    4. Adapter "smartmeter"
    • a200
      a200 last edited by
      Hier habe ich aus dem Logfile
      ! ` > 2017-02-08 23:12:12.696 - info: host.miniyou instance system.adapter.smartmeter.0 started with pid 3638
      2017-02-08 23:12:14.942 - info: smartmeter.0 starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.2
      2017-02-08 23:12:18.133 - error: smartmeter.0 uncaught exception: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
      2017-02-08 23:12:18.143 - error: smartmeter.0 Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
      at SmlProtocol.handleMessage (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/protocols/SmlProtocol.js:48:15)
      at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialResponseTransport.js:45:46)
      at emitOne (events.js:77:13)
      at SerialPort.emit (events.js:169:7)
      at SerialPort.module.exports.raw (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/parsers.js:7:13)
      at SerialPort._emitData (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:313:18)
      at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:293:14)
      at SerialPort. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/node_modules/serialport/lib/serialport.js:306:7)
      at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17)
      2017-02-08 23:12:18.146 - warn: smartmeter.0 Exception: Error: Error while parsing SML message: Error: Unknown TL-Field 0x77 for OctetString [Offset: 533]!: Message: 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
      2017-02-08 23:12:18.659 - info: smartmeter.0 terminating
      2017-02-08 23:12:18.674 - error: host.miniyou instance system.adapter.smartmeter.0 terminated with code 0 (OK)
      2017-02-08 23:12:18.674 - info: host.miniyou Restart adapter system.adapter.smartmeter.0 because enabled
      2017-02-08 23:12:23.739 - info: host.miniyou object change system.adapter.smartmeter.0
      2017-02-08 23:12:50.922 - error: host.miniyou instance system.adapter.smartmeter.0 terminated with code 3 (Adapter disabled or invalid config)
      2017-02-08 23:12:50.923 - info: host.miniyou Do not restart adapter system.adapter.smartmeter.0 because disabled or deleted</anonymous></anonymous></anonymous> `
      Vielleicht bringt das was?!
        apollon77 last edited by
        Super, hast Du auch noch ein log als er wegen dem 0x3b gemeckert hatte?
          @a200: Also dein 0x77er Fehler ist gefunden … Die Daten behaupten das 21 Listen-Datensätze kommen ... es sind aber 22 drin. Der Parser machts halt genau und fliegt damit auf die schnauze weil halt was anderes drin ist als erwartet.
          Ich überlege mal und rede mit dem Entwickler der SML-Library ... ich würde was einbauen was das trotzdem liesst ... melde mich, kann aber paar Tage dauern weil der das akzeptieren muss und so!
            chemieka last edited by
            @a200:
            Das kann aber nach einem reboot auch passieren… Morgen kriegen wir das hin. `
            Super da bin ich dabei, bekomme heute auch meinen zweiten Lesekopf.
            • a200
              a200 last edited by
              @apollon77:
              Super, hast Du auch noch ein log als er wegen dem 0x3b gemeckert hatte? `
              Kann ich dir erst heute Abend liefern.
              Ansonsten vielen Dank für die tolle Arbeit!
                So, den 0x77er kann ich bei mir lokal auslesen …
                @a200:
                Kann ich dir erst heute Abend liefern. `
                Passt. Dann baue ich das noch ein und dann kanns weiter gehen
                • Thisoft
                  Thisoft last edited by
                  @a200:
                  Ja, hast schon Recht mit dem Reboot. Allerdings wird ja von manchen Leuten suggeriert dass Linux stabiler wäre als Windows 😉
                  Nein - Spaß beiseite. Wenn Du uns helfen kannst das noch korrekt hinzubekommen bin ich natürlich auch gerne dabei was dazuzulernen.
                    ein-bayer last edited by
                    bei läuft der Adapter seit gestern Nachmittag. Strombezug passt. Ich bekomme jedoch keine Daten vom Solarertrag. Ich hab den Lesekopf von Volkszähler.
                    Gibt es hier irgendetwas zum umstellen?
