    4. [Vorlage]-Zeit herunterzählen bis GoogleTermin Eintritt
    • hanan
      hanan @liv-in-sky last edited by
      @liv-in-sky
      Guten Morgen
      Hier mal meine ical2-html:
      <span style="font-weight: bold; color: white"><span class="icalNormal iCal-FC_Basel 1893">25.03.2021 13:00-15:00</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-FC_Basel 18932'> SC Freiburg - FC Basel 1893</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Mondkalender">28.03.2021  </span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Mondkalender2'> 🌕 Vollmond</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Mondkalender">04.04.2021  </span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Mondkalender2'> 🌗 Abnehmender Halbmond</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-FC_Basel 1893">05.04.2021 16:00-18:00</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-FC_Basel 18932'> FC Basel 1893 - FC Vaduz</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-FC_Basel 1893">10.04.2021 20:30-22:30</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-FC_Basel 18932'> FC Luzern - FC Basel 1893</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Mondkalender">12.04.2021  </span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Mondkalender2'> 🌑 Neumond</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-FC_Basel 1893">18.04.2021 16:00-18:00</span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-FC_Basel 18932'> FC Basel 1893 - Servette FC</span></span><br/><span style="font-weight: bold; color: white"><span class="icalNormal iCal-Mondkalender">20.04.2021  </span></span><span style="font-weight: normal; color:white"><span class='icalNormal2 iCal-Mondkalender2'> 🌓 Zunehmender Halbmond</span></span>
      und hier das Blockly für die Suche "FC Basel 1893", welche ich danach in den Countdown-Adapter schreibe.
      Der Minutenintervall ist nur wegen dem Test:
      <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="/Z@?iF|RB-}UWrCdgO8l" x="-287" y="-336">
        <field name="SCHEDULE">* * * * *</field>
          <block type="controls_if" id="k$7XJl4TwwsH#F^BA]o!">
              <block type="logic_compare" id="M76Fa)lSqWA4~DpUBx]#">
                <field name="OP">EQ</field>
                  <block type="get_value" id="~cXDg*N0V}(j;3:-g@=W">
                    <field name="OID">countdown.0.countdowns.FCB Matsch.endDate</field>
                  <block type="text" id="(L7Thmh8pK[9|obXZlJE">
                    <field name="TEXT">Invalid date</field>
              <block type="variables_set" id="Yn_03ee.K$F#2@`28d/M">
                <field name="VAR" id="l6*`|-^*E}19Ax.o8gS3">suchBegriff</field>
                  <block type="text" id="_%5/XWgSJPtR10.BNE?,">
                    <field name="TEXT">Basel 1893</field>
                  <block type="variables_set" id="[xt^RuL~Y|TiS0Re2?+#">
                    <field name="VAR" id="dl(4-B)s(J1z0(yKCcPM">eventDatum</field>
                      <block type="procedures_callcustomreturn" id="N;K:A$!9$8_uIv=#kGsc">
                        <mutation name="StringManipulation">
                          <arg name="i"></arg>
                          <arg name="j"></arg>
                        </mutation>
                        <value name="ARG0">
                          <block type="convert_tostring" id="}NBT];(s+uXuO#z=FiD.">
                              <block type="get_value" id="?}[v,-QV{dczpnW|a=qd">
                                <field name="OID">ical.2.data.html</field>
                        <value name="ARG1">
                          <block type="variables_get" id="K2N=*^9uaX6H0}j]s5=*">
                      <block type="controls_if" id="/zQZ~5M`WY$~j~oKdH5z">
                          <block type="logic_compare" id="Z?!zm|/x#bu*Q7]r4,%4">
                            <field name="OP">NEQ</field>
                              <block type="variables_get" id="F$bDE3t^u;v%QO/XXCr6">
                              <block type="math_number" id="NcEs_VXKEGxjrfy]h3_[">
                                <field name="NUM">-1</field>
                          <block type="variables_set" id="GYrFB;7cr*:#h}.et0I~">
                            <field name="VAR" id="xKL%f`?jvCh0ok?{c^rL">stunde</field>
                              <block type="text_getSubstring" id="-/-p`iD:y_vgxgLa5+dk">
                                <mutation at1="true" at2="true"></mutation>
                                <field name="WHERE1">FROM_START</field>
                                <field name="WHERE2">FROM_START</field>
                                <value name="STRING">
                                  <block type="variables_get" id="6{Y.CU(rNYFSz7JKw6gr">
                                <value name="AT1">
                                  <block type="math_number" id="Kq.B-X,mqp;-N#)X=Q+P">
                                    <field name="NUM">10</field>
                                <value name="AT2">
                                  <block type="math_number" id="t@;2+]ISoUKt$e,;oqY3">
                                    <field name="NUM">14</field>
                              <block type="variables_set" id="vT$zjFC6[`*5|+?^FUYb">
