    4. Rega Fehler
    Rega Fehler
      Homoran Global Moderator Administrators @Homoran last edited by Homoran
      @homoran sagte in Rega Fehler:
      @thomas-braun package-lock.json löschen
      nicht die package.json
      @Chris-D-0
      hast du ein Backup?
      Thomas Braun C 2 Replies Last reply Reply Quote 0
        Ja, hab ich dann auch gesehen...
        C 1 Reply Last reply Reply Quote 1
          Chris-D 0 @Homoran last edited by
          @homoran ja backup habe ich
            Chris-D 0 @Thomas Braun last edited by
            2021-08-20 13:22:25.557  - info: hm-rpc.1 (23665) Connected
            2021-08-20 13:22:21.109  - info: hm-rpc.0 (23523) xmlrpc <- listDevices ["raspberrypi:hm-rpc.0"]
            2021-08-20 13:22:21.182  - info: hm-rpc.0 (23523) xmlrpc -> 52 devices
            2021-08-20 13:22:21.209  - info: hm-rpc.0 (23523) Connected
            2021-08-20 13:22:25.580  - info: hm-rpc.1 (23665) xmlrpc <- listDevices ["raspberrypi:hm-rpc.1"]
            2021-08-20 13:22:30.516  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24164
            2021-08-20 13:22:30.560  - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
            2021-08-20 13:22:30.575  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24170
            2021-08-20 13:22:31.165  - info: hm-rpc.1 (23665) xmlrpc -> 0 devices
            2021-08-20 13:22:31.198  - info: samsung.0 (24138) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v14.17.5
            2021-08-20 13:22:32.466  - info: ical.0 (24170) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
            2021-08-20 13:22:32.784  - info: hm-rpc.1 (23665) xmlrpc <- newDevices 415
            2021-08-20 13:22:33.037  - info: ical.0 (24170) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
            2021-08-20 13:22:33.087  - info: hm-rpc.1 (23665) new HMIP devices/channels after filter: 0
            2021-08-20 13:22:33.279  - info: ical.0 (24170) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
            2021-08-20 13:22:33.329  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 24190
            2021-08-20 13:22:34.712  - info: ical.0 (24170) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
            2021-08-20 13:22:35.046  - info: hm-rega.0 (24190) starting. Version 3.0.29 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.17.5
            2021-08-20 13:22:35.209  - info: hm-rega.0 (24190) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
            2021-08-20 13:22:35.415  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:22:35.524  - info: backitup.0 (24164) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.5
            2021-08-20 13:22:35.610  - info: backitup.0 (24164) [iobroker] backup was activated at 02:00 every 5 day(s)
            2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:22:35.695  - info: backitup.0 (24164) [ccu] backup was activated at 01:30 every 5 day(s)
            2021-08-20 13:22:36.183  - error: backitup.0 (24164) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.20/Datensicherung\SmartHome /opt/iobroker/backups
            mount error(2): No such file or directory
            Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
            2021-08-20 13:22:37.346  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 24226
            2021-08-20 13:22:41.032  - info: ical.0 (24170) Terminated (NO_ERROR): Without reason
            2021-08-20 13:22:41.184  - info: echarts.0 (24226) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.17.5
            2021-08-20 13:22:41.327  - info: host.raspberrypi instance system.adapter.history.0 started with pid 24250
            2021-08-20 13:22:41.560  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2021-08-20 13:22:42.388  - info: history.0 (24250) starting. Version 1.9.13 in /opt/iobroker/node_modules/iobroker.history, node: v14.17.5
            2021-08-20 13:22:42.459  - info: history.0 (24250) enabled logging of hm-rpc.1.000A1A49A1021D.1.ACTUAL_TEMPERATURE (Count=1), Alias=false
            2021-08-20 13:22:42.460  - info: history.0 (24250) enabled logging of hm-rpc.1.000A9A49A2C621.1.HUMIDITY (Count=2), Alias=false
            2021-08-20 13:22:45.344  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 24267
            2021-08-20 13:22:46.757  - info: simple-api.0 (24267) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.17.5
            2021-08-20 13:22:46.818  - info: simple-api.0 (24267) simpleAPI server listening on port 8087
            2021-08-20 13:22:46.819  - info: simple-api.0 (24267) Allow states only when user is owner: false
            2021-08-20 13:22:46.823  - info: simple-api.0 (24267) http server listening on port 8087
            2021-08-20 13:22:49.314  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "2.2.10", required ">=3.1.0
            2021-08-20 13:22:53.346  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 24293
            2021-08-20 13:22:57.507  - info: host.raspberrypi instance scheduled system.adapter.openweathermap.0 23 * * * *
            2021-08-20 13:22:57.533  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 24305
            2021-08-20 13:22:59.686  - info: javascript.0 (24293) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.17.5
            2021-08-20 13:22:59.840  - info: javascript.0 (24293) requesting all states
            2021-08-20 13:22:59.844  - info: javascript.0 (24293) requesting all objects
            2021-08-20 13:23:00.032  - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 24305
            2021-08-20 13:23:00.844  - info: openweathermap.0 (24305) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.17.5
            2021-08-20 13:23:01.119  - info: javascript.0 (24293) received all objects
            2021-08-20 13:23:01.186  - info: javascript.0 (24293) received all states
            2021-08-20 13:23:03.830  - info: openweathermap.0 (24305) Terminated (NO_ERROR): Without reason
            2021-08-20 13:23:04.371  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
            2021-08-20 13:23:25.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:23:25.827  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:23:25.828  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:24:05.379  - error: tr-064.0 (24042) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:24:05.381  - error: tr-064.0 (24042) ~
            2021-08-20 13:24:05.383  - error: tr-064.0 (24042) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:24:05.384  - error: tr-064.0 (24042) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:24:05.385  - error: tr-064.0 (24042) ~
            2021-08-20 13:24:05.387  - warn: tr-064.0 (24042) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:24:05.951  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:24:05.953  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:24:15.873  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:24:15.956  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:24:15.957  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:24:35.986  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24403
