    4. Real Weather (Bald)
    Real Weather (Bald)
      sigi234 Forum Testing Most Active @wawyo last edited by sigi234
      @wawyo
      Ok, wie bringe ich das jetzt in Vis? Die HTML?
      Erledigt.
      Die Schrift kann man bei einen schwarzen Hintergrund nicht lesen.
      wawyo 1 Reply Last reply Reply Quote 0
      • wawyo
        wawyo Developer @sigi234 last edited by wawyo
        @sigi234
        1- Weather.html anpassen:
        ändere alle
        Weather-Dateien/**.png
        zu
        http://192.168.xxx.xx:8082/vis.0/Wetter/WeatherAnimation/**.png
        2- Erstelle Basic html unter vis (600px X 300px)
        3- Weater.html Code kopieren unter Basic html .
        4- Importiere die Daten von DasWetter Adapter.
        (Du brauchst WeatherStation.0.Weatherurl Datenpunkt)
        Datenpunkt Code:
          "common": {
            "name": "WeatherAnimation",
            "desc": "WeatherAnimation",
            "type": "number",
            "role": "value",
            "read": true,
            "write": true,
            "def": false
          "native": {},
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
            "state": 1636
          "_id": "WeatherStation.0.WeatherAnimation",
          "type": "state",
          "user": "system.user.admin",
          "ts": 1629733667565
        5- Script unter Javascript Adapter:
        var ImageName, ImageNumber, ImageNumberConverted, NewLink;
        on({id: "daswetter.0.NextHours.Location_1.Day_1.current.iconURL", change: "any"}, async function (obj) {
          var value = obj.state.val;
          ImageName = (obj.state ? obj.state.val : "").split('/');
          ImageNumber = ImageName[6];
          ImageNumberConverted = parseFloat((ImageNumber.slice(0, ImageNumber.length - 4)));
          var sunrise = getDateObject(getAstroDate("sunrise", undefined, 0));
          var sunrise_m = sunrise.getHours() * 60 + sunrise.getMinutes();
          var sunset = getDateObject(getAstroDate("sunset", undefined, 0));
          var sunset_m = sunset.getHours() * 60 + sunset.getMinutes();
          var now = new Date();
          var now_m = now.getHours() * 60 + now.getMinutes();
        setState("WeatherStation.0.WeatherAnimation", ImageNumberConverted);
        if (now_m > sunset_m - 60 && now_m <= sunset_m + 60) {
            log("dusk" + sunrise_m + " " + sunset_m);
            setState("WeatherStation.0.Weatherurl", (obj.state ? obj.state.val : ""));
        } else if (now_m > sunrise_m - 60 && now_m <= sunrise_m + 60) {
            log("dawn" + sunrise_m + " " + sunset_m);
            NewLink = ['http://192.168.xxx.xx:8082/vis.0/Wetter/myweather/',ImageNumberConverted + 50,'.png'].join('');
            setState("WeatherStation.0.Weatherurl", NewLink);
        } else if (now_m > sunrise_m + 60 && now_m <= sunset_m - 60) {
            log("day" + sunrise_m + " " + sunset_m);
        } else {
            log("night" + sunrise_m + " " + sunset_m);
        Glasfaser sigi234 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @wawyo last edited by Glasfaser
          @wawyo sagte in Real Weather (Bald):
          (Du brauchst WeatherStation.0. Weatherurl Datenpunkt)
          Kommt noch ein Adapter von dir , sonst für selbst erstellte Datenpunkte ist das sehr schlecht gewählt ?
          wawyo sigi234 2 Replies Last reply Reply Quote 0
          • wawyo
            wawyo Developer @Glasfaser last edited by wawyo
            @glasfaser
            Ja, der Adapter ist geplant.
            Es wird dauern bis zum Release.
            @all ich bin offen für alle Anfragen ☺️
            Edit:
            Bitte verzeiht mir wenn ich nicht sofort antworten kann.
              @wawyo
              Puh, jetzt wird es kompliziert, warte auf den Adapter.😀
              Habe mal es in einen iFrame Widget getestet.
              Das Non plus ultra wären natürlich sound effects
              • Chaot
                Chaot @sigi234 last edited by
                @sigi234 sagte in Real Weather (Bald):
                Nachts um Vier Gewitter am Tablet.
                Ich fürchte dann könnte ich zukünftig mit dem IoBroker in die Garage umziehen.......
                  sigi234 Forum Testing Most Active @Chaot last edited by
                  @chaot sagte in Real Weather (Bald):
                  Eventuell als Option und nur zwischen Zeit xy
                    sigi234 Forum Testing Most Active @Glasfaser last edited by sigi234
                    @glasfaser sagte in Real Weather (Bald):
                    Hast du das schon getestet? Punkte 1-5
                    Punkt 4 ?
                    DP sollte eher unter 0_userdata.0 sein?
                    • Glasfaser
                      Glasfaser @sigi234 last edited by Glasfaser
                      @sigi234
                      Ja habe es unter 0_userdata.0 angelegt .
                      Alles soweit geändert ,
                      nur bei der Scenenänderung behält er die alte Auswahl im Hintergrund , dadurch sind zwei Scenen vorhanden und erst bei einem View neuladen ist die gewünschte Scene richtig.
                      setState("0_userdata.0.RealWeather.WeatherAnimation", ImageNumberConverted);
                         setState("0_userdata.0.RealWeather.Weatherurl", (obj.state ? obj.state.val : ""));
                         NewLink = ['http://192.168.178.11:8082/vis.0/Wetter/myweather/',ImageNumberConverted + 50,'.png'].join('');
                         setState("0_userdata.0.RealWeather.Weatherurl", NewLink);
                      } else {
                      <html><head>
                      <meta http-equiv="content-type" content="text/html; charset=UTF-8">
                      </head>
                       <body onload="FirstStartWeather()">
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/01.png" id="SkyBack" class="Sky"></div>
                         <div class="twinkling"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/02.png" id="Startshoot" class="StartShooting" style="--Shoot-X1: 0px; --Shoot-X2: 600px; --Shoot-Z1: 280deg; --Shoot-Z2: 280deg; --Shoot-Time: 3000ms; animation-play-state: paused; visibility: hidden;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/2.png" id="Ray" class="AnimateRay" style="visibility: visible; animation-play-state: running;"> </div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/1.png" id="Sun" class="AnimateSun" style="visibility: visible; animation-play-state: running;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/3.png" id="Cloud1" class="AnimateChildCloud" style="visibility: hidden; animation-play-state: paused;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/3.png" id="Cloud2" class="AnimateSubCloud" style="visibility: hidden; animation-play-state: paused;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/3.png" id="Cloud3" class="AnimateCloud" style="visibility: hidden; animation-play-state: paused; --Cloud-Y1: -10%;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/3.png" id="Cloud4" class="AnimateDarkCloud" style="visibility: hidden; animation-play-state: paused;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/3.png" id="Cloud5" class="AnimateSubDarkCloud" style="visibility: hidden; animation-play-state: paused;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/5.png" id="Lightning" class="AnimateLightning" style="animation-play-state: paused; visibility: hidden;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/6.png" id="LightningChild" class="AnimateLightningChild" style="animation-play-state: paused; visibility: hidden;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/7.png" id="LightningSub" class="AnimateLightningSub" style="animation-play-state: paused; visibility: hidden;"></div>
                         <div><img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/7.png" id="LightningBack" class="AnimateLightningBack" style="animation-play-state: paused; visibility: hidden;"></div>
                         <div class="Rainstorm" id="RainAnimation">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDropBack" class="Rain-Back">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop1" class="Rain-1" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop2" class="Rain-2" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop3" class="Rain-3" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop4" class="Rain-4" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop5" class="Rain-5" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop6" class="Rain-6" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop7" class="Rain-7" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop8" class="Rain-8" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop9" class="Rain-9" style="visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="RainDrop10" class="Rain-10" style="visibility: hidden; animation-play-state: paused;">
                         </div>
                         <div class="Snowstorm" id="SnowAnimation">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-1" class="fallingSnow-1" style="--animation-time: 6s; visibility: hidden; animation-play-state: paused;">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-2" class="fallingSnow-2" style="--animation-time: 5s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-3" class="fallingSnow-3" style="--animation-time: 4s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-4" class="fallingSnow-4" style="--animation-time: 6s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-5" class="fallingSnow-5" style="--animation-time: 6s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-6" class="fallingSnow-6" style="--animation-time: 7s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-7" class="fallingSnow-7" style="--animation-time: 5s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-8" class="fallingSnow-8" style="--animation-time: 5s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-9" class="fallingSnow-9" style="--animation-time: 7s; visibility: hidden; animation-play-state: paused;">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="Snow-10" class="fallingSnow-10" style="--animation-time: 5s; visibility: hidden; animation-play-state: paused;">
                         </div>
                         <div class="wrapLeaf">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/9.png" id="Leaf" class="AnimateWind" style="animation-play-state: paused; visibility: hidden;">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/8.png" id="Leaf2" class="AnimateSubWind" style="animation-play-state: paused; visibility: hidden;">
                         </div>
                         <div class="Icicle">
