    4. Rega Fehler
    Rega Fehler
      Thomas Braun Most Active @Chris-D 0 last edited by
      @chris-d-0 sagte in Rega Fehler:
      keine Verbesserung
      Was heißt das genau?
        Chris-D 0 @Thomas Braun last edited by
          @chris-d-0
          iobroker list instances
            pi@raspberrypi:~ $ iobroker list instances
             system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0              : backitup              -  enabled
            + system.adapter.discovery.0             : discovery             -  enabled
            + system.adapter.echarts.0               : echarts               -  enabled
             system.adapter.email.0                 : email                 - disabled
             system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
             system.adapter.fritzdect.0             : fritzdect             - disabled
             system.adapter.habpanel.0              : habpanel              -  enabled
            + system.adapter.history.0               : history               -  enabled
            + system.adapter.hm-rega.0               : hm-rega               -  enabled
            + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
            + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
             system.adapter.ical.0                  : ical                  -  enabled
            + system.adapter.info.0                  : info                  -  enabled
            + system.adapter.iot.0                   : iot                   -  enabled
            + system.adapter.javascript.0            : javascript            -  enabled
             system.adapter.material.0              : material              -  enabled
             system.adapter.mobile.0                : mobile                - disabled
             system.adapter.openweathermap.0        : openweathermap        -  enabled
            + system.adapter.ping.0                  : ping                  -  enabled
            + system.adapter.samsung.0               : samsung               -  enabled
            + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonos.0                 : sonos                 -  enabled
             system.adapter.synology.0              : synology              - disabled, port: 5000
            + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                : tr-064                -  enabled
            + system.adapter.tr-064.1                : tr-064                -  enabled
             system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
             system.adapter.vis.0                   : vis                   - disabled
             system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            pi@raspberrypi:~ $
              @chris-d-0
              Zweite Konsole öffnen, mit
              iobroker logs --watch
              schauen wass da passiert, wenn der admin gestartet werden soll.
              iobroker list adapters
                Homoran Global Moderator Administrators @Homoran last edited by Homoran
                @homoran sagte in Rega Fehler:
                @thomas-braun package-lock.json löschen
                nicht die package.json
                @Chris-D-0
                hast du ein Backup?
                Thomas Braun C 2 Replies Last reply Reply Quote 0
                  Ja, hab ich dann auch gesehen...
                  C 1 Reply Last reply Reply Quote 1
                    Chris-D 0 @Homoran last edited by
                    @homoran ja backup habe ich
                      2021-08-20 13:22:25.557  - info: hm-rpc.1 (23665) Connected
                      2021-08-20 13:22:21.109  - info: hm-rpc.0 (23523) xmlrpc <- listDevices ["raspberrypi:hm-rpc.0"]
                      2021-08-20 13:22:21.182  - info: hm-rpc.0 (23523) xmlrpc -> 52 devices
                      2021-08-20 13:22:21.209  - info: hm-rpc.0 (23523) Connected
                      2021-08-20 13:22:25.580  - info: hm-rpc.1 (23665) xmlrpc <- listDevices ["raspberrypi:hm-rpc.1"]
                      2021-08-20 13:22:30.516  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24164
                      2021-08-20 13:22:30.560  - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
                      2021-08-20 13:22:30.575  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24170
                      2021-08-20 13:22:31.165  - info: hm-rpc.1 (23665) xmlrpc -> 0 devices
                      2021-08-20 13:22:31.198  - info: samsung.0 (24138) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v14.17.5
                      2021-08-20 13:22:32.466  - info: ical.0 (24170) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                      2021-08-20 13:22:32.784  - info: hm-rpc.1 (23665) xmlrpc <- newDevices 415
                      2021-08-20 13:22:33.037  - info: ical.0 (24170) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                      2021-08-20 13:22:33.087  - info: hm-rpc.1 (23665) new HMIP devices/channels after filter: 0
                      2021-08-20 13:22:33.279  - info: ical.0 (24170) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                      2021-08-20 13:22:33.329  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 24190
                      2021-08-20 13:22:34.712  - info: ical.0 (24170) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                      2021-08-20 13:22:35.046  - info: hm-rega.0 (24190) starting. Version 3.0.29 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.17.5
                      2021-08-20 13:22:35.209  - info: hm-rega.0 (24190) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                      2021-08-20 13:22:35.415  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:22:35.524  - info: backitup.0 (24164) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.5
                      2021-08-20 13:22:35.610  - info: backitup.0 (24164) [iobroker] backup was activated at 02:00 every 5 day(s)
                      2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:22:35.695  - info: backitup.0 (24164) [ccu] backup was activated at 01:30 every 5 day(s)
                      2021-08-20 13:22:36.183  - error: backitup.0 (24164) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.20/Datensicherung\SmartHome /opt/iobroker/backups
                      mount error(2): No such file or directory
                      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                      2021-08-20 13:22:37.346  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 24226
                      2021-08-20 13:22:41.032  - info: ical.0 (24170) Terminated (NO_ERROR): Without reason
                      2021-08-20 13:22:41.184  - info: echarts.0 (24226) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.17.5
                      2021-08-20 13:22:41.327  - info: host.raspberrypi instance system.adapter.history.0 started with pid 24250
