    4. eBus Adapter Vaillant
    • Glasfaser
      Glasfaser @Cino last edited by
      @cino sagte in eBus Adapter Vaillant:
      @glasfaser für den 700 er müsste er trotzdem die config finden.
      Die address 15 fehlt aber laut seiner ebusctl info Ausgabe dafür .
        floret88 @Glasfaser last edited by
        @glasfaser So - ich bin wieder da, frisches Raspbian (Buster) aufgesetzt und nur ebusd installiert.
        Leider noch immer dasselbe.
        Vllt. hilft dies, um den Fehler auf die schliche zu kommen:
        pi@raspberrypi:~ $ sudo ebusd --scanconfig=full --logfile=/var/log/ebusd.log --loglevel=debug -f
        2021-08-25 15:56:51.744 [main notice] ebusd 21.2.v21.2-36-gfb5ab14 started with full scan on device /dev/ttyUSB0
        2021-08-25 15:56:51.744 [main info] loading configuration files from http://ebusd.eu/config/
        2021-08-25 15:56:51.883 [main info] reading templates /
        2021-08-25 15:56:52.022 [main info] read templates in /
        2021-08-25 15:56:52.022 [main info] reading file memory.csv
        2021-08-25 15:56:52.157 [main info] successfully read file memory.csv
        2021-08-25 15:56:52.157 [main info] reading file broadcast.csv
        2021-08-25 15:56:52.297 [main info] successfully read file broadcast.csv
        2021-08-25 15:56:52.297 [main info] read config files
        2021-08-25 15:56:52.300 [bus error] unable to open /dev/ttyUSB0: ERR: generic device error
        2021-08-25 15:56:52.301 [bus notice] bus started with own address 31/36
        2021-08-25 15:56:52.301 [bus notice] device invalid
        2021-08-25 15:56:52.301 [main info] registering data handlers
        2021-08-25 15:56:52.301 [main info] registered data handlers
        2021-08-25 15:56:57.302 [bus error] unable to open /dev/ttyUSB0: ERR: generic device error
        2021-08-25 15:56:57.302 [bus notice] device invalid
        PS: ebusctl sagt noch immer nicht mehr
        pi@raspberrypi:~ $ ebusctl info
        version: ebusd 21.2.v21.2-36-gfb5ab14
        signal: acquired
        symbol rate: 23
        max symbol rate: 105
        reconnects: 0
        masters: 4
        conditional: 0
        poll: 0
        update: 4
        address 03: master #11
        address 08: slave #11
        address 10: master #2
        address 26: slave
        address 31: master #8, ebusd
        address 36: slave #8, ebusd
        address 71: master #9
        address 76: slave #9
        • Glasfaser
          Glasfaser @floret88 last edited by
          @floret88 sagte in eBus Adapter Vaillant:
          das sieht doch erstmal gut aus .
          Aber ab hier :
            @glasfaser Ja, und ich weis nicht, woher das kommt - in der Config ist eindeutig der Esera drinnen
            • Glasfaser
              Glasfaser @floret88 last edited by Glasfaser
              @floret88
              du hast aber das in der Konsole eigegeben :
              das ist aber nicht die Config
              und deshalb /dev/ttyUSB0
                floret88 @Glasfaser last edited by floret88
                @glasfaser Sollte dies der Config gleichen?
                Einen Moment bitte.
                Hier kommt gar nichts raus:
                pi@raspberrypi:~ $ service ebusd status
                * ebusd.service - ebusd, the daemon for communication with eBUS heating systems.
                   Loaded: loaded (/etc/systemd/system/ebusd.service; enabled; vendor preset: enabled)
                   Active: active (running) since Wed 2021-08-25 17:21:28 CEST; 48s ago
                  Process: 661 ExecStart=/usr/bin/ebusd $EBUSD_OPTS (code=exited, status=0/SUCCESS)
                 Main PID: 662 (ebusd)
                    Tasks: 4 (limit: 4915)
                   CGroup: /system.slice/ebusd.service
                           `-662 /usr/bin/ebusd --scanconfig=full -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --configpath=http://ebusd.eu/config/
                Aug 25 17:21:28 raspberrypi systemd[1]: Starting ebusd, the daemon for communication with eBUS heating systems....
                Aug 25 17:21:28 raspberrypi systemd[1]: Started ebusd, the daemon for communication with eBUS heating systems..
                pi@raspberrypi:~ $ sudo ebusd --scanconfig=full -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --configpath=http://ebusd.eu/config/
                pi@raspberrypi:~ $
                • Glasfaser
                  Glasfaser last edited by Glasfaser
                  @floret88
                  ebusctl info
                    @glasfaser immer noch das gleiche
                    Glasfaser 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      @floret88
                      Das ist bei mir schon laaaange her das ich es eingerichtet habe ..
                      sieht eigentlich gleich aus :
                      root@DietPi:~# service ebusd status
                      ● ebusd.service - ebusd, the daemon for communication with eBUS heati
                      ng systems.
                      abled)
                         Active: active (running) since Mon 2021-08-16 00:12:48 CEST; 1 wee
                      ks 2 days ago
                        Process: 285 ExecStart=/usr/bin/ebusd $EBUSD_OPTS (code=exited, status=0/SUCCE
                      SS)
                       Main PID: 297 (ebusd)
                          Tasks: 5 (limit: 566)
                         Memory: 4.6M
                                 └─297 /usr/bin/ebusd -d /dev/ttyUSB0 --httpport=8889 --scanconfig=ful
                      l --enablehex --latency=0 --configpath=/etc/ebusd -l /var/log/ebusd.log
                      Aug 16 00:12:47 DietPi systemd[1]: Starting ebusd, the daemon for communication
                      Aug 16 00:12:48 DietPi systemd[1]: Started ebusd, the daemon for communication w
                      • Glasfaser
                        @floret88
                        Zeige nochmal den Inhalt :
