihe nach durchgeführt:
                          iob backup
                          iob stop
                          iob update
                          iob upgrade self
                          iob start
                          Davon lief alles ohne Probleme, bis auf das es nicht mehr gestartet hat.
                          cash 1 Reply Last reply Reply Quote 0
                          • cash
                            cash Most Active @Mechy last edited by
                            Auch hier mein Zwischenbericht: Gestern ohne Probleme Admi und Javascript auf die aktuelle Version gezogen und heute war dann der js-controller dran.
                            Das sind auch die drei Sachen die ich immer sehr ungern update, weil ohne die geht es halt nicht. Auch der Thread machte mir nicht besonders Mut aber wie so oft sollte man weniger lesen und einfach machen 🙂
                            Das Update war schnell und ohne Fehler eingespielt. Neustart iobroker und schon hatte ich wieder Zugriff. Das Log sah insgesamt normal aus. 2 Adapter meldeten ein paar Warn-Hinweise. Einmal der Homematic Adapter. Dort die virtuellen Heizungsgruppen. Dort habe ich ein paar max Angaben angepasst. Bei Alexa gab es ein paar mehr Meldungen. Dort habe ich einen Teilbaum gelöscht das führte nicht so richtig zum erfolg. Die Meldungen blieben bzw es wurden sogar noch ein paar mehr. Dazu habe ich auf github ein Issue angelegt. Die eigene Scripte laufen alle (zumindest die, die bisher getriggert wurden. Endlich wieder auf dem aktuellen Stand. Ich würde sagen ganze Arbeit von den Entwicklern und Betatestern…
                            • Q
                              Qlink last edited by
                              @apollon77
                              Hab gerade erfolgreich auf 3.3.15 upgedatet.
                              Mir ist klar, dass nun ein paar Warnungen im Log erscheinen bei den Adapter die oben genannt wurden.
                              Allerdings ist hier der hm-rega Adapter nicht aufgeführt, deshalb hier die Info von mir, dass bei dem ebenfalls nun Warnungen im Log produziert werden:
                              Die Meldungen kommen alle von einem wiffi-wz:
                                "_id": "hm-rega.0.62803",
                                "type": "state",
                                "common": {
                                  "name": "wig_iaq_rr0_value",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "role": "state",
                                  "min": 0,
                                  "max": 1,
                                  "unit": "kOhm",
                                  "desc": "IAQ-Widerstand"
                                "native": {
                                  "Name": "wig_iaq_rr0_value",
                                  "TypeName": "VARDP",
                                  "DPInfo": "IAQ-Widerstand",
                                  "ValueMin": 0,
                                  "ValueMax": 1,
                                  "ValueUnit": "kOhm",
                                  "ValueType": 4,
                                  "ValueSubType": 0,
                                  "ValueList": ""
                                "from": "system.adapter.hm-rega.0",
                                "user": "system.user.admin",
                                "ts": 1630045530021,
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                  "owner": "system.user.admin",
                                "_id": "hm-rega.0.62799",
                                "type": "state",
                                "common": {
                                  "name": "wig_minuten_vor_su",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "role": "state",
                                  "min": 0,
                                  "max": 360,
                                  "unit": "min",
                                  "desc": "Minuten vor SU"
                                "native": {
                                  "Name": "wig_minuten_vor_su",
                                  "DPInfo": "Minuten vor SU",
                                  "ValueMin": 0,
                                  "ValueMax": 360,
                                  "ValueUnit": "min",
                                  "ValueType": 4,
                                  "ValueSubType": 0,
                                  "ValueList": ""
                                "ts": 1630045529990,
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                               "_id": "hm-rega.0.62798",
                               "type": "state",
                               "common": {
                                 "name": "wig_minuten_vor_sa",
                                 "type": "number",
                                 "read": true,
                                 "write": true,
                                 "role": "state",
                                 "min": 0,
                                 "max": 360,
                                 "unit": "min",
                                 "desc": "Minuten vor SA"
                               "native": {
                                 "Name": "wig_minuten_vor_sa",
                                 "DPInfo": "Minuten vor SA",
                                 "ValueMin": 0,
                                 "ValueMax": 360,
                                 "ValueUnit": "min",
                                 "ValueType": 4,
                                 "ValueSubType": 0,
                                 "ValueList": ""
                               "ts": 1630045529974,
                               "acl": {
                                 "object": 1636,
                                 "state": 1636,
                              Ich hätte schon versucht die DPs zu löschen, aber nach einem Adapter Restart werden sie wieder genau so angelegt und die Warnung kommt wieder.