                      2021-08-20 13:22:41.560  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                      2021-08-20 13:22:42.388  - info: history.0 (24250) starting. Version 1.9.13 in /opt/iobroker/node_modules/iobroker.history, node: v14.17.5
                      2021-08-20 13:22:42.459  - info: history.0 (24250) enabled logging of hm-rpc.1.000A1A49A1021D.1.ACTUAL_TEMPERATURE (Count=1), Alias=false
                      2021-08-20 13:22:42.460  - info: history.0 (24250) enabled logging of hm-rpc.1.000A9A49A2C621.1.HUMIDITY (Count=2), Alias=false
                      2021-08-20 13:22:45.344  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 24267
                      2021-08-20 13:22:46.757  - info: simple-api.0 (24267) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.17.5
                      2021-08-20 13:22:46.818  - info: simple-api.0 (24267) simpleAPI server listening on port 8087
                      2021-08-20 13:22:46.819  - info: simple-api.0 (24267) Allow states only when user is owner: false
                      2021-08-20 13:22:46.823  - info: simple-api.0 (24267) http server listening on port 8087
                      2021-08-20 13:22:49.314  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "2.2.10", required ">=3.1.0
                      2021-08-20 13:22:53.346  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 24293
                      2021-08-20 13:22:57.507  - info: host.raspberrypi instance scheduled system.adapter.openweathermap.0 23 * * * *
                      2021-08-20 13:22:57.533  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 24305
                      2021-08-20 13:22:59.686  - info: javascript.0 (24293) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.17.5
                      2021-08-20 13:22:59.840  - info: javascript.0 (24293) requesting all states
                      2021-08-20 13:22:59.844  - info: javascript.0 (24293) requesting all objects
                      2021-08-20 13:23:00.032  - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 24305
                      2021-08-20 13:23:00.844  - info: openweathermap.0 (24305) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.17.5
                      2021-08-20 13:23:01.119  - info: javascript.0 (24293) received all objects
                      2021-08-20 13:23:01.186  - info: javascript.0 (24293) received all states
                      2021-08-20 13:23:03.830  - info: openweathermap.0 (24305) Terminated (NO_ERROR): Without reason
                      2021-08-20 13:23:04.371  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                      2021-08-20 13:23:25.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:23:25.827  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:23:25.828  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:24:05.379  - error: tr-064.0 (24042) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:24:05.381  - error: tr-064.0 (24042) ~
                      2021-08-20 13:24:05.383  - error: tr-064.0 (24042) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:24:05.384  - error: tr-064.0 (24042) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:24:05.385  - error: tr-064.0 (24042) ~
                      2021-08-20 13:24:05.387  - warn: tr-064.0 (24042) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:24:05.951  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:24:05.953  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:24:15.873  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:24:15.956  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:24:15.957  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:24:35.986  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24403
                      2021-08-20 13:24:37.537  - info: tr-064.0 (24403) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:25:06.003  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:25:06.054  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:25:06.055  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:25:56.103  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:25:56.149  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:25:56.150  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:26:28.738  - error: tr-064.0 (24403) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:26:28.740  - error: tr-064.0 (24403) ~
                      2021-08-20 13:26:28.741  - error: tr-064.0 (24403) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:26:28.742  - error: tr-064.0 (24403) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:26:28.743  - error: tr-064.0 (24403) ~
                      2021-08-20 13:26:28.746  - warn: tr-064.0 (24403) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:26:29.293  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:26:29.294  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:26:46.194  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:26:46.235  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:26:46.236  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:26:59.349  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24563
                      2021-08-20 13:27:00.989  - info: tr-064.0 (24563) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:27:36.311  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:27:36.383  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:27:36.384  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:28:26.425  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:28:26.459  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:28:26.461  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:28:52.099  - error: tr-064.0 (24563) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:28:52.101  - error: tr-064.0 (24563) ~
                      2021-08-20 13:28:52.103  - error: tr-064.0 (24563) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:28:52.104  - error: tr-064.0 (24563) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:28:52.105  - error: tr-064.0 (24563) ~
                      2021-08-20 13:28:52.107  - warn: tr-064.0 (24563) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:28:52.648  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:28:52.649  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:29:16.497  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:29:16.515  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:29:16.516  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:29:22.687  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24700
                      2021-08-20 13:29:24.211  - info: tr-064.0 (24700) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:30:06.556  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:30:06.598  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:30:06.599  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:30:56.641  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:30:56.671  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:30:56.672  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:31:15.458  - error: tr-064.0 (24700) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:31:15.460  - error: tr-064.0 (24700) ~