                        nano /etc/default/ebusd
                          @glasfaser
                          # /etc/default/ebusd:
                          # config file for ebusd service.
                          # Options to pass to ebusd (run "ebusd -?" for more info):
                          #EBUSD_OPTS="--scanconfig"
                          #EBUSD_OPTS="--scanconfig=full --enablehex -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --receivetimeout=100000 --port=8888 --logfile=/var/log/ebusd.log --loglevel d$
                          EBUSD_OPTS="--scanconfig=full -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --configpath=http://ebusd.eu/config/"
                          # MULTIPLE EBUSD INSTANCES WITH SYSV
                          # In order to run multiple ebusd instances on a SysV enabled system, simply
                          # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
                          # use a number as suffix for all EBUSD_OPTS settings. That number will then be
                          # taken as additional "instance" parameter to the init.d script in order to
                          # start/stop an individual ebusd instance instead of all instances.
                          # Example: (uncomment the EBUSD_OPTS above)
                          #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
                          #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
                          #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
                          # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
                          # In order to run muiltiple ebusd instances on a systemd enabled system, just
                          # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
                          # with a different name (e.g. ebusd-2.service), remove the line starting with
                          # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
                          # particular ebusd instance.
                          • Glasfaser
                            @floret88
                            Letzter Versuch ... mehr weiß ich auch nicht .
                            EBUSD_OPTS="--scanconfig=full --enablehex -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --httpport 8890 --configpath=http://ebusd.eu/config/"
                            • Glasfaser
                              Glasfaser @Glasfaser last edited by Glasfaser
                              @glasfaser sagte in eBus Adapter Vaillant:
                              usb-ESERA
                              Stop den habe ich auch .... aber auf /dev/ttyUSB0
                              Die Konfig wäre dann so bei mir und funktioniert auch :
                              EBUSD_OPTS="-d /dev/ttyUSB0 --httpport=8889 --scanconfig=full --enablehex --latency=0 --configpath=http://ebusd.eu/config/ "
                                @glasfaser Ich glaube, ich gebe es für den Moment auf, egal ob mit lokalen Config Dateien (mit root Rechten oder auch pi von Github gezogen) oder auch Online - es will nicht funktionieren.
                                Ich habe bei Github einen Issue aufgemacht (siehe hier: https://github.com/john30/ebusd-configuration/issues/229) und warte dort auch auf eine Rückmeldung.
                                Fakt ist, die Verbindung von ebus zur Heizung funktioniert, aber ich bekomme nur "Nonsense" an Daten weil nicht decodierbar.
                                Vielen Dank dennoch an alle, die versucht haben mir zu helfen.
                                Falls noch jemand weitere Ideen und Gedankensprünge hat, bin ich jederzeit froh über Euren Input.
                                LG
                                hr-automation created this issue in john30/ebusd-configuration
                                closed Missing config - Config not readable (VWF 197/4) #229
                                  floret88 @floret88 last edited by floret88
                                  @floret88 Des Weiteren wollte ich Euch noch folgendes zeigen, um meine Aussagen zu verifizieren.
                                  Es sieht gut aus, findet aber keine "richtige" Config Datei 🙂
                                  Kann es sein, dass ich einfach eine nicht unterstützte Software bzw. Hardware seitens Vaillant habe?
                                  pi@raspberrypi:~ $ sudo ebusd --scanconfig=full --logfile=/var/log/ebusd.log --configpath=/etc/ebusd --loglevel=debug -f
                                  2021-08-26 12:27:26.977 [main notice] ebusd 21.2.v21.2 started with full scan on device /dev/ttyUSB0
                                  2021-08-26 12:27:26.977 [main info] loading configuration files from /etc/ebusd
                                  2021-08-26 12:27:26.977 [main info] reading templates /
                                  2021-08-26 12:27:26.978 [main info] read templates in /
                                  2021-08-26 12:27:26.979 [main info] reading file broadcast.csv
                                  2021-08-26 12:27:26.980 [main info] successfully read file broadcast.csv
                                  2021-08-26 12:27:26.980 [main info] reading file memory.csv
                                  2021-08-26 12:27:26.981 [main info] successfully read file memory.csv
                                  2021-08-26 12:27:26.981 [main info] read config files
                                  2021-08-26 12:27:26.988 [bus notice] bus started with own address 31/36
                                  2021-08-26 12:27:26.989 [main info] registering data handlers
                                  2021-08-26 12:27:26.989 [main info] registered data handlers
                                  2021-08-26 12:27:26.991 [bus debug] ERR: SYN received during no signal, switching to ready
                                  2021-08-26 12:27:26.992 [bus notice] signal acquired
                                  2021-08-26 12:27:29.199 [bus notice] new master 10, master count 2
                                  2021-08-26 12:27:29.259 [bus notice] new master 03, master count 3
                                  2021-08-26 12:27:29.259 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:29.259 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:29.526 [bus notice] new master 71, master count 4
                                  2021-08-26 12:27:29.526 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:29.526 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:29.792 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:29.792 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:30.089 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:27:30.089 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:27:30.381 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:30.381 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:30.647 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:30.647 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:30.914 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:30.914 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:31.003 [bus notice] max. symbols per second: 103
                                  2021-08-26 12:27:32.398 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:32.398 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:32.643 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:32.643 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:32.888 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:32.888 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:33.132 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:33.133 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:36.989 [main debug] performing regular tasks
                                  2021-08-26 12:27:36.989 [main notice] starting initial full scan
                                  2021-08-26 12:27:36.989 [bus info] scan 02 cmd: 3102070400
                                  2021-08-26 12:27:36.990 [bus debug] start request 31
                                  2021-08-26 12:27:36.990 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:39.175 [bus debug] arbitration lost
                                  2021-08-26 12:27:39.176 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:39.260 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:39.261 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:39.263 [bus debug] start request 31
                                  2021-08-26 12:27:39.263 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:39.441 [bus debug] arbitration lost
                                  2021-08-26 12:27:39.441 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:39.527 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:39.528 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:39.529 [bus debug] start request 31
                                  2021-08-26 12:27:39.529 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:39.707 [bus debug] arbitration lost
                                  2021-08-26 12:27:39.707 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:39.793 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:39.793 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:39.796 [bus debug] start request 31
                                  2021-08-26 12:27:39.796 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:39.973 [bus debug] arbitration lost
                                  2021-08-26 12:27:39.973 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:39.974 [bus info] scan 04 cmd: 3104070400
