    4. [Vorlage]-Zeit herunterzählen bis GoogleTermin Eintritt
      liv-in-sky @hanan last edited by
      @hanan
      poste bitte das script - ich muss das importieren
      hanan 1 Reply Last reply Reply Quote 0
      • hanan
        hanan @liv-in-sky last edited by hanan
        @liv-in-sky
          <variables>
            <variable id="toV%#XU#+u-q8j}%lQO5">i</variable>
            <variable id="=laq7tvUO(q,%US6)j!u">j</variable>
            <variable id="l6*`|-^*E}19Ax.o8gS3">suchBegriff</variable>
            <variable id="dl(4-B)s(J1z0(yKCcPM">eventDatum</variable>
            <variable id="xKL%f`?jvCh0ok?{c^rL">stunde</variable>
            <variable id="4_[a*D)c$D0Fg1e?^r-#">minute</variable>
            <variable type="timeout" id="timeout4">timeout4</variable>
            <variable type="cron" id="datumSchedule">datumSchedule</variable>
            <variable type="timeout" id="timeout2">timeout2</variable>
          </variables>
          <block type="procedures_defcustomreturn" id=".4jhH[;Isgq*k0Elo0tw" x="163" y="-712">
            <mutation statements="false">
              <arg name="i" varid="toV%#XU#+u-q8j}%lQO5"></arg>
              <arg name="j" varid="=laq7tvUO(q,%US6)j!u"></arg>
            </mutation>
            <field name="NAME">StringManipulation2</field>
            <field name="SCRIPT">DQoNCi8vbG9nKEpTT04uc3RyaW5naWZ5KGkpKQ0KbGV0IG15RXJnZWJuaXM9LTE7DQoNCmZvciAobGV0IGFhPTA7YWE8aS5sZW5ndGg7YWErKyl7DQogIC8vICBsb2coaVthYV0uZXZlbnQpDQogICAgaWYoaVthYV0uZXZlbnQuaW5jbHVkZXMoaikpIHsvKmxvZyhpW2FhXS5ldmVudCk7Ki9teUVyZ2VibmlzPWlbYWFdLmRhdGU7c3VjaEJlZ3JpZmY9aVthYV0uZXZlbnQ7YnJlYWt9DQogICANCn0NCg0KDQovL2xvZyhteUVyZ2VibmlzKQ0KcmV0dXJuIG15RXJnZWJuaXM7</field>
          <block type="on_ext" id="qMd2zp!`jX-7i1:h/_G;" x="-287" y="-662">
            <value name="OID0">
              <shadow type="field_oid" id="kr$tstAFs]QhLrKlNNoz">
                <field name="oid">countdown.0.countdowns.FC Basel.reached</field>
              <block type="controls_if" id="$g`#_r*#6^uxk0K|Q|Tt">
                  <block type="logic_operation" id="]sXJg]u-cPjXadE5=hG1" inline="false">
                    <field name="OP">AND</field>
                      <block type="logic_compare" id="{!Rnk_(=3t]X67`petBQ">
                        <field name="OP">EQ</field>
                          <block type="get_value" id="mTL6SIt(Aj~_.;mH3=xR">
                            <field name="OID">countdown.0.countdowns.FC Basel.reached</field>
                          <block type="logic_boolean" id="-6I4]}?W]Xv:4E=2q#i4">
                      <block type="logic_compare" id=".cvPRJXKUfkd4*DBc@IW">
                          <block type="get_value" id="2=ZjTG(T#VNZbpFE]Zzd">
                            <field name="OID">0_userdata.0.Variablen.Vis_Schalter.FCB_Matsch</field>
                          <block type="logic_boolean" id="W6z=qlg;ult*~@$K!0ri">
                  <block type="control" id="1Na}tzv^U0BpCL+?qud}">
                      <block type="logic_boolean" id="v_r~x-0mXdB:rHJSK.gK">
                <value name="IF1">
                  <block type="logic_operation" id="~0{ny@u#Q8+yY-AOe:):" inline="false">
                    <field name="OP">OR</field>
                      <block type="logic_operation" id="d@K~FVUoKm}~Y~(k2ObJ" inline="false">
                          <block type="logic_compare" id="kloYtw+X3N4YvdcPj%uD">
                              <block type="get_value" id="z-4a^}oAR]v6`qKT^Fni">
                              <block type="logic_boolean" id="8HLnr6B`/LTuA9O:1[Rp">
                          <block type="logic_compare" id="v_f#g|UNmN+B?=wm(01d">
                              <block type="get_value" id=":1EY%O5Fw5mBph*IF]Xa">
                              <block type="logic_boolean" id="M#70+@ciE48e!Dm{RuJR">
                      <block type="logic_compare" id="[Y1?|yhYN89xcT~o[Qf_">
                          <block type="get_value" id="Z.0oguVR%/AWy3TO]x!R">
                            <field name="OID">countdown.0.countdowns.FC Basel.endDate</field>
                          <block type="text" id="v5KT*)FSpKtToJ7K:[@(">
                            <field name="TEXT">Invalid date</field>
                <statement name="DO1">
                  <block type="control" id="oS*Vfh7N8]Hu9=*V%W6t">
                      <block type="logic_boolean" id=")(C6tn!lD(v?|{_tYt;Q">
                      <block type="control" id="4RjTm,E[-};p]-jxu-Ze">
