    4. Zigbee Stick CC2652P wird nicht mehr erkannt
      sauerstofff @Glasfaser last edited by
      @glasfaser said in Zigbee Stick CC2652P wird nicht mehr erkannt:
      dmesg
      ls -l /dev/ttyA*
      ls -l /dev/ttyU*
      ls -l /dev/serial/by-id/*
      Sorry, ich hab den ersten Teil deiner Nachricht übersehen! 😬
      Hier die fehlende Ausgabe:
      dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.10.60-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:01 BST 2021
      [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
      [    0.000000] random: fast init done
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000]   Normal   empty
      [    0.000000] Movable zone start for each node
      [    0.000000] Early memory node ranges
      [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
      [    0.000000] On node 0 totalpages: 242688
      [    0.000000]   DMA zone: 2133 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 242688 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
      [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=3371abfc-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                     Please use sysfs to set IO scheduler for individual devices.
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] Memory: 878804K/970752K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 26412K reserved, 65536K cma-reserved)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 32048 entries in 63 pages
      [    0.000000] ftrace: allocated 63 pages with 6 groups
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000]  Rude variant of Tasks RCU enabled.
      [    0.000000]  Tracing variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
      [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      [    0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      [    0.000012] Switching to timer-based delay loop, resolution 52ns
      [    0.000167] Console: colour dummy device 80x30
      [    0.000549] printk: console [tty1] enabled
      [    0.000591] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      [    0.000618] pid_max: default: 32768 minimum: 301
      [    0.000731] LSM: Security Framework initializing
      [    0.000861] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.000884] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.001661] cgroup: Disabling memory control group subsystem
      [    0.001819] CPU: Testing write buffer coherency: ok
      [    0.002126] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002749] Setting up static identity map for 0x100000 - 0x10003c
      [    0.002846] rcu: Hierarchical SRCU implementation.
      [    0.003325] smp: Bringing up secondary CPUs ...
      [    0.003976] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.004645] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.005241] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.005310] smp: Brought up 1 node, 4 CPUs
      [    0.005356] SMP: Total of 4 processors activated (153.60 BogoMIPS).
      [    0.005370] CPU: All CPU(s) started in HYP mode.
      [    0.005382] CPU: Virtualization extensions available.
      [    0.005955] devtmpfs: initialized
      [    0.013955] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
      [    0.014104] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.014133] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.015643] pinctrl core: initialized pinctrl subsystem
      [    0.016293] NET: Registered protocol family 16
      [    0.018642] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.021244] audit: initializing netlink subsys (disabled)
      [    0.021415] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
      [    0.021714] thermal_sys: Registered thermal governor 'step_wise'
      [    0.022164] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.022191] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.022373] Serial: AMBA PL011 UART driver
      [    0.030997] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
      [    0.050053] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-31T14:55:00, variant start
      [    0.060058] raspberrypi-firmware soc:firmware: Firmware hash is 67615e950e1e28b92dfae6303cf7a8b879a8908f
      [    0.084823] Kprobes globally optimized
      [    0.087271] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.088324] SCSI subsystem initialized
      [    0.088451] usbcore: registered new interface driver usbfs
      [    0.088496] usbcore: registered new interface driver hub
      [    0.088536] usbcore: registered new device driver usb
      [    0.089504] clocksource: Switched to clocksource arch_sys_counter
      [    0.866441] VFS: Disk quotas dquot_6.6.0
      [    0.866518] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.866628] FS-Cache: Loaded
      [    0.866808] CacheFiles: Loaded
      [    0.871766] NET: Registered protocol family 2
      [    0.871961] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
      [    0.872778] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.872819] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.872882] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.872974] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.873095] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.873129] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.873451] NET: Registered protocol family 1
      [    0.873904] RPC: Registered named UNIX socket transport module.
      [    0.873921] RPC: Registered udp transport module.
      [    0.873934] RPC: Registered tcp transport module.
