    4. [ESPHome] Beta release
    • Slowman
      Slowman @Dutchman last edited by Slowman
      @dutchman
      hmm... Update von 0.2.2 auf 0.2.4
      npm install Drozmotix/ioBroker.esphome#a1f9adad9bfa6b6de20de3c8b293f26b6b44dff5 --loglevel error --prefix "/opt/iobroker" (System call)
      Traceback (most recent call last): File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module> main() File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main bootstrap(tmpdir=tmpdir) File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap import pip File "/tmp/tmp4tlzbwf7/pip.zip/pip/__init__.py", line 26, in <module> File "/tmp/tmp4tlzbwf7/pip.zip/pip/utils/__init__.py", line 23, in <module> File "/tmp/tmp4tlzbwf7/pip.zip/pip/locations.py", line 9, in <module>ImportError: cannot import name 'sysconfig' from 'distutils' (/usr/lib/python3.7/distutils/__init__.py)
      Error: Exited with code 1.
      at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20) at ChildProcess.emit (events.js:400:28) at maybeClose (internal/child_process.js:1055:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-30T18_41_53_478Z-debug.log
      host.ioBroker Cannot install Drozmotix/ioBroker.esphome#a1f9adad9bfa6b6de20de3c8b293f26b6b44dff5: 1
      ERROR: Process exited with code 25
      Habe jetzt eine Sicherung eingespielt Debian 10 Nodejs 12.x , da geht das Update ohne Probleme. Werde morgen nochmal auf Debian Bullseye plus Nodejs 14.x updaten und schauen, ob das Problem noch besteht.
      • Dutchman
        Dutchman Developer Most Active Administrators @Slowman last edited by Dutchman
        @slowman
        Welche Python und js-Controller Version?
          klassisch Most Active @Dutchman last edited by
          @dutchman sagte in [ESPHome] Beta release:
          Momentan stehen bei jedem Channel auch ein Ordner mit 8states bezüglich der Configuration.
          sind das diese hier?
            Falls gestattet, hier noch eine Frage zu ESPHome an sich:
            Wie kann man die Erfassung und Übertragung von Werten an den ioBroker synchronisieren?
            Beispiel:
            Gerät mit
            • 2 Sensoren
            • 3 Messwerten aus den Sensoren
            • 3 zusätzlich per "lambda" berechnete Werte
            Alle update_ interval stehen auf 1 min
            Dennoch kommen die Daten nicht gleichzeitig beim ioBroker an, sondern einzeln, nach und nach zu verschiedenen Zeiten.
            Kann man den Ablauf innerhalb des ESP zeitlich synchronisieren oder steuern?
            Dutchman E 2 Replies Last reply Reply Quote 0
            • Dutchman
              Dutchman Developer Most Active Administrators @klassisch last edited by
              @klassisch sagte in [ESPHome] Beta release:
              Nein Ordner conf
              • Dutchman
                Kan ich dir leider nicht beantworten
                  @dutchman diese?
                    e-s @klassisch last edited by
                    @klassisch
                    Heute war im changelog von esphone das templates auch das change intervall nutzen sollen.
                    Also etwas abwarten auf die nächste esphome Version, alternativ dev Version installieren und im discord chat von esphome nachfragen.
                    • Dutchman
                      @dutchman diese?
                      Jup
                        klassisch Most Active @e-s last edited by klassisch
                        @e-s sagte in [ESPHome] Beta release:
                        Vielen Dank für den Hinweis. Bin mal gespannt, ob dann das erwartete Verhalten eintritt. Mir ist unklar, was der ESP so lange rechnet. An der Rechenleistung kann das nicht liegen.
                        Es gibt zwar on_.. und then: Dazu finde ich Beispiele zum Triggern von switches. Vielleicht noch zum Ausführen eines Lambda aber leider nicht zum Starten eines Sensor read.
                        Werde ich tun. Bin sicher nicht der Einzige, der sich übr das dynamische Verhalten wundert
                          DocGame last edited by
                          Vielen Dank für den Adapter. Ich bin durch diesen erst auf ESPHome aufmerksam geworden.
                          Bis jetzt habe ich meine ESP's immer mit Tasmota, EspEasy oder Spezial Iso's für RFID, Kamera usw. betrieben.
