    4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
    • Dutchman
      Dutchman Developer Most Active Administrators last edited by Dutchman
      0.6.0-1 released
      0.6.0-1 (2021-08-28)
      (DutchmanNL) System load reduced
      (DutchmanNL) Communication by websocket implemented, this feature allows live data updates (instead of interval polling). Requires WLED firmware >= 12
      • Palm_Maniac
        Palm_Maniac last edited by
        ich hab gerade auf die neue Version 0.60.0-2 aktualisiert und jetzt reagiert kein WLED-Licht mehr. Das Log wird mit diesen Einträgen geflutet:
        2021-08-29 12:22:39.912 - info: host.Server(KuhnHome) Updating repository "Beta (latest)" under "http://download.iobroker.net/sources-dist-latest.json"
        2021-08-29 12:22:56.205 - info: wled.0 (2761329) Initialising : " WLED-Treppe-Keller" on IP : 192.168.2.41
        2021-08-29 12:22:56.215 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.234 - info: wled.0 (2761329) WLED-Treppe-Keller connected
        2021-08-29 12:22:56.260 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.285 - info: wled.0 (2761329) WLED-Treppe-Keller disconnected
        2021-08-29 12:22:56.426 - info: wled.0 (2761329) Initialising : " WLED-Wohnzimmer" on IP : 192.168.2.42
        2021-08-29 12:22:56.434 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.452 - info: wled.0 (2761329) WLED-Wohnzimmer connected
        2021-08-29 12:22:56.518 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.525 - info: wled.0 (2761329) WLED-Wohnzimmer disconnected
        2021-08-29 12:22:56.562 - info: wled.0 (2761329) Initialising : " WLED-Treppe-OG" on IP : 192.168.2.40
        2021-08-29 12:22:56.569 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.583 - info: wled.0 (2761329) WLED-Treppe-OG connected
        2021-08-29 12:22:56.593 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:22:56.634 - info: wled.0 (2761329) WLED-Treppe-OG disconnected
        2021-08-29 12:23:26.264 - info: wled.0 (2761329) Initialising : " WLED-Treppe-Keller" on IP : 192.168.2.41
        2021-08-29 12:23:26.271 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.288 - info: wled.0 (2761329) WLED-Treppe-Keller connected
        2021-08-29 12:23:26.300 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.311 - info: wled.0 (2761329) WLED-Treppe-Keller disconnected
        2021-08-29 12:23:26.521 - info: wled.0 (2761329) Initialising : " WLED-Wohnzimmer" on IP : 192.168.2.42
        2021-08-29 12:23:26.528 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.589 - info: wled.0 (2761329) WLED-Wohnzimmer connected
        2021-08-29 12:23:26.600 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.603 - info: wled.0 (2761329) Initialising : " WLED-Treppe-OG" on IP : 192.168.2.40
        2021-08-29 12:23:26.612 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.620 - info: wled.0 (2761329) WLED-Wohnzimmer disconnected
        2021-08-29 12:23:26.626 - info: wled.0 (2761329) WLED-Treppe-OG connected
        2021-08-29 12:23:26.644 - info: wled.0 (2761329) [Error caught and sent to Sentry, thank you for collaborating!] error: [handleStates] TypeError: Cannot read property 'initialized' of undefined
        2021-08-29 12:23:26.651 - info: wled.0 (2761329) WLED-Treppe-OG disconnected
        Ich werde wohl erstmal einen Downgrade durchführen müssen, um meine Lichter wieder Gangbar zu machen.
        • Dutchman
          Dutchman Developer Most Active Administrators @Palm_Maniac last edited by
          @palm_maniac sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
          Danke fürs log, muss da heute Abend nochmal ran für beatimmte Firmwares
            Einstein67 @Dutchman last edited by
            Mit Version 13b2 läuft die neue Version problemlos!
            Palm_Maniac Dutchman 2 Replies Last reply Reply Quote 0
            • Palm_Maniac
              Palm_Maniac @Einstein67 last edited by
              @einstein67 Läuft die 0.13b2 denn stabil? Es wird ja gewarnt und ich kann mir da Probleme nicht leisten.
              da_Woody E 2 Replies Last reply Reply Quote 0
              • da_Woody
                da_Woody @Palm_Maniac last edited by
                @palm_maniac wenn du dir probleme nicht leisten kannst/willst, dann lass es. wenn du es nicht probierst, wirst du es nie wissen.
                hast du vllt keine backups?
                könnte ja auch sein, daß einer keine probs hat, ein anderer schon. jede install ist anders...
                  Einstein67 @Palm_Maniac last edited by Einstein67
                  @palm_maniac Also ich konnte keine Probleme mit der Beta2 feststellen. Das einzige war, dass sich ein WemosD1 beim Update über WLAN verabschiedet hat. Da musste ich kurz mit dem Kabel ran.