                        <field name="OID">countdown.0.setup.FC Basel</field>
                          <block type="text" id="+7kxy.u*8]]~r#ftU0/y">
                            <field name="TEXT"></field>
                          <block type="control" id="pEj1$]dz*s]leHe`YR#-">
                            <field name="OID">0_userdata.0.Variablen.Vis_Schalter.FCB_gegen</field>
                            <field name="DELAY_MS">120</field>
                              <block type="text" id="mj,l#mf/+X7x|D%x.Cf}">
                              <block type="control" id="LVXT1Gs5f3a:Vw,C3f?a">
                                  <block type="logic_boolean" id="^j1BUs13H$ii7XTRc@fy">
              <block type="schedule" id="/Z@?iF|RB-}UWrCdgO8l">
                <field name="SCHEDULE">*/30 8-21 * * *</field>
                  <block type="controls_if" id="k$7XJl4TwwsH#F^BA]o!">
                      <block type="logic_operation" id="#HG.._U-Ge,?pWE#S[:X" inline="false">
                          <block type="logic_compare" id="9f+@Q))b-J0s6E[!|u12">
                              <block type="get_value" id="oqo=zB1v[Zu2]hs{Q0^|">
                              <block type="logic_boolean" id="yElSM@?hiE5nlmJBWK1/">
                          <block type="logic_compare" id=";c.w*taLtS%5+thu.:Z6">
                              <block type="get_value" id="Ho.I%k;m:ufg)Fk3G;3]">
                              <block type="text" id="hH9![JK-i;6O5)JWf$hG">
                      <block type="variables_set" id="Yn_03ee.K$F#2@`28d/M">
                        <field name="VAR" id="l6*`|-^*E}19Ax.o8gS3">suchBegriff</field>
                          <block type="text" id="_%5/XWgSJPtR10.BNE?,">
                            <field name="TEXT">Basel</field>
                          <block type="variables_set" id="[xt^RuL~Y|TiS0Re2?+#">
                            <field name="VAR" id="dl(4-B)s(J1z0(yKCcPM">eventDatum</field>
                              <block type="procedures_callcustomreturn" id="g?#2EB$^BkG@k+r=Bv|]">
                                <mutation name="StringManipulation2">
                                  <arg name="i"></arg>
                                  <arg name="j"></arg>
                                </mutation>
                                <value name="ARG0">
                                  <block type="get_value" id="?}[v,-QV{dczpnW|a=qd">
                                    <field name="OID">ical.2.data.table</field>
                                <value name="ARG1">
                                  <block type="variables_get" id="K2N=*^9uaX6H0}j]s5=*">
                              <block type="controls_if" id="/zQZ~5M`WY$~j~oKdH5z">
                                  <block type="logic_compare" id="Z?!zm|/x#bu*Q7]r4,%4">
                                    <field name="OP">NEQ</field>
                                      <block type="variables_get" id="F$bDE3t^u;v%QO/XXCr6">
                                      <block type="math_number" id="NcEs_VXKEGxjrfy]h3_[">
                                        <field name="NUM">-1</field>
                                  <block type="variables_set" id="GYrFB;7cr*:#h}.et0I~">
                                    <field name="VAR" id="xKL%f`?jvCh0ok?{c^rL">stunde</field>
                                      <block type="text_getSubstring" id="-/-p`iD:y_vgxgLa5+dk">
                                        <mutation at1="true" at2="true"></mutation>
                                        <field name="WHERE1">FROM_START</field>
                                        <field name="WHERE2">FROM_START</field>
                                        <value name="STRING">
                                          <block type="variables_get" id="6{Y.CU(rNYFSz7JKw6gr">
                                        <value name="AT1">
                                          <block type="math_number" id="Kq.B-X,mqp;-N#)X=Q+P">
                                            <field name="NUM">12</field>
                                        <value name="AT2">
                                          <block type="math_number" id="t@;2+]ISoUKt$e,;oqY3">
                                            <field name="NUM">13</field>
                                      <block type="variables_set" id="vT$zjFC6[`*5|+?^FUYb">
                                        <field name="VAR" id="4_[a*D)c$D0Fg1e?^r-#">minute</field>
                                          <block type="text_getSubstring" id="iKSGk7wasI6U%DoU%/~`">
