    4. eBus Adapter Vaillant
      floret88 @Glasfaser last edited by floret88
      @glasfaser Man glaubt es kaum, aber nach abnehmen des VRC700/4 und neu rauf stecken, ergibt sich nun eine neue Ansicht 😉
      pi@raspberrypi:~ $ ebusctl i
      version: ebusd 21.2.v21.2
      signal: acquired
      symbol rate: 109
      max symbol rate: 122
      reconnects: 0
      masters: 4
      conditional: 0
      poll: 0
      update: 10
      address 03: master #11
      address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
      address 10: master #2
      address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503"
      address 31: master #8, ebusd
      address 36: slave #8, ebusd
      address 71: master #9
      address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
      pi@raspberrypi:~ $ ebusctl scan result
      1 scan(s) still running
      08;Vaillant;HMU00;0308;0403
      26;Vaillant;VR_71;0104;0503
      76;Vaillant;VWZ00;0308;0403
      pi@raspberrypi:~ $ ebusctl grab result
      1008b507010a / 03828202 = 1
      1008b5110100 / 09d90113000008000100 = 6
      1008b5160111 / 09010506100634060a06 = 1
      1026b5160111 / 090103010e0130010301 = 1
      1026b5230106 / 10ec01f401d5012202df0100800080003c = 34
      1026b5230107 / 0f008000800080008000008000805705 = 34
      1076b5110101 / 09ff3b6010ff690000ff = 33
      1076b5160111 / 00 = 1
      10feb505025c00 = 6
      10feb510020601 = 1
      1008b507020900 / 029f02 = 1
      1008b507020946 / 020202 = 5
      1008b512020464 / 0101 = 1
      1008b5120204ff / 0101 = 1
      1008b513020528 / 0101 = 1
      1076b512030f0000 / 074a030000801302 = 1
      1076b512030f0201 / 0748030000801302 = 33
      1076b51303040d00 / 02ffff = 6
      1008b516081000ffff0200212a / 0b0000ff02001a2b88f5014b = 4
      1008b516081002ffff02008129 / 0b12ffff0200812900000000 = 52
      1026b5030c0700ffffffffffffffffffff / 0101 = 1
      1026b516081000ffff0304212a / 0b2000ff03041a2b00000000 = 3
      1026b516081002ffff0304e12a / 0b2201ff0304e12a00000000 = 28
      1026b5230402000000 / 020105 = 1
      1026b5230402010000 / 020100 = 1
      1026b5230402020000 / 020105 = 1
      1026b5230b0401010100002022000000 / 0101 = 1
      1026b523040201013c / 020105 = 31
      1026b5230402000140 / 020105 = 31
      1026b5230402020146 / 020105 = 31
      1026b5230f05ffffff000000ffffffffffff0000 / 0101 = 32
      1076b51009000000ffffff010000 / 0101 = 31
      1076b510090000ffffffff050000 / 0101 = 1
      Was ist nun alles möglich? oder fehlen hier noch wichtige CSV Konfigurationen?
      Danke und LG
      • Glasfaser
        Glasfaser @floret88 last edited by
        @floret88 sagte in eBus Adapter Vaillant:
        Er erkennt aber nur ein Vaillant VR 71 Mischermodul , aber nicht den VRC700.
        Hast du mal alles ausgeschaltet ,so wie das aussieht ist der Bus zusammen gebrochen .
          Cino last edited by
          Ich würde den Bus mal neustarten ohne das Ersa Modul.
            @glasfaser Ok. Gibt es hier eine Abfolge wie das Ausschalten / Einschalten zu erfolgen hat.
            @Cino Bzw. wie kann ich den Bus getrennt neu starten? Mittlerweile habe ich auch die Baudrate und auch die Latenzzeit herunter geschraubt.
            Im FHEM Forum wird des weiteren Berichtet, dass man auch am Poti drehen soll. Was sagt Ihr dazu?
            Anscheinend "müllt" auch der USB Adapter von ESERA den Bus ziemlich voll.
            LG
            • Glasfaser
              Glasfaser @floret88 last edited by Glasfaser
              Du hast aber kein Fehler in deinen Log´s , da würde ich nicht rumschrauben
              Beispiel mit Fehler im Log:
              [bus notice] signal acquired
              [bus error] signal lost
              • Glasfaser
                [bus debug] arbitration lost
                Diese Meldung hast du auch ,
                Schau mal bei Ihm
                https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/177
                  @glasfaser klare Aussage von John30 99704C91-1968-4562-B32B-2EE38BB58405.png
                    Cino last edited by
                    Verstell bloß nicht die Baudrate. Die muss stimmen.
                    Mach den Adapter ab und dann die Therme einmal Stromlos machen. Danach kannste den Adapter wieder verbinden.
                    Ist mir auch schon passiert das der Bus abgestürzt ist. Das Polling darf auch nicht so intensiv sein vom Adapter. Damit blockierst du auch den Bus.
