    4. Adapter "smartmeter"
    • Scotty89
      Scotty89 last edited by Homoran
      Hey,
      sorry hab den log vergessen 😉
      hier der auszug vom Log wenn man den adapter startet in "Debug Mode"
      smartmeter.0
      2021-08-28 19:32:54.811	debug	connected set to false
      smartmeter.0
      2021-08-28 19:32:54.721	debug	SET MESSAGE TIMEOUT TIMER: 120000
      smartmeter.0
      2021-08-28 19:32:54.713	debug	CREATE SERIALPORT: 9600 8 1 none
      smartmeter.0
      2021-08-28 19:32:54.711	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"2","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
      smartmeter.0
      2021-08-28 19:32:54.676	info	starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.5, js-controller: 3.3.15
      smartmeter.0
      2021-08-28 19:32:54.626	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      smartmeter.0
      2021-08-28 19:32:54.620	debug	Plugin sentry Initialize Plugin (enabled=true)
      smartmeter.0
      2021-08-28 19:32:54.216	debug	statesDB connected
      smartmeter.0
      2021-08-28 19:32:54.214	debug	States connected to redis: 127.0.0.1:9000
      smartmeter.0
      2021-08-28 19:32:54.158	debug	States create User PubSub Client
      smartmeter.0
      2021-08-28 19:32:54.157	debug	States create System PubSub Client
      smartmeter.0
      2021-08-28 19:32:54.144	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      smartmeter.0
      2021-08-28 19:32:54.142	debug	objectDB connected
      smartmeter.0
      2021-08-28 19:32:54.134	debug	Objects connected to redis: 127.0.0.1:9001
      smartmeter.0
      2021-08-28 19:32:54.111	debug	Objects client initialize lua scripts
      smartmeter.0
      2021-08-28 19:32:54.110	debug	Objects create User PubSub Client
      smartmeter.0
      2021-08-28 19:32:54.109	debug	Objects create System PubSub Client
      smartmeter.0
      2021-08-28 19:32:54.107	debug	Objects client ready ... initialize now
      smartmeter.0
      2021-08-28 19:32:54.073	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      MOD-Edit: Code in code-tags gesetzt!
        apollon77 @Scotty89 last edited by
        @scotty89 bissl mehr log sollte es schon sein
        Scotty89 1 Reply Last reply Reply Quote 0
        • Scotty89
          Scotty89 @apollon77 last edited by Scotty89
          @apollon77
          leider kommt da nicht mehr ...
          das ist alles ...
          nach etwas Zeit kommt dann das hier in einer "loop"
          • Glasfaser
            Glasfaser @Scotty89 last edited by
            @scotty89 sagte in Adapter "smartmeter":
            Mein Iobroker läuft auf einer Synology DS218+
            und die USB ports sind "eigentlich" verfügbar (das regel ich über ein Skript beim hochfahren)
            nur wenn du DSM 7 hast .
            In der Umgebung bei ENV das eintragen
            /dev/ttyUSB0
            Habe fast den gleichen Lesekopf , es mußte die Bautrate 9600 eingetragen werden .
            interessant ist das nun der Adapter gar keine verbidung mehr aufbauen kann...
            Da bin ich auch schon reingefallen bei der Synology , ziehst du den Stick/Lesekopf und stecks Ihn wieder rein geht nichts mehr , obwohl er als USB erkannt wird.
            Da hilft nur ein Neustart des Containers !!!
            Scotty89 1 Reply Last reply Reply Quote 1
            • Scotty89
              Scotty89 @Glasfaser last edited by
              @glasfaser sagte in Adapter "smartmeter":
              der Umgebung bei E
              danke dir für den Tipp das ist echt Strange den es lief ja vorher ohne Probleme aber irgendwie sind die USB einstellungen aus dem Container "geflogen" es war in der tat keine USB Weiterleitung mehr aktiv..
              hab es nun follegend aufgenommen:
              nun geht es wieder... mal sehne wie lange....
              du hast "Schon" DSM 7 drauf ? lohnt das ?
              ich hab da irgendwie "Respekt" vor da ja auch USB Geräte wohl Probleme machen ... und ich habe den Lesekopf und ein USB DVBS adapter dran...