                          Ich habe jetzt mal einen Nodemcu genommen und einige Sensoren zum Test eingebunden. Soweit klappt alles und auch das übertragen der Werte an den Adapter bzw. MQTT klappt super.
                          Woran ich im Moment scheitere sind Rules mit denen ich einige Sensoren direkt "Onboard" verbinden kann. Zum testen wollte ich mit einem Touchsensor ein Relais steuern. Mit dem ioBroker über Blockly kein Problem. Aber mit "on_.. und then:" usw. bekomme ich es leider nicht hin.
                          Hier mal die "Nackten" Sensoreinträge, die auch alle funktionieren:
                          esphome:
                            platform: ESP8266
                            board: nodemcuv2
                          # Enable logging
                          logger:
                          # Enable Home Assistant API
                          api:
                          ota:
                            password: "##########"
                          wifi:
                            ssid: "######"
                            password: "########"
                            # Enable fallback hotspot (captive portal) in case wifi connection fails
                            ap:
                              ssid: "Lolin-Esphometest"
                              password: "#########"
                          captive_portal:
                          mqtt:
                            broker: 192.168.###.##
                            username: ####
                            password: #####
                            port: ####
                          i2c:
                            sda: 4
                            scl: 5
                            scan: true
                          sensor:
                            - platform: dht
                              pin: D3
                              model: AM2302
                              temperature:
                              humidity:
                              update_interval: 60s
                            - platform: ultrasonic
                              trigger_pin: D5
                              echo_pin: D6
                              update_interval: 5s
                            - platform: vl53l0x
                              address: 0x29
                              update_interval: 8s
                              long_range: false
                              enable_pin: D7
                          switch:
                            - platform: gpio
                              pin: D7
                          binary_sensor:
                            - platform: gpio
                              pin: D8
                          Was muss ich eintragen um mit dem Switch (Touch) das Relais zu schalten?
                          E Dutchman 2 Replies Last reply Reply Quote 0
                            klassisch Most Active last edited by klassisch
                            @docgame Habe das bisher in ESPHome selber noch nicht gebraucht. Und ich kenne den nodemcu nicht, sondern nutze den Wemos D1 mini
                            Was mir aber auffällt:
                            • Beim Lidar Sensor nutzt Du enable_pin, der wohl für die Adressumschaltung gedacht ist. Das würde ich mal weglassen.
                            • Pin D7 wird gleichzeitig als Relais und zur Adressumschaltung des Lidar-Sensors verwendet
                            Wenn Du das aufgeräumt hast, dann wäre mal das einen Versuch mit on_press innerhalb des binary sensor wert Zitat ESPHome Doku
                            on_press
                            This automation will be triggered when the button is first pressed down, or in other words on the leading edge of the signal.
                            binary_sensor:
                              - platform: gpio
                                on_press:
                                  then:
                                    - switch.turn_on: relay_1
                            ich nehme an, daß relay_1 der id ist, bei Dir also relais
                            Wenn Du toggeln lassen willst, sollte auch das gehen:
                            Zitat ESPHome Doku
                            switch.toggle Action
                            This action toggles a switch with the given ID when executed.
                            on_...:
                              then:
                                - switch.toggle: relay_1
                            Wie gesagt, in ESPHome habe ich es noch nicht gebraucht, weil ich in meiner "ESP-Zeit" den meisten Kram und u.a. auch das Relaistoggeln selbst zusammengefrickelt habe. Und was stabil läuft (z.B. 1146 Tage up), läuft erst mal weiter....
                              e-s @DocGame last edited by
                              @docgame
                              Kleiner Hinweis, der Vorteil an esphome und dem Adapter ist, daß man kein mqtt braucht.
                              Das kannst du also weglassen, nur api rein und fertig.