                                              <block type="variables_get" id="|d#VH=fnVXwAs^x#8Z{d">
                                            <value name="AT1">
                                              <block type="math_number" id="t#m1rz,4t`GTw`v1v_YC">
                                                <field name="NUM">15</field>
                                            <value name="AT2">
                                              <block type="math_number" id="Jz.]{TpX{G65p$t=zQmh">
                                                <field name="NUM">16</field>
                                          <block type="debug" id="dCLeDz(n@AvlXBiXCXw.">
                                            <value name="TEXT">
                                              <shadow type="text" id="J42$[^PW@Pg,FMd8dx~}">
                                              <block type="variables_get" id="t]8dz(9aJ4fbLd(JPv5p">
                                              <block type="debug" id="--O3@Ew@70yHrA|80r^B">
                                                <value name="TEXT">
                                                  <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="vUqJQDqZYEP1~M}JHa]U">
                                                  <block type="variables_get" id="KmvnGC^%j/LAP~CH2O.=">
                                                  <block type="debug" id="@D}2|sZ`qt0Jw`}~MHoZ">
                                                    <value name="TEXT">
                                                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="text">
                                                      <block type="variables_get" id="*!vl!IxcFiTS+=$S@iu*">
                                                      <block type="debug" id="U/?(?G1iL7EA@=.oE`-#">
                                                        <value name="TEXT">
                                                          <block type="variables_get" id="^8:$QQ;mFMZx^e-Y%)S6">
                                                          <block type="timeouts_settimeout" id=":8H?ff.:HrbvkOig[yJ[">
                                                            <field name="NAME">timeout4</field>
                                                            <field name="DELAY">3</field>
                                                              <block type="controls_if" id="^-$KSt-IwY$gkV9zU9Pd">
        <block type="logic_compare" id="4o(6_1vMy*Fpu#As|X14">
        <field name="OP">GT</field>
        <block type="variables_get" id="b-p,2nK}n*ke1Xi9wl`g">
        <block type="time_get" id="Bi$kG3R-!qDo[PIR;#wq">
        <field name="OPTION">h</field>
        <block type="schedule_create" id="4Q,qI3!9]bUX-]NQvf-P">
        <field name="NAME">datumSchedule</field>
        <value name="SCHEDULE">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="field_cron" id="?75wOi3|4ORjpXgU9SSn">
        <field name="CRON">* * * * *</field>
        <block type="text_join" id="A*!}}?bQe6=SR5,+#z@4">
        <mutation items="6"></mutation>
        <value name="ADD0">
        <block type="variables_get" id="hJOK@v*3*~(!S5cOgth;">
        <value name="ADD1">
        <block type="text" id="=cxyzRaBVprL+dg3GT/{">
        <field name="TEXT"> </field>
        <value name="ADD2">
        <block type="variables_get" id="*Tk9Oa|zErcUBQUUxT!U">
        <value name="ADD3">
        <block type="text" id="U=3Zo6aR4L#}:M|v)x:M">
        <field name="TEXT"> *</field>
        <value name="ADD4">
        <block type="text" id="U.G0Et9x?LX,p)Rxpg-e">
        <value name="ADD5">
        <block type="text" id="*[F-,a-H0aNhT2AJ6JmU">
        <block type="control" id="Mbk~Q;0UP@A8@^F[0Mou">
        <field name="DELAY_MS">1000</field>
        <field name="UNIT">ms</field>
        <block type="variables_get" id="r?o81v9MAq6qgqme2YN?">
        <block type="control" id="Nz%11urUbBT2c_+6~vUK">
        <field name="DELAY_MS">2000</field>
        <block type="variables_get" id=":D;!al^ufSTpm5dn;HqV">
        <block type="timeouts_settimeout" id="ryfODWCYatf{RY8|7?C%">
        <field name="DELAY">10</field>
        <block type="schedule_clear" id="@}/RY2BL~F{L#mhFxsM=">
        <statement name="ELSE">
        <block type="control" id="--.){w[29%H}dCX)QZre">
        <block type="variables_get" id="0qiq9Ta*z-gm~VXO{T]/">
        <block type="control" id="J@u{-ak8EhzU+j]BLUpd">
        <block type="variables_get" id="=`c+9CFW^h@u=EyPJ34$">
