    4. Test Adapter Admin 5.0.x: Alpha der neuen UI
      gyle @apollon77 last edited by
      @apollon77
      pi@iobroker:~ $ iobroker cert view
        "certificateFilename": null,
        "certificate": "-----BEGIN CERTIFICATE-----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\r\nqJ5/mYB0bMtxCNYvIhDYzXfeucMT4ucJ2hJeBsufIabo9w==\r\n-----END CERTIFICATE-----\r\n",
        "serialNumber": "091c0da3e1a18d9147",
        "signature": "sha256WithRSAEncryption",
        "keyLength": 2048,
        "issuer": {
          "attributes": [
              "type": "2.5.4.3",
              "value": "iobroker",
              "valueTagClass": 19,
              "name": "commonName",
              "shortName": "CN"
              "type": "2.5.4.10",
              "value": "ioBroker GmbH",
              "name": "organizationName",
              "shortName": "O"
              "type": "2.5.4.11",
              "name": "organizationalUnitName",
              "shortName": "OU"
          "hash": "7e4805a252caec3f7eeed95aba55c8417d8ad7a7"
        "subject": {
          "attributes": [
              "type": "2.5.4.3",
              "shortName": "CN"
              "type": "2.5.4.10",
              "shortName": "O"
              "type": "2.5.4.11",
              "shortName": "OU"
        "dnsNames": [
            "type": 2,
            "value": "iobroker"
        "keyUsage": {
          "id": "2.5.29.15",
          "critical": true,
          "name": "keyUsage",
          "digitalSignature": true,
          "nonRepudiation": false,
          "keyEncipherment": true,
          "dataEncipherment": true,
          "keyAgreement": true,
          "keyCertSign": true,
          "cRLSign": true,
          "encipherOnly": true,
          "decipherOnly": true
        "extKeyUsage": {
          "id": "2.5.29.37",
          "critical": false,
          "name": "extKeyUsage",
          "serverAuth": true,
          "clientAuth": true
        "validityNotBefore": "2021-07-25T07:09:11.000Z",
        "validityNotAfter": "2022-07-25T07:09:11.000Z"
      pi@iobroker:~ $
        apollon77 @gyle last edited by
        @gyle Hm ... sieht an sich ok aus ... ist aktuell und nur 1 Jahr gültig
        • ice987
          ice987 @gyle last edited by ice987
          @gyle sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
          habe rausgefunden, wo das problem lag...
          Ich hatte https akiviert (mit den default-zertifikaten, kein lets encrypt)...
          habe die admin-instanz komplett gelöscht, neu installiert, ohne https....damit funktioniert es....
          sobald ich https wieder aktiviere klappt es auf den mobil-geraten nicht mehr!?
          Dieses Verhalten kann ich bestätigen. Sobald https aktiviert ist, kann der Admin auf den Apple-Geräten nicht mehr geöffnet werden (egal ob iPad oder iPhone). Unter Chrome funktioniert alles einwandfrei. Wird https deaktiviert, funktioniert es auch auf den Apple-Geräte.
          • I
            ioStarter last edited by
            nachdem ich auf die neue UI gewechselt bin, habe ich im Abschnitt Objekte 3x auf das obere linke Ordnersymbol gedrückt. Seid dem wurden zuerst nicht mehr alle Objekte dargestellt, der Iobroker nimmt daraufhin auch keine Befehle mehr an. Erst nach längerem Warten kann man dann wieder auf Adapter oder Instanzen gehen. Hier ist dann ein normales Arbeiten möglich. Aber sobald ich dann wieder in die Objekte wechsle, ist alles wieder langsam. Schlimmer noch, jetzt kann der iobroker nicht mehr geöffnet werden. Hier kommt die Meldung das die Seite nicht erreichbar ist. Daraufhin habe ich den iobroker komplett neu in einer anderen VM installiert. Auch hier kommt es zum gleichen Verhalten nachdem ich mehrmals auf dieses Ordnersymbol gedrückt habe. Sämtliche Reparaturversuche waren bisher erfolglos. Hat jemand eine Idee, was hier schief gelaufen ist und wie ich meinen iobroker wieder zum Laufen bekomme?
            Mitte lasst mich wissen, welche Informationen Ihr benötigt um das Problem zu lösen.
            Viele Grüße
            Thomas
            apollon77 amg_666 2 Replies Last reply Reply Quote 0
              apollon77 @ioStarter last edited by
              @iostarter "Das ober linke Ordnersymbol" ... also "alles zuklappen"? ... Kann ich nciht nachstellen ... bei mir klappt da alles zu und alles tut perfekt weiter.
              • amg_666
                amg_666 @ioStarter last edited by
                @iostarter Was genau meinst du mit " im Abschnitt Objekte ... obere linke Ordnersymbol "? Im Abschnitt Objekte wäre das bei mir der Ordner 0_Userdata, da kann ich draufklicken soviel ich will, iobroker läuft stabil. Oben links im Abschnitt Objete ist das "Refresh" Symbol, wenn ich da draufklicke dauert es gefühlt 1-2 Sekunden bis alles wieder da ist.