            2021-08-20 13:24:37.537  - info: tr-064.0 (24403) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:25:06.003  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:25:06.054  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:25:06.055  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:25:56.103  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:25:56.149  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:25:56.150  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:26:28.738  - error: tr-064.0 (24403) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:26:28.740  - error: tr-064.0 (24403) ~
            2021-08-20 13:26:28.741  - error: tr-064.0 (24403) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:26:28.742  - error: tr-064.0 (24403) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:26:28.743  - error: tr-064.0 (24403) ~
            2021-08-20 13:26:28.746  - warn: tr-064.0 (24403) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:26:29.293  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:26:29.294  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:26:46.194  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:26:46.235  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:26:46.236  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:26:59.349  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24563
            2021-08-20 13:27:00.989  - info: tr-064.0 (24563) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:27:36.311  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:27:36.383  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:27:36.384  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:28:26.425  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:28:26.459  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:28:26.461  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:28:52.099  - error: tr-064.0 (24563) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:28:52.101  - error: tr-064.0 (24563) ~
            2021-08-20 13:28:52.103  - error: tr-064.0 (24563) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:28:52.104  - error: tr-064.0 (24563) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:28:52.105  - error: tr-064.0 (24563) ~
            2021-08-20 13:28:52.107  - warn: tr-064.0 (24563) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:28:52.648  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:28:52.649  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:29:16.497  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:29:16.515  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:29:16.516  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:29:22.687  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24700
            2021-08-20 13:29:24.211  - info: tr-064.0 (24700) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:30:06.556  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:30:06.598  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:30:06.599  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:30:56.641  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:30:56.671  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:30:56.672  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:31:15.458  - error: tr-064.0 (24700) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:31:15.460  - error: tr-064.0 (24700) ~
            2021-08-20 13:31:15.462  - error: tr-064.0 (24700) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:31:15.463  - error: tr-064.0 (24700) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:31:15.464  - error: tr-064.0 (24700) ~
            2021-08-20 13:31:15.466  - warn: tr-064.0 (24700) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:31:16.019  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:31:16.020  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:31:46.047  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24828
            2021-08-20 13:31:46.712  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:31:46.734  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:31:46.735  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:31:47.595  - info: tr-064.0 (24828) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:32:36.775  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:33:26.876  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:33:26.947  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:33:26.948  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:33:43.938  - error: tr-064.0 (24828) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:33:43.940  - error: tr-064.0 (24828) ~
            2021-08-20 13:33:43.942  - error: tr-064.0 (24828) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:33:43.943  - error: tr-064.0 (24828) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:33:43.944  - error: tr-064.0 (24828) ~
            2021-08-20 13:33:43.946  - warn: tr-064.0 (24828) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:33:44.494  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:33:44.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:34:14.550  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24956
            2021-08-20 13:34:16.029  - info: tr-064.0 (24956) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:34:16.992  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:34:17.024  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:34:17.025  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:35:07.064  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:35:07.087  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:35:07.088  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:35:57.125  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:35:57.159  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:35:57.160  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:36:07.298  - error: tr-064.0 (24956) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:36:07.300  - error: tr-064.0 (24956) ~
            2021-08-20 13:36:07.301  - error: tr-064.0 (24956) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:36:07.302  - error: tr-064.0 (24956) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:36:07.303  - error: tr-064.0 (24956) ~
            2021-08-20 13:36:07.305  - warn: tr-064.0 (24956) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:36:07.867  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:36:07.869  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:36:37.931  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25084