                      2021-08-20 13:31:15.462  - error: tr-064.0 (24700) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:31:15.463  - error: tr-064.0 (24700) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:31:15.464  - error: tr-064.0 (24700) ~
                      2021-08-20 13:31:15.466  - warn: tr-064.0 (24700) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:31:16.019  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:31:16.020  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:31:46.047  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24828
                      2021-08-20 13:31:46.712  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:31:46.734  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:31:46.735  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:31:47.595  - info: tr-064.0 (24828) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:32:36.775  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:33:26.876  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:33:26.947  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:33:26.948  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:33:43.938  - error: tr-064.0 (24828) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:33:43.940  - error: tr-064.0 (24828) ~
                      2021-08-20 13:33:43.942  - error: tr-064.0 (24828) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:33:43.943  - error: tr-064.0 (24828) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:33:43.944  - error: tr-064.0 (24828) ~
                      2021-08-20 13:33:43.946  - warn: tr-064.0 (24828) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:33:44.494  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:33:44.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:34:14.550  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24956
                      2021-08-20 13:34:16.029  - info: tr-064.0 (24956) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:34:16.992  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:34:17.024  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:34:17.025  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:35:07.064  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:35:07.087  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:35:07.088  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:35:57.125  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:35:57.159  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:35:57.160  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:36:07.298  - error: tr-064.0 (24956) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:36:07.300  - error: tr-064.0 (24956) ~
                      2021-08-20 13:36:07.301  - error: tr-064.0 (24956) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:36:07.302  - error: tr-064.0 (24956) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:36:07.303  - error: tr-064.0 (24956) ~
                      2021-08-20 13:36:07.305  - warn: tr-064.0 (24956) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:36:07.867  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:36:07.869  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:36:37.931  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25084
                      2021-08-20 13:36:39.428  - info: tr-064.0 (25084) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:36:47.203  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:36:47.232  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:36:47.233  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:37:37.275  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:37:37.310  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:37:37.311  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:38:27.383  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:38:27.452  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:38:27.453  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:38:30.658  - error: tr-064.0 (25084) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:38:30.659  - error: tr-064.0 (25084) ~
                      2021-08-20 13:38:30.660  - error: tr-064.0 (25084) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:38:30.661  - error: tr-064.0 (25084) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:38:30.662  - error: tr-064.0 (25084) ~
                      2021-08-20 13:38:30.664  - warn: tr-064.0 (25084) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:38:31.227  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:38:31.239  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:39:01.302  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25224
                      2021-08-20 13:39:02.883  - info: tr-064.0 (25224) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:39:17.496  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:39:17.530  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:39:17.531  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:40:07.576  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:40:07.606  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:40:07.607  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:40:54.014  - error: tr-064.0 (25224) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:40:54.017  - error: tr-064.0 (25224) ~
                      2021-08-20 13:40:54.018  - error: tr-064.0 (25224) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:40:54.019  - error: tr-064.0 (25224) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:40:54.020  - error: tr-064.0 (25224) ~
                      2021-08-20 13:40:54.022  - warn: tr-064.0 (25224) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:40:54.574  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:40:54.585  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:40:57.648  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:40:57.673  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:40:57.674  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:41:24.645  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25417
                      2021-08-20 13:41:26.131  - info: tr-064.0 (25417) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:41:47.710  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:41:47.757  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:41:47.758  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:42:37.803  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:42:37.836  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:42:37.837  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:43:17.376  - error: tr-064.0 (25417) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:43:17.378  - error: tr-064.0 (25417) ~
                      2021-08-20 13:43:17.379  - error: tr-064.0 (25417) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:43:17.380  - error: tr-064.0 (25417) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:43:17.381  - error: tr-064.0 (25417) ~
