    3. Marktplatz
    4. [Verkauft] CC2652P Zigbee Stick
      sauerstofff @Ritter last edited by sauerstofff
      @ritter ich klinke mich mal ein. Habe das selbe Problem. Heute erst wieder festgestellt.
      Bei mir half mal ein reflash. Aktuell aber auch nicht mehr...
      zigbee.0
      2021-09-01 00:10:06.211	error	Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32) at Generator.next (<anonymous>) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71 at new Promise (<anonymous>) at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12) at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49) at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0
      2021-09-01 00:10:06.209	error	Failed to start Zigbee
      zigbee.0
      2021-09-01 00:09:55.933	error	Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31) at Generator.throw (<anonymous>) at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      zigbee.0
      2021-09-01 00:09:55.928	error	Failed to start Zigbee
        Thomas Braun Most Active @Ritter last edited by
        @ritter
        Welchen device link hast du im Adapter drin?
          Thomas Braun Most Active @sauerstofff last edited by
          @sauerm
          Keine Screenshots von Logs. Die kann man nicht durchsuchen. Und schlecht zu lesen sind die auch.
            sauerstofff @Thomas Braun last edited by
            Das stimmt, ist korrigiert 👍
              @sauerm
              Schau da mal rein:
              https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start
                sauerstofff @Thomas Braun last edited by sauerstofff
                @thomas-braun Danke, alles gut aus. Bis auf:
                [  796.268302] dwc_otg 3f980000.usb: Invalid offset (0xffffffff)
                ... und ich habe gerade noch im log gefunden:
                zigbee.0
                2021-09-01 00:32:14.699	warn	Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  Ritter @Thomas Braun last edited by Ritter
                  @thomas-braun Hallo,
                  meinst du unter device Link das? /dev/ttyUSB0
                  pi@raspberrypi:~ $ ls -l /dev/serial/by-id
                  total 0
                  lrwxrwxrwx 1 root root 13 Aug 29 16:24 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
                    Thomas Braun Most Active @Ritter last edited by Thomas Braun
                    @ritter Stell das auf
                    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                    um
                      @thomas-braun Wo stell ich das um?
                        @ritter
                        In den Einstellungen des Adapters.
                          @thomas-braun Hier gibts nur noch das zur Auswahl: /dev/ttyAMA0
                            Ritter @Ritter last edited by
                            @ritter sagte in [Verkaufe] Neueste Entwicklung: CC2652P Zigbee Stick:
                            Hoffe ich habs gefunden kann man unter COM Anschluß einfach einfügen
                              @ritter
                              Richtig.
                                @thomas-braun Hab den Raspi mal neugestartet jetzt findet er den Stick nicht mehr
                                vorher war der Stick drann und da war das Problem nicht: CC2538+CC2592 PA Zigbee Stick
                                der war auf /dev/ttyAMA0 eingestellt
                                  @thomas-braun könnte es bei mir daran liegen, dass der Adapter auf einem Slave liegt?
                                  Und welche Zigbee Adapter Version soll nun verwendet werden 1.4.4.oer 1.5.6?
                                    Thomas Braun Most Active last edited by
                                    @ritter
                                    Das kann eigentlich nicht sein, der Link geht immer auf das richtige Gerät. Tippfehler? Führendes / übersehen?
                                      @sauerm
                                      Immer die neueste.
                                        @thomas-braun mehrfach überprüft aber geht nicht, d.h. wenn ich den COM Anschluss eingebe und den Adapter neu starte wird er auch grün, erst wenn ich den Raspi neu starte findet er ihn nicht.
                                          Danke, habe mal geupdated.
                                          Anbei noch die dritte Fehlermeldung die ich noch nicht gepostet hatte. Ich habe aktuell wirklich keine Ahnung mehr. Im Git auch nichts gefunden...
                                          Ich mache für heute erstmal Schluss - wirklich ärgerlich 😕
                                          Trotzdem vielen Dank für die Hilfe! 🙂
                                          zigbee.0
                                          2021-09-01 01:31:21.041	error	Cannot read property 'getEntries' of null
                                          zigbee.0
                                          2021-09-01 01:31:21.039	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:273:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41) at Zigbee.emit (events.js:314:20) at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
                                          zigbee.0
                                          2021-09-01 01:31:21.030	error	unhandled promise rejection: Cannot read property 'getEntries' of null
                                          zigbee.0
                                          2021-09-01 01:31:21.029	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            Wenn ich das aus der verlinkten Hilfe Seite eingebe wird er nach neustart wieder grün.
                                            sudo usermod -a -G uucp $USER
                                            sudo usermod -a -G tty $USER
                                            sudo usermod -a -G dialout $USER
                                            glaub aber langsam es ist nur Zufall.
                                            81.1k
                                            cc2531 cc2538 cc2652 cc26x2r1 modkam modkamru slaesh ti board zigbee zigbee stick
                                            45
                                            155
                                            45780