                                  2021-08-26 12:27:40.090 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:27:40.090 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:27:40.092 [bus debug] start request 31
                                  2021-08-26 12:27:40.092 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:40.270 [bus debug] arbitration lost
                                  2021-08-26 12:27:40.270 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:40.383 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:40.384 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:40.387 [bus debug] start request 31
                                  2021-08-26 12:27:40.387 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:40.563 [bus debug] arbitration lost
                                  2021-08-26 12:27:40.564 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:40.648 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:40.649 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:40.650 [bus debug] start request 31
                                  2021-08-26 12:27:40.651 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:40.828 [bus debug] arbitration lost
                                  2021-08-26 12:27:40.829 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:40.915 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:40.916 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:40.918 [bus debug] start request 31
                                  2021-08-26 12:27:40.918 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:42.336 [bus debug] arbitration lost
                                  2021-08-26 12:27:42.337 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:42.337 [bus info] scan 05 cmd: 3105070400
                                  2021-08-26 12:27:42.443 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:42.443 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:42.446 [bus debug] start request 31
                                  2021-08-26 12:27:42.446 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:42.623 [bus debug] arbitration lost
                                  2021-08-26 12:27:42.624 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:42.688 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:42.689 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:42.692 [bus debug] start request 31
                                  2021-08-26 12:27:42.692 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:42.868 [bus debug] arbitration lost
                                  2021-08-26 12:27:42.868 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:42.933 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:42.934 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:42.935 [bus debug] start request 31
                                  2021-08-26 12:27:42.936 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:43.113 [bus debug] arbitration lost
                                  2021-08-26 12:27:43.113 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:43.178 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:43.178 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:43.179 [bus debug] start request 31
                                  2021-08-26 12:27:43.179 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:46.990 [main debug] performing regular tasks
                                  2021-08-26 12:27:46.990 [bus info] scan 08 cmd: 3108070400
                                  2021-08-26 12:27:49.220 [bus debug] arbitration lost
                                  2021-08-26 12:27:49.220 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:49.220 [bus info] scan 06 cmd: 3106070400
                                  2021-08-26 12:27:49.306 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:49.306 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:49.309 [bus debug] start request 31
                                  2021-08-26 12:27:49.309 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:49.486 [bus debug] arbitration lost
                                  2021-08-26 12:27:49.486 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:49.572 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:49.572 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:49.574 [bus debug] start request 31
                                  2021-08-26 12:27:49.574 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:49.753 [bus debug] arbitration lost
                                  2021-08-26 12:27:49.753 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:49.839 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:49.839 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:49.840 [bus debug] start request 31
                                  2021-08-26 12:27:49.840 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:50.019 [bus debug] arbitration lost
                                  2021-08-26 12:27:50.019 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:50.135 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:27:50.135 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:27:50.136 [bus debug] start request 31
                                  2021-08-26 12:27:50.136 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:50.314 [bus debug] arbitration lost
                                  2021-08-26 12:27:50.315 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:50.427 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:50.428 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:27:50.429 [bus debug] start request 31
                                  2021-08-26 12:27:50.429 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:50.607 [bus debug] arbitration lost
                                  2021-08-26 12:27:50.607 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:50.693 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:50.694 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:27:50.694 [bus debug] start request 31
                                  2021-08-26 12:27:50.694 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:50.873 [bus debug] arbitration lost
                                  2021-08-26 12:27:50.873 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:50.959 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:50.960 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:27:50.962 [bus debug] start request 31
                                  2021-08-26 12:27:50.962 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:51.007 [bus notice] max. symbols per second: 110
                                  2021-08-26 12:27:52.381 [bus debug] arbitration lost
                                  2021-08-26 12:27:52.381 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:52.381 [main error] scan config 08: ERR: arbitration lost
                                  2021-08-26 12:27:52.488 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:52.488 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:27:52.490 [bus debug] start request 31
                                  2021-08-26 12:27:52.490 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:52.669 [bus debug] arbitration lost
                                  2021-08-26 12:27:52.669 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:52.669 [bus info] scan 08 cmd: 3108070400
                                  2021-08-26 12:27:52.734 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:52.734 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:27:52.736 [bus debug] start request 31
                                  2021-08-26 12:27:52.736 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:52.914 [bus debug] arbitration lost
                                  2021-08-26 12:27:52.914 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:52.979 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:52.979 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:27:52.981 [bus debug] start request 31
                                  2021-08-26 12:27:52.981 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:53.158 [bus debug] arbitration lost
                                  2021-08-26 12:27:53.158 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:53.223 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:53.223 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:27:53.225 [bus debug] start request 31
                                  2021-08-26 12:27:53.225 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:54.382 [main debug] performing regular tasks
                                  2021-08-26 12:27:54.382 [bus info] scan 15 cmd: 3115070400
                                  2021-08-26 12:27:59.264 [bus debug] arbitration lost
                                  2021-08-26 12:27:59.264 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:59.351 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:59.351 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:27:59.353 [bus debug] start request 31
                                  2021-08-26 12:27:59.353 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:59.531 [bus debug] arbitration lost
                                  2021-08-26 12:27:59.531 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:27:59.617 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:59.617 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:27:59.618 [bus debug] start request 31
                                  2021-08-26 12:27:59.619 [bus debug] arbitration start with 31
