    4. [ESPHome] Beta release
      Was macht eigentlich die Neuerung in V 0.2.4
      option if config of ESPHome device should be shown as states
      Slowman Dutchman 2 Replies Last reply Reply Quote 0
      • Slowman
        Slowman @klassisch last edited by
        @klassisch
        Sehe gerade das die .2.4 raus ist
        • Dutchman
          Dutchman Developer Most Active Administrators @klassisch last edited by
          @klassisch sagte in [ESPHome] Beta release:
          Momentan stehen bei jedem Channel auch ein Ordner mit 8states bezüglich der Configuration.
          Mit dieser Option kann man das erstellen davon ausschalten
          @slowman sagte in [ESPHome] Beta release:
          @klassisch
          Damit sollte der Fehler behoben sein hier der fix dazu
          https://github.com/DrozmotiX/ioBroker.esphome/commit/d9e3e5c7290c9fbb9b2e9433216ca711e170d6bb#diff-58417e0f781b6656949d37258c8b9052ed266e2eb7a5163cad7b0863e6b2916a
          0 DutchmanNL committed to DrozmotiX/ioBroker.esphome
          update compatibility to version 1.19.4 of ESPHome Dashboard
          Slowman K 2 Replies Last reply Reply Quote 0
          • Slowman
            Slowman @Dutchman last edited by Slowman
            @dutchman
            hmm... Update von 0.2.2 auf 0.2.4
            npm install Drozmotix/ioBroker.esphome#a1f9adad9bfa6b6de20de3c8b293f26b6b44dff5 --loglevel error --prefix "/opt/iobroker" (System call)
            Traceback (most recent call last): File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module> main() File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main bootstrap(tmpdir=tmpdir) File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap import pip File "/tmp/tmp4tlzbwf7/pip.zip/pip/__init__.py", line 26, in <module> File "/tmp/tmp4tlzbwf7/pip.zip/pip/utils/__init__.py", line 23, in <module> File "/tmp/tmp4tlzbwf7/pip.zip/pip/locations.py", line 9, in <module>ImportError: cannot import name 'sysconfig' from 'distutils' (/usr/lib/python3.7/distutils/__init__.py)
            Error: Exited with code 1.
            at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20) at ChildProcess.emit (events.js:400:28) at maybeClose (internal/child_process.js:1055:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
            npm ERR! code ELIFECYCLEnpm ERR! errno 1
            npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-30T18_41_53_478Z-debug.log
            host.ioBroker Cannot install Drozmotix/ioBroker.esphome#a1f9adad9bfa6b6de20de3c8b293f26b6b44dff5: 1
            ERROR: Process exited with code 25
            Habe jetzt eine Sicherung eingespielt Debian 10 Nodejs 12.x , da geht das Update ohne Probleme. Werde morgen nochmal auf Debian Bullseye plus Nodejs 14.x updaten und schauen, ob das Problem noch besteht.
            • Dutchman
              Dutchman Developer Most Active Administrators @Slowman last edited by Dutchman
              @slowman
              Welche Python und js-Controller Version?
                klassisch Most Active @Dutchman last edited by
                @dutchman sagte in [ESPHome] Beta release:
                sind das diese hier?
                  Falls gestattet, hier noch eine Frage zu ESPHome an sich:
                  Wie kann man die Erfassung und Übertragung von Werten an den ioBroker synchronisieren?
                  Beispiel:
                  Gerät mit
                  • 2 Sensoren
                  • 3 Messwerten aus den Sensoren
                  • 3 zusätzlich per "lambda" berechnete Werte
                  Alle update_ interval stehen auf 1 min
                  Dennoch kommen die Daten nicht gleichzeitig beim ioBroker an, sondern einzeln, nach und nach zu verschiedenen Zeiten.
                  Kann man den Ablauf innerhalb des ESP zeitlich synchronisieren oder steuern?
                  Dutchman E 2 Replies Last reply Reply Quote 0
                  • Dutchman
                    Nein Ordner conf
                    • Dutchman
                      Kan ich dir leider nicht beantworten
                        @dutchman diese?