                      @Thisoft:
                      @a200:
                      Nein - Spaß beiseite. Wenn Du uns helfen kannst das noch korrekt hinzubekommen bin ich natürlich auch gerne dabei was dazuzulernen. `
                      Also bei mir hat die Anleitung von der Volkszähler-Seite funktioniert … aber Achtung da sind Unterschiede zwischen Debian und Ubuntu ... Also vorher lesen und das "richtige" machen 🙂
                      @ein-bayer: Wenns nicht aus Datenpunkt drin ist kommt es nicht als Daten. Hatten wir glaube weiter oben schon ... da wäre die einzig Sinnvolle Option per Javascript differenzen der Zählerstände zu nehmen
                        simpixo last edited by
                        Heute Nacht hat sich der Adapter verabschiedet und lief seit 2:20 bis heute Morgen nicht mehr [emoji53]
                        Mit ist dann aufgefallen das zwei gleiche Prozesse liefen! Denn im log wurde angezeigt das der serial Port nicht geöffnet werden kann
                        Ich habe einen Prozess abgeschossen! Den anderen konnte ich erst beenden als iobroker gestoppt wurde!
                        Als ich dann iobroker gestartet habe lief alles wieder wunderbar
                        Muss ich mal beobachten, woran das schon wieder lag
                        Adrian
                          @apollon
                          die Datenpunkte hab ich !! Bei inbetriebnahme gestern Nachmittag wurde der Zählerstand übertragen, seit dem nichts mehr
                            @apollon77:
                            @Thisoft:
                            @a200:
                            @ein-bayer: Wenns nicht aus Datenpunkt drin ist kommt es nicht als Daten. Hatten wir glaube weiter oben schon ... da wäre die einzig Sinnvolle Option per Javascript differenzen der Zählerstände zu nehmen `
                            Naja bei mir isses das IOBroker SD Image auf einer Raspberry liegt. Wie gesagt ich habe mit Linux nicht viel zu tun, wüste nicht mal wo die Befehle eingegeben werden müssen.
                            • Thisoft
                              Hallo chemieka,
                              ein klein wenig weiter bin ich schon;-) Um Befehle auf deinem RasPi eingeben zu können brauchst du ein sog. Terminalfenster. Ich empfehle dir das Programm "PuTTY". Um Dateien zu editieren nehme ich allerdings auch nicht das Terminal (obwohl das schon geht - ist mir aber ehrlich gesagt zu steinzeitlich), dafür nehme ich FileZilla. Installiere dir mal die beiden Programme und schau ob du weiterkommst - ansonsten frag noch mal.
                              Ich habe beide Varianten von der Volkszähler-Seite ausprobiert, sowohl .conf als auch .rules als Dateiendung - hat beides nicht funktioniert. Was mir dabei völlig schleierhaft ist -warum soll die DAtei "99-lesekopf" heißen wenn dann das Gerät als "lesekopf0" definiert wird? Und nächste Frage - wie definiert man dann den zweiten? Neue Datei? Wie muss die dann heißen? Oder nur zusätzliche Zeile in der Datei?
                              • a200
                                a200 last edited by
                                @Thisoft:
                                Hallo chemieka,
                                Ich habe beide Varianten von der Volkszähler-Seite ausprobiert, sowohl .conf als auch .rules als Dateiendung - hat beides nicht funktioniert. Was mir dabei völlig schleierhaft ist -warum soll die DAtei "99-lesekopf" heißen wenn dann das Gerät als "lesekopf0" definiert wird? Und nächste Frage - wie definiert man dann den zweiten? Neue Datei? Wie muss die dann heißen? Oder nur zusätzliche Zeile in der Datei? `
                                Schau dir das mal an http://www.raspifun.de/viewtopic.php?t=4
                                Hier ist alles step by step beschrieben. auch wie du mit putty auf dein Raspi kommst. 😉
                                Die Zahl 99 vor Lesekopf besagt nur die Reihenfolge in der die Geräte geladen werden. Willst du ein Gerät vor einem anderen laden, dann muss seine Nummer kleiner sein.