                              Liegt hier das Problem am Adapter oder daran wie der wiffi-wz die Daten in der CCU anlegt ?
                              Wie bekomme ich die Meldungen weg ?
                              Beste Grüße
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @Qlink last edited by
                                @qlink Das liegt am Adapter. Der hinterlegt in den Datenpunkten der Geräte den Maximal- bzw. Minimalwert. Die CCU liefert allerdings Werte, die außerhalb dieser Bereiche liegen und daher kommt die Warnung.
                                Du kannst ein issue auf Github anlegen und als ersten Schritt die min/max Werte bei den entsprechenden Datenpunkten selbst anpassen (kann aber vom Adapter wieder überschrieben werden) um die Warnungen weg zu bekommen. Oder du stellst das Logging des Adapters entsprechend höher.
                                  apollon77 @Dr. Bakterius last edited by
                                  @dr-bakterius sagte in js-controller 3.3 jetzt im STABLE!:
                                  Das Thema ist das die gemeldeten Min/max werte von der CCU kommen ... aber ja mal issue anlegen bei hm-rpc Adapter und dann schaut sich @foxriver76 das an. ggf kommen aber auch Mond-Werte von dem "custom" Gerät wiffi-wz
                                  • Q
                                    Qlink @apollon77 last edited by
                                    @apollon77
                                    issue erstellt
                                    • RK62
                                      RK62 last edited by
                                      Der Umstieg auf Admin V5 und js-controller 3.3 hat bei mir einwandfrei funktioniert.
                                      Das sieht nach viel Arbeit aus: Danke an alle die daran mitgewirkt haben!
                                      An einer Stelle habe ich etwas suchen müssen: Vorher hatte für die Dateispeicherung aus javascript und dem Mirroring der Javascripte ("Mirror scripts to file path:") den Pfad
                                      iobroker-data/files/0_userdata.0/backup-js
                                      verwendet. Das führte mit dem neuen js-controller zu Abbrüchen.
                                      Nach der Änderung auf den vollqualifizierten Pfad
                                      /opt/iobroker/iobroker-data/files/0_userdata.0/backup-js
                                      läuft es jetzt wieder einwandfrei.
                                      Gruß, Ralf
                                        apollon77 @RK62 last edited by
                                        @rk62 dann ändere bitte mal direkt den Pfad. Der mirror Pfad darf nicht im
                                        IoBroker eigenen internen Storage liegen. Also in iobroker-data ist ok. Aber nicht danach files/…
                                        RK62 1 Reply Last reply Reply Quote 1
                                        • RK62
                                          RK62 @apollon77 last edited by
                                          @apollon77 Danke für den Hinweis, ist umgestellt!
                                          opossum 1 Reply Last reply Reply Quote 1
                                          • opossum
                                            opossum @RK62 last edited by
                                            ich habe eine komplette Neuinstallation vom iobroker vorgenommen. Bisher lief es ohne Probleme. Heute abend ein Neustart des JS-Adapters nach vorhergegangenem Error.
                                            Auszug aus dem Log:
                                            2021-09-05 22:11:08.967 - error: javascript.0 (23899) In file included from ../src/binding.cc:1:
                                            /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
                                            (node::addon_register_func) (regfunc), \
                                            /home/iobroker/.cache/node-gyp/12.22.5/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                                            NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
                                            ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
                                            NODE_MODULE(cpufeatures, init)
                                            2021-09-05 22:11:09.737 - info: javascript.0 (23899) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
                                            2021-09-05 22:11:09.885 - info: javascript.0 (23899) COPY Release/cpufeatures.node
                                            2021-09-05 22:11:09.899 - info: javascript.0 (23899) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build“ wird verlassen
                                            2021-09-05 22:11:10.084 - info: javascript.0 (23899)
                                            > ssh2@1.3.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
                                            > node install.js
                                            2021-09-05 22:11:11.425 - info: javascript.0 (23899) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build“ wird betreten
                                            2021-09-05 22:11:11.427 - info: javascript.0 (23899) CXX(target) Release/obj.target/sshcrypto/src/binding.o
                                            2021-09-05 22:11:12.999 - error: javascript.0 (23899) In file included from ../src/binding.cc:6:
                                            ../src/binding.cc:2013:1: note: in expansion of macro ‘NODE_MODULE’
                                            NODE_MODULE(sshcrypto, init)
                                            Was hat es mit diesen gyp-Fehlermeldungen und dieser Node cpu-features auf sich?
                                            Kann da jemand etwas zu sagen? Vielen Dank.
                                            344
                                            90062