                                <field name="VAR" id="4_[a*D)c$D0Fg1e?^r-#">minute</field>
                                  <block type="text_getSubstring" id="iKSGk7wasI6U%DoU%/~`">
                                      <block type="variables_get" id="|d#VH=fnVXwAs^x#8Z{d">
                                    <value name="AT1">
                                      <block type="math_number" id="t#m1rz,4t`GTw`v1v_YC">
                                        <field name="NUM">15</field>
                                    <value name="AT2">
                                      <block type="math_number" id="Jz.]{TpX{G65p$t=zQmh">
                                        <field name="NUM">16</field>
                                  <block type="debug" id="--O3@Ew@70yHrA|80r^B">
                                    <value name="TEXT">
                                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="vUqJQDqZYEP1~M}JHa]U">
                                      <block type="variables_get" id="KmvnGC^%j/LAP~CH2O.=">
                                      <block type="timeouts_settimeout" id=":8H?ff.:HrbvkOig[yJ[">
                                        <field name="NAME">timeout4</field>
                                        <field name="DELAY">3</field>
                                          <block type="controls_if" id="^-$KSt-IwY$gkV9zU9Pd">
                                              <block type="logic_compare" id="4o(6_1vMy*Fpu#As|X14">
                                                <field name="OP">GT</field>
                                                  <block type="variables_get" id="b-p,2nK}n*ke1Xi9wl`g">
                                                  <block type="time_get" id="Bi$kG3R-!qDo[PIR;#wq">
                                                    <field name="OPTION">h</field>
                                              <block type="schedule_create" id="4Q,qI3!9]bUX-]NQvf-P">
                                                <field name="NAME">datumSchedule</field>
                                                <value name="SCHEDULE">
                                                  <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_cron" id="?75wOi3|4ORjpXgU9SSn">
                                                    <field name="CRON">* * * * *</field>
                                                  <block type="text_join" id="A*!}}?bQe6=SR5,+#z@4">
                                                    <mutation items="6"></mutation>
                                                    <value name="ADD0">
                                                      <block type="variables_get" id="hJOK@v*3*~(!S5cOgth;">
                                                    <value name="ADD1">
                                                      <block type="text" id="=cxyzRaBVprL+dg3GT/{">
                                                        <field name="TEXT"> </field>
                                                    <value name="ADD2">
                                                      <block type="variables_get" id="*Tk9Oa|zErcUBQUUxT!U">
                                                    <value name="ADD3">
                                                      <block type="text" id="U=3Zo6aR4L#}:M|v)x:M">
                                                        <field name="TEXT"> *</field>
                                                    <value name="ADD4">
                                                      <block type="text" id="U.G0Et9x?LX,p)Rxpg-e">
                                                    <value name="ADD5">
                                                      <block type="text" id="*[F-,a-H0aNhT2AJ6JmU">
                                                  <block type="control" id="Mbk~Q;0UP@A8@^F[0Mou">
                                                    <field name="OID">countdown.0.setup.FCB Matsch</field>
                                                    <field name="DELAY_MS">1000</field>
                                                    <field name="UNIT">ms</field>
                                                      <block type="variables_get" id="r?o81v9MAq6qgqme2YN?">
                                                      <block type="timeouts_settimeout" id="ryfODWCYatf{RY8|7?C%">
                                                        <field name="DELAY">10</field>
                                                          <block type="schedule_clear" id="@}/RY2BL~F{L#mhFxsM=">
                                            <statement name="ELSE">
                                              <block type="control" id="--.){w[29%H}dCX)QZre">
                                                  <block type="variables_get" id="0qiq9Ta*z-gm~VXO{T]/">
      und hier noch den Termineintrag vom Outlook:
        liv-in-sky @hanan last edited by
        @hanan
        hier ist eine variante - ich habe nur den teil mit der funktion geändert - darin wird die zeit bestimmt und die variable suchbegriff wird auf den kalendereintags-namen gesetzt - du mußt dann die var suchbegriff in deinen dp setzen.
