    4. Rega Fehler
    Rega Fehler
      Chris-D 0 @Thomas Braun last edited by
      pi@raspberrypi:~ $ iobroker stop
      pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
      pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
      pi@raspberrypi:~ $ iobroker start
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0              : backitup              -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.echarts.0               : echarts               -  enabled
        system.adapter.email.0                 : email                 - disabled
        system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
        system.adapter.fritzdect.0             : fritzdect             - disabled
        system.adapter.habpanel.0              : habpanel              -  enabled
        system.adapter.history.0               : history               -  enabled
        system.adapter.hm-rega.0               : hm-rega               -  enabled
      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
        system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
        system.adapter.ical.0                  : ical                  -  enabled
      + system.adapter.info.0                  : info                  -  enabled
        system.adapter.iot.0                   : iot                   -  enabled
        system.adapter.javascript.0            : javascript            -  enabled
        system.adapter.material.0              : material              -  enabled
        system.adapter.mobile.0                : mobile                - disabled
        system.adapter.openweathermap.0        : openweathermap        -  enabled
        system.adapter.ping.0                  : ping                  -  enabled
        system.adapter.samsung.0               : samsung               -  enabled
        system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sonos.0                 : sonos                 -  enabled
        system.adapter.synology.0              : synology              - disabled, port: 5000
        system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                : tr-064                -  enabled
        system.adapter.tr-064.1                : tr-064                -  enabled
        system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
        system.adapter.vis.0                   : vis                   - disabled
        system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
        Thomas Braun Most Active @Chris-D 0 last edited by Thomas Braun
        @chris-d-0
        iobroker start web
        iobroker start admin
          @thomas-braun schon direkt mit gemacht
          pi@raspberrypi:~ $ iobroker start admin
          pi@raspberrypi:~ $ iobroker start web
          keine Verbesserung
            @chris-d-0 sagte in Rega Fehler:
            keine Verbesserung
            Was heißt das genau?
                @chris-d-0
                  + system.adapter.backitup.0              : backitup              -  enabled
                  + system.adapter.echarts.0               : echarts               -  enabled
                  + system.adapter.history.0               : history               -  enabled
                  + system.adapter.hm-rega.0               : hm-rega               -  enabled
                  + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
                  + system.adapter.iot.0                   : iot                   -  enabled
                  + system.adapter.javascript.0            : javascript            -  enabled
                  + system.adapter.ping.0                  : ping                  -  enabled
                  + system.adapter.samsung.0               : samsung               -  enabled
                  + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonos.0                 : sonos                 -  enabled
                  + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                : tr-064                -  enabled
                  + system.adapter.tr-064.1                : tr-064                -  enabled
                  + instance is alive
                  pi@raspberrypi:~ $
                    @chris-d-0
                    Zweite Konsole öffnen, mit
                    iobroker logs --watch
                    schauen wass da passiert, wenn der admin gestartet werden soll.
                    iobroker list adapters
                      Homoran Global Moderator Administrators @Homoran last edited by Homoran
                      @homoran sagte in Rega Fehler:
                      @thomas-braun package-lock.json löschen
                      nicht die package.json
                      @Chris-D-0
                      hast du ein Backup?
                      Thomas Braun C 2 Replies Last reply Reply Quote 0
                        Ja, hab ich dann auch gesehen...