                              • Dutchman
                                Dutchman Developer Most Active Administrators @DocGame last edited by
                                @docgame sagte in [ESPHome] Beta release:
                                Schau dir mal die yaml Beispiele auf meiner Doku Seite an, die Steckdosen haben im Grunde was du suchst (Button press/toggle und Relais schalten) zb die shp7
                                https://drozmotix.github.io/languages/de/Adapter/ESPHome/08.yamlTemplates.html#shp7
                                Hier werden zb per Button die Relais geschalten und je nach Status die led
                                binary_sensor:
                                - platform: gpio
                                  internal: true
                                  pin:
                                  number: GPIO0
                                  mode: INPUT_PULLUP
                                  inverted: true
                                  on_press:
                                  - switch.toggle: relay1
                                - platform: gpio
                                  internal: true
                                  pin:
                                  number: GPIO12
                                  mode: INPUT_PULLUP
                                  inverted: true
                                  on_press:
                                  - switch.toggle: relay2
                                output:
                                - platform: esp8266_pwm
                                  pin:
                                  number: GPIO13
                                  inverted: true
                                  pin:
                                  number: GPIO2
                                  inverted: true
                                switch:
                                - platform: gpio
                                  pin: GPIO14
                                  on_turn_on:
                                  - output.turn_on: red_led1
                                    on_turn_off:
                                  - output.turn_off: red_led1
                                - platform: gpio
                                  pin: GPIO16
                                  on_turn_on:
                                  - output.turn_on: red_led2
                                    on_turn_off:
                                  - output.turn_off: red_led2
                                  DocGame @Dutchman last edited by
                                  @dutchman @klassisch @e-s
                                  Danke für eure Antworten. Die Doppelte "D7" war noch von meinen unzähligen Versuchen versehentlich drin...haben aber komischerweise nicht gestört.
                                  Die Fehlermeldungen kamen scheinbar nur durch ein falsches "Einrücken" in der Formatierung (Leerzeichen).
                                  switch:
                                    - platform: gpio
                                      pin: D7
                                  binary_sensor:
                                    - platform: gpio
                                      pin: D8
                                      on_press:
                                        then:
                                  Jetzt teste ich mal weiter wie ich den Status des Relays abfrage und gezielt ein und ausschalte.
                                  Denke, das ich die nächsten Probleme bekomme wenn ich jetzt ein LED-Display an den I2c h#nge und versuche einige Werte anzuzeigen. Bei ESPRasy war das noch kein Problem. Ich denke, wenn man sich einmal in die Materie reingedacht hat ist ESPHome schon nee feine Sache.
                                  • Dutchman
                                    Beachte bitte das GitHub issue bezüglich Displays bin da noch dran
                                      @dutchman Alles klar, dann stelle ich die Displaytests mal hinten an. Habe verschiedene da. 0,96", 1,3" und noch einige 2,8" SPI mit Touchdisplay.
                                      Werde mich mal an den Radarsensor RCWL-0516 (Steht leider nicht auf der Liste) machen.
                                      Danke erstmal
                                        klassisch Most Active @DocGame last edited by
                                        @docgame diese einfachen Radarsensoren liefern ein Digitalsignal. Müßte wie ein button einzulesen sein, motion sensor.
                                        Aber aufpassen mit der Versorgung. Ich hatte mit solchen einfachen Radarsensoren die Erfahrung gemacht, daß sie mit DC/DC-Wandlern nicht klarkamen und auch nicht mit der "verseuchten" Versorgung eines ESP. Es gab dann immer false postives.
                                        Falls Dir so etwas begenet, dann einen analogen Spannungsregler nehmen und die Teile separat versorgen.
                                          DocGame @klassisch last edited by
                                          @klassisch Gut zu wissen... Werde ich diese Woche mal testen. An Radarsensoren habe ich auch noch einige der "Luxusvariante" HFS-DC06H da.
                                          Da ich gerade kein aktuelles Projekt im Auge habe werde ich mal nach und nach alle Sensoren durchtesten die ich noch hier habe (Sind noch einige wie Schall, Wasser, Lux, Gyro usw.)
                                          Fürs erste halte ich in diesem Thread erstmal den Fuß still (das Thema ist ja der Adapter und nicht die Sensoren)
                                            Ich habe gestern mal versuchsweise eine esp32 cam in meinem ESPHome Adapter eingebunden. Hat soweit funktioniert sprich ich bin auf grün. Es werden einige Objekte angelegt. Nur wie ich ans Bild bzw Video komme ist mir ein Rätsel. Ist es überhaupt schon möglich?
                                            Dutchman A 2 Replies Last reply Reply Quote 0
                                            591
                                            153324