                    Falls ein Poti vorhanden ist würde ich nicht daran drehen. Die sind schon richtig eingestellt beim Vertrieb,
                      floret88 @Cino last edited by
                      @cino Standardmäßig war die Baudrate auf 9600 und lt Bedienungsanleitung von Esera soll diese bei 2400 sein! (Brachte keine Änderung!)
                      Ja ich weigere mich Wehement etwas daran zu drehen! Aber langsam will ich das zum laufen bekommen, und versuche jede Nadel im Heuhaufen zu finden!
                      Da gerade die kühle Phase anfängt, möchte ich ungern die Heizung zerstören - werde morgen dennoch den kompletten Neustart der WP probieren und Euch berichten!
                      a200 1 Reply Last reply Reply Quote 0
                      • a200
                        a200 @floret88 last edited by
                        @floret88 Also das mit dem Drehen ist so eine Sache...
                        Bei meinem Esera-Adapter sehe ich folgende LED:
                        • Anschluss 10: Leuchtet konstant
                        • Pwr: Leuchtet konstant
                        • Data: blinkt unregelmäßig
                        Wenn es bei dir auch so ist, dann kannst du dir wenigstens sicher sein, dass dein Esera Daten empfangen kann.
                        • Sollte die Anschluss 10 LED nicht leuchten, dann hast du ein Problem in der eBus Verkabelung.
                        • Sollte die Power LED nicht leuchten, dann hast du Probleme mit der Stromversorgung bzw. dem USB-Anschluss.
                        • Sollte die Data-LED nicht blinken, dann werden keine Daten empfangen. das kann mehrere Ursachen haben.
                        1. eBus Verkabelung
                        2. Der eBus Signal-Level muss angepasst werden (war bei mir so). In dem Fall musst du an dem kleinen Potentiometer am Adapter leicht drehen. Siehe eBus Anleitungen von John30 im Netz. z.B. https://wiki.fhem.de/wiki/EBUS unter dem Punkt: Poti abgleichen.
                        Wir sind gespannt auf deine Berichte. Viel Erfolg,
                        a200.
                          floret88 @Cino last edited by floret88
                          @cino Neustart ohne eBus Adapter und anschließenden wieder verbinden, bringt keinen Erfolg!
                          @a200 Alles bereits überprüft, bis auf die Poti Einstellungen.
                          Hier ein kleines Video, damit man sieht - alles OK 🐶
                          https://www.youtube.com/watch?v=5-BFxLjh02g
                          Dann bleibt mir eigtl. nur noch Option: Einstellung am Poti verändern.
                          • a200
                            @floret88 Na dann ist ja aus der Hardware-Sicht alles in Ordnung. Ich hätte weiter oben lesen sollen. Da steht:
                            signal: acquired
                            symbol rate: 109
                            Sorry. Mea culpa.
                              floret88 @a200 last edited by floret88
                              @a200 kein Problem und ich bekomme langsam einen Nervenzusammenbruch!
                              Jetzt lese ich im Wiki das der Esera USB Adapter ebenfalls Probleme mit der Latency hat. Also am Poti drehen - Die Freude ist riesig wie Ihr euch denken könnt.
                              Des Weiteren auch noch angemeldet für den eBus Adapter v3 🤡 - i don‘t like
                              Werde Euch nach Poti Dreherei auf den aktuellen Stand bringen! Trotzdem Danke an alle für die Versuche mir zu helfen! Danke.
                                floret88 @floret88 last edited by
                                @floret88 nach 2 stündigen Drehen am Poti und x Neustarts des Raspberrys und X mal runter nehmen des VRC habe ich die Nase voll, und lass es bleiben! Abwarten auf den eBus Adapter v3 von John30.
                                Haben fertig, schönes Wochenende
                                  Cino last edited by
                                  Ich hab den hier, funktioniert top
                                  https://www.esera.de/produkte/ebus/135/1-wire-hub-platine
                                    @cino Den habe ich auch, und funkt leider nicht zufriedenstellend.
                                      Cino @floret88 last edited by Cino
                                      @floret88 wenn du willst kann ich dir meine config mal schicken.
                                      ebusctl i
                                      update check: OK
                                      signal: acquired
                                      symbol rate: 23
                                      max symbol rate: 360
                                      min arbitration micros: 319
                                      max arbitration micros: 9955
                                      min symbol latency: 0
                                      max symbol latency: 28
                                      reconnects: 0
                                      masters: 3
                                      conditional: 3
                                      poll: 1
                                      update: 10
                                      address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
                                      address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0614;HW=6903", loaded "vaillant/15.700.csv"
                                      address ec: slave, scanned "MF=Vaillant;ID=SOL00;SW=0614;HW=6903", loaded "vaillant/ec.sol.sc.csv"
                                      a# /etc/default/ebusd:
                                      # config file for ebusd service.
                                      # Options to pass to ebusd (run "ebusd -?" for more info):
                                      #EBUSD_OPTS="--scanconfig"
                                      EBUSD_OPTS="--configpath=http://ebusd.eu/config/ -d /dev/ttyUSB0 -p 8888  --latency=0 --receivetimeout=100000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
                                      # MULTIPLE EBUSD INSTANCES WITH SYSV
                                      # In order to run multiple ebusd instances on a SysV enabled system, simply
                                      # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
                                      # use a number as suffix for all EBUSD_OPTS settings. That number will then be
                                      # taken as additional "instance" parameter to the init.d script in order to
                                      # start/stop an individual ebusd instance instead of all instances.
                                      # Example: (uncomment the EBUSD_OPTS above)
                                      #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
                                      #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
                                      #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
                                      # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
                                      # In order to run muiltiple ebusd instances on a systemd enabled system, just
                                      # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
                                      # with a different name (e.g. ebusd-2.service), remove the line starting with
                                      # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
                                      # particular ebusd instance.
                                        Dan.Master last edited by
                                        Also meine Config die quasi Fehlerfrei zusammen mit dem ESERA EBUS Adapter seit Januar läuft:
                                        EBUSD_OPTS="--scanconfig=full --configpath=/etc/ebusd/ -d /dev/ttyUSB0 -p 8888 --latency=0 --receivetimeout=
                                        100000 -l /var/log/ebusd.log --httpport=8889 --htmlpath=/var/www/"
                                        # MULLE EBUSD INSTANCES WITH SYSV In order to run multiple ebusd instances on a SysV enabled system,
                                        # simply define several EBUSD_OPTS with a unique suffix for each. Recommended is to use a number as
                                        # suffix for all EBUSD_OPTS settings. That number will then be taken as additional "instance"
                                        # parameter to the init.d script in order to start/stop an individual ebusd instance instead of all
                                        # instances. Example: (uncomment the EBUSD_OPTS above)
                                        /log/ebusd1.log"
                                        /log/ebusd2.log"
                                        /log/ebusd3.log"
                                        Und der Auszug aus dem ebusctl info
                                        signal: acquired
                                        symbol rate: 58
                                        max symbol rate: 150
                                        min arbitration micros: 326
                                        max arbitration micros: 573
                                        min symbol latency: 5
                                        max symbol latency: 14
                                        reconnects: 0
                                        masters: 5
                                        conditional: 0
                                        poll: 1
                                        update: 10
                                        address 00: master #1
                                        address 05: slave #1, scanned "MF=Vaillant;ID=VR921;SW=2206;HW=5703"
                                        Die 921 wird nicht erkannt (Das Internetmodul).
                                        Der ESERA ist Busmäig ca 2.5m entfernt von der Wärmepumpe vond dort wird er weiter geleitet zum 921 und 700er.
                                        Ich habe den abgleich direkt am ESERA mit Laptop via HTERM gemacht. Auch ich musste das Poti anpassen.
                                        DerDani
                                        • MassiveAttack
                                          MassiveAttack last edited by
                                          Ich hatte auch den Esera Adapter, und damit so meine Probleme. Hauptsächlich gehts da um die latency. Kurzum, nachdem ich den selbstgebastelten Adapter von John verwende, funktioniert alles tadellos.
                                          Du kannst an der Config drehen und wenden was du willst, bringt aber nur mäßigen Erfolg. Glaub mir, ich habe Stunden oder eher Tage damit verbracht 🙂
                                          • Hasont
                                            Hasont last edited by Hasont
                                            Hallo, ich verwende den EBus schon einige Jahre zum Auslesen von Werten und der Einstellung der Heizkurve.
                                            Leider gelingt es mir nicht die Auto Raumtemperatur welche an der calorMatic 430 eingestellt werden kann auch über die VIS einzustellen.
                                            Wenn ich mir die eBusDaten über [IP IoBroker]:8891/data auslese werden meine Änderungen an der calorMatic 430 als "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" angezeigt. Diese kann ich über das Terminal mit ebusctl r ActualRoomTempDesiredHc1 oder ebusctl r DisplayedHc1RoomTempDesired ebenfalls auslesen.
                                            Eine Änderung mit ebusctl w -c 430 ActualRoomTempDesiredHc1 22 oder ebusctl w -c 430 DisplayedHc1RoomTempDesired 22 wird mit ERR: element not found beantwortet. Somit gehe ich davon aus, dass er in "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" keine Werte schreiben kann.
                                            Ich kann mir aber auch nicht vorstellen, dass man grad diesen Komfortwert zur kurzfristigen Erhöhung oder Absenkung der Soll Zimmertemperatur nicht auch extern verstellen kann.
                                            Hat hierzu jemand eine Idee oder Lösung?
                                            LG
                                            Horst
                                            ebus ebus adapter error erste schritte problem
                                            49
                                            388
                                            101728