                             <img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/4.png" id="Icicle1" class="Icicle-1" style="--animation-W: 1; --animation-H: 1; --animation-Y: -27.5%;">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/10.png" id="IcicleSub1" class="IcicleWater-1" style="--animation-W1: 187.5%; --animation-W2: 217.5%;">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/12.png" id="IcicleSub2" class="IcicleGlass-1" style="visibility: hidden;">
                         	<img src="http://192.168.178.11:8082/vis.0/Wetter/myweather/4.png" id="Icicle2" class="Icicle-2">
                         </div>
                         <div class="controlWeather">
                             <div>
                         	    <p></p>Animation Number: <input type="number" style="margin-top: 40%;" id="myWeather" value="1">
                         		<button onclick="FirstStartWeather()">Change Weather</button>
                             </div>
                             <div><label id="State"> Sun Ray</label></div>
                         	<div><input type="checkbox" id="WindCheckBox" onclick="FirstStartWind()"></div>
                         </div>
                      <style>
                      body {
                         height: 300px;
                         width: 600px;
                         position: absolute;
                      .controlWeather{
                         margin-top: 15%;
                         margin-left: 5%;
                      /*-----------------------------------------Sky--------------------------------------*/
                      .Icicle {
                         width: 600px;
                         height: 280px;
                         margin-top: -50%;
                         margin-left: -2%;
                         z-index: 19;
                         background: #ff0000;
                      .Icicle-1 {
                         position: absolute;
                         margin-top: 5%;
                         margin-left: 20%;
                         width: 25px;
                         height: 100px;
                         z-index: 10;
                         transform: translateY(var(--animation-Y)) scaleX(var(--animation-W)) scaleY(var(--animation-H));
                      .IcicleWater-1{
                         position: absolute;
                         margin-top: 5%;
                         margin-left: 20%;
                         width: 25px;
                         height: 25px;
                         z-index: 11;
                         animation: AnimationIcicle-1 3s linear infinite;
                      @keyframes AnimationIcicle-1 {
                         0%{
                         	transform: translateY(30%) rotate(3deg);
                         10%{
                         	transform: translateY(60%) rotate(6deg);
                         20%{
                         	transform: translateY(90%) rotate(0deg);
                         30%{
                         	transform: translateY(120%) rotate(3deg) scaleY(2);
                         40%{
                         	transform: translateY(210%) rotate(6deg);
                         50%{
                         	transform: translateY(var(--animation-W1)) rotate(3deg);
                         60%{
                         	transform: translateY(var(--animation-W2)) rotate(0deg);
                         	opacity : 1;
                         70%{
                         	transform: translateY(var(--animation-W2)) scaleY(2) scaleX(0.8);
                         80%{
                         	transform: translateY(500%) rotate(3deg) scaleY(1);
                         90%{
                         	transform: translateY(975%) scaleX(1) scaleY(0.3) rotate(0);
                         	filter:contrast(200%) brightness(150%) saturate(8);
                         	opacity : 1;
                         95%{
                             transform: translateY(950%) scaleX(3) scaleY(0.1);
                         	filter: blur(5px);
                         	opacity : 0.5;
                         100%{
                         	transform: translateY(925%) rotate(180deg) scaleX(5) scaleY(0.8) rotate(180deg);
                         	filter: brightness(10000%) sepia(80) saturate(10) hue-rotate(180deg);
                             opacity : 0;
                      .IcicleGlass-1 {
                         position: absolute;
                         margin-top: 42%;
                         margin-left: 5%;
                         width: 200px;
                         height: 70px;
                         z-index: 11;
                         filter: invert(100%) brightness(2000%);
                      .Icicle-2 {
                         position: absolute;
                         margin-top: 5%;
                         margin-left: 30%;
                         width: 15px;
                         height: 75px;
                         z-index: 10;
                      .Sky {
                         margin-top: -2%;
                         margin-left: -2%;
                         position: absolute;
                         height: 300px;
                         width: 600px;
                         background: #000000;
                         z-index: 0;
                      .twinkling{
                         margin-top: -2%;
                         margin-left: -2%;
                         position: absolute;
                         height: 300px;
                         width: 600px;
                         background: transparent url('http://xxx.xxx.xxx.xxx:8082/vis.0/Wetter/WeatherAnimation/00.png') repeat center;
                         z-index: 1;
                         animation: SkyAnimation 50s linear infinite;
                      .StartShooting {
                         position: absolute;
                         margin-top: -20%;
                         margin-left: -5%;
                         width: 30px;
                         height: 30px;
                         z-index: 2;
                         animation: ShootingAnimation var(--Shoot-Time) infinite;
                      @keyframes SkyAnimation {
                         0% {
                         background-position: 600px -300px;
                         background-size: 150px 150px;
                         50% {
                         background-position: 0px 0px;
                         background-size: 500px 500px;
                         100% {
                      @keyframes ShootingAnimation {
                         0% {
                         transform: translate(var(--Shoot-X1), 300px) scaleX(1) scaleY(1) rotate(var(--Shoot-Z1));
                         opacity : 1;
                         100% {
                         transform: translate(var(--Shoot-X2), 50px) scaleX(0.1) scaleY(0.1) rotate(var(--Shoot-Z2));
                         opacity : 0;
                      /*-------------------------------------Sun---------------------------------------*/
                      .AnimateSun {
                         position: absolute;
                         margin-top: -5%;
                         margin-left: 20%;
                         width: 300px;
                         height: 300px;
                         z-index: 4;
                         animation-name : sunRotate;
                         animation-duration : 10s;
                         animation-iteration-count : infinite;
                         animation-direction : alternate;
                      @keyframes sunRotate {
                         from {
                         transform: rotate(0deg);
                         to {
                         transform: rotate(59deg);
                      /*-------------------------------------Ray---------------------------------------*/
                      .AnimateRay {
                         position: absolute;
                         margin-top: -15%;
                         margin-left: 15%;
                         width: 400px;
                         height: 400px;
                         z-index: 3;
                         animation-name : RayRotate, RayShrink;
                         animation-duration : 10s, 5s;
                         animation-iteration-count : infinite , infinite ;
                         animation-direction : alternate , alternate ;
                      @keyframes RayRotate {
                         from {
                         opacity : 0;
                         to {
                         transform: rotate(359deg);
                      @keyframes RayShrink {
                         0%{
                         transform: scale(0.2);
                         opacity : 0.2;
                         50%{
                         transform: scale(0.5);
                         opacity : 0.5;
                         75%{
                         opacity : 0.3;
                         transform: scale(2);
                         100%{
                         opacity : 0;
                         transform: scale(0.3);
                      /*------------------------------------Cloud 1---------------------------------------*/
                      .AnimateCloud {
                         position: absolute;
                         margin-top: var(--Cloud-Y1);
                         margin-left: 2%;
                         width: 400px;
                         height: 350px;
                         z-index: 5;
                         animation-name : CloudFade, CloudMove;
                         animation-duration : 5s, 20s;
                         animation-delay: -2s;
                      @keyframes CloudFade {
                         from {
                         opacity : 0.7;
                         to {
                         opacity : 0.5;
                      @keyframes CloudMove {
                         0% {
                         transform: translateX(30%);
                         50% {
                         transform: translateX(5%);
                         100% {
                         transform: translateX(40%);
                      @keyframes CloudShrink {
                         0%{
                         transform: scale(0.7);
                         box-shadow: none;
                         100%{
                         box-shadow: none;
                      /*-------------------------------------Cloud 2------------------------------------*/
                      .AnimateChildCloud {
                         position: absolute;
                         margin-top: var(--CloudChild-Y1);
                         margin-left: 2%;
                         width: 300px;
                         height: 250px;
                         z-index: 5;
                         animation-name : ChildCloudFade, ChildCloudMove;
                         animation-duration : 5s, 15s;