            2021-08-20 13:36:39.428  - info: tr-064.0 (25084) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:36:47.203  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:36:47.232  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:36:47.233  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:37:37.275  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:37:37.310  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:37:37.311  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:38:27.383  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:38:27.452  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:38:27.453  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:38:30.658  - error: tr-064.0 (25084) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:38:30.659  - error: tr-064.0 (25084) ~
            2021-08-20 13:38:30.660  - error: tr-064.0 (25084) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:38:30.661  - error: tr-064.0 (25084) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:38:30.662  - error: tr-064.0 (25084) ~
            2021-08-20 13:38:30.664  - warn: tr-064.0 (25084) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:38:31.227  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:38:31.239  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:39:01.302  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25224
            2021-08-20 13:39:02.883  - info: tr-064.0 (25224) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:39:17.496  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:39:17.530  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:39:17.531  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:40:07.576  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:40:07.606  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:40:07.607  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:40:54.014  - error: tr-064.0 (25224) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:40:54.017  - error: tr-064.0 (25224) ~
            2021-08-20 13:40:54.018  - error: tr-064.0 (25224) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:40:54.019  - error: tr-064.0 (25224) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:40:54.020  - error: tr-064.0 (25224) ~
            2021-08-20 13:40:54.022  - warn: tr-064.0 (25224) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:40:54.574  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:40:54.585  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:40:57.648  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:40:57.673  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:40:57.674  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:41:24.645  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25417
            2021-08-20 13:41:26.131  - info: tr-064.0 (25417) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:41:47.710  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:41:47.757  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:41:47.758  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:42:37.803  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:42:37.836  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:42:37.837  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:43:17.376  - error: tr-064.0 (25417) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:43:17.378  - error: tr-064.0 (25417) ~
            2021-08-20 13:43:17.379  - error: tr-064.0 (25417) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:43:17.380  - error: tr-064.0 (25417) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:43:17.381  - error: tr-064.0 (25417) ~
            2021-08-20 13:43:17.383  - warn: tr-064.0 (25417) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:43:17.923  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:43:17.925  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:43:27.884  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:43:27.930  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:43:27.931  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:43:47.963  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25546
            2021-08-20 13:43:49.562  - info: tr-064.0 (25546) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:44:18.000  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:45:08.109  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:45:08.139  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:45:08.140  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:45:40.738  - error: tr-064.0 (25546) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:45:40.741  - error: tr-064.0 (25546) ~
            2021-08-20 13:45:40.742  - error: tr-064.0 (25546) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:45:40.743  - error: tr-064.0 (25546) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:45:40.744  - error: tr-064.0 (25546) ~
            2021-08-20 13:45:40.746  - warn: tr-064.0 (25546) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:45:41.299  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:45:41.300  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:45:58.178  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:45:58.212  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:45:58.213  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:46:11.356  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25653
            2021-08-20 13:46:12.879  - info: tr-064.0 (25653) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:46:48.251  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:46:48.280  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:46:48.281  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:47:38.326  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:47:38.401  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:47:38.402  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:48:04.097  - error: tr-064.0 (25653) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:48:04.100  - error: tr-064.0 (25653) ~
            2021-08-20 13:48:04.101  - error: tr-064.0 (25653) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:48:04.102  - error: tr-064.0 (25653) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:48:04.103  - error: tr-064.0 (25653) ~
            2021-08-20 13:48:04.106  - warn: tr-064.0 (25653) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:48:04.652  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:48:04.653  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:48:28.445  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:48:28.495  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:48:28.496  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:48:34.689  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25770