         <variables>
           <variable id="toV%#XU#+u-q8j}%lQO5">i</variable>
           <variable id="=laq7tvUO(q,%US6)j!u">j</variable>
           <variable id="l6*`|-^*E}19Ax.o8gS3">suchBegriff</variable>
           <variable id="dl(4-B)s(J1z0(yKCcPM">eventDatum</variable>
           <variable id="xKL%f`?jvCh0ok?{c^rL">stunde</variable>
           <variable id="4_[a*D)c$D0Fg1e?^r-#">minute</variable>
           <variable type="timeout" id="timeout4">timeout4</variable>
           <variable type="cron" id="datumSchedule">datumSchedule</variable>
           <variable type="timeout" id="timeout2">timeout2</variable>
         </variables>
         <block type="schedule" id="/Z@?iF|RB-}UWrCdgO8l" x="-287" y="-336">
         <block type="procedures_defcustomreturn" id=".4jhH[;Isgq*k0Elo0tw" x="612" y="-263">
           <mutation statements="false">
             <arg name="i" varid="toV%#XU#+u-q8j}%lQO5"></arg>
             <arg name="j" varid="=laq7tvUO(q,%US6)j!u"></arg>
           </mutation>
           <field name="NAME">StringManipulation2</field>
           <field name="SCRIPT">DQoNCi8vbG9nKEpTT04uc3RyaW5naWZ5KGkpKQ0KbGV0IG15RXJnZWJuaXM9LTE7DQoNCmZvciAobGV0IGFhPTA7YWE8aS5sZW5ndGg7YWErKyl7DQogIC8vICBsb2coaVthYV0uZXZlbnQpDQogICAgaWYoaVthYV0uZXZlbnQuaW5jbHVkZXMoaikpIHsvKmxvZyhpW2FhXS5ldmVudCk7Ki9teUVyZ2VibmlzPWlbYWFdLmRhdGU7c3VjaEJlZ3JpZmY9aVthYV0uZXZlbnQ7YnJlYWt9DQogICANCn0NCg0KDQovL2xvZyhteUVyZ2VibmlzKQ0KcmV0dXJuIG15RXJnZWJuaXM7</field>
         <block type="variables_set" id="Yn_03ee.K$F#2@`28d/M" x="-113" y="-212">
                 <block type="procedures_callcustomreturn" id="g?#2EB$^BkG@k+r=Bv|]">
                   <mutation name="StringManipulation2">
                   </mutation>
                   <value name="ARG0">
                       <field name="OID">ical.0.data.table</field>
                   <value name="ARG1">
                           <value name="AT1">
                               <field name="NUM">12</field>
                           <value name="AT2">
                               <field name="NUM">13</field>
                               <value name="AT1">
                               <value name="AT2">
                             <block type="debug" id="dCLeDz(n@AvlXBiXCXw.">
                               <value name="TEXT">
                                 <shadow type="text" id="J42$[^PW@Pg,FMd8dx~}">
                                 <block type="variables_get" id="t]8dz(9aJ4fbLd(JPv5p">
                                   <value name="TEXT">
                                     <block type="debug" id="@D}2|sZ`qt0Jw`}~MHoZ">
                                       <value name="TEXT">
                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="text">
                                         <block type="variables_get" id="*!vl!IxcFiTS+=$S@iu*">
                                         <block type="debug" id="U/?(?G1iL7EA@=.oE`-#">
                                           <value name="TEXT">
                                             <block type="variables_get" id="^8:$QQ;mFMZx^e-Y%)S6">
                                                           <value name="ADD0">
                                                           <value name="ADD1">
                                                           <value name="ADD2">
                                                           <value name="ADD3">
                                                           <value name="ADD4">
                                                           <value name="ADD5">
        • hanan
          Hallo liv-in-sky
          Supi, besten Dank. Das funktioniert top und ist genau das was ich gesucht habe.
          Besten Dank für Deine schnelle Hilfe, ich hätte dieses nie hinbekommen.
            @hanan gerne
            hanan 1 Reply Last reply Reply Quote 0
            • hanan
              Hallo liv-in-sky
              Seit dem Update auf v5.1.23 funktioniert das Schreiben in die Datenpunkte nicht mehr.
              Hast Du mir eventuell einen Tipp?