                      2021-08-20 13:43:17.383  - warn: tr-064.0 (25417) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:43:17.923  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:43:17.925  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:43:27.884  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:43:27.930  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:43:27.931  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:43:47.963  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25546
                      2021-08-20 13:43:49.562  - info: tr-064.0 (25546) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:44:18.000  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:45:08.109  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:45:08.139  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:45:08.140  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:45:40.738  - error: tr-064.0 (25546) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:45:40.741  - error: tr-064.0 (25546) ~
                      2021-08-20 13:45:40.742  - error: tr-064.0 (25546) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:45:40.743  - error: tr-064.0 (25546) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:45:40.744  - error: tr-064.0 (25546) ~
                      2021-08-20 13:45:40.746  - warn: tr-064.0 (25546) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:45:41.299  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:45:41.300  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:45:58.178  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:45:58.212  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:45:58.213  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:46:11.356  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25653
                      2021-08-20 13:46:12.879  - info: tr-064.0 (25653) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:46:48.251  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:46:48.280  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:46:48.281  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:47:38.326  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:47:38.401  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:47:38.402  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:48:04.097  - error: tr-064.0 (25653) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:48:04.100  - error: tr-064.0 (25653) ~
                      2021-08-20 13:48:04.101  - error: tr-064.0 (25653) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:48:04.102  - error: tr-064.0 (25653) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:48:04.103  - error: tr-064.0 (25653) ~
                      2021-08-20 13:48:04.106  - warn: tr-064.0 (25653) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:48:04.652  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:48:04.653  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:48:28.445  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:48:28.495  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:48:28.496  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:48:34.689  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25770
                      2021-08-20 13:48:36.152  - info: tr-064.0 (25770) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:49:18.566  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:49:18.599  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:49:18.600  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:50:08.645  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:50:08.713  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:50:08.714  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:50:27.460  - error: tr-064.0 (25770) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:50:27.463  - error: tr-064.0 (25770) ~
                      2021-08-20 13:50:27.465  - error: tr-064.0 (25770) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:50:27.467  - error: tr-064.0 (25770) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:50:27.468  - error: tr-064.0 (25770) ~
                      2021-08-20 13:50:27.471  - warn: tr-064.0 (25770) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:50:28.040  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:50:28.052  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:50:58.104  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25863
                      2021-08-20 13:50:58.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:50:58.781  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:50:58.782  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:50:59.632  - info: tr-064.0 (25863) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:51:48.824  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:51:48.850  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:51:48.851  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:52:38.894  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:52:38.920  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:52:38.921  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:52:50.812  - error: tr-064.0 (25863) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:52:50.814  - error: tr-064.0 (25863) ~
                      2021-08-20 13:52:50.815  - error: tr-064.0 (25863) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:52:50.816  - error: tr-064.0 (25863) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:52:50.817  - error: tr-064.0 (25863) ~
                      2021-08-20 13:52:50.819  - warn: tr-064.0 (25863) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:52:51.373  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:52:51.374  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:53:21.409  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25970
                      2021-08-20 13:53:22.902  - info: tr-064.0 (25970) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:53:28.957  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:54:19.016  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:54:19.038  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:54:19.039  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:55:09.112  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:55:09.179  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:55:09.180  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:55:14.178  - error: tr-064.0 (25970) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:55:14.180  - error: tr-064.0 (25970) ~
                      2021-08-20 13:55:14.182  - error: tr-064.0 (25970) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:55:14.183  - error: tr-064.0 (25970) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:55:14.184  - error: tr-064.0 (25970) ~