            2021-08-20 13:48:36.152  - info: tr-064.0 (25770) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:49:18.566  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:49:18.599  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:49:18.600  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:50:08.645  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:50:08.713  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:50:08.714  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:50:27.460  - error: tr-064.0 (25770) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:50:27.463  - error: tr-064.0 (25770) ~
            2021-08-20 13:50:27.465  - error: tr-064.0 (25770) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:50:27.467  - error: tr-064.0 (25770) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:50:27.468  - error: tr-064.0 (25770) ~
            2021-08-20 13:50:27.471  - warn: tr-064.0 (25770) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:50:28.040  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:50:28.052  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:50:58.104  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25863
            2021-08-20 13:50:58.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:50:58.781  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:50:58.782  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:50:59.632  - info: tr-064.0 (25863) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:51:48.824  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:51:48.850  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:51:48.851  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:52:38.894  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:52:38.920  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:52:38.921  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:52:50.812  - error: tr-064.0 (25863) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:52:50.814  - error: tr-064.0 (25863) ~
            2021-08-20 13:52:50.815  - error: tr-064.0 (25863) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:52:50.816  - error: tr-064.0 (25863) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:52:50.817  - error: tr-064.0 (25863) ~
            2021-08-20 13:52:50.819  - warn: tr-064.0 (25863) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:52:51.373  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:52:51.374  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:53:21.409  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25970
            2021-08-20 13:53:22.902  - info: tr-064.0 (25970) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:53:28.957  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:54:19.016  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:54:19.038  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:54:19.039  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:55:09.112  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:55:09.179  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:55:09.180  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:55:14.178  - error: tr-064.0 (25970) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:55:14.180  - error: tr-064.0 (25970) ~
            2021-08-20 13:55:14.182  - error: tr-064.0 (25970) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:55:14.183  - error: tr-064.0 (25970) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:55:14.184  - error: tr-064.0 (25970) ~
            2021-08-20 13:55:14.186  - warn: tr-064.0 (25970) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:55:14.748  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:55:14.761  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:55:44.821  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26097
            2021-08-20 13:55:46.478  - info: tr-064.0 (26097) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:55:59.224  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:55:59.249  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:55:59.250  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:56:49.294  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:56:49.370  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:56:49.371  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:57:37.538  - error: tr-064.0 (26097) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 13:57:37.540  - error: tr-064.0 (26097) ~
            2021-08-20 13:57:37.542  - error: tr-064.0 (26097) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:57:37.543  - error: tr-064.0 (26097) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 13:57:37.544  - error: tr-064.0 (26097) ~
            2021-08-20 13:57:37.546  - warn: tr-064.0 (26097) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 13:57:38.085  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 13:57:38.087  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 13:57:39.412  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:57:39.438  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:57:39.439  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:58:08.120  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26200
            2021-08-20 13:58:09.574  - info: tr-064.0 (26200) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 13:58:29.477  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:58:29.501  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:58:29.502  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 13:59:19.543  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 13:59:19.558  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 13:59:19.559  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:00:00.074  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 26327
            2021-08-20 14:00:00.885  - error: tr-064.0 (26200) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:00:00.886  - error: tr-064.0 (26200) ~
            2021-08-20 14:00:00.887  - error: tr-064.0 (26200) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:00:00.888  - error: tr-064.0 (26200) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:00:00.889  - warn: tr-064.0 (26200) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:00:01.423  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:00:01.424  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 14:00:01.884  - info: ical.0 (26327) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
            2021-08-20 14:00:02.716  - info: ical.0 (26327) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
            2021-08-20 14:00:02.738  - info: ical.0 (26327) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
            2021-08-20 14:00:02.917  - info: ical.0 (26327) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
            2021-08-20 14:00:07.955  - info: ical.0 (26327) Terminated (NO_ERROR): Without reason
            2021-08-20 14:00:08.486  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2021-08-20 14:00:09.598  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:00:09.675  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:00:09.676  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:00:31.477  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26353