                          e-s @klassisch last edited by
                          @klassisch
                          Heute war im changelog von esphone das templates auch das change intervall nutzen sollen.
                          Also etwas abwarten auf die nächste esphome Version, alternativ dev Version installieren und im discord chat von esphome nachfragen.
                          • Dutchman
                            @dutchman diese?
                            Jup
                              klassisch Most Active @e-s last edited by klassisch
                              @e-s sagte in [ESPHome] Beta release:
                              Vielen Dank für den Hinweis. Bin mal gespannt, ob dann das erwartete Verhalten eintritt. Mir ist unklar, was der ESP so lange rechnet. An der Rechenleistung kann das nicht liegen.
                              Es gibt zwar on_.. und then: Dazu finde ich Beispiele zum Triggern von switches. Vielleicht noch zum Ausführen eines Lambda aber leider nicht zum Starten eines Sensor read.
                              Werde ich tun. Bin sicher nicht der Einzige, der sich übr das dynamische Verhalten wundert
                                DocGame last edited by
                                Vielen Dank für den Adapter. Ich bin durch diesen erst auf ESPHome aufmerksam geworden.
                                Bis jetzt habe ich meine ESP's immer mit Tasmota, EspEasy oder Spezial Iso's für RFID, Kamera usw. betrieben.
                                Ich habe jetzt mal einen Nodemcu genommen und einige Sensoren zum Test eingebunden. Soweit klappt alles und auch das übertragen der Werte an den Adapter bzw. MQTT klappt super.
                                Woran ich im Moment scheitere sind Rules mit denen ich einige Sensoren direkt "Onboard" verbinden kann. Zum testen wollte ich mit einem Touchsensor ein Relais steuern. Mit dem ioBroker über Blockly kein Problem. Aber mit "on_.. und then:" usw. bekomme ich es leider nicht hin.
                                Hier mal die "Nackten" Sensoreinträge, die auch alle funktionieren:
                                esphome:
                                  platform: ESP8266
                                  board: nodemcuv2
                                # Enable logging
                                logger:
                                # Enable Home Assistant API
                                api:
                                ota:
                                  password: "##########"
                                wifi:
                                  ssid: "######"
                                  password: "########"
                                  # Enable fallback hotspot (captive portal) in case wifi connection fails
                                  ap:
                                    ssid: "Lolin-Esphometest"
                                    password: "#########"
                                captive_portal:
                                mqtt:
                                  broker: 192.168.###.##
                                  username: ####
                                  password: #####
                                  port: ####
                                i2c:
                                  sda: 4
                                  scl: 5
                                  scan: true
                                sensor:
                                  - platform: dht
                                    pin: D3
                                    model: AM2302
                                    temperature:
                                    humidity:
                                    update_interval: 60s
                                  - platform: ultrasonic
                                    trigger_pin: D5
                                    echo_pin: D6
                                    update_interval: 5s
                                  - platform: vl53l0x
                                    address: 0x29
                                    update_interval: 8s
                                    long_range: false
                                    enable_pin: D7
                                switch:
                                  - platform: gpio
                                    pin: D7
                                binary_sensor:
                                  - platform: gpio
                                    pin: D8
                                Was muss ich eintragen um mit dem Switch (Touch) das Relais zu schalten?
                                E Dutchman 2 Replies Last reply Reply Quote 0
                                  klassisch Most Active last edited by klassisch
                                  @docgame Habe das bisher in ESPHome selber noch nicht gebraucht. Und ich kenne den nodemcu nicht, sondern nutze den Wemos D1 mini
                                  Was mir aber auffällt:
                                  • Beim Lidar Sensor nutzt Du enable_pin, der wohl für die Adressumschaltung gedacht ist. Das würde ich mal weglassen.
                                  • Pin D7 wird gleichzeitig als Relais und zur Adressumschaltung des Lidar-Sensors verwendet
                                  Wenn Du das aufgeräumt hast, dann wäre mal das einen Versuch mit on_press innerhalb des binary sensor wert Zitat ESPHome Doku
                                  on_press
                                  This automation will be triggered when the button is first pressed down, or in other words on the leading edge of the signal.