                                Was danach steht ist egal, wobei Lesekopf ist schon ganz gut. Also 99-lesekopf.rules ist schon i.O. Die Datei muss auf rules enden und sollte in etwa so aussehen:
                                SUBSYSTEMS=="usb",KERNEL=="ttyUSB*", ATTRS{serial}=="********", SYMLINK+="lesekopf0"
                                Sterne mit entsprechenden Werten ersetzen. Und dann noch````
                                sudo udevadm trigger
                                  Ich halte nochmal fest die Datei muss: 99-lesekopf.rules heißen
                                  Und in der Datei muss die Codezeile rein. Bei zwei Leseköpfen dann bestimmt zwei Zeilen oder?
                                  Dann hochladen in welchen Ordner?
                                  Und am Ende mit dem Befehl starten.
                                  • a200
                                    a200 last edited by
                                    @chemieka:
                                    Und am Ende mit dem Befehl starten. `
                                    ja. du erstellst die Datei /etc/udev/rules.d/99-lesekopf.rules
                                    Da rein schreibst du:
                                    SUBSYSTEMS=="usb",KERNEL=="ttyUSB0", ATTRS{serial}=="********", SYMLINK+="lesekopf0"
                                    SUBSYSTEMS=="usb",KERNEL=="ttyUSB1", ATTRS{serial}=="********", SYMLINK+="lesekopf1"
                                    für * die entsprechende Seriennummer. Danach aktivieren. Das sollte auch so gehen:
                                    cd /etc/udev/rules.d/
                                    sudo echo 'SUBSYSTEMS=="usb",KERNEL=="ttyUSB0", ATTRS{serial}=="********", SYMLINK+="lesekopf0"' > 99-lesekopf.rules
                                    sudo echo 'SUBSYSTEMS=="usb",KERNEL=="ttyUSB1", ATTRS{serial}=="********", SYMLINK+="lesekopf1"' >> 99-lesekopf.rules
                                    Serial nicht vergessen!
                                      Das mit dem Serial ist klar.
                                      Hast du nun die erste oder zweite Variante?
                                      Würde sonst die erste Variante wählen und dann starten.
                                      Wie bekomme ich raus obs geklappt hat?
                                      • a200
                                        a200 last edited by
                                        @chemieka:
                                        Wie bekomme ich raus obs geklappt hat? `
                                        was meinst du? mit zwei Varianten?
                                        Das sind die Befehle:
                                        1. wechselt ins /etc/udev/rules.d/ Verzeichnis
                                        2. Erzeugt die Datei 99-lesekopf.rules mit dem Inhalt SUBSYSTEMS=="usb",KERNEL=="ttyUSB0", ATTRS{serial}=="********", SYMLINK+="lesekopf0" (Anpassen!!!)
                                        3. Fügt in die Datei 99-lesekopf.rules den Inhalt SUBSYSTEMS=="usb",KERNEL=="ttyUSB1", ATTRS{serial}=="********", SYMLINK+="lesekopf1" ein (Anpassen!!!)
                                        4. restartet udevadm
                                          @ein-bayer:
                                          @apollon
                                          die Datenpunkte hab ich !! Bei inbetriebnahme gestern Nachmittag wurde der Zählerstand übertragen, seit dem nichts mehr `
                                          Was sagt log? Andere Werte werden aktualisiert?
                                            @apollo
                                            ich hab jetzt nochmals nachgesehen und überlegt. ich hab teilweise auch den falschen wert beobachtet.
                                            Der Wert 1-0:16_7_0255.value war für mich der Wert den ich beziehe. Dem ist ja nicht so , das ist ein rechnerischer wert zwischen Bezug und Ertrag. Die Werte 1-0:2_8_2255.value und 1-0:1_8_2*255.value haben ihren anfangswert von 0, da kommt auch nix. Da vermute ich , wie du ja auch schon vermutet hast, das die nicht übergeben werden, eigentlich schade da ich dann ja kein Diagramm der aktuellen Einspeisung machen kann oder?
                                            Die Gesamtwerte Bezug und Verbrauch aktualisieren sich.
                                            Was ist eigentlich der Unterschied zwischen :
                                            1-0:2_8_1255.value und 1-0:2_8_0255.value ?
                                            81.1k
                                            3625
                                            2335828