            2021-08-20 14:00:32.997  - info: tr-064.0 (26353) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 14:00:59.742  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:01:49.826  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:01:49.859  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:01:49.860  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:02:24.258  - error: tr-064.0 (26353) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:02:24.260  - error: tr-064.0 (26353) ~
            2021-08-20 14:02:24.261  - error: tr-064.0 (26353) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:02:24.263  - error: tr-064.0 (26353) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:02:24.264  - error: tr-064.0 (26353) ~
            2021-08-20 14:02:24.266  - warn: tr-064.0 (26353) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:02:24.825  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:02:24.836  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 14:02:39.922  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:02:39.946  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:02:39.947  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:02:54.938  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26489
            2021-08-20 14:02:56.448  - info: tr-064.0 (26489) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 14:03:29.987  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:04:20.056  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:04:20.093  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:04:20.094  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:04:47.618  - error: tr-064.0 (26489) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:04:47.620  - error: tr-064.0 (26489) ~
            2021-08-20 14:04:47.622  - error: tr-064.0 (26489) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:04:47.623  - error: tr-064.0 (26489) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:04:47.624  - error: tr-064.0 (26489) ~
            2021-08-20 14:04:47.626  - warn: tr-064.0 (26489) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:04:48.177  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:04:48.179  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 14:05:10.140  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:05:10.216  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:05:10.217  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:05:18.244  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26596
            2021-08-20 14:05:19.768  - info: tr-064.0 (26596) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 14:06:00.286  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:06:50.404  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:06:50.432  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:06:50.433  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:07:10.978  - error: tr-064.0 (26596) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:07:10.980  - error: tr-064.0 (26596) ~
            2021-08-20 14:07:10.981  - error: tr-064.0 (26596) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:07:10.983  - error: tr-064.0 (26596) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:07:10.984  - error: tr-064.0 (26596) ~
            2021-08-20 14:07:10.986  - warn: tr-064.0 (26596) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:07:11.538  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:07:11.540  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 14:07:40.472  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:07:40.497  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:07:40.498  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:07:41.599  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26712
            2021-08-20 14:07:43.185  - info: tr-064.0 (26712) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 14:08:30.537  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:08:30.563  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:08:30.564  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:09:20.601  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:09:20.704  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:09:20.705  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:09:34.338  - error: tr-064.0 (26712) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:09:34.341  - error: tr-064.0 (26712) ~
            2021-08-20 14:09:34.342  - error: tr-064.0 (26712) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:09:34.344  - error: tr-064.0 (26712) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:09:34.345  - error: tr-064.0 (26712) ~
            2021-08-20 14:09:34.347  - warn: tr-064.0 (26712) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:09:34.907  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:09:34.919  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
            2021-08-20 14:10:04.983  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26843
            2021-08-20 14:10:06.495  - info: tr-064.0 (26843) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
            2021-08-20 14:10:10.746  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:10:10.780  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:10:10.781  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:11:00.819  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:11:50.913  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
            2021-08-20 14:11:50.987  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
            2021-08-20 14:11:50.988  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
            2021-08-20 14:11:57.690  - error: tr-064.0 (26843) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
            2021-08-20 14:11:57.692  - error: tr-064.0 (26843) ~
            2021-08-20 14:11:57.693  - error: tr-064.0 (26843) ~~ Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:11:57.694  - error: tr-064.0 (26843) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            2021-08-20 14:11:57.695  - error: tr-064.0 (26843) ~
            2021-08-20 14:11:57.697  - warn: tr-064.0 (26843) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            2021-08-20 14:11:58.237  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2021-08-20 14:11:58.246  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              Homoran Global Moderator Administrators @Chris-D 0 last edited by
              @chris-d-0 sagte in Rega Fehler:
              @homoran ja backup habe ich
              dann mach doch alles neu bevor du hier Stunden verbrätst.
              node 14
              kommt mit npm v6
              curl -sLf https://iobroker.net/install.sh | bash -
              Backup einspielen - warten - fertig!