      [    0.873946] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.874793] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
      [    0.876590] Initialise system trusted keyrings
      [    0.876760] workingset: timestamp_bits=14 max_order=18 bucket_order=4
      [    0.881076] zbud: loaded
      [    0.882063] FS-Cache: Netfs 'nfs' registered for caching
      [    0.882508] NFS: Registering the id_resolver key type
      [    0.882540] Key type id_resolver registered
      [    0.882552] Key type id_legacy registered
      [    0.882638] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.882655] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    0.883237] Key type asymmetric registered
      [    0.883252] Asymmetric key parser 'x509' registered
      [    0.883288] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.883306] io scheduler mq-deadline registered
      [    0.883319] io scheduler kyber registered
      [    0.885082] bcm2708_fb soc:fb: FB found 1 display(s)
      [    0.895094] Console: switching to colour frame buffer device 82x26
      [    0.898857] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
      [    0.903700] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
      [    0.906462] bcm2835-rng 3f104000.rng: hwrng registered
      [    0.907981] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    0.911053] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [    0.920056] brd: module loaded
      [    0.928206] loop: module loaded
      [    0.930609] Loading iSCSI transport class v2.0-870.
      [    0.932877] libphy: Fixed MDIO Bus: probed
      [    0.934355] usbcore: registered new interface driver lan78xx
      [    0.935723] usbcore: registered new interface driver smsc95xx
      [    0.937038] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.666315] Core Release: 2.80a
      [    1.667391] Setting default values for core params
      [    1.668490] Finished setting default values for core params
      [    1.869798] Using Buffer DMA mode
      [    1.870898] Periodic Transfer Interrupt Enhancement - disabled
      [    1.872019] Multiprocessor Interrupt Enhancement - disabled
      [    1.873128] OTG VER PARAM: 0, OTG VER FLAG: 0
      [    1.874209] Dedicated Tx FIFOs mode
      [    1.875550] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
      [    1.878582] FIQ FSM acceleration enabled for :
                     Non-periodic Split Transactions
                     Periodic Split Transactions
                     High-Speed Isochronous Endpoints
                     Interrupt/Control Split Transaction hack enabled
      [    1.883323] dwc_otg: Microframe scheduler enabled
      [    1.883360] WARN::hcd_init_fiq:457: FIQ on core 1
      [    1.885244] WARN::hcd_init_fiq:458: FIQ ASM at 807c8db0 length 36
      [    1.887181] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
      [    1.889135] dwc_otg 3f980000.usb: DWC OTG Controller
      [    1.890158] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
      [    1.891200] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
      [    1.892234] Init: Port Power? op_state=1
      [    1.893211] Init: Power Port (0)
      [    1.894333] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
      [    1.896344] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.897422] usb usb1: Product: DWC OTG Controller
      [    1.898447] usb usb1: Manufacturer: Linux 5.10.60-v7+ dwc_otg_hcd
      [    1.899496] usb usb1: SerialNumber: 3f980000.usb
      [    1.900917] hub 1-0:1.0: USB hub found
      [    1.901981] hub 1-0:1.0: 1 port detected
      [    1.903743] dwc_otg: FIQ enabled
      [    1.903749] dwc_otg: NAK holdoff enabled
      [    1.903754] dwc_otg: FIQ split-transaction FSM enabled
      [    1.903763] Module dwc_common_port init
      [    1.903910] usbcore: registered new interface driver usb-storage
      [    1.905090] mousedev: PS/2 mouse device common for all mice
      [    1.906759] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.908740] sdhci: Secure Digital Host Controller Interface driver
      [    1.909862] sdhci: Copyright(c) Pierre Ossman
      [    1.911250] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
      [    1.912680] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
      [    1.913906] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.916310] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.917621] hid: raw HID events driver (C) Jiri Kosina
      [    1.918849] usbcore: registered new interface driver usbhid
      [    1.920005] usbhid: USB HID core driver
      [    1.924345] Initializing XFRM netlink socket
      [    1.925501] NET: Registered protocol family 17
      [    1.926666] Key type dns_resolver registered
      [    1.927973] Registering SWP/SWPB emulation handler
      [    1.929110] registered taskstats version 1
      [    1.930161] Loading compiled-in X.509 certificates
      [    1.931639] Key type ._fscrypt registered
      [    1.932647] Key type .fscrypt registered
      [    1.933654] Key type fscrypt-provisioning registered
      [    1.941514] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 31250000) is a 16550
      [    1.944094] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.945993] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.947076] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
      [    1.972970] sdhost: log_buf @ (ptrval) (f7513000)
      [    2.010133] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    2.012702] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    2.015330] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    2.019203] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    2.026489] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
      [    2.029121] of_cfs_init
      [    2.030253] of_cfs_init: OK
      [    2.052074] Indeed it is in host mode hprt0 = 00021501
      [    2.052094] Waiting for root device PARTUUID=3371abfc-02...