                         animation-delay: -3s;
                      @keyframes ChildCloudFade {
                         from {
                         opacity : 0.7;
                         to {
                         opacity : 0.5;
                      @keyframes ChildCloudMove {
                         0% {
                         50% {
                         100% {
                      /*------------------------------------Cloud 3---------------------------------------*/
                      .AnimateSubCloud {
                         position: absolute;
                         margin-top: var(--CloudSub-Y1);
                         margin-left: -10%;
                         width: 450px;
                         height: 400px;
                         z-index: 5;
                         animation-name : SubCloudFade, SubCloudMove;
                         animation-duration : 5s, 25s;
                         animation-delay: -1s;
                      @keyframes SubCloudFade {
                         from {
                         opacity : 0.7;
                         to {
                         opacity : 0.5;
                      @keyframes SubCloudMove {
                         0% {
                         50% {
                         100% {
                      /*------------------------------------Cloud 4---------------------------------------*/
                      .AnimateDarkCloud {
                         position: absolute;
                         margin-top: -20%;
                         margin-left: -10%;
                         width: 450px;
                         height: 400px;
                         z-index: 5;
                         animation-name : DarkCloudFade, DarkCloudMove;
                         animation-duration : 2s, 20s;
                      @keyframes DarkCloudFade {
                         from {
                         opacity : 1;
                         to {
                         opacity : 0.8;
                      @keyframes DarkCloudMove {
                         0% {
                         transform: translateX(15%) rotate(-5deg);
                         filter: grayscale(100%) contrast(100%) invert(90%);
                         50% {
                         transform: translateX(30%) rotate(5deg);
                         filter: grayscale(100%) contrast(80%) invert(100%);
                         100% {
                         transform: translateX(40%) rotate(0deg);
                         /*filter: saturate(5) grayscale(100%) contrast(200%) brightness(100) blur(1px) invert(1000%) sepia(100%) hue-rotate(180deg) opacity(50%);*/
                         filter: grayscale(100%) contrast(100%)invert(90%);
                      /*------------------------------------Cloud 5---------------------------------------*/
                      .AnimateSubDarkCloud {
                         position: absolute;
                         margin-top: -15%;
                         margin-left: -10%;
                         width: 450px;
                         height: 400px;
                         z-index: 5;
                         animation-name : SubDarkCloudFade, SubDarkCloudMove;
                         animation-delay: -4s;
                      @keyframes SubDarkCloudFade {
                         from {
                         opacity : 1;
                         to {
                         opacity : 0.8;
                      @keyframes SubDarkCloudMove {
                         0% {
                         50% {
                         transform: translateX(10%);
                         100% {
                      /*-------------------------------------lightning---------------------------------------*/
                      .AnimateLightning {
                         position: absolute;
                         margin-left: 20%;
                         width: 300px;
                         height: 300px;
                         z-index: 6;
                         animation: fadeLightning 10s linear infinite;
                      @keyframes fadeLightning {
                         0% {
                         opacity : 1;
                         2% {
                         opacity : 0;
                         4% {
                         opacity : 1;
                         6% {
                         opacity : 0;
                         100% {
                         opacity : 0;
                      /*-------------------------------------lightningChild---------------------------------------*/
                      .AnimateLightningChild {
                         position: absolute;
                         margin-left: 20%;
                         width: 300px;
                         height: 300px;
                         z-index: 6;
                         animation: fadeLightningChild 7s linear infinite;
                      @keyframes fadeLightningChild {
                         0% {
                         opacity : 1;
                         2% {
                         opacity : 0;
                         4% {
                         opacity : 1;
                         6% {
                         opacity : 0;
                         100% {
                         opacity : 0;
                      /*-------------------------------------lightningSub---------------------------------------*/
                      .AnimateLightningSub {
                         position: absolute;
                         margin-left: 10%;
                         margin-top: -15%;
                         width: 400px;
                         height: 400px;
                         z-index: 6;
                         animation: fadeLightningSub 5s linear infinite;
                      @keyframes fadeLightningSub {
                         0% {
                         opacity : 1;
                         2% {
                         opacity : 0;
                         4% {
                         opacity : 1;
                         6% {
                         opacity : 0;
                         100% {
                         opacity : 0;
                      /*-------------------------------------lightningBacK---------------------------------------*/
                      .AnimateLightningBack {
                         position: absolute;
                         margin-left: 10%;
                         margin-top: -5%;
                         border-radius: 90%;
                         box-shadow: 0px 0px 50px 50px rgba(255,255,255,1);
                         width: 400px;
                         height: 300px;
                         filter:blur(50px);
                         z-index: 3;
                         animation: fadeLightningBack 7s linear infinite;
                      @keyframes fadeLightningBack {
                         0% {
                         opacity : 1;
                         background-color: #ffffff;
                         2% {
                         opacity : 0;
                         100% {
                         opacity : 0;
                      /*----------------------------------------Rain---------------------------------------*/
                      .Rainstorm {
                         position: relative;
                         width: 600px;
                         height: 280px;
                      .Rain-1 {
                         position: absolute;
                         margin-left: 30%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                         animation: RainSubAnimation 0.8s infinite;
                      .Rain-2 {
                         position: absolute;
                         margin-left: 20%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-3 {
                         position: absolute;
                         margin-left: 35%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                         animation-delay: -1.5s;
                      .Rain-4 {
                         position: absolute;
                         margin-left: 60%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-5 {
                         position: absolute;
                         margin-left: 40%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                         animation-delay: -2.5s;
                      .Rain-6 {
                         position: absolute;
                         margin-left: 50%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-7 {
                         position: absolute;
                         margin-left: 25%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-8 {
                         position: absolute;
                         margin-left: 55%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-9 {
                         position: absolute;
                         margin-left: 45%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-10 {
                         position: absolute;
                         margin-left: 65%;
                         margin-top: 20%;
                         width: 30px;
                         height: 30px;
                         z-index: 3;
                      .Rain-Back {
                         position: absolute;
                         margin-left: 2%;
                         margin-top: 40%;
                         width: 500px;
                         height: 5px;
                         z-index: 3;
                         border-radius: 70%;
                         box-shadow: 0px 5px 20px 10px rgba(255,255,255,1);
                         filter: brightness(10000%) contrast(100000%);
                         background: white;
                         opacity : 0.1;
                      @keyframes RainSubAnimation {
                         0% {
                         opacity : 0.4;
                         transform: translate(10%, -50%) scaleX(0.5) scaleY(1) rotate(-16deg);
                         70% {
                         transform: translate(10%, 340%) scaleX(0.7) scaleY(1) rotate(-16deg);
                         90% {
                         transform: translate(10%, 350%) scaleX(1.5) scaleY(0) rotate(0);
                         opacity : 1;
                         100% {
                         transform: translate(10%, 330%) scaleX(5) scaleY(2) rotate(180deg);
                         opacity : 0;
                      /*----------------------------------------Snow---------------------------------------*/
                      .Snowstorm {
                         position: absolute;
                         width: 600px;
                         height: 280px;
                      .fallingSnow-1 {
                         margin-top: -25%;
