    4. NPM ERR
    NPM ERR
      Homoran Global Moderator Administrators @Pat last edited by
      @pat sagte in NPM ERR:
      Unsupported engine for dns@0.2.2: wanted: {"node":">= 0.10.0 < 0.11.0"} (current: {"node":"12.22.5","npm"
      da ist eine Abhängigkeit zu dem Paket dns mit total veralteten node Voraussetzungen
        Pat @Pat last edited by
        Warscheinlich hier dann auch ??
        $ iobroker add squeezeboxrpc --host Haussteuerung
        NPM version: 6.14.14
        npm install iobroker.squeezeboxrpc@1.3.4 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for dns@0.2.2: wanted: {"node":">= 0.10.0 < 0.11.0"} (current: {"node":"12.22.5","npm":"6.14.14"})
        npm ERR! notsup Not compatible with your version of node/npm: dns@0.2.2npm ERR! notsup Not compatible with your version of node/npm: dns@0.2.2npm ERR! notsup Required: {"node":">= 0.10.0 < 0.11.0"}npm ERR! notsup Actual: {"npm":"6.14.14","node":"12.22.5"}
          Thomas Braun Most Active @Pat last edited by Thomas Braun
          @pat
          Da scheint irgendwas schräg im System zu hängen. Ich glaube nicht, dass beide Adapter das angemeckerte Modul als Dependency haben.
          Ich weiß aber offengesagt nicht wie man das wirkliche Problem löst.
          Schau vielleicht mal hier rein:
          cd /opt/iobroker
          npm list
            Pat @Thomas Braun last edited by
            @thomas-braun said in NPM ERR:
            npm ERR! missing: crypto@^1.0.1, required by iobroker.javascript@5.2.8
            npm ERR! missing: csv-parse@^4.16.0, required by iobroker.javascript@5.2.8
            npm ERR! missing: dns@^0.2.2, required by iobroker.javascript@5.2.8
            npm ERR! missing: events@^3.3.0, required by iobroker.javascript@5.2.8
            npm ERR! missing: fs@0.0.1-security, required by iobroker.javascript@5.2.8
            npm ERR! missing: iconv-lite@^0.6.3, required by iobroker.javascript@5.2.8
            npm ERR! missing: net@^1.0.2, required by iobroker.javascript@5.2.8
            npm ERR! missing: os@^0.1.2, required by iobroker.javascript@5.2.8
            npm ERR! missing: path@^0.12.7, required by iobroker.javascript@5.2.8
            npm ERR! missing: suncalc@^1.8.0, required by iobroker.javascript@5.2.8
            Habe mal nur die ERR rauskopiert die risiegeliste die da vor ist sieht so weit gut aus
              @pat
              Hast du das Modul dns evtl. im javascript-Adapter von Hand hinzugefügt? Wenn ja, warum? Schmeiß das mal raus.
              Ist dein node.js senkrecht installiert?
              which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
              Falls das Modul gemeint sein sollte:
              https://www.npmjs.com/package/dns
              Kein Wunder, denn
              Last publish
              7 years ago
                apt policy nodejs
                /usr/bin/node
                /usr/bin/npm
                das ist der Ausszug!!
                die Adapter die ich installieren will sind "inventwo Design Widgets" und "SqueezeboxRPC: Controller for Logitec"
                Bei beiden kommt der gleiche fehler
                Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                  @pat
                  Bei Ubuntu würde ich erst linken:
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  Dann bitte exakte Ein- und Ausgaben posten.
                  Sollte dann so in der Art aussehen:
                  echad@chet:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  /usr/bin/nodejs
                  v14.17.5
                  /usr/bin/node
                  v14.17.5
                  /usr/bin/npm
                  6.14.14
                  nodejs:
                    Installiert:           14.17.5-deb-1nodesource1
                    Installationskandidat: 16.8.0-deb-1nodesource1
                    Versionstabelle:
                       16.8.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                   *** 14.17.5-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       12.22.5-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  echad@chet:~ $
                  haselchen P 2 Replies Last reply Reply Quote 0
                  • haselchen
                    haselchen Most Active @Thomas Braun last edited by
                    Deine NPM Version würde ich vielleicht an Deiner Stelle schwärzen oder entfernen.
                    Wenn sich andere Deinen Daten zu Herzen nehmen und versuchen NPM7 ins System zu prügeln , haben wir wieder ne Menge Threads bezüglich des Problems.
                      Thomas Braun Most Active @haselchen last edited by
                      @haselchen Ja, hast ja Recht. Also auf node14 umgestellt.
                        /usr/bin/nodejs
                        v12.22.5
                        /usr/bin/node
                        v12.22.5
                        /usr/bin/npm
                        6.14.14
                        nodejs:
                          Installiert:           12.22.5-deb-1nodesource1
                          Installationskandidat: 12.22.5-deb-1nodesource1
                          Versionstabelle:
                         *** 12.22.5-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_12.x focal/main amd64 Packages
                             10.19.0~dfsg-3ubuntu1 500
                                500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                        N: Paket /usr/bin/nodejs kann nicht gefunden werden.
                          @pat
                          Hast du den Rechner dann mal neugebootet?
                          iobroker update -i
                          anschauen.
                          • OliverIO
                            OliverIO @Pat last edited by
                            Ich habe mir mal den dependency baum für squeezeboxrpc angeschaut. Also alle verwendeten Pakete, sowie die wieder von diesen verwendeten und so fort.
                            da wird nirgends ein paket namens dns verwendet.