      [    2.164838] mmc1: new high speed SDIO card at address 0001
      [    2.179645] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.187041] mmc0: new high speed SDHC card at address aaaa
      [    2.188719] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
      [    2.192670]  mmcblk0: p1 p2
      [    2.209484] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    2.211799] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    2.219932] devtmpfs: mounted
      [    2.224955] Freeing unused kernel memory: 1024K
      [    2.259522] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [    2.260628] Indeed it is in host mode hprt0 = 00001101
      [    2.339741] Run /sbin/init as init process
      [    2.340807]   with arguments:
      [    2.340812]     /sbin/init
      [    2.340817]   with environment:
      [    2.340822]     HOME=/
      [    2.340826]     TERM=linux
      [    2.499747] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [    2.502059] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    2.503749] hub 1-1:1.0: USB hub found
      [    2.505073] hub 1-1:1.0: 4 ports detected
      [    2.819539] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [    2.882563] systemd[1]: System time before build time, advancing clock.
      [    2.949763] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [    2.952623] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    2.954627] hub 1-1.1:1.0: USB hub found
      [    2.956156] hub 1-1.1:1.0: 3 ports detected
      [    3.001017] NET: Registered protocol family 10
      [    3.003069] Segment Routing with IPv6
      [    3.061031] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    3.065439] systemd[1]: Detected architecture arm.
      [    3.122767] systemd[1]: Set hostname to <ioslave01>.
      [    3.269587] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
      [    3.402687] usb 1-1.1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.62
      [    3.405460] usb 1-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      [    3.408305] usb 1-1.1.3: Product: USB2.0-Serial
      [    3.642453] systemd[1]: /lib/systemd/system/debmatic-lighttpd.service:15: PIDFile= references path below legacy directory /var/run/, updating /var/run/lighttpd-debmatic.pid → /run/lighttpd-debmatic.pid; please update the unit file accordingly.
      [    3.652545] systemd[1]: /lib/systemd/system/debmatic-hs485d.service:15: PIDFile= references path below legacy directory /var/run/, updating /var/run/hs485dLoader.pid → /run/hs485dLoader.pid; please update the unit file accordingly.
      [    3.712409] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.719602] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
      [    3.724469] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.726588] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    3.731931] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.733781] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [    3.748196] systemd[1]: Listening on Journal Audit Socket.
      [    3.752670] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    3.758617] systemd[1]: Listening on Journal Socket.
      [    3.850145] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
      [    3.850154] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    4.118320] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
      [    4.119574] libphy: lan78xx-mdiobus: probed
      [    4.132759] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
      [    4.305663] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    4.378814] systemd-journald[123]: Received request to flush runtime journal from PID 1
      [    4.856434] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.857931] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.857949] [vc_sm_connected_init]: start
      [    4.864649] [vc_sm_connected_init]: installed successfully
      [    4.869801] generic_raw_uart: loading out-of-tree module taints kernel.