                         margin-left: 0%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                         border-radius: 100%;
                         box-shadow: 0px 0px 5px 5px rgba(255,255,255,1);
                         filter: brightness(100%) contrast(100%);
                         animation: fallingSnow var(--animation-time) infinite linear;
                      .fallingSnow-2 {
                         margin-top: -25%;
                         margin-left: 15%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-3 {
                         margin-top: -25%;
                         margin-left: 40%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-4 {
                         margin-top: -25%;
                         margin-left: 20%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-5 {
                         margin-top: -25%;
                         margin-left: 30%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                         animation-delay: -5s;
                      .fallingSnow-6 {
                         margin-top: -25%;
                         margin-left: 5%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-7 {
                         margin-top: -25%;
                         margin-left: 35%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-8 {
                         margin-top: -25%;
                         margin-left: 25%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-9 {
                         margin-top: -25%;
                         margin-left: 45%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      .fallingSnow-10 {
                         margin-top: -25%;
                         margin-left: 10%;
                         position: absolute;
                         height: 0px;
                         width: 0px;
                         z-index: 7;
                      @keyframes fallingSnow {
                       0% {
                         opacity: 1;
                         transform: translate(100px, 0) rotateZ(0deg);
                       15% {
                         opacity: 0.9;
                         transform: translate(95px, 20px) rotateZ(90deg);
                       30% {
                         opacity: 1;
                         transform: translate(100px, 40px) rotateZ(180deg);
                       45% {
                         opacity: 0.9;
                         transform: translate(95px, 60px) rotateZ(270deg);
                        60% {
                         opacity: 1;
                         transform: translate(100px, 80px) rotateZ(270deg);
                        75% {
                         opacity: 0.9;
                         transform: translate(95px, 100px) rotateZ(270deg);
                       85% {
                         opacity: 1;
                         transform: translate(100px, 115px) rotateZ(270deg);
                       100% {
                         opacity: 0;
                         transform: translate(95px, 110px) rotateZ(360deg) scaleX(3) scaleY(2) ;
                      /*-------------------------------------Wind---------------------------------------*/
                      .wrapLeaf {
                         width: 600px;
                         height: 280px;
                         margin-top: -50%;
                         margin-left: -2%;
                         z-index: 19;
                      .AnimateWind {
                         position: absolute;
                         margin-top: 10%;
                         margin-left: 0%;
                         width: 200px;
                         height: 200px;
                         z-index: 10;
                         animation-name : shrinkLeaf;
                         animation-duration :  var(--Leaf-Z1);
                         animation-iteration-count : infinite ;
                      @keyframes shrinkLeaf {
                         0%{
                         transform: translateY(var(--Leaf-X1)) scaleX(0.5) rotate(180deg);
                         10%{
                         transform: translateX(var(--Leaf-X2)) scale(0.2) rotate(270deg);
                         20%{
                         transform: translateX(var(--Leaf-X3)) scaleX(0.2) rotate(360deg);
                         30%{
                         transform: translateX(var(--Leaf-X4)) scaleY(0.1) rotate(90deg);
                         40%{
                         transform: translateX(var(--Leaf-X5)) scaleX(0.8) rotate(0deg);
                         50%{
                         transform: translateY(var(--Leaf-X6)) scaleY(0.2) rotate(270deg);
                         10%{
                         transform: translateX(var(--Leaf-X7)) scale(0.7) rotate(180deg);
                         70%{
                         transform: translateX(var(--Leaf-X8)) scale(0.7) rotate(360deg);
                         80%{
                         transform: translate(var(--Leaf-X9)) scaleY(0.1) scaleX(0.4) rotate(1440deg);
                         90%{
                         transform: translateX(var(--Leaf-X10)) scaleX(0.4);
                         100%{
                         transform: translateX(var(--Leaf-X10)) scale(0.2) rotate(270deg) scaleX(0.2);
                         opacity : 0.9;
                      .AnimateSubWind {
                         position: absolute;
                         margin-top: 10%;
                         margin-left: 40%;
                         width: 100px;
                         height: 100px;
                         z-index: 10;
                         animation-name : shrinkLeaf2;
                         animation-duration :  var(--Leaf2-Z1);
                      @keyframes shrinkLeaf2 {
                         0%{
                         transform: translateX(var(--Leaf2-X1)) rotate(180deg) scaleX(0.8);
                         20%{
                         transform: translateY(var(--Leaf2-X2)) scale(0.7) scaleY(0.3);
                         30%{
                         transform: scaleX(1) scaleY(0.7) rotate(270deg);
                         40%{
                         transform: translateX(var(--Leaf2-X4)) scaleX(2) scaleY(0.7) rotate(720deg);
                         50%{
                         transform: translate(var(--Leaf2-X3)) scaleX(0.2) scaleY(0.7) rotate(270deg);
                         opacity : 1;
                         60%{
                         transform: translateY(var(--Leaf2-X2)) scaleX(2) scaleY(0.7) rotate(720deg);
                         70%{
                         transform: translateX(var(--Leaf2-X6))  scaleX(0.2) scaleY(0.5) rotate(360deg);
                         80%{
                         transform: translateY(var(--Leaf2-X5)) translateX(var(--Leaf2-X6)) scaleY(1);
                         90%{
                         transform: translateY(var(--Leaf2-X2)) scale(0.7) scaleY(0.3) rotate(720deg);
                         100%{
                      </style>
                      <script type="text/javascript">
                      //======================================Variable======================================================================
                      var WeatherValue = 0;
                      var OldWeatherValue = 0;
                      var WindValue = 0;
                      //======================================Get Variable===============================================================
                      var stateValue = Number(parseFloat('{daswetter.0.NextHours.Location_1.Day_1.current.clouds_value}'));
                      WindValue = Number(parseFloat('{daswetter.0.NextHours.Location_1.Day_1.current.wind_value}'));
                      WeatherValue = Number(parseFloat('{0_userdata.0.RealWeather.WeatherAnimation}'));
                      console.log("Cloud: " + stateValue);
                      console.log("Wind: " + WindValue);
                      console.log("Weather Icon: " + WeatherValue);
                      /*var ImageName, ImageNumber, ImageNumberConverted, NewLink;
                      setState("0_userdata..0.WeatherAnimation", ImageNumberConverted);
                         setState("0_userdata..0.Weatherurl", (obj.state ? obj.state.val : ""));
                         NewLink = ['http://xxx.xxx.xxx.xxx:8082/vis.0/Wetter/myweather/',ImageNumberConverted + 50,'.png'].join('');
                         setState("0_userdata..0.Weatherurl", NewLink);
                      } else {
                      //======================================Start======================================================================
                      FirstStartWeather();
                      FirstStartWind();
                      RandomSnow(4, 7);
                      RandomShoot();
                      ShrinkIcicle();
                      function FirstStartWeather() {
                         var WeatherVal = document.getElementById("myWeather").value;
                         WeatherValue = parseFloat(WeatherVal);
                      function FirstStartWind() {
                         var checkBox = document.getElementById("WindCheckBox");
                         if (checkBox.checked == true) {
                             AnimateLeaf();
                             AnimateLeaf2();
                             document.getElementById('Leaf').style.visibility = 'visible';
                             document.getElementById('Leaf2').style.visibility = 'visible';
                             document.getElementById("Leaf").style.webkitAnimationPlayState = "running";
                             document.getElementById("Leaf2").style.webkitAnimationPlayState = "running";
                         } else {
                             document.getElementById("Leaf").style.webkitAnimationPlayState = "paused";
                             document.getElementById("Leaf2").style.webkitAnimationPlayState = "paused";
                             document.getElementById('Leaf').style.visibility = 'hidden';
                             document.getElementById('Leaf2').style.visibility = 'hidden';
                             clearTimeout(LeafTimer1);
                             clearTimeout(LeafTimer2);
                      //======================================Update====================================================================
                      setInterval(function() {
                         if (OldWeatherValue !== WeatherValue) {
                             document.getElementById('State').innerText = "";
                             //console.log(WeatherValue);
                             OldWeatherValue = WeatherValue;
                             switch (WeatherValue) {
                                 case 1:
                                     ShowSun();
                                     ShowRay();