                      2021-08-20 13:55:14.186  - warn: tr-064.0 (25970) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:55:14.748  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:55:14.761  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:55:44.821  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26097
                      2021-08-20 13:55:46.478  - info: tr-064.0 (26097) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:55:59.224  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:55:59.249  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:55:59.250  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:56:49.294  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:56:49.370  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:56:49.371  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:57:37.538  - error: tr-064.0 (26097) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 13:57:37.540  - error: tr-064.0 (26097) ~
                      2021-08-20 13:57:37.542  - error: tr-064.0 (26097) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:57:37.543  - error: tr-064.0 (26097) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 13:57:37.544  - error: tr-064.0 (26097) ~
                      2021-08-20 13:57:37.546  - warn: tr-064.0 (26097) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 13:57:38.085  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 13:57:38.087  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 13:57:39.412  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:57:39.438  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:57:39.439  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:58:08.120  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26200
                      2021-08-20 13:58:09.574  - info: tr-064.0 (26200) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 13:58:29.477  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:58:29.501  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:58:29.502  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 13:59:19.543  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 13:59:19.558  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 13:59:19.559  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:00:00.074  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 26327
                      2021-08-20 14:00:00.885  - error: tr-064.0 (26200) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:00:00.886  - error: tr-064.0 (26200) ~
                      2021-08-20 14:00:00.887  - error: tr-064.0 (26200) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:00:00.888  - error: tr-064.0 (26200) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:00:00.889  - warn: tr-064.0 (26200) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:00:01.423  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:00:01.424  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 14:00:01.884  - info: ical.0 (26327) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                      2021-08-20 14:00:02.716  - info: ical.0 (26327) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                      2021-08-20 14:00:02.738  - info: ical.0 (26327) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                      2021-08-20 14:00:02.917  - info: ical.0 (26327) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                      2021-08-20 14:00:07.955  - info: ical.0 (26327) Terminated (NO_ERROR): Without reason
                      2021-08-20 14:00:08.486  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                      2021-08-20 14:00:09.598  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:00:09.675  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:00:09.676  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:00:31.477  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26353
                      2021-08-20 14:00:32.997  - info: tr-064.0 (26353) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 14:00:59.742  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:01:49.826  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:01:49.859  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:01:49.860  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:02:24.258  - error: tr-064.0 (26353) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:02:24.260  - error: tr-064.0 (26353) ~
                      2021-08-20 14:02:24.261  - error: tr-064.0 (26353) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:02:24.263  - error: tr-064.0 (26353) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:02:24.264  - error: tr-064.0 (26353) ~
                      2021-08-20 14:02:24.266  - warn: tr-064.0 (26353) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:02:24.825  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:02:24.836  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 14:02:39.922  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:02:39.946  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:02:39.947  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:02:54.938  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26489
                      2021-08-20 14:02:56.448  - info: tr-064.0 (26489) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 14:03:29.987  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:04:20.056  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:04:20.093  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:04:20.094  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:04:47.618  - error: tr-064.0 (26489) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:04:47.620  - error: tr-064.0 (26489) ~
                      2021-08-20 14:04:47.622  - error: tr-064.0 (26489) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:04:47.623  - error: tr-064.0 (26489) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:04:47.624  - error: tr-064.0 (26489) ~
                      2021-08-20 14:04:47.626  - warn: tr-064.0 (26489) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:04:48.177  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:04:48.179  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 14:05:10.140  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:05:10.216  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:05:10.217  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:05:18.244  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26596
                      2021-08-20 14:05:19.768  - info: tr-064.0 (26596) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 14:06:00.286  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:06:50.404  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:06:50.432  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:06:50.433  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:07:10.978  - error: tr-064.0 (26596) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:07:10.980  - error: tr-064.0 (26596) ~
                      2021-08-20 14:07:10.981  - error: tr-064.0 (26596) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:07:10.983  - error: tr-064.0 (26596) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:07:10.984  - error: tr-064.0 (26596) ~