      [    4.874939] mc: Linux media interface: v0.10
      [    4.876261] pl011_raw_uart 3f201000.serial: there is not valid maps for state default
      [    4.876386] pl011_raw_uart 3f201000.serial: I2C adapter of configured RTC device is not yet initialized
      [    4.876395] pl011_raw_uart 3f201000.serial: failed to initialize generic_raw_uart module
      [    4.904496] videodev: Linux video capture interface: v2.00
      [    4.927621] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.933918] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.935388] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.943083] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.947718] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    4.948085] pl011_raw_uart 3f201000.serial: there is not valid maps for state default
      [    4.948220] pl011_raw_uart 3f201000.serial: I2C adapter of configured RTC device is not yet initialized
      [    4.948229] pl011_raw_uart 3f201000.serial: failed to initialize generic_raw_uart module
      [    4.958206] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.974249] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.974280] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    4.975240] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    4.976420] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    4.977116] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    4.977177] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    4.977229] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    4.977269] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    4.977315] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    4.978613] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    4.979350] pl011_raw_uart 3f201000.serial: there is not valid maps for state default
      [    4.979486] pl011_raw_uart 3f201000.serial: I2C adapter of configured RTC device is not yet initialized
      [    4.979810] pl011_raw_uart 3f201000.serial: failed to initialize generic_raw_uart module
      [    4.982600] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    4.982656] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    4.986719] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    4.986768] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    4.995739] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    4.995787] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    4.996227] pl011_raw_uart 3f201000.serial: there is not valid maps for state default
      [    4.996424] pl011_raw_uart 3f201000.serial: I2C adapter of configured RTC device is not yet initialized
      [    4.996437] pl011_raw_uart 3f201000.serial: failed to initialize generic_raw_uart module
      [    5.064574] pl011_raw_uart 3f201000.serial: there is not valid maps for state default
      [    5.064713] pl011_raw_uart 3f201000.serial: Missing I2C driver of rtc device, trying to load
      [    5.064723] pl011_raw_uart 3f201000.serial: Requesting module i2c:rx8130-legacy
      [    5.088626] rtc-rx8130 1-0032: Unable to read registers #28..#30
      [    5.088644] i2c i2c-1: probing for rx8130 failed
      [    5.088671] rtc-rx8130: probe of 1-0032 failed with error -121
      [    5.090914] rtc-rx8130 1-0032: Unable to read registers #28..#30
      [    5.090930] i2c i2c-1: probing for rx8130 failed
      [    5.090951] rtc-rx8130: probe of 1-0032 failed with error -121
      [    5.217228] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    5.288622] usbcore: registered new interface driver usbserial_generic
      [    5.288667] usbserial: USB Serial support registered for generic
      [    5.297167] usbcore: registered new interface driver ch341
      [    5.297228] usbserial: USB Serial support registered for ch341-uart
      [    5.297312] ch341 1-1.1.3:1.0: ch341-uart converter detected
      [    5.301733] pl011_raw_uart 3f201000.serial: Initialized pl011 device; mapbase=0x3f201000; irq=114; clockrate=47999625
      [    5.303130] usb 1-1.1.3: ch341-uart converter now attached to ttyUSB0
      [    5.318215] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    5.381824] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    5.402324] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.403661] usbcore: registered new interface driver brcmfmac
      [    5.669324] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.669445] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.717578] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [    5.744307] random: crng init done
      [    5.744325] random: 7 urandom warning(s) missed due to ratelimiting
      [    6.892386] 8021q: 802.1Q VLAN Support v1.8
      [    7.179780] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    7.285626] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    7.667342] 8021q: adding VLAN 0 to HW filter on device eth0
      [   12.696940] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [   14.131396] Bluetooth: Core ver 2.22
      [   14.131492] NET: Registered protocol family 31
      [   14.131499] Bluetooth: HCI device and connection manager initialized
      [   14.131524] Bluetooth: HCI socket layer initialized
      [   14.131542] Bluetooth: L2CAP socket layer initialized
      [   14.131564] Bluetooth: SCO socket layer initialized
      [   14.142629] Bluetooth: HCI UART driver ver 2.3
      [   14.142643] Bluetooth: HCI UART protocol H4 registered
      [   14.142728] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   14.143588] Bluetooth: HCI UART protocol Broadcom registered
      [   14.429175] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   14.429188] Bluetooth: BNEP filters: protocol multicast
      [   14.429206] Bluetooth: BNEP socket layer initialized
      [   14.495565] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
      [   18.702001] raw-uart raw-uart: Reset radio module
      pi@ioslave01:/etc/network $ ls -l /dev/ttyA*
      ls: cannot access '/dev/ttyA*': No such file or directory
      pi@ioslave01:/etc/network $ ls -l /dev/ttyU*
      crw-rw---- 1 root dialout 188, 0 Sep  2 21:37 /dev/ttyUSB0
      pi@ioslave01:/etc/network $ ls -l /dev/serial/by-id/*
      • Glasfaser
        Glasfaser @sauerstofff last edited by
        @sauerm sagte in Zigbee Stick CC2652P wird nicht mehr erkannt:
        Hast du ein USB-to-serial Adapter
        K S 2 Replies Last reply Reply Quote 0
          klassisch Most Active @Glasfaser last edited by
          @glasfaser sagte in Zigbee Stick CC2652P wird nicht mehr erkannt:
          CH341 riecht nach CH340, der auf dem Stick von Dimav drauf ist bzw. drauf war. Da scheint es eine neue Version des Sticks zu geben mit einer anderen Bauform des CH34x.