              Datenpunkt für suchBegriff
                "_id": "0_userdata.0.Variablen.Vis_Schalter.FCB_gegen",
                "type": "state",
                "common": {
                  "name": "FCB_gegen",
                  "role": "",
                  "type": "string",
                  "desc": "Manuell erzeugt",
                  "def": "",
                  "read": true,
                  "write": true
                "native": {},
                "acl": {
                  "object": 1636,
                  "owner": "system.user.admin",
                  "state": 1636
                "user": "system.user.admin",
                "ts": 1630321470550
              Datenpunkt für eventDatum
                "type": "state",
                "common": {
                  "read": true,
                  "write": true,
                  "name": "FC Basel",
                  "type": "string",
                  "def": "29.08.2021 16:30:00",
                  "role": null
                "native": {},
                "_id": "countdown.0.setup.FC Basel",
                "acl": {
                  "object": 1636,
                  "state": 1636,
                "ts": 1630320897926
                @hanan oh mann - das ist lange her - ich muss das erstmal wieder finden - ich schau mal
                • hanan
                  @liv-in-sky
                  Das Skript funktioniert, sehe ich im Debug output, doch können die beiden Daten nichtmehr in die jeweiligen Datenpunkte geschrieben werden.
                    @hanan
                    poste bitte das script - ich muss das importieren
                    • hanan
                      hanan @liv-in-sky last edited by hanan
                      @liv-in-sky
                        <variables>
                        </variables>
                        <block type="procedures_defcustomreturn" id=".4jhH[;Isgq*k0Elo0tw" x="163" y="-712">
                          </mutation>
                        <block type="on_ext" id="qMd2zp!`jX-7i1:h/_G;" x="-287" y="-662">
                          <value name="OID0">
                            <shadow type="field_oid" id="kr$tstAFs]QhLrKlNNoz">
                              <field name="oid">countdown.0.countdowns.FC Basel.reached</field>
                            <block type="controls_if" id="$g`#_r*#6^uxk0K|Q|Tt">
                                <block type="logic_operation" id="]sXJg]u-cPjXadE5=hG1" inline="false">
                                  <field name="OP">AND</field>
                                    <block type="logic_compare" id="{!Rnk_(=3t]X67`petBQ">
                                        <block type="get_value" id="mTL6SIt(Aj~_.;mH3=xR">
                                          <field name="OID">countdown.0.countdowns.FC Basel.reached</field>
                                        <block type="logic_boolean" id="-6I4]}?W]Xv:4E=2q#i4">
                                    <block type="logic_compare" id=".cvPRJXKUfkd4*DBc@IW">
                                        <block type="get_value" id="2=ZjTG(T#VNZbpFE]Zzd">
                                          <field name="OID">0_userdata.0.Variablen.Vis_Schalter.FCB_Matsch</field>
                                        <block type="logic_boolean" id="W6z=qlg;ult*~@$K!0ri">
                                <block type="control" id="1Na}tzv^U0BpCL+?qud}">
                                    <block type="logic_boolean" id="v_r~x-0mXdB:rHJSK.gK">
                              <value name="IF1">
                                <block type="logic_operation" id="~0{ny@u#Q8+yY-AOe:):" inline="false">
                                  <field name="OP">OR</field>
                                    <block type="logic_operation" id="d@K~FVUoKm}~Y~(k2ObJ" inline="false">
                                        <block type="logic_compare" id="kloYtw+X3N4YvdcPj%uD">
                                            <block type="get_value" id="z-4a^}oAR]v6`qKT^Fni">
                                            <block type="logic_boolean" id="8HLnr6B`/LTuA9O:1[Rp">
                                        <block type="logic_compare" id="v_f#g|UNmN+B?=wm(01d">
                                            <block type="get_value" id=":1EY%O5Fw5mBph*IF]Xa">
                                            <block type="logic_boolean" id="M#70+@ciE48e!Dm{RuJR">
                                    <block type="logic_compare" id="[Y1?|yhYN89xcT~o[Qf_">
                                        <block type="get_value" id="Z.0oguVR%/AWy3TO]x!R">
                                          <field name="OID">countdown.0.countdowns.FC Basel.endDate</field>
                                        <block type="text" id="v5KT*)FSpKtToJ7K:[@(">
                              <statement name="DO1">
                                <block type="control" id="oS*Vfh7N8]Hu9=*V%W6t">
