    4. Easee Wallbox mit iobroker
    • Newan
      Newan @Scotty89 last edited by
      @scotty89 Nur cloud
        stonemaan @Newan last edited by
        @newan ich habe heute morgen signalR angeschaltet. leider ist der adapter nach einiger Zeit wieder auf gelb gesprungen. Ich habe heute allerdings auch den JS controller geupdated und NodeJS auch..
        2021-08-06 11:34:42.697 - error: easee.0 (1381) Error: Request failed with status code 503
        2021-08-06 11:34:42.698 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
        2021-08-06 11:34:42.704 - error: easee.0 (1381) Error: Request failed with status code 503
        2021-08-06 11:34:42.705 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
        2021-08-06 11:34:53.251 - error: easee.0 (1381) SignalR Verbindung beendet!!!- restart
        2021-08-06 11:34:53.379 - error: easee.0 (1381) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-08-06 11:34:53.380 - error: easee.0 (1381) unhandled promise rejection: Service Temporarily Unavailable
        2021-08-06 11:34:53.381 - error: easee.0 (1381) Error: Service Temporarily Unavailable
        at new HttpError (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/Errors.js:27:24)
        at FetchHttpClient. (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:154:35)
        at step (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:52:23)
        at Object.next (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:33:53)
        at fulfilled (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:24:58)
        at runMicrotasks ()
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
        2021-08-06 11:34:53.381 - error: easee.0 (1381) Service Temporarily Unavailable
        2021-08-06 11:34:53.384 - info: easee.0 (1381) Adaptor easee cleaned up everything...
        2021-08-06 11:34:53.384 - info: easee.0 (1381) terminating
        2021-08-06 11:34:53.385 - warn: easee.0 (1381) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-08-06 11:35:02.486 - info: easee.0 (7331) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.easee, node: v12.22.4, js-controller: 3.3.15
        2021-08-06 11:35:02.742 - error: easee.0 (7331) Api login error - check Username and password
        Ich beobachte mal weiter
        Newan 1 Reply Last reply Reply Quote 0
        • Newan
          Newan @stonemaan last edited by
          @stonemaan ok ist aber 1.0.3?
          Schau mir das nochmal an
            @newan jo... 1.0.3
              Aiouh @stonemaan last edited by
              @Newan
              Ich bekomme seit Heute mit der 1.0.3 folg. Fehler
              easee.0	2021-08-06 23:14:23.569	error	(8630) Api login error - check Username and password
              Es wurde aber an user & passwort nichts geändert 😞
              • Newan
                Newan @Aiouh last edited by
                @aiouh mal aus der App abmelden und versuchen da wieder anzumelden. Die erros kommen ja direkt von der api
                  Aiouh @Newan last edited by
                  @newan said in Easee Wallbox mit iobroker:
                  abmelden aus der App hat leider nichts gebracht, nach Neustart des ioBroker ist aber wieder alles im Lot.
                  Ist 1.0.3 eigentlich die aktuelle?
                    @newan heute wieder der gleiche Fehler... ohne erkennbaren Grund. liegt wohl an SignalR. schalte es vorerst wieder aus ^^
                    • The Spirit
                      The Spirit last edited by
                      ich habe gerade noch das hier gefunden
                      https://github.com/fondberg/pyeasee/issues/35#issuecomment-760378451
                      von daher wäre es schon gut, wenn man auch die circuit dynamic currents schreiben könnte.
                      für mich ist dies relevant, da ich pv Überschuss laden will. so kann ich am Anfang nur mit einer Phase laden und dann einfach auf drei umschalten wenn genügend ström da ist ohne den Phasenmodus "echt" wechseln zu müssen (der Phasenmodus soll ja auch nicht zu oft umgeschalten werden, da dieser auch in den Flash geschrieben wird).
                      Danke für deine Tolle Arbeit
                      jscmidt created this issue in fondberg/pyeasee
                      closed 1-Phase Charching #35
                        Aiouh @The Spirit last edited by
                        @newan
                        Mittlerweile läuft mein Überschussladen mit der Easee recht gut, nochmal vielen Dank für den Adapter, habe damit bisher 663kWh in den e-Soul geschoben.