                Was für ein System hast du, welche Versionen node.js etc?
                Ichz fahre iobroker master auf einem intel nuc mit proxmox und da dann als container (nicht vm), das läuft alles sehr stabil mit derzeit 44 Adaptern.
                • BBTown
                  BBTown @amg_666 last edited by
                  @amg_666 Links wurde der Bereich "Objekte" ausgewählt, und in der Symbolleiste werden die Ordner Auf/Zugeklappt
                  • amg_666
                    amg_666 @BBTown last edited by
                    @bbtown Hab ich grad bei mir ausprobiert. Das funktioniert, allerdings dauert das auf-/zuklappen bis zu ca 2 Sekunden bis er wieder reagiert.
                    Wie gesagt, bei mir proxmox auf nuc, Debian 10 und iobroker als Container, node.js v14.17.4 und npm 6.14.14, js-controller 3.3.15 also eigentlich ziemlich ähnliches System...
                    BBTown apollon77 2 Replies Last reply Reply Quote 0
                    • BBTown
                      @amg_666 das könnte womöglich mit der Anzahl Ordner und Datenpunkte im Zusammenhang stehen.
                        apollon77 @amg_666 last edited by
                        @amg_666 Naja ich denke ist ein Kombination aus Ladezeit und Anzeigezeit - so ein Baum ist recht aufwändig und da wird auch der Browser zu ackern haben - könnt ja mal CPU Verbrauch des Browser Tabs ansehen.
                        Also ja na klar "alles aufklappen" ist echt teuer! Auch weil er im backend dann auf ALLE Daten subscribed weil alle Werte aktualisiert werden.
                        Also ich habe ca. 30.000 Objekte ... Von daher ist da auch viel der PC und Browser entscheident und der freie RAM dort und so. Also kann mir gut vorstellen das bei schwächeren Systemen (und ich meine NICHT den Host wo iobroker drauf läuft) da Grenzen kommen
                        • amg_666
                          amg_666 @apollon77 last edited by
                          @apollon77 Sehe ich genauso und ich hab das auch nicht als "Fehler" oder "Kritik" gemeint, wollte nur sagen, dass es etwas dauert aber dass das System weiterhin stabil läuft und das schein ja bei @BBTown nicht der Fall zu sein...
                          • BBTown
                            @amg_666
                            was redest Du da? ... mein System läuft einwandfrei?!
                            Ich habe dir lediglich in einem GIF dargestellt, was Du zuvor anscheinend nicht genau verstanden hattest :
                            @amg_666 sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
                            • amg_666
                              @bbtown sorry, ich meinte @ioStarter nicht dich
                              • I
                                ioStarter @amg_666 last edited by
                                @amg_666
                                Eigentlich ist mein System nicht zu schwach…ich scheine aber definitiv ein Problem mit meinem Browser (Safari) zu haben. Am PC funktioniert alles, sobald ich aber mit dem I Pad auf die Objekte klicke wird das System sehr langsam. Ich melde mich morgen noch mal mit mehr Details zu meinem System.
                                Gruß Thomas
                                apollon77 cash 2 Replies Last reply Reply Quote 0
                                  @iostarter Sfari ist halt auch so ne Sache ... Was macht denn Chrome oder Firefox?
                                  • OliverIO
                                    OliverIO @apollon77 last edited by OliverIO
                                    @apollon77 sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
                                    Auf Apple Geräten ist die render engine immer Safari bzw webkit, egal wie der Browser heißt.
                                    https://www.thefastcode.com/de-eur/article/why-third-party-browsers-will-always-be-inferior-to-safari-on-iphone-and-ipad
                                    • cash
                                      cash Most Active @ioStarter last edited by
                                      @iostarter habe auf meinen ipad mit safari keine Probleme. Allerdings habe ich auch das 2021 ipad pro welches ja nicht zur Gattung der schwachen Systeme zählt…
                                      • I
                                        ioStarter @cash last edited by
                                        @cash
                                        So, das Problem gehört der Geschichte an 😎
                                        Ich arbeite auch mit einem I Pad pro 12.9 der neueren Generation.
                                        Nach dem ich den Cache des I Pads zurück gesetzt habe, funktioniert alles wieder. Es lief ja auch sehr lange gut. Das Problem trat wahrscheinlich eher zufällig mit dem Wechsel auf den Admin 5.0 auf. Nur komisch, dass mir hier das ganze System geschossen worden ist.
                                        P.S. mein iobroker läuft auf einem Suttle System DS10U unter Proxmox in einer VM.
                                          apollon77 @OliverIO last edited by
                                          @oliverio Ääähhhmmm ... Ja auf iPad und iOhne ... aber nicht auf einem macOS. Ich weiss ja nicht was er nutzt (oder habs überlesen)
                                            @iostarter sagte in Test Adapter Admin 5.0.x: Alpha der neuen UI:
                                            Kannst Du mal sagen wie das geht? Vllt hilft das auch bei anderen Issues dies mit Admin5 auf Safari gibt
                                            938
                                            253454