                  Hab jetzt 3 Lampen testweise auf V12 gebracht. Auch damit gibts keine Probleme mit der aktuellen Adapter Version.
                  Palm_Maniac 1 Reply Last reply Reply Quote 0
                  • Dutchman
                    Dutchman Developer Most Active Administrators @Einstein67 last edited by Dutchman
                    @einstein67 sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                    Danke damit bestätigt sich meine Vermutung und weis ich auch wo es schief geht ich lade hier auf meiner dev Umgebung mal alles ein von wled 0.10 bis 0.13 und probiere alle Versionen zu unterstützen
                    Aber erst Formel 1 schauen
                    • da_Woody
                      da_Woody @Dutchman last edited by
                      @dutchman sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                      da ist halt nicht viel zu sehn... 😄
                      • Dutchman
                        Dutchman Developer Most Active Administrators @da_Woody last edited by
                        @da_woody sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                        Man oh man ja heute ist echt schlimm das komplette Rennen wird sowieso nix mehr
                        Schade die start Aufstellung ist interessant
                        • da_Woody
                          @dutchman as u say. wirklich schade. regenrennen wäre interessannt gewesen, aber so hat das keinen sinn...
                          läuft halt wieder mal alles für mercedes... unglaublich manchmal...
                          • Dutchman
                            Offtopic *
                            Wen ich an 10-15 Jahre zurück denke, regen… egal starten auch wen nur 6 ins Ziel kommen schöne alte Zeit 😁
                            da_Woody 1 Reply Last reply Reply Quote 2
                              Einstein67 @Dutchman last edited by Einstein67
                              @dutchman said in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                              Ich hatte leider das Log auf Warnung gestellt. Mit Info hab ich jetzt gesehen dass die WLED-Instanz im Minutentakt die LEDs rauswirft und neu verbindet.
                              wled.0 2021-08-29 17:14:55.777	info	NicNac-Ku disconnected
                              wled.0 2021-08-29 17:14:55.757	info	NicNac-Ku connected
                              wled.0 2021-08-29 17:14:55.724	info	Initialising : " NicNac-Ku" on IP : 192.168.0.193
                              wled.0 2021-08-29 17:14:55.355	info	Bild-Wz disconnected
                              wled.0 2021-08-29 17:14:55.337	info	Bild-Wz connected
                              wled.0 2021-08-29 17:14:55.309	info	Initialising : " Bild-Wz" on IP : 192.168.0.191
                              wled.0 2021-08-29 17:13:55.628	info	NicNac-Ku disconnected
                              wled.0 2021-08-29 17:13:55.610	info	NicNac-Ku connected
                              wled.0 2021-08-29 17:13:55.575	info	Initialising : " NicNac-Ku" on IP : 192.168.0.193
                              wled.0 2021-08-29 17:13:55.187	info	Bild-Wz disconnected
                              wled.0 2021-08-29 17:13:55.168	info	Bild-Wz connected
                              wled.0 2021-08-29 17:13:55.137	info	Initialising : " Bild-Wz" on IP : 192.168.0.191
                              wled.0 2021-08-29 17:12:55.569	info	NicNac-Ku disconnected
                              wled.0 2021-08-29 17:12:55.548	info	NicNac-Ku connected
                              • da_Woody
                                Offtopic *
                                jep, leider off, aber als admin kannst du das ja auslagern... 😄
                                gehört nicht da her. ich geh jetzt in mein stammlokal auf ein bier... keine lust mehr zu warten.
                                • Dutchman
                                  Welche fw?
                                    Welche fw?
                                    Mit der WLED Version 13b2 und Adapter 0.60.0-2 tritt das auf.
                                    • Dutchman
                                      die Probleme sollte mit v0.6.0-3 behoben sein, hab probiert mit
                                      0.10.x
                                      0.12.x
                                      0.13.x (inclusive letzten build von git)
                                      • Palm_Maniac
                                        @einstein67 Meine NodeMCUs sind alle so verbaut, dass ich nicht mal eben ran kann, deshalb wäre es schlimm, wenn sie aussteigen und ich mit dem Kabel ran müßte. Aktuell läuft bei mir die 0.12.
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @Palm_Maniac last edited by Dutchman
                                          0.12 ist supported ab 0.6.0-3 das sollte kein problem sein
                                          PS: Flahen geht bei WLED per OTA (Webinterface) nur wen das schief geht musste per USB dran
                                          crunchip E 2 Replies Last reply Reply Quote 1
                                            crunchip Forum Testing Most Active @Dutchman last edited by
                                            Ging bei mir schon 3mal schief, zum Glück hängen die wemos frei herum🤣
                                            79.9k
                                            adapater adapter neu hier test testen tester wled
                                            73
                                            655
                                            141643