                                  2021-08-26 12:27:59.799 [bus debug] arbitration lost
                                  2021-08-26 12:27:59.799 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:27:59.799 [bus info] scan 09 cmd: 3109070400
                                  2021-08-26 12:27:59.884 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:59.884 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:27:59.886 [bus debug] start request 31
                                  2021-08-26 12:27:59.886 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:00.064 [bus debug] arbitration lost
                                  2021-08-26 12:28:00.064 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:00.182 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
                                  2021-08-26 12:28:00.182 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
                                  2021-08-26 12:28:00.185 [bus debug] start request 31
                                  2021-08-26 12:28:00.185 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:00.361 [bus debug] arbitration lost
                                  2021-08-26 12:28:00.361 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:00.473 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:00.473 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:00.475 [bus debug] start request 31
                                  2021-08-26 12:28:00.475 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:00.654 [bus debug] arbitration lost
                                  2021-08-26 12:28:00.654 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:00.739 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:00.739 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:00.741 [bus debug] start request 31
                                  2021-08-26 12:28:00.741 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:00.918 [bus debug] arbitration lost
                                  2021-08-26 12:28:00.918 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:01.005 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:01.005 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:01.006 [bus debug] start request 31
                                  2021-08-26 12:28:01.006 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:02.426 [bus debug] arbitration lost
                                  2021-08-26 12:28:02.426 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:02.427 [main error] scan config 15: ERR: arbitration lost
                                  2021-08-26 12:28:02.533 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:02.533 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:02.534 [bus debug] start request 31
                                  2021-08-26 12:28:02.534 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:02.714 [bus debug] arbitration lost
                                  2021-08-26 12:28:02.714 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:02.778 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:02.778 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:02.780 [bus debug] start request 31
                                  2021-08-26 12:28:02.780 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:02.958 [bus debug] arbitration lost
                                  2021-08-26 12:28:02.958 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:02.958 [bus info] scan 0a cmd: 310a070400
                                  2021-08-26 12:28:03.023 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:03.023 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:03.025 [bus debug] start request 31
                                  2021-08-26 12:28:03.026 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:03.203 [bus debug] arbitration lost
                                  2021-08-26 12:28:03.203 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:03.268 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:03.268 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:03.271 [bus debug] start request 31
                                  2021-08-26 12:28:03.271 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:04.427 [main debug] performing regular tasks
                                  2021-08-26 12:28:04.427 [bus info] scan 26 cmd: 3126070400
                                  2021-08-26 12:28:09.316 [bus debug] arbitration lost
                                  2021-08-26 12:28:09.316 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:09.403 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:09.403 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:09.405 [bus debug] start request 31
                                  2021-08-26 12:28:09.405 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:09.582 [bus debug] arbitration lost
                                  2021-08-26 12:28:09.582 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:09.668 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:09.668 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:09.671 [bus debug] start request 31
                                  2021-08-26 12:28:09.671 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:09.849 [bus debug] arbitration lost
                                  2021-08-26 12:28:09.849 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:09.935 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:09.936 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:09.938 [bus debug] start request 31
                                  2021-08-26 12:28:09.939 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:10.115 [bus debug] arbitration lost
                                  2021-08-26 12:28:10.115 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:10.144 [update info] received BC cmd: 10feb505025c00
                                  2021-08-26 12:28:10.144 [update notice] received unknown BC cmd: 10feb505025c00
                                  2021-08-26 12:28:10.146 [bus debug] start request 31
                                  2021-08-26 12:28:10.146 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:10.325 [bus debug] arbitration lost
                                  2021-08-26 12:28:10.325 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:10.325 [bus info] scan 0b cmd: 310b070400
                                  2021-08-26 12:28:10.442 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:28:10.443 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:28:10.444 [bus debug] start request 31
                                  2021-08-26 12:28:10.445 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:10.621 [bus debug] arbitration lost
                                  2021-08-26 12:28:10.622 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:10.733 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:10.734 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:10.735 [bus debug] start request 31
                                  2021-08-26 12:28:10.735 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:10.914 [bus debug] arbitration lost
                                  2021-08-26 12:28:10.914 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:11.001 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:11.001 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:11.004 [bus debug] start request 31
                                  2021-08-26 12:28:11.005 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:11.182 [bus debug] arbitration lost
                                  2021-08-26 12:28:11.182 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:11.182 [main error] scan config 26: ERR: arbitration lost
                                  2021-08-26 12:28:11.247 [update info] received MS cmd: 1008b507020900 / 029f02
                                  2021-08-26 12:28:11.247 [update notice] received unknown MS cmd: 1008b507020900 / 029f02
                                  2021-08-26 12:28:11.249 [bus debug] start request 31
                                  2021-08-26 12:28:11.249 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:11.426 [bus debug] arbitration lost
                                  2021-08-26 12:28:11.426 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:11.513 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:11.513 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:11.514 [bus debug] start request 31
                                  2021-08-26 12:28:11.515 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:11.693 [bus debug] arbitration lost
                                  2021-08-26 12:28:11.693 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:11.781 [update info] received MS cmd: 1008b5040100 / 0a03122812260804210013
                                  2021-08-26 12:28:11.781 [update notice] received unknown MS cmd: 1008b5040100 / 0a03122812260804210013
                                  2021-08-26 12:28:11.784 [bus debug] start request 31
                                  2021-08-26 12:28:11.784 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:11.962 [bus debug] arbitration lost
                                  2021-08-26 12:28:11.962 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:11.962 [bus info] scan 0c cmd: 310c070400
                                  2021-08-26 12:28:12.017 [update info] received BC cmd: 10feb516080010281226080421
                                  2021-08-26 12:28:12.017 [update notice] received unknown BC cmd: 10feb516080010281226080421