                                     HideCloud1();
                                     HideCloud2();
                                     HideCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSnow();
                                     break;
                                 case 2:
                                     ShowSun();
                                     ShowRay();
                                     ShowCloud1();
                                     ShowCloud2();
                                     HideCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSnow();
                                     break;
                                 case 3:
                                     ShowSun();
                                     HideRay();
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSnow();
                                     break;
                                 case 4:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSun();
                                     HideRay();
                                     HideSnow();
                                     break;
                                 case 5:
                                     ShowSun();
                                     ShowRay();
                                     ShowRain();
                                     HideLightning();
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     Rain1();
                                     HideSnow();
                                     break;
                                 case 6:
                                     ShowSun();
                                     HideRay();
                                     ShowRain();
                                     HideLightning();
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     Rain2();
                                     HideSnow();
                                     break;
                                 case 7:
                                     ShowRain();
                                     HideLightning();
                                     Rain3();
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     HideCloud5();
                                     HideSun();
                                     HideRay();
                                     HideSnow();
                                     break;
                                 case 8:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     HideCloud5();
                                     ShowSun();
                                     ShowRay();
                                     ShowRain();
                                     HideLightning();
                                     Rain1();
                                     HideSnow();
                                     break;
                                 case 9:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     ShowCloud5();
                                     ShowSun();
                                     HideRay();
                                     ShowRain();
                                     HideLightning();
                                     Rain2();
                                     HideSnow();
                                     break;
                                 case 10:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     ShowCloud5();
                                     ShowRain();
                                     HideLightning();
                                     Rain3();
                                     HideSun();
                                     HideRay();
                                     HideSnow();
                                     break;
                                 case 11:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     ShowSun();
                                     ShowRay();
                                     ShowRain();
                                     Rain1();
                                     ShowLightning();
                                     HideSnow();
                                     break;
                                 case 12:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     HideCloud5();
                                     ShowSun();
                                     HideRay();
                                     ShowRain();
                                     Rain2();
                                     ShowLightning();
                                     HideSnow();
                                     break;
                                 case 13:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     ShowCloud5();
                                     ShowRain();
                                     Rain3();
                                     ShowLightning();
                                     HideSun();
                                     HideRay();
                                     HideSnow();
                                     break;
                                 case 17:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     ShowSun();
                                     ShowRay();
                                     ShowSnow();
                                     break;
                                 case 18:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSun();
                                     HideRay();
                                     RandomSnow(3, 6);
                                     ShowSnow();
                                     break;
                                 case 19:
                                     ShowCloud1();
                                     ShowCloud2();
                                     ShowCloud3();
                                     ShowCloud4();
                                     ShowCloud5();
                                     HideRain();
                                     HideLightning();
                                     HideSun();
                                     HideRay();
                                     RandomSnow(2, 5);
                                     ShowSnow();
                                     break;
                                 default:
                                     HideCloud1();
                                     HideCloud2();
                                     HideCloud3();
                                     HideCloud4();
                                     HideCloud5();
                                     HideRain();
                                     HideLightning();
                                     Rain1();
                                     HideSun();
                                     HideRay();
                                     HideSnow();
                                     break;
                      }, 1000);
                      //======================================Shoot======================================================================
                      function randomTime(mval) {
                         var RetTVar = Math.floor(Math.random() * mval) + .5;
                         return RetTVar;
                      function RandomShoot() {
                         var ShootCord = [
                             [600, -100, 160, 180, 1000, 8000],
                             [0, 600, 280, 280, 2000, 5000],
                             [600, -100, 160, 180, 500, 8000],
                             [0, 600, 280, 280, 3000, 10000],
                             [0, 600, 280, 280, 500, 2000],
                         var ShootCrdIndex = randomInterval(0, 4)
                         document.querySelector('.StartShooting').style.setProperty('--Shoot-X1', ShootCord[ShootCrdIndex][0] + 'px');
                         document.querySelector('.StartShooting').style.setProperty('--Shoot-X2', ShootCord[ShootCrdIndex][1] + 'px');
                         document.querySelector('.StartShooting').style.setProperty('--Shoot-Z1', ShootCord[ShootCrdIndex][2] + 'deg');
                         document.querySelector('.StartShooting').style.setProperty('--Shoot-Z2', ShootCord[ShootCrdIndex][3] + 'deg');
                         document.querySelector('.StartShooting').style.setProperty('--Shoot-Time', ShootCord[ShootCrdIndex][4] + 'ms');
                         setTimeout(function() {
                             document.getElementById("Startshoot").style.webkitAnimationPlayState = "paused";
                             document.getElementById('Startshoot').style.visibility = 'hidden';
                                 RandomShoot();
                                 document.getElementById("Startshoot").style.webkitAnimationPlayState = "running";
                                 document.getElementById('Startshoot').style.visibility = 'visible';
                             }, ShootCord[ShootCrdIndex][5]);
                         }, ShootCord[ShootCrdIndex][4]);
                      //======================================Sun=====================================================================
                      function ShowSun() {
                         var OldWeatherString = document.getElementById('State').textContent;
                         document.getElementById('State').innerText = OldWeatherString + " Sun";
                         document.getElementById("Sun").style.visibility = 'visible';
                         document.getElementById("Sun").style.webkitAnimationPlayState = "running";
                      function HideSun() {
                         document.getElementById("Sun").style.visibility = 'hidden';
                         document.getElementById("Sun").style.webkitAnimationPlayState = "paused";
                      function ShowRay() {
                         document.getElementById('State').innerText = OldWeatherString + " Ray";
                         document.getElementById("Ray").style.visibility = 'visible';
                         document.getElementById("Ray").style.webkitAnimationPlayState = "running";
                      function HideRay() {
                         document.getElementById("Ray").style.visibility = 'hidden';
                         document.getElementById("Ray").style.webkitAnimationPlayState = "paused";
                      //======================================Cloud=====================================================================
                      function ShowCloud1() {
                         document.getElementById('State').innerText = OldWeatherString + " Cloud 1";
                         document.getElementById("Cloud1").style.visibility = 'visible';
                         document.getElementById("Cloud1").style.webkitAnimationPlayState = "running";
                         document.querySelector('.AnimateChildCloud').style.setProperty('--CloudChild-Y1', '-5%');