                                    <block type="logic_boolean" id=")(C6tn!lD(v?|{_tYt;Q">
                                    <block type="control" id="4RjTm,E[-};p]-jxu-Ze">
                                      <field name="OID">countdown.0.setup.FC Basel</field>
                                        <block type="text" id="+7kxy.u*8]]~r#ftU0/y">
                                          <field name="TEXT"></field>
                                        <block type="control" id="pEj1$]dz*s]leHe`YR#-">
                                          <field name="OID">0_userdata.0.Variablen.Vis_Schalter.FCB_gegen</field>
                                          <field name="DELAY_MS">120</field>
                                            <block type="text" id="mj,l#mf/+X7x|D%x.Cf}">
                                            <block type="control" id="LVXT1Gs5f3a:Vw,C3f?a">
                                                <block type="logic_boolean" id="^j1BUs13H$ii7XTRc@fy">
                            <block type="schedule" id="/Z@?iF|RB-}UWrCdgO8l">
                              <field name="SCHEDULE">*/30 8-21 * * *</field>
                                    <block type="logic_operation" id="#HG.._U-Ge,?pWE#S[:X" inline="false">
                                        <block type="logic_compare" id="9f+@Q))b-J0s6E[!|u12">
                                            <block type="get_value" id="oqo=zB1v[Zu2]hs{Q0^|">
                                            <block type="logic_boolean" id="yElSM@?hiE5nlmJBWK1/">
                                        <block type="logic_compare" id=";c.w*taLtS%5+thu.:Z6">
                                            <block type="get_value" id="Ho.I%k;m:ufg)Fk3G;3]">
                                            <block type="text" id="hH9![JK-i;6O5)JWf$hG">
                                          <field name="TEXT">Basel</field>
                                              </mutation>
                                              <value name="ARG0">
                                                  <field name="OID">ical.2.data.table</field>
                                              <value name="ARG1">
                                                      <value name="AT1">
                                                      <value name="AT2">
                                                          <value name="AT1">
                                                          <value name="AT2">
                                                          <value name="TEXT">
                                                              <value name="TEXT">
        <value name="TEXT">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <block type="control" id="Nz%11urUbBT2c_+6~vUK">
        <field name="DELAY_MS">2000</field>
        <block type="variables_get" id=":D;!al^ufSTpm5dn;HqV">
        <block type="control" id="J@u{-ak8EhzU+j]BLUpd">
        <block type="variables_get" id="=`c+9CFW^h@u=EyPJ34$">
                        @hanan sagte in [Vorlage]-Zeit herunterzählen bis GoogleTermin Eintritt:
                        ich muss gestehen, ich glaube, ich habe den countdown adapter etwas missbraucht - ich schau mal, ob ich morgen ein anderes script zusammenbringe
                        der countdown adapter ist bei dir noch gestartet ?
                        • hanan
                          @liv-in-sky
                          Habe oben eben nochmals mein aktuelles Blockly-Skript eingefügt...
                          Jep, und ich beschreibe im Ordner setup den Datenpunkt FC Basel mit dem eventDatum, welches eben nicht mehr übernommen wird.
                          liv-in-sky hanan 2 Replies Last reply Reply Quote 0
                            @hanan ist bei mir auch - da machen wir uns einen neuen datenpunkt und schreiben den mit dem richtigen namen - in der vis nimmst du dann den neuen dp zur anzeige des namen
                            • hanan
                              hanan @hanan last edited by
                              Hmmmm....
                              Komisch, jetzt hat es soeben geklappt. Verstehe ich nichts mehr.
                              Die Datenpunkte wurden um 16:30 Uhr plötzlich beschrieben.
                                @hanan
                                ich gebe dir ein neues script, welches auch den countdown adapter nutzt
                                • hanan
                                  Einen neuen Datenpunkt im countdowns/setup/FC Basel kann ich doch seit v5.1.23 nicht mehr erstellen oder?
                                    @hanan
                                    das macht der adapter - hast du im adapter setting den counter angelegt - oder geht das nicht mehr
                                    • hanan
                                      Sorry, muss um 19:15 Uhr weg.
                                      Aber erstmal Danke für Deine Hilfe.