          Bei meinem war noch ein CH340 auf der Rückseite drauf, weshalb ich ihn auch einfach umbauen und so direkt ohne USB mit einem Serial <-> Ethernet Wandler ins LAN bringen konnte. Damit wären dann auch die USB-/Serial-Probleme weg gewesen, wenn ich die denn gehabt hätte.
            @glasfaser Ja, ich habe den Stick von Dimaiv.
            @klassisch kannst du mir da mal einen Link schicken? Würde ich mir gern mal anschauen 🙂
              klassisch Most Active @sauerstofff last edited by
              @sauerm Hier der Link zu meinem Umbau Zigbee CC2652 per LAN anbinden.
              Habe das vor allem wegen der Netztopologie gemacht. , Mein ioBroker Rechner steht nicht dort, wo der Zigbee Controller stehen sollte. USB Themen waren bei mir nicht die Ursache, kennt man mit Windows nicht so sehr.
              Für den Umbau braucht man halt so ein Modul, man muß löten und eine Leiterbahn unterbrechen. Nicht jedermanns Sache.
              Läuft dann aber rocksolid.
                sauerstofff @klassisch last edited by
                @klassisch vielen Dank!
                Mein Hauptsystem steht ebenfalls im Keller. Ich nutze als Extension einen Pi mit Slave mit CC2652P Stick. Ethernet wäre aber auch sehr reizvoll 🙂
                Bin E-Techniker, das sollte also machbar sein 😊
                  @sauerm na dann, ran an den Speck.
                  Ich wollte mir die Komplexität eines Multi Host Systems ersparen. Mit ser2net war es bei mir nicht stabil und ich reduziere generell meine linux SBCs. Zu viel Uruhe, zu viele Überraschungen nach updates. Die USRIOTs gehen gut. Zigbee Adapter und Smartmeter Adapter unterstützen tcp. Damit läuft's stabil und ich kann meine USBs anderweitig nutzen.
                  • Asgothian
                    Asgothian Developer @klassisch last edited by Asgothian
                    @klassisch sagte in Zigbee Stick CC2652P wird nicht mehr erkannt:
                    Ohne diese Lösung schlecht reden zu wollen (sie ist gut, und für alle die sich das Umlöten zutrauen auf jeden Fall empfehlenswert) - sie wird das Problem in diesem Fall nicht sauber lösen können.
                    Das Log vom Startup zeigt Folgendes:
                    1. Startversuch
                    zigbee.0 2021-09-02 11:30:50.074	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                    Der Adapter öffnet die serielle Schnittstelle (erfolgreich), und versucht dann mit über diese mit der Firmware zu kommunizieren - bekommt aber keine Antwort von der Firmware.
                    1. (und alle Folgenden) Startversuche:
                    zigbee.0 2021-09-02 11:31:00.256	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    Der Adapter konnte die Serielle Schnittstelle nicht öffnen da sie vom System noch nicht wieder Freigegeben war. Dieses ist darauf zurück zu führen das in der im 1.5.6 verbundenen Herdsman Version der Herdsman nicht sauber beendet wird und daher die Schnittstelle nicht freigegeben wird.
                    Ein Update auf den Zigbee Adapter 1.6.1 von Github ist an dieser Stelle ratsam.
                    Es ist also (leider) zu befürchten das es entweder ein problem mit der Firmware auf dem Stick oder mit der seriellen Kommunikation zum Stick gibt. Der Wechsel an einen anderen USB Port oder auf ein anderes USB Verlängerungskabel (sofern eines verwendet wird) ist in diesem Fall ratsam, um zwischen Störungen durch USB und Problemen mit der Hardware / Firmware des Sticks unterscheiden zu können.