                         document.querySelector('.AnimateSubCloud').style.setProperty('--CloudSub-Y1', '-15%');
                      function HideCloud1() {
                         document.getElementById("Cloud1").style.visibility = 'hidden';
                         document.getElementById("Cloud1").style.webkitAnimationPlayState = "paused";
                      function ShowCloud2() {
                         document.getElementById('State').innerText = OldWeatherString + " Cloud 2";
                         document.getElementById("Cloud2").style.visibility = 'visible';
                         document.getElementById("Cloud2").style.webkitAnimationPlayState = "running";
                      function HideCloud2() {
                         document.getElementById("Cloud2").style.visibility = 'hidden';
                         document.getElementById("Cloud2").style.webkitAnimationPlayState = "paused";
                      function ShowCloud3() {
                         document.getElementById('State').innerText = OldWeatherString + " Cloud 3";
                         document.getElementById("Cloud3").style.visibility = 'visible';
                         document.getElementById("Cloud3").style.webkitAnimationPlayState = "running";
                      function HideCloud3() {
                         document.getElementById("Cloud3").style.visibility = 'hidden';
                         document.getElementById("Cloud3").style.webkitAnimationPlayState = "paused";
                         document.querySelector('.AnimateCloud').style.setProperty('--Cloud-Y1', '-10%');
                      function ShowCloud4() {
                         document.getElementById('State').innerText = OldWeatherString + " Cloud 4";
                         document.getElementById("Cloud4").style.visibility = 'visible';
                         document.getElementById("Cloud4").style.webkitAnimationPlayState = "running";
                         document.querySelector('.AnimateChildCloud').style.setProperty('--CloudChild-Y1', '-10%');
                         document.querySelector('.AnimateCloud').style.setProperty('--CloudSub-Y1', '-20%');
                      function HideCloud4() {
                         document.getElementById("Cloud4").style.visibility = 'hidden';
                         document.getElementById("Cloud4").style.webkitAnimationPlayState = "paused";
                      function ShowCloud5() {
                         document.getElementById('State').innerText = OldWeatherString + " Cloud 5";
                         document.getElementById("Cloud5").style.visibility = 'visible';
                         document.getElementById("Cloud5").style.webkitAnimationPlayState = "running";
                         document.querySelector('.AnimateSubCloud').style.setProperty('--CloudSub-Y1', '-11%');
                      function HideCloud5() {
                         document.getElementById("Cloud5").style.visibility = 'hidden';
                         document.getElementById("Cloud5").style.webkitAnimationPlayState = "paused";
                      //======================================Rain=======================================================================
                      function ShowRain() {
                         document.getElementById('State').innerText = OldWeatherString + " Rain";
                         document.getElementById("RainDrop1").style.visibility = 'visible';
                         document.getElementById("RainDrop2").style.visibility = 'visible';
                         document.getElementById("RainDrop3").style.visibility = 'visible';
                         document.getElementById("RainDrop4").style.visibility = 'visible';
                         document.getElementById("RainDrop5").style.visibility = 'visible';
                         document.getElementById("RainDrop6").style.visibility = 'visible';
                         document.getElementById("RainDrop7").style.visibility = 'visible';
                         document.getElementById("RainDrop8").style.visibility = 'visible';
                         document.getElementById("RainDrop9").style.visibility = 'visible';
                         document.getElementById("RainDrop10").style.visibility = 'visible';
                         document.getElementById("RainDrop1").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop2").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop3").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop4").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop5").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop6").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop7").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop8").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop9").style.webkitAnimationPlayState = "running";
                         document.getElementById("RainDrop10").style.webkitAnimationPlayState = "running";
                      function HideRain() {
                         document.getElementById("RainDrop1").style.visibility = 'hidden';
                         document.getElementById("RainDrop2").style.visibility = 'hidden';
                         document.getElementById("RainDrop3").style.visibility = 'hidden';
                         document.getElementById("RainDrop4").style.visibility = 'hidden';
                         document.getElementById("RainDrop5").style.visibility = 'hidden';
                         document.getElementById("RainDrop6").style.visibility = 'hidden';
                         document.getElementById("RainDrop7").style.visibility = 'hidden';
                         document.getElementById("RainDrop8").style.visibility = 'hidden';
                         document.getElementById("RainDrop9").style.visibility = 'hidden';
                         document.getElementById("RainDrop10").style.visibility = 'hidden';
                         document.getElementById("RainDrop1").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop2").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop3").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop4").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop5").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop6").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop7").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop8").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop9").style.webkitAnimationPlayState = "paused";
                         document.getElementById("RainDrop10").style.webkitAnimationPlayState = "paused";
                      function Rain1() {
                         document.getElementById("RainDrop1").style.animationDuration = "800ms";
                         document.getElementById("RainDrop2").style.animationDuration = "800ms";
                         document.getElementById("RainDrop3").style.animationDuration = "800ms";
                         document.getElementById("RainDrop4").style.animationDuration = "800ms";
                         document.getElementById("RainDrop5").style.animationDuration = "800ms";
                         document.getElementById("RainDrop6").style.animationDuration = "800ms";
                         document.getElementById("RainDrop7").style.animationDuration = "800ms";
                         document.getElementById("RainDrop8").style.animationDuration = "800ms";
                         document.getElementById("RainDrop9").style.animationDuration = "800ms";
                         document.getElementById("RainDrop10").style.animationDuration = "800ms";
                      function Rain2() {
                         document.getElementById("RainDrop1").style.animationDuration = "600ms";
                         document.getElementById("RainDrop2").style.animationDuration = "600ms";
                         document.getElementById("RainDrop3").style.animationDuration = "600ms";
                         document.getElementById("RainDrop4").style.animationDuration = "600ms";
                         document.getElementById("RainDrop5").style.animationDuration = "600ms";
                         document.getElementById("RainDrop6").style.animationDuration = "600ms";
                         document.getElementById("RainDrop7").style.animationDuration = "600ms";
                         document.getElementById("RainDrop8").style.animationDuration = "600ms";
                         document.getElementById("RainDrop9").style.animationDuration = "600ms";
                         document.getElementById("RainDrop10").style.animationDuration = "600ms";
                      function Rain3() {
                         document.getElementById("RainDrop1").style.animationDuration = "300ms";
                         document.getElementById("RainDrop2").style.animationDuration = "300ms";
                         document.getElementById("RainDrop3").style.animationDuration = "300ms";
                         document.getElementById("RainDrop4").style.animationDuration = "300ms";
                         document.getElementById("RainDrop5").style.animationDuration = "300ms";
                         document.getElementById("RainDrop6").style.animationDuration = "300ms";
                         document.getElementById("RainDrop7").style.animationDuration = "300ms";
                         document.getElementById("RainDrop8").style.animationDuration = "300ms";
                         document.getElementById("RainDrop9").style.animationDuration = "300ms";
                         document.getElementById("RainDrop10").style.animationDuration = "300ms";
                      //======================================Snow======================================================================
                      function RandomSnow(min, max) {
                         var time;
                         //setInterval(function() {
                         time = randomInterval(min, max);
                         document.querySelector('.fallingSnow-1').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-2').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-3').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-4').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-5').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-6').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-7').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-8').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-9').style.setProperty('--animation-time', time + 's');
                         document.querySelector('.fallingSnow-10').style.setProperty('--animation-time', time + 's');
                         //}, 7000);
                      function ShowSnow() {