                Chris-D 0 @Homoran last edited by
                @homoran ok welche befehle brauche ich genau?
                  wofür genau?
                    apollon77 last edited by
                    Jetzt mal langsam ... Also laut Log ist doch alles ok, ausser:
                    • tr-064 meldet das die Fritzbox die Verbindung ablehnt, da musst man Fritzbox Einstellungen checken
                    • hm-rega/rpc meldet das die CCU "401 Unauthorized" meldet ... hast du da irgendwie username/passwort konfiguriert aber nicht im Adapter?
                    • backitup meldet das ein CIFS Mount nicht da ist
                    Der Rest sieht alles normal und ok aus.
                    Von Admin finde ich im Log ausschnitt nicht
                    Also wenn das die Themen sind dann hilft auch ein backup einspielen nix
                      @homoran neu aufsetzen?
                        Chris-D 0 @apollon77 last edited by
                        @apollon77 das ist leider nicht mehr das Problem, siehe verlauf
                        haselchen apollon77 2 Replies Last reply Reply Quote 0
                        • haselchen
                          haselchen Most Active @Chris-D 0 last edited by
                          @chris-d-0
                          Wo liegt denn der Hase noch im Pfeffer?
                          Welche Probleme gibt es noch?
                            apollon77 @Chris-D 0 last edited by
                            @chris-d-0 ja was ist denn das Problem? Ich blicke bei dem Verkauf nimmer durch
                              Chris-D 0 @haselchen last edited by Chris-D 0
                              @haselchen die IObroker Oberfläche wird nicht angezeigt. "Seite kann nicht angezeigt werden" Also Webseite nicht erreichbar
                                @chris-d-0
                                ich versuche mal zusammenzufassen:
                                hu hast
                                • Pi4 mit SD Karte
                                • ein brauchbares iobroker backup
                                Dann nimmst du eine neue Karte
                                installierst darauf das aktuelle Raspberry OS lite
                                dann den iobroker
                                und spielst das Backup zurück.
                                Dann sollte alles laufen
                                Für den Notfall hast du immer noch die alte Karte
                                @apollon77
                                Problem ist admin 5 mit controller 2.x
                                C apollon77 2 Replies Last reply Reply Quote 0
                                  @homoran Das Problem ist das auf dem Raspberry auch wireguard läuft... also komplett (d.h. das Raspberrry) aufsetzen ist schwierig...
                                    apollon77 @Homoran last edited by apollon77
                                    @homoran sagte in Rega Fehler:
                                    Wie kriegt man das hin ausser manuell gefrickelt??
                                    Adrmin 5 braucht mindestens "js-controller": ">=3.2.16"
                                    Also Controller updaten und Problem ist erledigt. Oder Admin Downgrade
                                      @apollon77 System neu aufgesetzt, Rega Fehler bleibt
                                      Homoran apollon77 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Chris-D 0 last edited by Homoran
                                        immerhin läuft er jetzt wieder.
                                        Dieser Fehler deutet auf ein Problem mit der Firewall der CCU hin.
                                        Bitte vollständig als Text in code-tags posten und nicht als Screenshot
                                          @chris-d-0 Das hatte ich doch oben schon geschrierben: hast Du ggf irgendwie bei der CCU (oder was genau nutzt du) Ein username/Passwort angegeben aber nicht in der Adapter Konfiguration?
                                            @apollon77 Nutze eine CCU 3 habe https mit Benutzername und Passwort - der passt aber (mehrfach kontrolliert)
                                            10327