                                        @hanan wir machen morgen weiter
                                          @hanan melde dich, wenn/wann du morgen zeit hast
                                            @hanan
                                            hier mal ein neues script - hier wird direkt der countdown adapter verwendet
                                            • du musst das suchwort eingeben (FC Basel - denke ich)
                                            • in der vis und im script wird nun ein eigener datenpunkt (musst du erstellen) für deinen termin-namen verwendet - die anderen datenpunkte sind weiterhin unter dem countdown-adapter zu finden
                                            • du kannst einfach ein paar termine eingeben (bei mir war es im test googletest) um 15: 00 und um 15:30 und um 16:00 - dann sollte das script alle termine abarbeiten und immer den nächsten nehmen um ihn anzuzeigen
                                            bei mir klappt es
                                             <variables>
                                             </variables>
                                             <block type="comment" id="j6e86Yh}})qd~}SJM:_y" x="-137" y="-537">
                                               <field name="COMMENT">jede stunde check</field>
                                                   <field name="SCHEDULE">3 * * * *</field>
                                                     <block type="procedures_callnoreturn" id="A3h[pUrx|MqlRSn$*JPQ">
                                                       <mutation name="etwas tun"></mutation>
                                             <block type="procedures_defcustomreturn" id=".4jhH[;Isgq*k0Elo0tw" x="462" y="-412">
                                               </mutation>
                                               <field name="SCRIPT">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</field>
                                             <block type="comment" id="G_V|(=^[ypn!vkvsU]XB" x="-212" y="-362">
                                               <field name="COMMENT">beim scriptstart check</field>
                                                 <block type="procedures_callnoreturn" id="(T6N=EXH(4.!PxCR{IYK">
                                             <block type="procedures_defnoreturn" id="0N=R]U_AG[J;@9EK(vYA" x="138" y="-362">
                                               <field name="NAME">etwas tun</field>
                                               <statement name="STACK">
                                                 <block type="debug" id="ad$]%p%RkeI%BxJKt469">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="^2eW4BEub1^5b;yPYf=O">
                                                     <block type="get_value" id="pNaLg6ywW,iFN=^nZ@tF">
                                                         <block type="comment" id="REz{J.~}%h,YKvF[zs=_">
                                                           <field name="COMMENT">hier suchbegriff eingeben</field>
        <field name="TEXT">testgoogle</field>
        </mutation>
        <value name="ARG0">
        <value name="ARG1">
        <block type="sendto_custom" id="^YhY9:$x2@qbWS~VCIK5">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="name,date" with_statement="false"></mutation>
        <field name="INSTANCE">countdown.0</field>
        <field name="COMMAND">send</field>
        <field name="LOG"></field>
        <field name="WITH_STATEMENT">FALSE</field>
        <value name="ARG0">
        <shadow type="text" id="tl;X*tr8on5.=HLtbZ/a">
        <field name="TEXT">FC Basel</field>
        <value name="ARG1">
        <shadow type="text" id="y/t5`WMGw*c4N:#sdPa_">
        <block type="variables_get" id="s)+RK.KUUfie[zN:Tywv">
        <block type="comment" id="@uK?Qf/kh|@heM}Tk9uC">
        <field name="COMMENT">extra datenpunkt für namensgebung</field>
        <block type="control" id="uXG,7qdhL8|?C3}od=?I">
        <field name="OID">0_userdata.0.CONTROL-OWN.AAATEST.TestString3</field>
        <block type="text_join" id="Zs=q~.oy@-0qwbp1)zpY">
        <value name="ADD0">
        <block type="variables_get" id="5*V4+R9Jk3Qqa+#(E:-8">
        <value name="ADD1">
        <block type="text" id="7cNrB9:j~Cv(XHq2YlJO">
        <field name="TEXT"> - testAusgabe</field>
                                             <block type="comment" id="isqUSbF].;LNH[UPvx:M" x="-287" y="-262">
                                               <field name="COMMENT">wenn timer abgelaufen check</field>
                                                 <block type="comment" id="Ll:4~U0m?h3RX8dU9qfy">
                                                   <field name="COMMENT">wenn ical0 geändert - check</field>
                                                     <block type="on_ext" id="Y:?1wx{7^s0oge[=Y2mL">
                                                       <value name="OID0">
                                                         <shadow type="field_oid" id="^i|V1-4b4ry]#HY{95P0">
                                                       <value name="OID1">
                                                         <shadow type="field_oid" id="~Rg*PL%T(xsgFno;zT/O">
                                                           <field name="oid">ical.0.data.table</field>
                                                         <block type="timeouts_settimeout" id="M0p2VkDf=$/lw.?QCu*J">
                                                           <field name="DELAY">5</field>
                                                             <block type="procedures_callnoreturn" id="jg5gbBuQuyU)VTHWW0Rt">
                                            blockly javascript
                                            5433