                         document.getElementById('State').innerText = OldWeatherString + " Snow";
                         document.getElementById("Snow-1").style.visibility = 'visible';
                         document.getElementById("Snow-2").style.visibility = 'visible';
                         document.getElementById("Snow-3").style.visibility = 'visible';
                         document.getElementById("Snow-4").style.visibility = 'visible';
                         document.getElementById("Snow-5").style.visibility = 'visible';
                         document.getElementById("Snow-6").style.visibility = 'visible';
                         document.getElementById("Snow-7").style.visibility = 'visible';
                         document.getElementById("Snow-8").style.visibility = 'visible';
                         document.getElementById("Snow-9").style.visibility = 'visible';
                         document.getElementById("Snow-10").style.visibility = 'visible';
                         document.getElementById("Snow-1").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-2").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-3").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-4").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-5").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-6").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-7").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-8").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-9").style.webkitAnimationPlayState = "running";
                         document.getElementById("Snow-10").style.webkitAnimationPlayState = "running";
                      function HideSnow() {
                         document.getElementById("Snow-1").style.visibility = 'hidden';
                         document.getElementById("Snow-2").style.visibility = 'hidden';
                         document.getElementById("Snow-3").style.visibility = 'hidden';
                         document.getElementById("Snow-4").style.visibility = 'hidden';
                         document.getElementById("Snow-5").style.visibility = 'hidden';
                         document.getElementById("Snow-6").style.visibility = 'hidden';
                         document.getElementById("Snow-7").style.visibility = 'hidden';
                         document.getElementById("Snow-8").style.visibility = 'hidden';
                         document.getElementById("Snow-9").style.visibility = 'hidden';
                         document.getElementById("Snow-10").style.visibility = 'hidden';
                         document.getElementById("Snow-1").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-2").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-3").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-4").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-5").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-6").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-7").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-8").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-9").style.webkitAnimationPlayState = "paused";
                         document.getElementById("Snow-10").style.webkitAnimationPlayState = "paused";
                      //======================================Lightning================================================================
                      function ShowLightning() {
                         document.getElementById('State').innerText = OldWeatherString + " Lightning";
                         document.getElementById('Lightning').style.visibility = 'visible';
                         document.getElementById('LightningChild').style.visibility = 'visible';
                         document.getElementById('LightningSub').style.visibility = 'visible';
                         document.getElementById('LightningBack').style.visibility = 'visible';
                         document.getElementById("Lightning").style.webkitAnimationPlayState = "running";
                         document.getElementById("LightningChild").style.webkitAnimationPlayState = "running";
                         document.getElementById("LightningSub").style.webkitAnimationPlayState = "running";
                         document.getElementById("LightningBack").style.webkitAnimationPlayState = "running";
                         //}, 500);
                      function HideLightning() {
                         document.getElementById("Lightning").style.webkitAnimationPlayState = "paused";
                         document.getElementById("LightningChild").style.webkitAnimationPlayState = "paused";
                         document.getElementById("LightningSub").style.webkitAnimationPlayState = "paused";
                         document.getElementById("LightningBack").style.webkitAnimationPlayState = "paused";
                         document.getElementById('Lightning').style.visibility = 'hidden';
                         document.getElementById('LightningChild').style.visibility = 'hidden';
                         document.getElementById('LightningSub').style.visibility = 'hidden';
                         document.getElementById('LightningBack').style.visibility = 'hidden';
                         //}, 500);
                      //======================================Wind==================================================================
                      var LeafTimer1, LeafTimer2;
                      if (isNumber(WindValue)) {
                         console.log("New Wind: " + WindValue);
                         if (WindValue > 13) {
                             AnimateLeaf();
                             AnimateLeaf2();
                         } else {
                      function AnimateLeaf() {
                         var LeafX1Pos = randomInterval(-200, 150);
                         var LeafX2Pos = randomInterval(50, 100);
                         var LeafX3Pos = randomInterval(-300, 150);
                         var LeafX4Pos = randomInterval(300, 400);
                         var LeafX5Pos = randomInterval(150, 200);
                         var LeafX6Pos = randomInterval(-200, 150);
                         var LeafX7Pos = randomInterval(400, 450);
                         var LeafX8Pos = randomInterval(0, 100);
                         var LeafX9Pos = randomInterval(-200, 450);
                         var LeafX10Pos = randomInterval(-200, -300);
                         var LeafZ1Pos = randomInterval(8, 12);
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X1', LeafX1Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X2', LeafX2Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X3', LeafX3Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X4', LeafX4Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X5', LeafX5Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X6', LeafX6Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X7', LeafX7Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X8', LeafX8Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X9', LeafX9Pos + 'px');
                         document.querySelector('.AnimateWind').style.setProperty('--Leaf-X10', LeafX10Pos + 'px');
                         ShowLeaf();
                         LeafTimer1 = setTimeout(function() {
                             HideLeaf();
                             document.querySelector('.AnimateWind').style.setProperty('--Leaf-Z1', LeafZ1Pos + 's');
                             AnimateLeaf();
                         }, LeafZ1Pos * 1000);
                      function ShowLeaf() {
                      function HideLeaf() {
                      function AnimateLeaf2() {
                         var Leaf2X1Pos = randomInterval(-200, 250);
                         var Leaf2X2Pos = randomInterval(50, 100);
                         var Leaf2X3Pos = randomInterval(-350, -400);
                         var Leaf2X4Pos = randomInterval(-200, 250);
                         var Leaf2X5Pos = randomInterval(-200, 150);
                         var Leaf2X6Pos = randomInterval(200, 250);
                         var Leaf2Z1Pos = randomInterval(8, 12);
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X1', Leaf2X1Pos + 'px');
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X2', Leaf2X2Pos + 'px');
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X3', Leaf2X3Pos + 'px');
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X4', Leaf2X4Pos + 'px');
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X5', Leaf2X5Pos + 'px');
                         document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-X6', Leaf2X6Pos + 'px');
                         ShowLeaf2();
                         LeafTimer2 = setTimeout(function() {
                             HideLeaf2();
                             document.querySelector('.AnimateSubWind').style.setProperty('--Leaf2-Z1', Leaf2Z1Pos + 's');
                             AnimateLeaf2();
                         }, Leaf2Z1Pos * 1000);
                      function ShowLeaf2() {
                      function HideLeaf2() {
                      //======================================Icicle=======================================================================
                      var IcicleShrink, IcicleShrink2;
                      var WIcicle = 1;
                      var HIcicle = 1;
                      var YIcicle = 0;
                      var W1Icicle = 270;
                      var W2Icicle = 300;
                      var IcicleMove;
                      let BrGlVal = 1;
                      var BrokenGlass;
                      var NewIcicle;
                      let NeIcVal = -100;
                      document.getElementById('IcicleSub2').style.visibility = 'hidden';
                      IcicleShrink = setInterval(function() {
                         ShrinkIcicle();
                      }, 1000);
                      function ShrinkIcicle() {
                         //WIcicle -= 0.00625;
                         //HIcicle -= 0.00625;
                         YIcicle -= 0.625;
                         W1Icicle -= 1.875;
                         W2Icicle -= 1.875;
                         if (WIcicle <= 0.6) {
                             WIcicle = 1;
                         if (HIcicle <= 0.6) {
                             HIcicle = 1;
                         if (YIcicle <= -50) {
                             console.log("Shrink Icicle Y: " + YIcicle + " Icicle W: " + WIcicle + " Icicle H: " + HIcicle);
                             YIcicle = -30;
                         	WIcicle = 0.7;
                         	HIcicle = 0.6;
                         	document.querySelector('.Icicle-1').style.setProperty('--animation-W', WIcicle);
                         	document.querySelector('.Icicle-1').style.setProperty('--animation-H', HIcicle);