                        C 1 Reply Last reply Reply Quote 1
                          Chris-D 0 @Homoran last edited by
                          @homoran ja backup habe ich
                            2021-08-20 13:22:25.557  - info: hm-rpc.1 (23665) Connected
                            2021-08-20 13:22:21.109  - info: hm-rpc.0 (23523) xmlrpc <- listDevices ["raspberrypi:hm-rpc.0"]
                            2021-08-20 13:22:21.182  - info: hm-rpc.0 (23523) xmlrpc -> 52 devices
                            2021-08-20 13:22:21.209  - info: hm-rpc.0 (23523) Connected
                            2021-08-20 13:22:25.580  - info: hm-rpc.1 (23665) xmlrpc <- listDevices ["raspberrypi:hm-rpc.1"]
                            2021-08-20 13:22:30.516  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24164
                            2021-08-20 13:22:30.560  - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
                            2021-08-20 13:22:30.575  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24170
                            2021-08-20 13:22:31.165  - info: hm-rpc.1 (23665) xmlrpc -> 0 devices
                            2021-08-20 13:22:31.198  - info: samsung.0 (24138) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v14.17.5
                            2021-08-20 13:22:32.466  - info: ical.0 (24170) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                            2021-08-20 13:22:32.784  - info: hm-rpc.1 (23665) xmlrpc <- newDevices 415
                            2021-08-20 13:22:33.037  - info: ical.0 (24170) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                            2021-08-20 13:22:33.087  - info: hm-rpc.1 (23665) new HMIP devices/channels after filter: 0
                            2021-08-20 13:22:33.279  - info: ical.0 (24170) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                            2021-08-20 13:22:33.329  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 24190
                            2021-08-20 13:22:34.712  - info: ical.0 (24170) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                            2021-08-20 13:22:35.046  - info: hm-rega.0 (24190) starting. Version 3.0.29 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.17.5
                            2021-08-20 13:22:35.209  - info: hm-rega.0 (24190) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                            2021-08-20 13:22:35.415  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:22:35.524  - info: backitup.0 (24164) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.5
                            2021-08-20 13:22:35.610  - info: backitup.0 (24164) [iobroker] backup was activated at 02:00 every 5 day(s)
                            2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:22:35.695  - info: backitup.0 (24164) [ccu] backup was activated at 01:30 every 5 day(s)
                            2021-08-20 13:22:36.183  - error: backitup.0 (24164) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.20/Datensicherung\SmartHome /opt/iobroker/backups
                            mount error(2): No such file or directory
                            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                            2021-08-20 13:22:37.346  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 24226
                            2021-08-20 13:22:41.032  - info: ical.0 (24170) Terminated (NO_ERROR): Without reason
                            2021-08-20 13:22:41.184  - info: echarts.0 (24226) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.17.5
                            2021-08-20 13:22:41.327  - info: host.raspberrypi instance system.adapter.history.0 started with pid 24250
                            2021-08-20 13:22:41.560  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2021-08-20 13:22:42.388  - info: history.0 (24250) starting. Version 1.9.13 in /opt/iobroker/node_modules/iobroker.history, node: v14.17.5
                            2021-08-20 13:22:42.459  - info: history.0 (24250) enabled logging of hm-rpc.1.000A1A49A1021D.1.ACTUAL_TEMPERATURE (Count=1), Alias=false
                            2021-08-20 13:22:42.460  - info: history.0 (24250) enabled logging of hm-rpc.1.000A9A49A2C621.1.HUMIDITY (Count=2), Alias=false
                            2021-08-20 13:22:45.344  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 24267
                            2021-08-20 13:22:46.757  - info: simple-api.0 (24267) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.17.5
                            2021-08-20 13:22:46.818  - info: simple-api.0 (24267) simpleAPI server listening on port 8087
                            2021-08-20 13:22:46.819  - info: simple-api.0 (24267) Allow states only when user is owner: false
                            2021-08-20 13:22:46.823  - info: simple-api.0 (24267) http server listening on port 8087
                            2021-08-20 13:22:49.314  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "2.2.10", required ">=3.1.0
                            2021-08-20 13:22:53.346  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 24293
                            2021-08-20 13:22:57.507  - info: host.raspberrypi instance scheduled system.adapter.openweathermap.0 23 * * * *
                            2021-08-20 13:22:57.533  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 24305
                            2021-08-20 13:22:59.686  - info: javascript.0 (24293) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.17.5
                            2021-08-20 13:22:59.840  - info: javascript.0 (24293) requesting all states
                            2021-08-20 13:22:59.844  - info: javascript.0 (24293) requesting all objects
                            2021-08-20 13:23:00.032  - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 24305
                            2021-08-20 13:23:00.844  - info: openweathermap.0 (24305) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.17.5
                            2021-08-20 13:23:01.119  - info: javascript.0 (24293) received all objects
                            2021-08-20 13:23:01.186  - info: javascript.0 (24293) received all states
                            2021-08-20 13:23:03.830  - info: openweathermap.0 (24305) Terminated (NO_ERROR): Without reason
                            2021-08-20 13:23:04.371  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                            2021-08-20 13:23:25.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:23:25.827  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:23:25.828  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:24:05.379  - error: tr-064.0 (24042) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:24:05.381  - error: tr-064.0 (24042) ~
                            2021-08-20 13:24:05.383  - error: tr-064.0 (24042) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:24:05.384  - error: tr-064.0 (24042) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:24:05.385  - error: tr-064.0 (24042) ~
                            2021-08-20 13:24:05.387  - warn: tr-064.0 (24042) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:24:05.951  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:24:05.953  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:24:15.873  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:24:15.956  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:24:15.957  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:24:35.986  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24403