          @hanan sagte in [Vorlage]-Zeit herunterzählen bis GoogleTermin Eintritt:
          ich muss gestehen, ich glaube, ich habe den countdown adapter etwas missbraucht - ich schau mal, ob ich morgen ein anderes script zusammenbringe
          der countdown adapter ist bei dir noch gestartet ?
          • hanan
            @liv-in-sky
            Habe oben eben nochmals mein aktuelles Blockly-Skript eingefügt...
            Jep, und ich beschreibe im Ordner setup den Datenpunkt FC Basel mit dem eventDatum, welches eben nicht mehr übernommen wird.
            liv-in-sky hanan 2 Replies Last reply Reply Quote 0
              @hanan ist bei mir auch - da machen wir uns einen neuen datenpunkt und schreiben den mit dem richtigen namen - in der vis nimmst du dann den neuen dp zur anzeige des namen
              • hanan
                hanan @hanan last edited by
                Hmmmm....
                Komisch, jetzt hat es soeben geklappt. Verstehe ich nichts mehr.
                Die Datenpunkte wurden um 16:30 Uhr plötzlich beschrieben.
                  @hanan
                  ich gebe dir ein neues script, welches auch den countdown adapter nutzt
                  • hanan
                    Einen neuen Datenpunkt im countdowns/setup/FC Basel kann ich doch seit v5.1.23 nicht mehr erstellen oder?
                      @hanan
                      das macht der adapter - hast du im adapter setting den counter angelegt - oder geht das nicht mehr
                      • hanan
                        Sorry, muss um 19:15 Uhr weg.
                        Aber erstmal Danke für Deine Hilfe.
                          @hanan wir machen morgen weiter
                            @hanan melde dich, wenn/wann du morgen zeit hast
                              @hanan
                              hier mal ein neues script - hier wird direkt der countdown adapter verwendet
                              • du musst das suchwort eingeben (FC Basel - denke ich)
                              • in der vis und im script wird nun ein eigener datenpunkt (musst du erstellen) für deinen termin-namen verwendet - die anderen datenpunkte sind weiterhin unter dem countdown-adapter zu finden
                              • du kannst einfach ein paar termine eingeben (bei mir war es im test googletest) um 15: 00 und um 15:30 und um 16:00 - dann sollte das script alle termine abarbeiten und immer den nächsten nehmen um ihn anzuzeigen
                              bei mir klappt es
                               <variables>
                               </variables>
                               <block type="comment" id="j6e86Yh}})qd~}SJM:_y" x="-137" y="-537">
                                 <field name="COMMENT">jede stunde check</field>
                                     <field name="SCHEDULE">3 * * * *</field>
                                       <block type="procedures_callnoreturn" id="A3h[pUrx|MqlRSn$*JPQ">
                                         <mutation name="etwas tun"></mutation>
                               <block type="procedures_defcustomreturn" id=".4jhH[;Isgq*k0Elo0tw" x="462" y="-412">
                                 </mutation>
                                 <field name="SCRIPT">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</field>
                               <block type="comment" id="G_V|(=^[ypn!vkvsU]XB" x="-212" y="-362">
                                 <field name="COMMENT">beim scriptstart check</field>
                                   <block type="procedures_callnoreturn" id="(T6N=EXH(4.!PxCR{IYK">
                               <block type="procedures_defnoreturn" id="0N=R]U_AG[J;@9EK(vYA" x="138" y="-362">
                                 <field name="NAME">etwas tun</field>
                                 <statement name="STACK">
                                   <block type="debug" id="ad$]%p%RkeI%BxJKt469">
                                     <value name="TEXT">
                                       <shadow type="text" id="^2eW4BEub1^5b;yPYf=O">
                                       <block type="get_value" id="pNaLg6ywW,iFN=^nZ@tF">
                                           <block type="logic_compare" id="M76Fa)lSqWA4~DpUBx]#">
                                               <block type="get_value" id="~cXDg*N0V}(j;3:-g@=W">
                                               <block type="text" id="(L7Thmh8pK[9|obXZlJE">