                                  2021-08-26 12:28:12.018 [bus debug] start request 31
                                  2021-08-26 12:28:12.018 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:12.197 [bus debug] arbitration lost
                                  2021-08-26 12:28:12.197 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:12.283 [update info] received MS cmd: 1008b5110100 / 09030214000000000100
                                  2021-08-26 12:28:12.283 [update notice] received unknown MS cmd: 1008b5110100 / 09030214000000000100
                                  2021-08-26 12:28:12.284 [bus debug] start request 31
                                  2021-08-26 12:28:12.284 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:12.463 [bus debug] arbitration lost
                                  2021-08-26 12:28:12.463 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:12.529 [update info] received MS cmd: 1076b51303040d00 / 02ffff
                                  2021-08-26 12:28:12.529 [update notice] received unknown MS cmd: 1076b51303040d00 / 02ffff
                                  2021-08-26 12:28:12.530 [bus debug] start request 31
                                  2021-08-26 12:28:12.530 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:12.708 [bus debug] arbitration lost
                                  2021-08-26 12:28:12.708 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:12.815 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:12.815 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:12.816 [bus debug] start request 31
                                  2021-08-26 12:28:12.816 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:12.995 [bus debug] arbitration lost
                                  2021-08-26 12:28:12.995 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:12.995 [bus info] scan 0d cmd: 310d070400
                                  2021-08-26 12:28:13.060 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:13.060 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:13.062 [bus debug] start request 31
                                  2021-08-26 12:28:13.062 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:13.182 [main debug] performing regular tasks
                                  2021-08-26 12:28:13.182 [bus info] scan 76 cmd: 3176070400
                                  2021-08-26 12:28:13.239 [bus debug] arbitration lost
                                  2021-08-26 12:28:13.240 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:13.303 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:13.304 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:13.305 [bus debug] start request 31
                                  2021-08-26 12:28:13.306 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:13.483 [bus debug] arbitration lost
                                  2021-08-26 12:28:13.484 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:13.517 [update info] received BC cmd: 10feb51603010013
                                  2021-08-26 12:28:13.518 [update notice] received unknown BC cmd: 10feb51603010013
                                  2021-08-26 12:28:13.519 [bus debug] start request 31
                                  2021-08-26 12:28:13.519 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:13.697 [bus debug] arbitration lost
                                  2021-08-26 12:28:13.697 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:13.763 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:13.764 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:13.766 [bus debug] start request 31
                                  2021-08-26 12:28:13.766 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:19.343 [bus debug] arbitration lost
                                  2021-08-26 12:28:19.344 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:19.430 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:19.431 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:19.432 [bus debug] start request 31
                                  2021-08-26 12:28:19.432 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:19.610 [bus debug] arbitration lost
                                  2021-08-26 12:28:19.610 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:19.697 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:19.698 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:19.699 [bus debug] start request 31
                                  2021-08-26 12:28:19.699 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:19.877 [bus debug] arbitration lost
                                  2021-08-26 12:28:19.878 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:19.963 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:19.964 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:19.967 [bus debug] start request 31
                                  2021-08-26 12:28:19.967 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:20.145 [bus debug] arbitration lost
                                  2021-08-26 12:28:20.146 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:20.147 [bus info] scan 0e cmd: 310e070400
                                  2021-08-26 12:28:20.262 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:28:20.263 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
                                  2021-08-26 12:28:20.266 [bus debug] start request 31
                                  2021-08-26 12:28:20.266 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:20.441 [bus debug] arbitration lost
                                  2021-08-26 12:28:20.442 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:20.442 [main error] scan config 76: ERR: arbitration lost
                                  2021-08-26 12:28:20.554 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:20.555 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:20.558 [bus debug] start request 31
                                  2021-08-26 12:28:20.558 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:20.735 [bus debug] arbitration lost
                                  2021-08-26 12:28:20.735 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:20.822 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:20.822 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:20.824 [bus debug] start request 31
                                  2021-08-26 12:28:20.824 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:21.002 [bus debug] arbitration lost
                                  2021-08-26 12:28:21.002 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:21.089 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:21.089 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:21.091 [bus debug] start request 31
                                  2021-08-26 12:28:21.091 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:22.443 [main debug] performing regular tasks
                                  2021-08-26 12:28:22.510 [bus debug] arbitration lost
                                  2021-08-26 12:28:22.510 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:22.617 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:22.617 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:22.619 [bus debug] start request 31
                                  2021-08-26 12:28:22.619 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:22.798 [bus debug] arbitration lost
                                  2021-08-26 12:28:22.798 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:22.798 [bus info] scan 12 cmd: 3112070400
                                  2021-08-26 12:28:22.863 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:22.863 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:22.865 [bus debug] start request 31
                                  2021-08-26 12:28:22.865 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:23.043 [bus debug] arbitration lost
                                  2021-08-26 12:28:23.043 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:23.108 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:23.108 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:23.111 [bus debug] start request 31
                                  2021-08-26 12:28:23.111 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:23.288 [bus debug] arbitration lost
                                  2021-08-26 12:28:23.288 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:23.353 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:23.353 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:23.354 [bus debug] start request 31
                                  2021-08-26 12:28:23.354 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:29.403 [bus debug] arbitration lost
                                  2021-08-26 12:28:29.403 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:29.488 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:29.488 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:29.489 [bus debug] start request 31
                                  2021-08-26 12:28:29.489 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:29.668 [bus debug] arbitration lost
                                  2021-08-26 12:28:29.668 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:29.668 [bus info] scan 14 cmd: 3114070400
                                  2021-08-26 12:28:29.754 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:29.754 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:29.756 [bus debug] start request 31