                         	document.querySelector('.Icicle-1').style.setProperty('--animation-Y', YIcicle + '%');
                             clearTimeout(IcicleShrink);
                         	clearTimeout(IcicleShrink2);
                                 var iC = -30;
                         	   IcicleMove = setInterval(function() {
                         			document.querySelector('.Icicle-1').style.setProperty('--animation-Y', iC + '%');
                         			iC += 50;
                                     if (iC > 230) {
                         			    document.getElementById('IcicleSub1').style.visibility = 'hidden';
                                         document.getElementById("IcicleSub1").style.webkitAnimationPlayState = "paused";
                         			    document.getElementById('IcicleSub2').style.visibility = 'visible';
                         				document.getElementById("IcicleSub2").style.opacity = "1";
                                         clearTimeout(IcicleMove);
                         				document.querySelector('.Icicle-1').style.setProperty('--animation-W', "3");
                         				document.querySelector('.Icicle-1').style.setProperty('--animation-H', "0.05");
                         				document.getElementById("Icicle1").style.filter = "blur(5px)";
                         					document.getElementById("Icicle1").style.opacity = "0.5";
                         					document.getElementById("Icicle1").style.filter = "blur(10px)";
                         				}, 200);
                         					document.getElementById('Icicle1').style.visibility = 'hidden';
                         					document.getElementById("Icicle1").style.opacity = "0.2";
                         				}, 300);
                         					document.getElementById("Icicle1").style.opacity = "1";
                         					document.getElementById("Icicle1").style.filter = "blur(0px)";
                         				}, 500);
                         				BrGlVal = 1;
                         				BrokenGlass = setInterval(function() {
                         				BrGlVal -= 0.1;
                         				//console.log(BrGlVal);
                         				document.getElementById("IcicleSub2").style.opacity = BrGlVal;
                         				if (Number(BrGlVal) >= 0) {clearTimeout(BrokenGlass);}
                         				}, 3000);
                         				NeIcVal = -100;
                         				NewIcicle = setInterval(function() {
                         				    if (Number(NeIcVal) <= -5) {
                         				        NeIcVal += 5;}
                         					//console.log(NeIcVal);
                         				    document.querySelector('.Icicle-1').style.setProperty('--animation-Y', NeIcVal + '%');
                         				    WIcicle = 1;
                         					HIcicle = 1;
                         					document.getElementById('Icicle1').style.visibility = 'visible';
                         				}, 1000);
                                         YIcicle = 0;
                         				    clearTimeout(NewIcicle);
                         				    IcicleShrink2 = setInterval(function() {
                         					    document.querySelector('.Icicle-1').style.setProperty('--animation-Y', '5%');
                         					    document.getElementById('IcicleSub1').style.visibility = 'visible';
                                                 document.getElementById("IcicleSub1").style.webkitAnimationPlayState = "running";
                                                 ShrinkIcicle();
                         					}, 1000);
                         				}, 20000);
                                 }, 50);
                             }, 2000);
                         if (W1Icicle <= 120) {
                             W1Icicle = 270;
                         if (W2Icicle <= 150) {
                             W2Icicle = 300;
                         document.querySelector('.IcicleWater-1').style.setProperty('--animation-W1', W1Icicle + '%');
                         document.querySelector('.IcicleWater-1').style.setProperty('--animation-W2', W2Icicle + '%');
                      //======================================Helper======================================================================
                      function randomInterval(min, max) { // min and max included
                         return Math.floor(Math.random() * (max - min + 1) + min)
                      function makeNewPosition(CalcleafPos) {
                         var NewCalcleafPos = Math.floor(Math.random() * CalcleafPos);
                         return NewCalcleafPos;
                      function isNumber(i) {
                         return !isNaN(i && i !== true ? Number(i) : parseFloat(i)) && [Number.POSITIVE_INFINITY, Number.NEGATIVE_INFINITY].indexOf(i) === -1;
                      void setInterval( () => {
                         setTimeout( function () {}, 1000)
                      }, 100)
                      </script>
                      </body></html>
                      Die Bilder sind unter /vis.0/Wetter/myweather/
                        @glasfaser
                        Hallo, kommt das bei dir auch im Skript?
                        javascript.0
                        2021-08-28 18:00:14.838	error	at processImmediate (internal/timers.js:461:21)
                        javascript.0
                        2021-08-28 18:00:14.838	error	at Immediate.<anonymous> (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:5706:41)
                        javascript.0
                        2021-08-28 18:00:14.838	error	at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:525:29)
                        javascript.0
                        2021-08-28 18:00:14.838	error	at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1087:38)
                        javascript.0
                        2021-08-28 18:00:14.838	error	at Object.<anonymous> (script.js.Sigi.myweather:15:49)
                        javascript.0
                        2021-08-28 18:00:14.837	error	script.js.Sigi.myweather: TypeError: Cannot read property 'slice' of undefined
                        javascript.0
                        2021-08-28 17:51:06.590	error	at processImmediate (internal/timers.js:461:21)
                        javascript.0
                        2021-08-28 17:51:06.590	error	at Immediate.<anonymous> (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:5706:41)
                        javascript.0
                        2021-08-28 17:51:06.590	error	at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:525:29)
                        javascript.0
                        2021-08-28 17:51:06.590	error	at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1087:38)
                        javascript.0
                        2021-08-28 17:51:06.590	error	at Object.<anonymous> (script.js.Sigi.myweather:15:49)
                        javascript.0
                        2021-08-28 17:51:06.589	error	script.js.Sigi.myweather: TypeError: Cannot read property 'slice' of undefined
                        javascript.0
                        2021-08-28 17:00:14.555	error	at Immediate.<anonymous> (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:5706:41)
                        javascript.0
                        2021-08-28 17:00:14.555	error	at Object.callback (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\lib\sandbox.js:1087:38)
                        javascript.0
                        2021-08-28 17:00:14.554	error	at Object.<anonymous> (script.js.Sigi.myweather:15:49)
                        javascript.0
                        2021-08-28 17:00:14.555	error	at Object.stateChange (C:\Program Files\iobroker\Home\node_modules\iobroker.javascript\main.js:525:29)
                        javascript.0
                        2021-08-28 17:00:14.555	error	at processImmediate (internal/timers.js:461:21)
                        javascript.0
                        2021-08-28 17:00:14.554	error	script.js.Sigi.myweather: TypeError: Cannot read property 'slice' of undefined
                        • Glasfaser
                          @sigi234
                          Nein kein Fehler , welches Script hast du genommen ?
                          Hast du beide Datenpunkte angelegt
                          ( so bei mir ) :
                            @sigi234
                            ( so bei mir ) :
                            Ja , dein Skript
                            • Glasfaser
                              @sigi234
                              Du Editer ..... war gerad am schreiben ....
                              Hast du den vorhanden :
                                @glasfaser
                                Ja
                                • Glasfaser
                                  @sigi234
                                  Trigger mal den Wert in
                                  Das steht bei mir
                                  /adapter/daswetter/icons/tiempo-weather/galeria1/6.png
                                  ändere mal auf
                                  adapter/daswetter/icons/tiempo-weather/galeria1/1. png
                                  Es kommt eine Fehlermeldung von dasWetter aber nicht beachten .
                                  .... so das das Script selber triggert
                                    Das steht bei mir
                                    Habe ja andere Icons bei mir
                                    /vis.0/Wettericons/Wetter Hd/3.png
                                    • Glasfaser
                                      @sigi234
                                      er holt sich hier den Wert her ,und slice Ihn ,
                                      obwohl die Nummer in den Datenpunkt auch bei dir schreibt
                                      nur dann anschließend nicht in
                                      Habe mich nur kurz mit dem Script befasst .
                                        Jupp, DP ist leer.
                                        • OliverIO
                                          OliverIO @wawyo last edited by
                                          @wawyo
                                          cih dachte das sei eher sowas
                                          • Nashra
                                            Nashra Most Active Forum Testing @OliverIO last edited by
                                            @oliverio sagte in Real Weather (Bald):
                                            @wawyo
                                            1.0k
                                            43
                                            6193