              • Glasfaser
                Sehr gerne ....
                Alles gut ...
                hier in den beigefügten Thread´s kannst du es erlesen :
                https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2507
                bzw. hier:
                https://forum.iobroker.net/topic/40110/docker-install-synology-dsm-7-zigbee-stick-nicht-erkannt
                  Tobi68 @Glasfaser last edited by
                  Lese mich derzeit in Sachen Smartmeter ein.
                  Funzen USB leseköpfe auch direkt am RPI4 angeschossen auch?
                  Hab da auf Ebay was gefunden.
                  Ebaybausatz
                  • Glasfaser
                    Glasfaser @Tobi68 last edited by
                    @tobi68
                    Ja der Funktioniert sehr gut , habe ihn auch . ( an Synology)
                      @glasfaser
                      Danke, meine DS213+ packt keinen IOBroker.. steht auch nicht beim Zähler..
                      Also kann ich den an den RPI4 einstecken und im Smartmeter adapter ansprechen?
                      Glasfaser K 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        @tobi68 sagte in Adapter "smartmeter":
                        Ja , ist der Baugleiche wie hier ( Weidmann ) :
                        https://forum.iobroker.net/topic/4685/adapter-smartmeter/871
                          klassisch Most Active @Tobi68 last edited by
                          @tobi68 Wenn Du Dich mit Linux auskennst und wei0t, wie man USB rebootfest mountet.
                          Wenn Du Zeit und Interesse hast, kannst Du ja meinen Guide lesen. Wobei ich als Linux-Laie und -Minimierer mich auf andere Lösungen konzentriert habe.
                          T apollon77 2 Replies Last reply Reply Quote 0
                            Tobi68 @klassisch last edited by
                            @klassisch
                            Ok,
                            Nee Linux ist nicht gerade meine stärke.. werd mich dann mal einlesen.. Ist bestellt..
                              apollon77 @klassisch last edited by
                              @klassisch das mounted ist an sich nicht mehr nötig da der Adapter die „by-id“ Pfade nutzt
                              frana120500 1 Reply Last reply Reply Quote 0
                              • frana120500
                                frana120500 @apollon77 last edited by
                                Guten Morgen zusammen,
                                ich bekomme keine Werte von meinem Stromzähler rein, wahrscheinlich weil ich falsche Werte in der Konfiguration habe.
                                Ich habe einen EMH mMe 4.0 Zeeirichtungszähler (diesen hier: https://emh-metering.com/wp-content/uploads/2021/06/mMe4.0-BIA-D-1.14.pdf).
                                Zudem habe ich einen IR Lesekopf der an ein USR TCP232 angeschlossen ist (GND an GND, VCC an 3,3v von einem Wemos abgegriffenm TX an RX und RX an TX).
                                Der USR macht ja einen Webserver auf, mit dem ich mich auch verbinden kann. Hier hätte ich ja die ersten Einstellungen vorzunehmen. Komme ich allerdings schon nicht weiter, da ich nicht weiß was.
                                Im Smartmeter Adapter sollten die Einstellungen mE stimmen (lediglich der TCP Port muss auf 20108 stehen). Ich bekomme so natürlich noch keine Daten rein.
                                Hat jemand den Zähler im Einsatz und kann mir hier helfen? Bin auch für andere Lösungen offen.
                                LG
                                F.
                                  klassisch Most Active @frana120500 last edited by klassisch
                                  @frana120500 Den Zähler habe ich nicht. Aber der USR muß auf TCP Server (nicht client wie bei Dir) stehen. Und die ports müssen zueinander passen
                                  So z.B. (Achtung, ich habe einen zweikanaligen, nicht verwirren lassen)
                                  • frana120500
                                    frana120500 @klassisch last edited by
                                    @klassisch klingt logisch. Werde ich gleich mal ändern und testen. Danke
                                      @frana120500 Du findest ein Beispiel im Guide (pdf), S. 40ff.