                            Bei installiertem Paket kann man, ausgehend vom jeweiligen Verzeichnis, sich das wie folgt anschauen:
                            npm ll
                              Pat @Thomas Braun last edited by Pat
                              Hey
                              den Rechner habe ich schon ein paar mal neugestartet aber ich glaube ich ich habe ein größeres Prob
                              hier erstmal der Auszug
                              pat@Haussteuerung:~$ iobroker update -i
                              Used repository: stable
                              hash unchanged, use cached sources
                              update done
                              Adapter    "admin"         : 5.1.23   , installed 5.1.23
                              Adapter    "backitup"      : 2.1.17   , installed 2.1.13 [Updateable]
                              Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                              Adapter    "denon"         : 1.11.2   , installed 1.11.2
                              Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                              Adapter    "flot"          : 1.10.6   , installed 1.10.6
                              Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                              Adapter    "history"       : 1.9.13   , installed 1.9.13
                              Adapter    "hm-rega"       : 3.0.31   , installed 3.0.29 [Updateable]
                              Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.43 [Updateable]
                              Adapter    "ical"          : 1.11.2   , installed 1.11.2
                              Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
                              Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
                              Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                              Adapter    "info"          : 1.9.8    , installed 1.9.8
                              Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                              Controller "js-controller" : 3.3.15   , installed 3.3.15
                              Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                              Adapter    "s7"            : 1.3.6    , installed 1.3.6
                              Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                              Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                              Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                              Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                              Adapter    "sql"           : 1.15.7   , installed 1.15.7
                              Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                              Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                              Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                              Adapter    "vis"           : 1.4.3    , installed 1.4.3
                              Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                              Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                              Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                              Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                              Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                              Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                              Adapter    "vis-inventwo"  : 3.1.3    , installed 3.0.11 [Updateable]
                              Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                              Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                              Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
                              Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                              Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                              Adapter    "web"           : 3.4.7    , installed 3.4.7
                              Adapter    "yahka"         : 0.12.0   , installed 0.12.0
                              Adapter    "yr"            : 3.0.5    , installed 3.0.5
                              Egal welchen adapter ich installieren will oder updaten will kommt der fehler
                              PS
                              Hatte erst vor kurzen das System neu aufgesetzt um Ubuntu zu updaten von 18 auf 20.04.2.0. Hat alles geklappt.
                              Danach habe kam das neue Admin und seid dem habe ich das Problem.
                              Muss ich mal NPM neuinstall ??
                                Pat @OliverIO last edited by
                                @oliverio
                                232 verbose stack Error: Unsupported engine for dns@0.2.2: wanted: {"node":">= 0.10.0 < 0.11.0"} (current: {"node":"12.22.5","npm":"6.14.14"})
                                232 verbose stack     at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/index.js:14:14)
                                232 verbose stack     at module.exports.isInstallable (/usr/lib/node_modules/npm/lib/install/validate-args.js:60:3)
                                232 verbose stack     at resolveWithNewModule (/usr/lib/node_modules/npm/lib/install/deps.js:677:10)
                                232 verbose stack     at /usr/lib/node_modules/npm/lib/install/deps.js:600:7
                                232 verbose stack     at /usr/lib/node_modules/npm/node_modules/iferr/iferr.js:3:64
                                232 verbose stack     at /usr/lib/node_modules/npm/node_modules/call-limit/call-limit.js:28:43
                                232 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:79:11)
                                233 verbose pkgid dns@0.2.2
                                234 verbose cwd /opt/iobroker
                                235 verbose Linux 5.11.0-25-generic
                                236 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.backitup@2.1.17" "--loglevel" "error" "--prefix" "/opt/iobroker"
                                237 verbose node v12.22.5
                                238 verbose npm  v6.14.14
                                239 error code ENOTSUP
                                240 error notsup Unsupported engine for dns@0.2.2: wanted: {"node":">= 0.10.0 < 0.11.0"} (current: {"node":"12.22.5","npm":"6.14.14"})
                                241 error notsup Not compatible with your version of node/npm: dns@0.2.2
                                242 error notsup Not compatible with your version of node/npm: dns@0.2.2
                                242 error notsup Required: {"node":">= 0.10.0 < 0.11.0"}
                                242 error notsup Actual:   {"npm":"6.14.14","node":"12.22.5"}
                                243 verbose exit [ 1, true ]
                                Hier ein auszug aus der LOG die erstellt wird
                                • OliverIO
                                  @pat
                                  danke, aber das nutzt nix, da es kein fehler des adapters ist.
                                  wie gesagt der adapter selbst, noch irgendein der verwendeten pakete nutzt ein package namens dns.
                                  entweder klärt man, wie iobroker oder npm denkt warum es dns installieren sollte oder (der bevorzugte weg) du installierst npm + iobroker komplett neu.
                                  vorzugsweise empfehle ich dir iobroker in einen docker container zu packen. dadurch kannst du kreuzreaktionen mit anderen softwares, die ebenfalls noch auf ubuntu installiert sind, vermeiden.
                                  anleitung ist hier im forum zu finden oder
                                  https://hub.docker.com/r/buanet/iobroker/
                                    @oliverio
                                    Hey
                                    Also ich habe noch mal alles neu aufgesetzt und habe mit Backitup mein Backup wieder draufgezogen und was soll ich sagen gleicher fehler .....
                                    Diesmal habe ich mir Proxmox drauf gehauen und ubuntu in einen LC installiert und nur rein Iobroker nach der Anleitung auf der HP von IObroker installiert.
                                      Klar, damit knallst du den Huddel ja auch wieder in den ioBroker rein.
                                        Hey
                                        Also ich habe noch ein paar versuche gestartet und ich musste wirklich alles neu aufsetzten.
                                        Aber war gleich mal den Anlass genutzt viele alt leichen zu entfernen.
                                        Nochmal vielen Dank für die hilfe.
                                        MfG
                                        Pat
                                        1731