                      2021-08-20 14:07:10.986  - warn: tr-064.0 (26596) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:07:11.538  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:07:11.540  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 14:07:40.472  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:07:40.497  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:07:40.498  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:07:41.599  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26712
                      2021-08-20 14:07:43.185  - info: tr-064.0 (26712) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 14:08:30.537  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:08:30.563  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:08:30.564  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:09:20.601  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:09:20.704  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:09:20.705  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:09:34.338  - error: tr-064.0 (26712) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:09:34.341  - error: tr-064.0 (26712) ~
                      2021-08-20 14:09:34.342  - error: tr-064.0 (26712) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:09:34.344  - error: tr-064.0 (26712) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:09:34.345  - error: tr-064.0 (26712) ~
                      2021-08-20 14:09:34.347  - warn: tr-064.0 (26712) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:09:34.907  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:09:34.919  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                      2021-08-20 14:10:04.983  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26843
                      2021-08-20 14:10:06.495  - info: tr-064.0 (26843) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                      2021-08-20 14:10:10.746  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:10:10.780  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:10:10.781  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:11:00.819  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:11:50.913  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                      2021-08-20 14:11:50.987  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                      2021-08-20 14:11:50.988  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                      2021-08-20 14:11:57.690  - error: tr-064.0 (26843) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2021-08-20 14:11:57.692  - error: tr-064.0 (26843) ~
                      2021-08-20 14:11:57.693  - error: tr-064.0 (26843) ~~ Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:11:57.694  - error: tr-064.0 (26843) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                      2021-08-20 14:11:57.695  - error: tr-064.0 (26843) ~
                      2021-08-20 14:11:57.697  - warn: tr-064.0 (26843) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                      2021-08-20 14:11:58.237  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-08-20 14:11:58.246  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        Homoran Global Moderator Administrators @Chris-D 0 last edited by
                        @chris-d-0 sagte in Rega Fehler:
                        @homoran ja backup habe ich
                        dann mach doch alles neu bevor du hier Stunden verbrätst.
                        node 14
                        kommt mit npm v6
                        curl -sLf https://iobroker.net/install.sh | bash -
                        Backup einspielen - warten - fertig!
                          Chris-D 0 @Homoran last edited by
                          @homoran ok welche befehle brauche ich genau?
                            wofür genau?
                              apollon77 last edited by
                              Jetzt mal langsam ... Also laut Log ist doch alles ok, ausser:
                              • tr-064 meldet das die Fritzbox die Verbindung ablehnt, da musst man Fritzbox Einstellungen checken
                              • hm-rega/rpc meldet das die CCU "401 Unauthorized" meldet ... hast du da irgendwie username/passwort konfiguriert aber nicht im Adapter?
                              • backitup meldet das ein CIFS Mount nicht da ist
                              Der Rest sieht alles normal und ok aus.
                              Von Admin finde ich im Log ausschnitt nicht
                              Also wenn das die Themen sind dann hilft auch ein backup einspielen nix
                                @homoran neu aufsetzen?
                                  Chris-D 0 @apollon77 last edited by
                                  @apollon77 das ist leider nicht mehr das Problem, siehe verlauf
                                  haselchen apollon77 2 Replies Last reply Reply Quote 0
                                  • haselchen
                                    haselchen Most Active @Chris-D 0 last edited by
                                    @chris-d-0
                                    Wo liegt denn der Hase noch im Pfeffer?
                                    Welche Probleme gibt es noch?
                                      apollon77 @Chris-D 0 last edited by
                                      @chris-d-0 ja was ist denn das Problem? Ich blicke bei dem Verkauf nimmer durch
                                        Chris-D 0 @haselchen last edited by Chris-D 0
                                        @haselchen die IObroker Oberfläche wird nicht angezeigt. "Seite kann nicht angezeigt werden" Also Webseite nicht erreichbar
                                          @chris-d-0
                                          ich versuche mal zusammenzufassen:
                                          hu hast
                                          • Pi4 mit SD Karte
                                          • ein brauchbares iobroker backup
                                          Dann nimmst du eine neue Karte
                                          installierst darauf das aktuelle Raspberry OS lite
                                          dann den iobroker
                                          und spielst das Backup zurück.
                                          Dann sollte alles laufen
                                          Für den Notfall hast du immer noch die alte Karte
                                          @apollon77
                                          Problem ist admin 5 mit controller 2.x
                                          C apollon77 2 Replies Last reply Reply Quote 0
                                            @homoran Das Problem ist das auf dem Raspberry auch wireguard läuft... also komplett (d.h. das Raspberrry) aufsetzen ist schwierig...
                                            10329