                            2021-08-20 13:24:37.537  - info: tr-064.0 (24403) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:25:06.003  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:25:06.054  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:25:06.055  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:25:56.103  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:25:56.149  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:25:56.150  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:26:28.738  - error: tr-064.0 (24403) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:26:28.740  - error: tr-064.0 (24403) ~
                            2021-08-20 13:26:28.741  - error: tr-064.0 (24403) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:26:28.742  - error: tr-064.0 (24403) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:26:28.743  - error: tr-064.0 (24403) ~
                            2021-08-20 13:26:28.746  - warn: tr-064.0 (24403) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:26:29.293  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:26:29.294  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:26:46.194  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:26:46.235  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:26:46.236  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:26:59.349  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24563
                            2021-08-20 13:27:00.989  - info: tr-064.0 (24563) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:27:36.311  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:27:36.383  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:27:36.384  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:28:26.425  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:28:26.459  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:28:26.461  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:28:52.099  - error: tr-064.0 (24563) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:28:52.101  - error: tr-064.0 (24563) ~
                            2021-08-20 13:28:52.103  - error: tr-064.0 (24563) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:28:52.104  - error: tr-064.0 (24563) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:28:52.105  - error: tr-064.0 (24563) ~
                            2021-08-20 13:28:52.107  - warn: tr-064.0 (24563) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:28:52.648  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:28:52.649  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:29:16.497  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:29:16.515  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:29:16.516  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:29:22.687  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24700
                            2021-08-20 13:29:24.211  - info: tr-064.0 (24700) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:30:06.556  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:30:06.598  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:30:06.599  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:30:56.641  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:30:56.671  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:30:56.672  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:31:15.458  - error: tr-064.0 (24700) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:31:15.460  - error: tr-064.0 (24700) ~
                            2021-08-20 13:31:15.462  - error: tr-064.0 (24700) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:31:15.463  - error: tr-064.0 (24700) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:31:15.464  - error: tr-064.0 (24700) ~
                            2021-08-20 13:31:15.466  - warn: tr-064.0 (24700) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:31:16.019  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:31:16.020  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:31:46.047  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24828
                            2021-08-20 13:31:46.712  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:31:46.734  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:31:46.735  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:31:47.595  - info: tr-064.0 (24828) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:32:36.775  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:33:26.876  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:33:26.947  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:33:26.948  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:33:43.938  - error: tr-064.0 (24828) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:33:43.940  - error: tr-064.0 (24828) ~
                            2021-08-20 13:33:43.942  - error: tr-064.0 (24828) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:33:43.943  - error: tr-064.0 (24828) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:33:43.944  - error: tr-064.0 (24828) ~
                            2021-08-20 13:33:43.946  - warn: tr-064.0 (24828) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:33:44.494  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:33:44.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:34:14.550  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24956
                            2021-08-20 13:34:16.029  - info: tr-064.0 (24956) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:34:16.992  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:34:17.024  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:34:17.025  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:35:07.064  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:35:07.087  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:35:07.088  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:35:57.125  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:35:57.159  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:35:57.160  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:36:07.298  - error: tr-064.0 (24956) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:36:07.300  - error: tr-064.0 (24956) ~
                            2021-08-20 13:36:07.301  - error: tr-064.0 (24956) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:36:07.302  - error: tr-064.0 (24956) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:36:07.303  - error: tr-064.0 (24956) ~
                            2021-08-20 13:36:07.305  - warn: tr-064.0 (24956) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:36:07.867  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:36:07.869  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:36:37.931  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25084
                            2021-08-20 13:36:39.428  - info: tr-064.0 (25084) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:36:47.203  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:36:47.232  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:36:47.233  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:37:37.275  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:37:37.310  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:37:37.311  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:38:27.383  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:38:27.452  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:38:27.453  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:38:30.658  - error: tr-064.0 (25084) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:38:30.659  - error: tr-064.0 (25084) ~