                        Ich frage bisher nur alle 10 Minuten den Überschuss ab und regle dann nach, denn erstens braucht das Fahrzeug ja auch ne ganze Weile bis es nachregelt UND...jetzt komme ich wieder zum Punkt - ich will das flash der Easee home nicht vorzeitig zerstören. DynamicCircuitCurrent läuft ja noch nicht 😞
                        Du hattest mal geschrieben dass die dynamiCircuitCurrent objekte nur "read only" sind und somit auch nicht an die API gesendet werden. Mir ist völlig klar, dass die Arbeit hier vermutlich eh schon zu viel Deiner Zeit frisst und ich kann ja leider selbst nicht programmieren, trotzdem frage ich mal gaaanz vorsichtig ob Du das mit dem DynamicCircuitCurrent vielleicht schon auf dem Plan hast 😉 ?
                          stonemaan @Aiouh last edited by
                          Hi @aiouh warum nutzt du nicht die DynamicChargerCurrent? Damit regle ich meine Easee auf den Pv Überschuss und die soll nicht „abnutzen“ 😉
                            Aiouh @stonemaan last edited by Aiouh
                            @stonemaan Hmm, das hört sich ja sehr gut an. Wird damit dann der Strom gleichmässig auf die genutzten Phasen verteilt ?
                            Also z. bei 20A einphasig =20A, zweiphasig je Phase 10A?
                              @aiouh oh, das kann ich dir nicht genau sagen, da ich nur nen Plugin Hybriden habe, der maximal mit unfassbaren 2.9kw an einer Phase lädt. Ich meine in Erinnerung zu haben, dass an einem anderen Auto alle Phasen gleichmäßig runtergeregelt wurden. Probiers doch mal aus 🙂
                                @stonemaan Ich habe das gerade mal mit dem dem einphasigen getestet, klappts schon prima. Werde das mit dem zweiphasigen dann später testen. Dann stelle ich mal noch mein Script um.
                                DANKE
                                Newan Uli977 2 Replies Last reply Reply Quote 0
                                • Newan
                                  @aiouh DynamicCircuitCurrent bin ich dran, meine Kinder haben aber derzeit Vorrang. Sobald Zeit kommt ein Update
                                  A S 2 Replies Last reply Reply Quote 0
                                    @newan Keine Eile, mit dem Tip von Stoneman komm ich ja schon gut weiter.
                                    • Uli977
                                      Uli977 @stonemaan last edited by Uli977
                                      kann mir jemand sagen warum ich regelmäßig diese Meldung bekomme?
                                      Danke Euch!
                                      • Uli977
                                        Uli977 @Aiouh last edited by
                                        @aiouh Hast du dein Skript nochmal umgestellt. Aktuell ist es bei mir so, dass wenn er z.B. auf 10A regelt, jede Phase mit 10A geregelt wird und somit zu viel Leistung herausgegeben wird.
                                          schweiger2 @Newan last edited by
                                          @newan
                                          ich erhalte seit einigen Tagen folgende Fehlermeldung(en). Weder Adapter-Restart noch ioBroker-Restart schaffen Abhilfe. Woran liegt das ? haben andere auch damit zu tun ?
                                          2021-10-13 15:22:14.266 - error: easee.0 (4558) Error: Request failed with status code 403
                                          2021-10-13 15:22:14.267 - warn: easee.0 (4558) No Chargers found!
                                          2021-10-13 15:23:14.376 - error: easee.0 (4558) Error: Request failed with status code 403
                                          2021-10-13 15:23:14.377 - warn: easee.0 (4558) No Chargers found!
                                          Beste Grüße
                                          • Newan
                                            Newan @Uli977 last edited by
                                            @uli977 Das sollte behoben sei in der 1.0.4, teste mal bitte
                                            adapter easee wallbox
                                            60
                                            510
                                            95972