                                  2021-08-26 12:28:29.756 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:29.936 [bus debug] arbitration lost
                                  2021-08-26 12:28:29.936 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:30.021 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:30.021 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:30.022 [bus debug] start request 31
                                  2021-08-26 12:28:30.022 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:30.201 [bus debug] arbitration lost
                                  2021-08-26 12:28:30.201 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:30.318 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:28:30.318 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
                                  2021-08-26 12:28:30.320 [bus debug] start request 31
                                  2021-08-26 12:28:30.320 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:30.498 [bus debug] arbitration lost
                                  2021-08-26 12:28:30.499 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:30.611 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:30.612 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:30.613 [bus debug] start request 31
                                  2021-08-26 12:28:30.613 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:30.791 [bus debug] arbitration lost
                                  2021-08-26 12:28:30.791 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:30.792 [bus info] scan 15 cmd: 3115070400
                                  2021-08-26 12:28:30.879 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:30.880 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:30.882 [bus debug] start request 31
                                  2021-08-26 12:28:30.882 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:31.059 [bus debug] arbitration lost
                                  2021-08-26 12:28:31.059 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:31.145 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:31.145 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:31.148 [bus debug] start request 31
                                  2021-08-26 12:28:31.148 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:32.444 [main debug] performing regular tasks
                                  2021-08-26 12:28:32.444 [bus info] scan 08 cmd: 3108070400
                                  2021-08-26 12:28:32.526 [bus debug] arbitration lost
                                  2021-08-26 12:28:32.526 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:32.633 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:32.633 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:32.634 [bus debug] start request 31
                                  2021-08-26 12:28:32.635 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:32.813 [bus debug] arbitration lost
                                  2021-08-26 12:28:32.813 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:32.878 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:32.878 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:32.880 [bus debug] start request 31
                                  2021-08-26 12:28:32.880 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:33.058 [bus debug] arbitration lost
                                  2021-08-26 12:28:33.058 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:33.122 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:33.122 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:33.124 [bus debug] start request 31
                                  2021-08-26 12:28:33.124 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:33.302 [bus debug] arbitration lost
                                  2021-08-26 12:28:33.302 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:33.367 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:33.367 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:33.369 [bus debug] start request 31
                                  2021-08-26 12:28:33.369 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:39.419 [bus debug] arbitration lost
                                  2021-08-26 12:28:39.419 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:39.419 [bus info] scan 16 cmd: 3116070400
                                  2021-08-26 12:28:39.505 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:39.505 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:39.508 [bus debug] start request 31
                                  2021-08-26 12:28:39.508 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:39.685 [bus debug] arbitration lost
                                  2021-08-26 12:28:39.685 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:39.771 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:39.771 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:39.773 [bus debug] start request 31
                                  2021-08-26 12:28:39.773 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:39.952 [bus debug] arbitration lost
                                  2021-08-26 12:28:39.952 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:40.038 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:40.038 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
                                  2021-08-26 12:28:40.041 [bus debug] start request 31
                                  2021-08-26 12:28:40.041 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:40.218 [bus debug] arbitration lost
                                  2021-08-26 12:28:40.218 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:40.218 [main error] scan config 08: ERR: arbitration lost
                                  2021-08-26 12:28:40.334 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:28:40.334 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:28:40.335 [bus debug] start request 31
                                  2021-08-26 12:28:40.335 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:40.514 [bus debug] arbitration lost
                                  2021-08-26 12:28:40.514 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:40.627 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:40.627 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:40.628 [bus debug] start request 31
                                  2021-08-26 12:28:40.628 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:40.807 [bus debug] arbitration lost
                                  2021-08-26 12:28:40.807 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:40.893 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:40.893 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:40.895 [bus debug] start request 31
                                  2021-08-26 12:28:40.895 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:41.072 [bus debug] arbitration lost
                                  2021-08-26 12:28:41.072 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:41.072 [bus info] scan 18 cmd: 3118070400
                                  2021-08-26 12:28:41.159 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:41.159 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:41.161 [bus debug] start request 31
                                  2021-08-26 12:28:41.161 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:42.218 [main debug] performing regular tasks
                                  2021-08-26 12:28:42.219 [bus info] scan 15 cmd: 3115070400
                                  2021-08-26 12:28:42.579 [bus debug] arbitration lost
                                  2021-08-26 12:28:42.579 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:42.686 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:42.687 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:42.689 [bus debug] start request 31
                                  2021-08-26 12:28:42.689 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:42.866 [bus debug] arbitration lost
                                  2021-08-26 12:28:42.866 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:42.931 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:42.931 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:42.933 [bus debug] start request 31
                                  2021-08-26 12:28:42.933 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:43.111 [bus debug] arbitration lost
                                  2021-08-26 12:28:43.111 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:43.176 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:43.176 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:43.178 [bus debug] start request 31
                                  2021-08-26 12:28:43.178 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:43.356 [bus debug] arbitration lost
                                  2021-08-26 12:28:43.356 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:43.421 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:43.421 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:43.424 [bus debug] start request 31
                                  2021-08-26 12:28:43.424 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:49.471 [bus debug] arbitration lost
                                  2021-08-26 12:28:49.471 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:49.557 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:49.557 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:49.560 [bus debug] start request 31
