    5. Zeitplan löst nicht aus
      lukas8519 @sigi234 last edited by Homoran
      @sigi234
       <variables>
         <variable type="cron" id="schedule1">schedule1</variable>
         <variable type="cron" id="schedule2">schedule2</variable>
       </variables>
       <block type="comment" id="+b;o$$PA4kQ|=OI)1!HB" x="87" y="88">
         <field name="COMMENT">Blumen gießen "grün"</field>
           <block type="schedule_create" id="l4-Ova`NDEBSh#.?uq(`">
             <field name="NAME">schedule1</field>
             <value name="SCHEDULE">
               <shadow type="field_cron" id="#m4#Jf|77_Qm/mu,A=F~">
                 <field name="CRON">* * * * *</field>
               <block type="field_cron" id="D?f8Q7^Y)O:3MwQo7Cy_">
                 <field name="CRON">1 0 * * *</field>
               <block type="toggle" id="-zPgABLZI8~dmWDlBPw5">
                 <field name="OID">javascript.0.Eigene_Datenpunkte.jeder_zweite_Tag</field>
               <block type="on" id="~!O!N7pRu$%Jy;*YMGF,">
                   <block type="schedule_create" id="ZpcNVql6=:Pp,{@lasQ4">
                     <field name="NAME">schedule2</field>
                       <shadow type="field_cron" id="n?)qnD~3lFB/eGP.c7)[">
                       <block type="cron_builder" id="eg1?t~eWJ;r,s1mzR8,P">
                         <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
                         <field name="LINE">FALSE</field>
                         <field name="WITH_SECONDS">FALSE</field>
                         <value name="DOW">
                           <shadow type="text" id="g6CemM7@[VFKY=sgk.6x">
                             <field name="TEXT">*</field>
                         <value name="MONTHS">
                           <shadow type="text" id="orv5UA?ReH$DK86hK})l">
                         <value name="DAYS">
                           <shadow type="text" id="GdTE4W+Nc:Kad%W.e(rW">
                         <value name="HOURS">
                           <shadow type="text" id="au9o?Jgt7_)#QhgdKO1-">
                             <field name="TEXT"></field>
                           <block type="text" id="|1Q4*AK):|.2te.k;b;G">
                             <field name="TEXT">17</field>
                         <value name="MINUTES">
                           <shadow type="text" id="Wk9_QhEk%,4`j5t6^n.W">
                           <block type="text" id="AQd81@)x#,+9`oSpR/F`">
                             <field name="TEXT">00</field>
                       <block type="control" id="IoW*or]ne}S0bH!a0phi">
                         <field name="OID">hue.0.Info-Leuchte.command</field>
                           <block type="text" id="bUK#^q*_[;(P6_!=yB*`">
                             <field name="TEXT">{"on":true,"level":100,"r":0,"g":255,"b":0,"transitiontime":1}</field>
                           <block type="control" id="^yUy}MyeWZ?*7a[lp,Mq">
                             <field name="OID">alexa2.0.Echo-Devices.G2A1B5031146019T.Commands.speak</field>
                             <field name="DELAY_MS">2</field>
                               <block type="text" id="kLk/_2#2*q.(cb3FATig">
                                 <field name="TEXT">Heute müssen die Blumen gegossen werden, das grüne Licht erinnert dich daran!</field>
                               <block type="control" id="%cpfkcgZKTm559LH54f$">
                                 <field name="OID">whatsapp-cmb.0.sendMessage</field>
                                 <field name="DELAY_MS">3</field>
                                   <block type="text" id="^-_Ap4cO-[D,6{]OGV!{">
                                     <field name="TEXT">Heute Blumen gießen :)</field>
                                   <block type="control" id="nK4:Yw6eP4{HeQNiX{os">
                                     <field name="OID">whatsapp-cmb.1.sendMessage</field>
                                     <field name="DELAY_MS">4</field>
                                       <block type="text" id="D}%Z,R!g6avFfJ~[04js">
        lukas8519 last edited by
          <variables>
          </variables>
                            <value name="DOW">
                            <value name="DAYS">
          @Jan1 @sigi234
            <variables>
            </variables>
                              <value name="DOW">
                              <value name="DAYS">
            paul53 @lukas8519 last edited by paul53
            @lukas8519
             <variables>
             </variables>
                           <value name="DOW">
                           <value name="DAYS">
                         <block type="controls_if" id=",OJ?+R*5i.?6K(+UcYqg">
                             <block type="get_value_var" id="b[6uoy{hL]s]8(^q=jZ,">
                               <value name="OID">
                                 <shadow type="text" id="1b*8Ul=T^w.c#8/P#Wn5">
                                   <field name="TEXT">javascript.0.Eigene_Datenpunkte.jeder_zweite_Tag</field>
              lukas8519 @paul53 last edited by
              @paul53 super vielen Dank, es funktioniert.
              ich würde gerne daraus lernen... was macht denn ""Wert" von ObjektID "...Datenpunkt...""?
                @lukas8519 sagte: was macht denn ""Wert" von ObjektID "...Datenpunkt...""?
                Liest den Wert aus dem Datenpunkt. Wenn der Wert wahr ist, wird der mache-Zweig ausgeführt.
                Einfachere Version mit nur einem Zeitplan:
                  @paul53 also ist das das gleiche wie:
                  aber "wert" wartet immer auf "wahr"?
                    @lukas8519 sagte: ist das das gleiche wie:
                    Ja, das Ergebnis eines Vergleiches ist falsch oder wahr. Da der Datenpunkt es schon so liefert ...
                      @paul53 ich danke dir!
                        @paul53 sagte in Zeitplan löst nicht aus:
                        aber in diesem Fall: würde er dann trotzdem nur bei "wahr" auslösen, oder auch bei "falsch"?
                          @lukas8519 sagte: würde er dann trotzdem nur bei "wahr" auslösen
                          Der mache-Zweig wird nur ausgeführt, wenn falls wahr übergeben bekommt.
                            @paul53 okay, nochmals danke!😊 😊
                            557