                            2021-08-20 13:38:30.660  - error: tr-064.0 (25084) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:38:30.661  - error: tr-064.0 (25084) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:38:30.662  - error: tr-064.0 (25084) ~
                            2021-08-20 13:38:30.664  - warn: tr-064.0 (25084) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:38:31.227  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:38:31.239  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:39:01.302  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25224
                            2021-08-20 13:39:02.883  - info: tr-064.0 (25224) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:39:17.496  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:39:17.530  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:39:17.531  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:40:07.576  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:40:07.606  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:40:07.607  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:40:54.014  - error: tr-064.0 (25224) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:40:54.017  - error: tr-064.0 (25224) ~
                            2021-08-20 13:40:54.018  - error: tr-064.0 (25224) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:40:54.019  - error: tr-064.0 (25224) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:40:54.020  - error: tr-064.0 (25224) ~
                            2021-08-20 13:40:54.022  - warn: tr-064.0 (25224) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:40:54.574  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:40:54.585  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:40:57.648  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:40:57.673  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:40:57.674  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:41:24.645  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25417
                            2021-08-20 13:41:26.131  - info: tr-064.0 (25417) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:41:47.710  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:41:47.757  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:41:47.758  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:42:37.803  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:42:37.836  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:42:37.837  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:43:17.376  - error: tr-064.0 (25417) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:43:17.378  - error: tr-064.0 (25417) ~
                            2021-08-20 13:43:17.379  - error: tr-064.0 (25417) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:43:17.380  - error: tr-064.0 (25417) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:43:17.381  - error: tr-064.0 (25417) ~
                            2021-08-20 13:43:17.383  - warn: tr-064.0 (25417) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:43:17.923  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:43:17.925  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:43:27.884  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:43:27.930  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:43:27.931  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:43:47.963  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25546
                            2021-08-20 13:43:49.562  - info: tr-064.0 (25546) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:44:18.000  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:45:08.109  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:45:08.139  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:45:08.140  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:45:40.738  - error: tr-064.0 (25546) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:45:40.741  - error: tr-064.0 (25546) ~
                            2021-08-20 13:45:40.742  - error: tr-064.0 (25546) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:45:40.743  - error: tr-064.0 (25546) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:45:40.744  - error: tr-064.0 (25546) ~
                            2021-08-20 13:45:40.746  - warn: tr-064.0 (25546) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:45:41.299  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:45:41.300  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:45:58.178  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:45:58.212  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:45:58.213  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:46:11.356  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25653
                            2021-08-20 13:46:12.879  - info: tr-064.0 (25653) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:46:48.251  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:46:48.280  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:46:48.281  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:47:38.326  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:47:38.401  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:47:38.402  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:48:04.097  - error: tr-064.0 (25653) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:48:04.100  - error: tr-064.0 (25653) ~
                            2021-08-20 13:48:04.101  - error: tr-064.0 (25653) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:48:04.102  - error: tr-064.0 (25653) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:48:04.103  - error: tr-064.0 (25653) ~
                            2021-08-20 13:48:04.106  - warn: tr-064.0 (25653) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:48:04.652  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:48:04.653  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:48:28.445  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:48:28.495  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:48:28.496  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:48:34.689  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25770
                            2021-08-20 13:48:36.152  - info: tr-064.0 (25770) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:49:18.566  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:49:18.599  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:49:18.600  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:50:08.645  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:50:08.713  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:50:08.714  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:50:27.460  - error: tr-064.0 (25770) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:50:27.463  - error: tr-064.0 (25770) ~
                            2021-08-20 13:50:27.465  - error: tr-064.0 (25770) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:50:27.467  - error: tr-064.0 (25770) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:50:27.468  - error: tr-064.0 (25770) ~
                            2021-08-20 13:50:27.471  - warn: tr-064.0 (25770) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:50:28.040  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:50:28.052  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:50:58.104  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25863