                                           <block type="comment" id="REz{J.~}%h,YKvF[zs=_">
                                             <field name="COMMENT">hier suchbegriff eingeben</field>
                                                     <field name="TEXT">testgoogle</field>
                                                         </mutation>
                                                         <value name="ARG0">
                                                             <field name="OID">ical.0.data.table</field>
                                                         <value name="ARG1">
                                                           <block type="sendto_custom" id="^YhY9:$x2@qbWS~VCIK5">
                                                             <mutation xmlns="http://www.w3.org/1999/xhtml" items="name,date" with_statement="false"></mutation>
                                                             <field name="INSTANCE">countdown.0</field>
                                                             <field name="COMMAND">send</field>
                                                             <field name="LOG"></field>
                                                             <field name="WITH_STATEMENT">FALSE</field>
                                                             <value name="ARG0">
                                                               <shadow type="text" id="tl;X*tr8on5.=HLtbZ/a">
        <field name="TEXT">FC Basel</field>
                                                             <value name="ARG1">
                                                               <shadow type="text" id="y/t5`WMGw*c4N:#sdPa_">
                                                               <block type="variables_get" id="s)+RK.KUUfie[zN:Tywv">
                                                               <block type="comment" id="@uK?Qf/kh|@heM}Tk9uC">
        <field name="COMMENT">extra datenpunkt für namensgebung</field>
        <block type="control" id="uXG,7qdhL8|?C3}od=?I">
        <field name="OID">0_userdata.0.CONTROL-OWN.AAATEST.TestString3</field>
        <block type="text_join" id="Zs=q~.oy@-0qwbp1)zpY">
        <value name="ADD0">
        <block type="variables_get" id="5*V4+R9Jk3Qqa+#(E:-8">
        <value name="ADD1">
        <block type="text" id="7cNrB9:j~Cv(XHq2YlJO">
        <field name="TEXT"> - testAusgabe</field>
                               <block type="comment" id="isqUSbF].;LNH[UPvx:M" x="-287" y="-262">
                                 <field name="COMMENT">wenn timer abgelaufen check</field>
                                   <block type="comment" id="Ll:4~U0m?h3RX8dU9qfy">
                                     <field name="COMMENT">wenn ical0 geändert - check</field>
                                       <block type="on_ext" id="Y:?1wx{7^s0oge[=Y2mL">
                                         <value name="OID0">
                                           <shadow type="field_oid" id="^i|V1-4b4ry]#HY{95P0">
                                         <value name="OID1">
                                           <shadow type="field_oid" id="~Rg*PL%T(xsgFno;zT/O">
                                             <field name="oid">ical.0.data.table</field>
                                           <block type="timeouts_settimeout" id="M0p2VkDf=$/lw.?QCu*J">
                                             <field name="DELAY">5</field>
                                               <block type="procedures_callnoreturn" id="jg5gbBuQuyU)VTHWW0Rt">
                              • hanan
                                @liv-in-sky
                                Hallo liv-in-sky
                                Danke für Deine Arbeit, doch ich kann es erst Morgenabend testen, da ich immer noch auf der Arbeit bin (sch....tag).
                                Liebe Grüsse und einen schönen Abend.
                                  @hanan kein thema - wenn es paßt - einfach melden
                                  • hanan
                                    @liv-in-sky
                                    Hallo liv-in-sky
                                    Habe das Skript importiert und die Datenpunkte angepasst.
                                    👏 super Arbeit, funz auf anhieb.
                                    Besten Dank nochmals für Deine Hilfe.
                                    blockly javascript
                                    5433
