Javascript Adapter läßt sich nicht updaten
@webdoc75 sagte in Javascript Adapter läßt sich nicht updaten:
Ein Update ist leider nicht möglich. Hat jemand eine Idee warum?
ohne log-keine Idee
iobroker update -i iobroker upgrade iobroker upload all
Bitte Ausgaben aus der Konsole in CodeTags wieder hier rein.
Adapter "admin" : 5.1.23 , installed 5.1.23
Adapter "alexa2" : 3.9.3 , installed 3.9.3
Adapter "backitup" : 2.1.17 , installed 1.7.0 [Updateable]
Adapter "broadlink2" : 2.0.3 , installed 2.0.2 [Updateable]
Adapter "cloud" : 4.1.0 , installed 4.1.0
Adapter "discovery" : 2.7.0 , installed 2.7.0
Adapter "flot" : 1.10.6 , installed 1.9.2 [Updateable]
Adapter "history" : 1.9.13 , installed 1.8.6 [Updateable]
Adapter "hm-rega" : 3.0.31 , installed 3.0.31
Adapter "hm-rpc" : 1.14.45 , installed 1.14.45
Adapter "hue" : 3.5.19 , installed 3.5.19
Adapter "ical" : 1.11.2 , installed 1.7.0 [Updateable]
Adapter "javascript" : 5.2.8 , installed 5.2.8
Controller "js-controller" : 3.3.15 , installed 3.3.15
Adapter "lightify" : 0.2.16 , installed 0.2.16
Adapter "mobile" : 1.0.1 , installed 0.5.0 [Updateable]
Adapter "ping" : 1.5.0 , installed 1.3.2 [Updateable]
Adapter "samsung" : 0.2.9 , installed 0.2.9
Adapter "sayit" : 1.12.3 , installed 1.9.8 [Updateable]
Adapter "shelly" : 4.0.7 , installed 4.0.7
Adapter "simple-api" : 2.6.1 , installed 2.3.2 [Updateable]
Adapter "socketio" : 3.1.4 , installed 2.1.2 [Updateable]
Adapter "sonos" : 2.1.1 , installed 2.0.1 [Updateable]
Adapter "telegram" : 1.10.0 , installed 1.10.0
Adapter "text2command" : 2.1.1 , installed 2.1.1
Adapter "vis" : 1.4.3 , installed 1.2.4 [Updateable]
Adapter "vis-bars" : 0.1.4 , installed 0.1.4
Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.3 [Updateable]
Adapter "vis-metro" : 1.1.2 , installed 1.1.2
Adapter "vis-players" : 0.1.6 , installed 0.1.5 [Updateable]
Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7
Adapter "vis-weather" : 2.5.3 , installed 2.5.2 [Updateable]
Adapter "web" : 3.4.7 , installed 2.4.10 [Updateable]
Adapter "wifilight" : 1.1.0 , installed 1.1.0
pi@All-In-One_RasPi:/opt/iobroker $ -
@thomas-braun ```
pi@All-In-One_RasPi:/opt/iobroker $ iobroker upgradeThis upgrade of "web" will at least introduce the following changes:
-> 3.4.7:
Corrected the small config GUI error-> 3.4.6:
Corrected the small config GUI error-> 3.4.5:
fix admin dependency because since 3.4.2 Admin 5.1 is required-> 3.4.4:
Fix missing www files-> 3.4.3:
Add tier for js-controller 3.3-> 3.4.2:
Update GUI-> 3.4.1:
Added support of admin5BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
Would you like to upgrade web from @2.4.10 to @3.4.7 now? [(y)es, (n)o]: -
@webdoc75 was hast du denn für eine js-controller-version?
sehr merkwürdig, jetzt scheint er es gemacht zu haben. Ich weiß nur nicht warum
@thomas-braun OK, grade auch in der Liste gefunden...
@guergen sollte ich jetzt noch etwas machen? Habe meine Installation eine ganze Zeit vernachlässigt. Echt blöd wenn man so lange raus ist. So großartig habe ich es auch nicht mit dem Pi auf Kommandoebende. Bin immer froh wenn alles läuft (
@webdoc75 Wenn jetzt alles auf Stand ist, egtl nicht
@guergen erstmal vielen Dank. Meine Pause ist nun vorbei. Gucke hier später nochmal rein