                                  2021-08-26 12:28:49.560 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:49.738 [bus debug] arbitration lost
                                  2021-08-26 12:28:49.738 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:49.824 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:49.824 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:49.825 [bus debug] start request 31
                                  2021-08-26 12:28:49.826 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:50.005 [bus debug] arbitration lost
                                  2021-08-26 12:28:50.005 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:50.005 [bus info] scan 19 cmd: 3119070400
                                  2021-08-26 12:28:50.090 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:28:50.090 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:28:50.091 [bus debug] start request 31
                                  2021-08-26 12:28:50.091 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:50.270 [bus debug] arbitration lost
                                  2021-08-26 12:28:50.270 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:50.270 [main error] scan config 15: ERR: arbitration lost
                                  2021-08-26 12:28:50.387 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:28:50.387 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:28:50.390 [bus debug] start request 31
                                  2021-08-26 12:28:50.390 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:50.567 [bus debug] arbitration lost
                                  2021-08-26 12:28:50.567 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:50.679 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:50.679 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:28:50.680 [bus debug] start request 31
                                  2021-08-26 12:28:50.680 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:50.859 [bus debug] arbitration lost
                                  2021-08-26 12:28:50.859 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:50.945 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:50.945 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:28:50.948 [bus debug] start request 31
                                  2021-08-26 12:28:50.948 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:51.035 [bus notice] max. symbols per second: 111
                                  2021-08-26 12:28:51.125 [bus debug] arbitration lost
                                  2021-08-26 12:28:51.125 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:51.212 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:51.212 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:28:51.213 [bus debug] start request 31
                                  2021-08-26 12:28:51.213 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:52.271 [main debug] performing regular tasks
                                  2021-08-26 12:28:52.271 [bus info] scan 26 cmd: 3126070400
                                  2021-08-26 12:28:52.591 [bus debug] arbitration lost
                                  2021-08-26 12:28:52.591 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:28:52.591 [bus info] scan 1a cmd: 311a070400
                                  2021-08-26 12:28:52.698 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:52.698 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:28:52.700 [bus debug] start request 31
                                  2021-08-26 12:28:52.700 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:52.879 [bus debug] arbitration lost
                                  2021-08-26 12:28:52.879 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:52.944 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:52.944 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:28:52.946 [bus debug] start request 31
                                  2021-08-26 12:28:52.946 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:53.123 [bus debug] arbitration lost
                                  2021-08-26 12:28:53.123 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:53.188 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:53.188 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:28:53.189 [bus debug] start request 31
                                  2021-08-26 12:28:53.189 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:53.367 [bus debug] arbitration lost
                                  2021-08-26 12:28:53.368 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:53.432 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:53.433 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:28:53.435 [bus debug] start request 31
                                  2021-08-26 12:28:53.435 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:59.483 [bus debug] arbitration lost
                                  2021-08-26 12:28:59.484 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:59.570 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:59.571 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:28:59.573 [bus debug] start request 31
                                  2021-08-26 12:28:59.573 [bus debug] arbitration start with 31
                                  2021-08-26 12:28:59.751 [bus debug] arbitration lost
                                  2021-08-26 12:28:59.751 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:28:59.837 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:59.838 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:28:59.839 [bus debug] start request 31
                                  2021-08-26 12:28:59.839 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:00.018 [bus debug] arbitration lost
                                  2021-08-26 12:29:00.018 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:00.103 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:29:00.103 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:29:00.104 [bus debug] start request 31
                                  2021-08-26 12:29:00.104 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:00.283 [bus debug] arbitration lost
                                  2021-08-26 12:29:00.283 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:29:00.283 [main error] scan config 26: ERR: arbitration lost
                                  2021-08-26 12:29:00.400 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:29:00.400 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
                                  2021-08-26 12:29:00.403 [bus debug] start request 31
                                  2021-08-26 12:29:00.403 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:00.580 [bus debug] arbitration lost
                                  2021-08-26 12:29:00.580 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:29:00.580 [bus info] scan 1b cmd: 311b070400
                                  2021-08-26 12:29:00.692 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:29:00.692 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
                                  2021-08-26 12:29:00.693 [bus debug] start request 31
                                  2021-08-26 12:29:00.693 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:00.872 [bus debug] arbitration lost
                                  2021-08-26 12:29:00.872 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:00.958 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:29:00.958 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
                                  2021-08-26 12:29:00.961 [bus debug] start request 31
                                  2021-08-26 12:29:00.961 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:01.138 [bus debug] arbitration lost
                                  2021-08-26 12:29:01.138 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:01.225 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:29:01.225 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
                                  2021-08-26 12:29:01.226 [bus debug] start request 31
                                  2021-08-26 12:29:01.226 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:02.284 [main debug] performing regular tasks
                                  2021-08-26 12:29:02.284 [bus info] scan 76 cmd: 3176070400
                                  2021-08-26 12:29:02.646 [bus debug] arbitration lost
                                  2021-08-26 12:29:02.646 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:02.753 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:29:02.753 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
                                  2021-08-26 12:29:02.755 [bus debug] start request 31
                                  2021-08-26 12:29:02.755 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:02.933 [bus debug] arbitration lost
                                  2021-08-26 12:29:02.933 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:02.998 [update info] received MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:29:02.998 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
                                  2021-08-26 12:29:03.000 [bus debug] start request 31
                                  2021-08-26 12:29:03.000 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:03.178 [bus debug] arbitration lost
                                  2021-08-26 12:29:03.178 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:29:03.178 [bus info] scan 1c cmd: 311c070400