                    Es macht auch Sinn den Adapter im Debug und mit dem Haken bei "Zigbee Herdsman Debug Info" zu starten, dann kommen ggf. mehr Meldungen aus dem Versuch mit dem Koordinator zu kommunizieren.
                    A.
                      sauerstofff @Asgothian last edited by
                      @asgothian vielen vielen Dank!!
                      Nun verstehe ich besser was los ist.
                      Der Stick ist direkt am Pi. Ich habe auch schon verschiedene Ports versucht.
                      Ich werde noch mal die Firmware neu flashen.
                      Bisher war ich mir nicht sicher ob der Fehler eher am Adapter oder eher am Stick liegt.
                        dimaiv @sauerstofff last edited by
                        @sauerm
                        Wenn du die Meinung hast, dass dein Stick nicht in Ordnung ist, dann tauschen wir um.
                          @dimaiv vielen Dank für das Angebot. Ich möchte erst gern alles andere ausschließen. 🙂
                          @Asgothian ich habe nun einmal die Zigbee Adapterversion 1.6.1 installiert. Bei der Installation sind auch zwei Fehlerblöcke aufgetreten. Wenn ich es richtig interpretiere hat es auch etwas mit der seriellen Schnittstelle zu tun:
                          $ iobroker url https://github.com/ioBroker/ioBroker.zigbee.git --host ioslave01 --debug
                          install ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                          NPM version: 6.14.15
                          npm install ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7 --prefix "/opt/iobroker" (System call)
                          > @serialport/bindings@9.2.0 install /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                          prebuild-install WARN install No prebuilt binaries found (target=12.22.6 runtime=node arch=arm libc= platform=linux)
                          make: Entering directory '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                          CXX(target) Release/obj.target/bindings/src/serialport.o
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                          ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^
                          ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                          In file included from ../../../nan/nan.h:58,
                          from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                          CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                          ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                          ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                          CXX(target) Release/obj.target/bindings/src/poller.o
                          CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                          SOLINK_MODULE(target) Release/obj.target/bindings.node
                          COPY Release/bindings.node
                          make: Leaving directory '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                          > @serialport/bindings@9.2.0 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                          make: Entering directory '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                          ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                          make: Leaving directory '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                          + iobroker.zigbee@1.6.1
                          added 39 packages from 15 contributors, removed 377 packages and updated 726 packages in 244.296s
                          68 packages are looking for funding run `npm fund` for details
                          upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                          upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
                          upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
                          upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
                          upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
                          upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
                          upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
                          upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
                          upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
                          upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
                          upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
                          upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
                          upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                          upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                          upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                          upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                          upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                          upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
                          upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                          upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                          upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                          upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                          upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                          upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                          upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                          upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                          upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                          upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                          upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                          upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                          upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                          upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                          upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                          Update "system.adapter.zigbee.0"
                          Process exited with code 0
                          Hier der Log von der Installation und Adapterkonfiguration - leider immer noch der selbe Fehler:
                          zigbee.0
                          2021-09-03 19:54:42.607	info	Installed Version: ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                          zigbee.0
                          2021-09-03 19:54:42.581	error	Error herdsman start
                          zigbee.0
                          2021-09-03 19:54:42.580	error	Failed to start Zigbee
                          zigbee.0
                          2021-09-03 19:54:42.579	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'"
                          zigbee.0
                          2021-09-03 19:54:42.549	info	Starting Zigbee npm ...
                          zigbee.0
                          2021-09-03 19:54:42.547	info	Try to reconnect. 1 attempts left
                          zigbee.0
                          2021-09-03 19:54:32.820	info	Installed Version: ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                          zigbee.0
                          2021-09-03 19:54:32.543	error	Error herdsman start
                          zigbee.0
                          2021-09-03 19:54:32.542	error	Failed to start Zigbee
                          zigbee.0
                          2021-09-03 19:54:32.540	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'"
                          zigbee.0
                          2021-09-03 19:54:32.073	info	Starting Zigbee npm ...
                          zigbee.0
                          2021-09-03 19:54:31.999	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
                          zigbee.0
                          2021-09-03 19:54:22.846	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zigbee.0
                          2021-09-03 19:54:22.844	info	terminating
                          zigbee.0
                          2021-09-03 19:54:22.842	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2021-09-03 19:54:22.559	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2021-09-03 19:54:22.555	info	cleaned everything up...