                                  binary_sensor:
                                    - platform: gpio
                                      on_press:
                                        then:
                                          - switch.turn_on: relay_1
                                  ich nehme an, daß relay_1 der id ist, bei Dir also relais
                                  Wenn Du toggeln lassen willst, sollte auch das gehen:
                                  Zitat ESPHome Doku
                                  switch.toggle Action
                                  This action toggles a switch with the given ID when executed.
                                  on_...:
                                    then:
                                      - switch.toggle: relay_1
                                  Wie gesagt, in ESPHome habe ich es noch nicht gebraucht, weil ich in meiner "ESP-Zeit" den meisten Kram und u.a. auch das Relaistoggeln selbst zusammengefrickelt habe. Und was stabil läuft (z.B. 1146 Tage up), läuft erst mal weiter....
                                    e-s @DocGame last edited by
                                    @docgame
                                    Kleiner Hinweis, der Vorteil an esphome und dem Adapter ist, daß man kein mqtt braucht.
                                    Das kannst du also weglassen, nur api rein und fertig.
                                    • Dutchman
                                      Dutchman Developer Most Active Administrators @DocGame last edited by
                                      @docgame sagte in [ESPHome] Beta release:
                                      Schau dir mal die yaml Beispiele auf meiner Doku Seite an, die Steckdosen haben im Grunde was du suchst (Button press/toggle und Relais schalten) zb die shp7
                                      https://drozmotix.github.io/languages/de/Adapter/ESPHome/08.yamlTemplates.html#shp7
                                      Hier werden zb per Button die Relais geschalten und je nach Status die led
                                      binary_sensor:
                                      - platform: gpio
                                        internal: true
                                        pin:
                                        number: GPIO0
                                        mode: INPUT_PULLUP
                                        inverted: true
                                        on_press:
                                        - switch.toggle: relay1
                                      - platform: gpio
                                        internal: true
                                        pin:
                                        number: GPIO12
                                        mode: INPUT_PULLUP
                                        inverted: true
                                        on_press:
                                        - switch.toggle: relay2
                                      output:
                                      - platform: esp8266_pwm
                                        pin:
                                        number: GPIO13
                                        inverted: true
                                        pin:
                                        number: GPIO2
                                        inverted: true
                                      switch:
                                      - platform: gpio
                                        pin: GPIO14
                                        on_turn_on:
                                        - output.turn_on: red_led1
                                          on_turn_off:
                                        - output.turn_off: red_led1
                                      - platform: gpio
                                        pin: GPIO16
                                        on_turn_on:
                                        - output.turn_on: red_led2
                                          on_turn_off:
                                        - output.turn_off: red_led2
                                        DocGame @Dutchman last edited by
                                        @dutchman @klassisch @e-s
                                        Danke für eure Antworten. Die Doppelte "D7" war noch von meinen unzähligen Versuchen versehentlich drin...haben aber komischerweise nicht gestört.
                                        Die Fehlermeldungen kamen scheinbar nur durch ein falsches "Einrücken" in der Formatierung (Leerzeichen).
                                        switch:
                                          - platform: gpio
                                            pin: D7
                                        binary_sensor:
                                          - platform: gpio
                                            pin: D8
                                            on_press:
                                              then:
                                        Jetzt teste ich mal weiter wie ich den Status des Relays abfrage und gezielt ein und ausschalte.
                                        Denke, das ich die nächsten Probleme bekomme wenn ich jetzt ein LED-Display an den I2c h#nge und versuche einige Werte anzuzeigen. Bei ESPRasy war das noch kein Problem. Ich denke, wenn man sich einmal in die Materie reingedacht hat ist ESPHome schon nee feine Sache.
                                        • Dutchman
                                          Beachte bitte das GitHub issue bezüglich Displays bin da noch dran
                                            @dutchman Alles klar, dann stelle ich die Displaytests mal hinten an. Habe verschiedene da. 0,96", 1,3" und noch einige 2,8" SPI mit Touchdisplay.
                                            Werde mich mal an den Radarsensor RCWL-0516 (Steht leider nicht auf der Liste) machen.
                                            Danke erstmal
                                            591
                                            153430