                            2021-08-20 13:50:58.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:50:58.781  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:50:58.782  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:50:59.632  - info: tr-064.0 (25863) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:51:48.824  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:51:48.850  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:51:48.851  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:52:38.894  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:52:38.920  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:52:38.921  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:52:50.812  - error: tr-064.0 (25863) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:52:50.814  - error: tr-064.0 (25863) ~
                            2021-08-20 13:52:50.815  - error: tr-064.0 (25863) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:52:50.816  - error: tr-064.0 (25863) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:52:50.817  - error: tr-064.0 (25863) ~
                            2021-08-20 13:52:50.819  - warn: tr-064.0 (25863) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:52:51.373  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:52:51.374  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:53:21.409  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25970
                            2021-08-20 13:53:22.902  - info: tr-064.0 (25970) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:53:28.957  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:54:19.016  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:54:19.038  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:54:19.039  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:55:09.112  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:55:09.179  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:55:09.180  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:55:14.178  - error: tr-064.0 (25970) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:55:14.180  - error: tr-064.0 (25970) ~
                            2021-08-20 13:55:14.182  - error: tr-064.0 (25970) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:55:14.183  - error: tr-064.0 (25970) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:55:14.184  - error: tr-064.0 (25970) ~
                            2021-08-20 13:55:14.186  - warn: tr-064.0 (25970) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:55:14.748  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:55:14.761  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:55:44.821  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26097
                            2021-08-20 13:55:46.478  - info: tr-064.0 (26097) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:55:59.224  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:55:59.249  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:55:59.250  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:56:49.294  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:56:49.370  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:56:49.371  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:57:37.538  - error: tr-064.0 (26097) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 13:57:37.540  - error: tr-064.0 (26097) ~
                            2021-08-20 13:57:37.542  - error: tr-064.0 (26097) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:57:37.543  - error: tr-064.0 (26097) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 13:57:37.544  - error: tr-064.0 (26097) ~
                            2021-08-20 13:57:37.546  - warn: tr-064.0 (26097) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 13:57:38.085  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 13:57:38.087  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 13:57:39.412  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:57:39.438  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:57:39.439  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:58:08.120  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26200
                            2021-08-20 13:58:09.574  - info: tr-064.0 (26200) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 13:58:29.477  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:58:29.501  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:58:29.502  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 13:59:19.543  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 13:59:19.558  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 13:59:19.559  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:00:00.074  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 26327
                            2021-08-20 14:00:00.885  - error: tr-064.0 (26200) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:00:00.886  - error: tr-064.0 (26200) ~
                            2021-08-20 14:00:00.887  - error: tr-064.0 (26200) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:00:00.888  - error: tr-064.0 (26200) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:00:00.889  - warn: tr-064.0 (26200) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:00:01.423  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:00:01.424  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 14:00:01.884  - info: ical.0 (26327) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                            2021-08-20 14:00:02.716  - info: ical.0 (26327) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                            2021-08-20 14:00:02.738  - info: ical.0 (26327) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                            2021-08-20 14:00:02.917  - info: ical.0 (26327) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                            2021-08-20 14:00:07.955  - info: ical.0 (26327) Terminated (NO_ERROR): Without reason
                            2021-08-20 14:00:08.486  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2021-08-20 14:00:09.598  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:00:09.675  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:00:09.676  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:00:31.477  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26353
                            2021-08-20 14:00:32.997  - info: tr-064.0 (26353) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 14:00:59.742  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:01:49.826  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:01:49.859  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:01:49.860  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:02:24.258  - error: tr-064.0 (26353) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:02:24.260  - error: tr-064.0 (26353) ~
                            2021-08-20 14:02:24.261  - error: tr-064.0 (26353) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:02:24.263  - error: tr-064.0 (26353) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:02:24.264  - error: tr-064.0 (26353) ~
                            2021-08-20 14:02:24.266  - warn: tr-064.0 (26353) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:02:24.825  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:02:24.836  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 14:02:39.922  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:02:39.946  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:02:39.947  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:02:54.938  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26489