                                  2021-08-26 12:29:03.243 [update info] received MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:29:03.243 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
                                  2021-08-26 12:29:03.244 [bus debug] start request 31
                                  2021-08-26 12:29:03.244 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:03.423 [bus debug] arbitration lost
                                  2021-08-26 12:29:03.423 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:03.488 [update info] received MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:29:03.488 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
                                  2021-08-26 12:29:03.489 [bus debug] start request 31
                                  2021-08-26 12:29:03.489 [bus debug] arbitration start with 31
                                  ^C2021-08-26 12:29:03.645 [main notice] SIGINT received
                                  2021-08-26 12:29:09.532 [bus debug] arbitration lost
                                  2021-08-26 12:29:09.532 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:09.619 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:29:09.619 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
                                  2021-08-26 12:29:09.620 [bus debug] start request 31
                                  2021-08-26 12:29:09.620 [bus debug] arbitration start with 31
                                  received unknown MS cmd: 1008b51009000000ffffff070000 / 01012021-08-26 12:29:09.799 [bus debug] arbitration lost
                                  2021-08-26 12:29:09.799 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:09.885 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:29:09.885 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
                                  2021-08-26 12:29:09.887 [bus debug] start request 31
                                  2021-08-26 12:29:09.887 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:10.066 [bus debug] arbitration lost
                                  2021-08-26 12:29:10.066 [bus debug] ERR: arbitration lost during ready, retry
                                  2021-08-26 12:29:10.152 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:29:10.152 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
                                  2021-08-26 12:29:10.153 [bus debug] start request 31
                                  2021-08-26 12:29:10.153 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:10.331 [bus debug] arbitration lost
                                  2021-08-26 12:29:10.331 [bus debug] notify request: ERR: arbitration lost
                                  2021-08-26 12:29:10.331 [main error] scan config 76: ERR: arbitration lost
                                  2021-08-26 12:29:10.361 [update info] received BC cmd: 10feb505025c00
                                  2021-08-26 12:29:10.361 [update notice] received unknown BC cmd: 10feb505025c00
                                  2021-08-26 12:29:10.363 [bus debug] start request 31
                                  2021-08-26 12:29:10.363 [bus debug] arbitration start with 31
                                  2021-08-26 12:29:10.454 [main notice] ebusd stopped
                                    floret88 @Glasfaser last edited by floret88
                                    @glasfaser Man glaubt es kaum, aber nach abnehmen des VRC700/4 und neu rauf stecken, ergibt sich nun eine neue Ansicht 😉
                                    pi@raspberrypi:~ $ ebusctl i
                                    version: ebusd 21.2.v21.2
                                    signal: acquired
                                    symbol rate: 109
                                    max symbol rate: 122
                                    reconnects: 0
                                    masters: 4
                                    conditional: 0
                                    poll: 0
                                    update: 10
                                    address 03: master #11
                                    address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
                                    address 10: master #2
                                    address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503"
                                    address 31: master #8, ebusd
                                    address 36: slave #8, ebusd
                                    address 71: master #9
                                    address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
                                    pi@raspberrypi:~ $ ebusctl scan result
                                    1 scan(s) still running
                                    08;Vaillant;HMU00;0308;0403
                                    26;Vaillant;VR_71;0104;0503
                                    76;Vaillant;VWZ00;0308;0403
                                    pi@raspberrypi:~ $ ebusctl grab result
                                    1008b507010a / 03828202 = 1
                                    1008b5110100 / 09d90113000008000100 = 6
                                    1008b5160111 / 09010506100634060a06 = 1
                                    1026b5160111 / 090103010e0130010301 = 1
                                    1026b5230106 / 10ec01f401d5012202df0100800080003c = 34
                                    1026b5230107 / 0f008000800080008000008000805705 = 34
                                    1076b5110101 / 09ff3b6010ff690000ff = 33
                                    1076b5160111 / 00 = 1
                                    10feb505025c00 = 6
                                    10feb510020601 = 1
                                    1008b507020900 / 029f02 = 1
                                    1008b507020946 / 020202 = 5
                                    1008b512020464 / 0101 = 1
                                    1008b5120204ff / 0101 = 1
                                    1008b513020528 / 0101 = 1
                                    1076b512030f0000 / 074a030000801302 = 1
                                    1076b512030f0201 / 0748030000801302 = 33
                                    1076b51303040d00 / 02ffff = 6
                                    1008b516081000ffff0200212a / 0b0000ff02001a2b88f5014b = 4
                                    1008b516081002ffff02008129 / 0b12ffff0200812900000000 = 52
                                    1026b5030c0700ffffffffffffffffffff / 0101 = 1
                                    1026b516081000ffff0304212a / 0b2000ff03041a2b00000000 = 3
                                    1026b516081002ffff0304e12a / 0b2201ff0304e12a00000000 = 28
                                    1026b5230402000000 / 020105 = 1
                                    1026b5230402010000 / 020100 = 1
                                    1026b5230402020000 / 020105 = 1
                                    1026b5230b0401010100002022000000 / 0101 = 1
                                    1026b523040201013c / 020105 = 31
                                    1026b5230402000140 / 020105 = 31
                                    1026b5230402020146 / 020105 = 31
                                    1026b5230f05ffffff000000ffffffffffff0000 / 0101 = 32
                                    1076b51009000000ffffff010000 / 0101 = 31
                                    1076b510090000ffffffff050000 / 0101 = 1
                                    Was ist nun alles möglich? oder fehlen hier noch wichtige CSV Konfigurationen?
                                    Danke und LG
                                    • Glasfaser
                                      Glasfaser @floret88 last edited by
                                      @floret88 sagte in eBus Adapter Vaillant:
                                      Er erkennt aber nur ein Vaillant VR 71 Mischermodul , aber nicht den VRC700.
                                      Hast du mal alles ausgeschaltet ,so wie das aussieht ist der Bus zusammen gebrochen .
                                        Cino last edited by
                                        Ich würde den Bus mal neustarten ohne das Ersa Modul.
                                          @glasfaser Ok. Gibt es hier eine Abfolge wie das Ausschalten / Einschalten zu erfolgen hat.
                                          @Cino Bzw. wie kann ich den Bus getrennt neu starten? Mittlerweile habe ich auch die Baudrate und auch die Latenzzeit herunter geschraubt.
                                          Im FHEM Forum wird des weiteren Berichtet, dass man auch am Poti drehen soll. Was sagt Ihr dazu?
                                          Anscheinend "müllt" auch der USB Adapter von ESERA den Bus ziemlich voll.
                                          LG
                                          • Glasfaser
                                            Glasfaser @floret88 last edited by Glasfaser
                                            Du hast aber kein Fehler in deinen Log´s , da würde ich nicht rumschrauben
                                            Beispiel mit Fehler im Log:
                                            [bus error] signal lost
                                            ebus ebus adapter error erste schritte problem
                                            49
                                            388
                                            101147