                                      • frana120500
                                        @klassisch mega, danke. Hoffe das hilft mir weiter.
                                        N frana120500 2 Replies Last reply Reply Quote 0
                                        • N
                                          NicoS @frana120500 last edited by
                                          Hi zusammen,
                                          nachdem ich kürzlich auch ein EFR SGM-C4 Smartmeter bekommen habe, das ich in iobroker anbinden wollte, bin ich zwangsweise auf diesen Thread hier gestoßen. Möchte hier meine Erfahrungen niederschreiben, die ich mit der Odysee hatte, es mittels Serial Server zum Laufen zu bringen.
                                          Iobroker auf Raspberry steht weit entfernt vom Zählerkasten, dementsprechend war mein Ansatz, einen NodeMCU mit ESPEasy als Serial Server über TCP anzubinden, um damit per Wlan die Verbindung herzustellen. Kurzum: ich hab es mit ESPEasy nicht zum Laufen gebracht.
                                          Setup: Sensor war ein zuerst nach Anleitung umgebauter TCRT-5000, dann ein Hichi IR TTL. Ein NodeMCU ESP8266 4MB it ESPEasy als Firmware; Serial Server konfiguriert mittels Communication-Device basierend auf Ser2Net aber auch in den Advanced Firmware Einstellungen; 9600N1. Sowohl probiert als Software Serial (da kam hauptsächlich Datenmüll mit ein paar lesbaren Fragmenten an), dann auch als Hardware Serial auf allen per Firmware möglichen RX ports (da kam gar nichts an). Input Pullup am RX-Pin an/aus (wo möglich als Software-Einstellung), aber auch Widerstände mit 4-10kOhm gegen V++ probiert, kein Unterschied.
                                          Geschirmte Kabel, kurze Leitungen Kurzum: ESPEasy (Release mega-20210802) hat irgendwelche Bugs oder macht irgendwas mit dem Encoding der Daten und ist für diese Anwendung scheinbar aktuell nicht geeignet. Ich hab nach drei vollen Tagen rumprobieren aufgegeben.
                                          Nach langer Suche habe ich jetzt testweise ESP-Link auf den selben NodeMCU geflashed (https://github.com/jeelabs/esp-link) - selbes Hardware-Setup, selbe Sensorik, selbe Verkabelung - und es funktioniert astrein und auf Anhieb. RX-Pin hängt jetzt am HW-RX-Pin des NodeMCU (GPIO3).
                                          Einschränkungen: TCP-Port nicht konfigurierbar (fix auf 23 - verschmerzbar) & Weboberfläche ist nicht passwortgeschützt (widerstrebt mir selbst im LAN, aber ich muss jetzt erstmal damit leben).
                                          Flashing des NodeMCU ist wegen der Toolchain-Einrichtung ein wenig komplizierter (Python muss installiert werden), aber mit der Anleitung aus der Readme machbar. (Zur Info: die Anleitung ist etwas überholt; unter Windows ist das Kommando für den 4MB/1MB ESP8266 NodeMCU: "esptool.py --port COM7 --baud 460800 write_flash -fs 4MB -ff 80m 0x00000 boot_v1.6.bin 0x1000 user1.bin 0x3FC000 esp_init_data_default.bin 0x3FE000 blank.bin").
                                          Im Anhang zur Info noch ein Output des EFR SGM-C4 Datenstreams, wie er eigentlich aussehen muss, und meine HW-Pin-Settings für den NodeMCU.
                                          Hoffe, dem ein oder anderen damit hoffentlich meinen Frust zu ersparen.
                                          • frana120500
                                            frana120500 @frana120500 last edited by
                                            @frana120500 sagte in Adapter "smartmeter":
                                            Tut es leider nicht. Alles böhmische Dörfer für mich.
                                            Ich hab schon zig Einstellungen durch, aber bekomme gar keine Werte rein.
                                            Muss ich TX/RX kreuzen? da liest man auch unterschiedliches drüber.
                                            Ich vermute fast, dass mein Zähler gar nix sendet.
                                            1.2k
                                            3625
                                            2287461