                            2021-08-20 14:02:56.448  - info: tr-064.0 (26489) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 14:03:29.987  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:04:20.056  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:04:20.093  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:04:20.094  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:04:47.618  - error: tr-064.0 (26489) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:04:47.620  - error: tr-064.0 (26489) ~
                            2021-08-20 14:04:47.622  - error: tr-064.0 (26489) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:04:47.623  - error: tr-064.0 (26489) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:04:47.624  - error: tr-064.0 (26489) ~
                            2021-08-20 14:04:47.626  - warn: tr-064.0 (26489) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:04:48.177  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:04:48.179  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 14:05:10.140  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:05:10.216  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:05:10.217  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:05:18.244  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26596
                            2021-08-20 14:05:19.768  - info: tr-064.0 (26596) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 14:06:00.286  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:06:50.404  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:06:50.432  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:06:50.433  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:07:10.978  - error: tr-064.0 (26596) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:07:10.980  - error: tr-064.0 (26596) ~
                            2021-08-20 14:07:10.981  - error: tr-064.0 (26596) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:07:10.983  - error: tr-064.0 (26596) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:07:10.984  - error: tr-064.0 (26596) ~
                            2021-08-20 14:07:10.986  - warn: tr-064.0 (26596) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:07:11.538  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:07:11.540  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 14:07:40.472  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:07:40.497  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:07:40.498  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:07:41.599  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26712
                            2021-08-20 14:07:43.185  - info: tr-064.0 (26712) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 14:08:30.537  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:08:30.563  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:08:30.564  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:09:20.601  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:09:20.704  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:09:20.705  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:09:34.338  - error: tr-064.0 (26712) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:09:34.341  - error: tr-064.0 (26712) ~
                            2021-08-20 14:09:34.342  - error: tr-064.0 (26712) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:09:34.344  - error: tr-064.0 (26712) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:09:34.345  - error: tr-064.0 (26712) ~
                            2021-08-20 14:09:34.347  - warn: tr-064.0 (26712) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:09:34.907  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:09:34.919  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                            2021-08-20 14:10:04.983  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26843
                            2021-08-20 14:10:06.495  - info: tr-064.0 (26843) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                            2021-08-20 14:10:10.746  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:10:10.780  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:10:10.781  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:11:00.819  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:11:50.913  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                            2021-08-20 14:11:50.987  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                            2021-08-20 14:11:50.988  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                            2021-08-20 14:11:57.690  - error: tr-064.0 (26843) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                            2021-08-20 14:11:57.692  - error: tr-064.0 (26843) ~
                            2021-08-20 14:11:57.693  - error: tr-064.0 (26843) ~~ Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:11:57.694  - error: tr-064.0 (26843) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                            2021-08-20 14:11:57.695  - error: tr-064.0 (26843) ~
                            2021-08-20 14:11:57.697  - warn: tr-064.0 (26843) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                            2021-08-20 14:11:58.237  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2021-08-20 14:11:58.246  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                              Homoran Global Moderator Administrators @Chris-D 0 last edited by
                              @chris-d-0 sagte in Rega Fehler:
                              @homoran ja backup habe ich
                              dann mach doch alles neu bevor du hier Stunden verbrätst.
                              node 14
                              kommt mit npm v6
                              curl -sLf https://iobroker.net/install.sh | bash -
                              Backup einspielen - warten - fertig!
                                Chris-D 0 @Homoran last edited by
                                @homoran ok welche befehle brauche ich genau?
                                  wofür genau?
                                    apollon77 last edited by
                                    Jetzt mal langsam ... Also laut Log ist doch alles ok, ausser:
                                    • tr-064 meldet das die Fritzbox die Verbindung ablehnt, da musst man Fritzbox Einstellungen checken
                                    • hm-rega/rpc meldet das die CCU "401 Unauthorized" meldet ... hast du da irgendwie username/passwort konfiguriert aber nicht im Adapter?
                                    • backitup meldet das ein CIFS Mount nicht da ist
                                    Der Rest sieht alles normal und ok aus.
                                    Von Admin finde ich im Log ausschnitt nicht
                                    Also wenn das die Themen sind dann hilft auch ein backup einspielen nix
                                      @homoran neu aufsetzen?
                                        Chris-D 0 @apollon77 last edited by
                                        @apollon77 das ist leider nicht mehr das Problem, siehe verlauf
                                        haselchen apollon77 2 Replies Last reply Reply Quote 0
                                        • haselchen
                                          haselchen Most Active @Chris-D 0 last edited by
                                          @chris-d-0
                                          Wo liegt denn der Hase noch im Pfeffer?
                                          Welche Probleme gibt es noch?
                                            apollon77 @Chris-D 0 last edited by
                                            @chris-d-0 ja was ist denn das Problem? Ich blicke bei dem Verkauf nimmer durch
                                            10328