                          zigbee.0
                          2021-09-03 19:54:22.552	info	Got terminate signal TERMINATE_YOURSELF
                          zigbee.0
                          2021-09-03 19:54:01.732	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                          zigbee.0
                          2021-09-03 19:51:30.049	info	Installed Version: ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                          zigbee.0
                          2021-09-03 19:51:30.034	error	Error herdsman start
                          zigbee.0
                          2021-09-03 19:51:30.033	error	Failed to start Zigbee
                          zigbee.0
                          2021-09-03 19:51:30.032	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'"
                          zigbee.0
                          2021-09-03 19:51:30.014	info	Starting Zigbee npm ...
                          zigbee.0
                          2021-09-03 19:51:30.011	info	Try to reconnect. 1 attempts left
                          zigbee.0
                          2021-09-03 19:51:20.248	info	Installed Version: ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                          zigbee.0
                          2021-09-03 19:51:20.006	error	Error herdsman start
                          zigbee.0
                          2021-09-03 19:51:20.006	error	Failed to start Zigbee
                          zigbee.0
                          2021-09-03 19:51:20.004	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'"
                          zigbee.0
                          2021-09-03 19:51:19.426	info	Starting Zigbee npm ...
                          zigbee.0
                          2021-09-03 19:51:19.354	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
                          zigbee.0
                          2021-09-03 19:51:08.685	error	Cannot read property 'getEntries' of null
                          zigbee.0
                          2021-09-03 19:51:08.684	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                          zigbee.0
                          2021-09-03 19:51:08.681	error	unhandled promise rejection: Cannot read property 'getEntries' of null
                          zigbee.0
                          2021-09-03 19:51:08.680	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          zigbee.0
                          2021-09-03 19:51:08.678	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zigbee.0
                          2021-09-03 19:51:08.676	info	terminating
                          zigbee.0
                          2021-09-03 19:51:08.675	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2021-09-03 19:51:08.672	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2021-09-03 19:51:08.665	info	cleaned everything up...
                          zigbee.0
                          2021-09-03 19:51:08.642	info	Got terminate signal TERMINATE_YOURSELF
                          Ich flashe den Stick nun noch einmal neu.
                            Thomas Braun Most Active @sauerstofff last edited by
                            @sauerm
                            Hast du bzw. der user iobroker die erforderlichen Rechte am Gerät?
                              @thomas-braun ja, hatte ich ebenfalls über die Seite geprüft, die du im Verkaufsthread verlinkt hattest:
                              https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start
                              Habe es eben noch einmal geprüft:
                              pi@ioslave01:~ $ test -w /dev/ttyUSB0 && echo success || echo failure
                              success
                              pi@ioslave01:~ $
                              Nach dem erneuten Flashen des Sticks sieht es nun so aus:
                              zigbee.0
                              2021-09-03 20:16:30.565	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              zigbee.0
                              2021-09-03 20:16:30.562	info	terminating
                              zigbee.0
                              2021-09-03 20:16:30.062	info	Zigbee: disabling joining new devices.
                              zigbee.0
                              2021-09-03 20:16:30.058	info	cleaned everything up...
                              zigbee.0
                              2021-09-03 20:16:30.028	error	SRSP - SYS - osalNvRead after 0,2ms
                              zigbee.0
                              2021-09-03 20:16:30.027	error	Error: SRSP - SYS - osalNvRead after 0,2ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7)
                              zigbee.0
                              2021-09-03 20:16:29.982	error	unhandled promise rejection: SRSP - SYS - osalNvRead after 0,2ms
                              zigbee.0
                              2021-09-03 20:16:29.981	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              zigbee.0
                              2021-09-03 20:16:29.975	info	Zigbee started
                              zigbee.0
                              2021-09-03 20:16:29.973	info	Currently no devices.
                              zigbee.0
                              2021-09-03 20:16:29.955	info	--> transmitPower : normal
                              zigbee.0
                              2021-09-03 20:16:29.941	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                              zigbee.0
                              2021-09-03 20:16:27.960	info	Installed Version: ioBroker/ioBroker.zigbee#216deafc3f5b3db95b256ad7054ad50ca41678f7
                              zigbee.0
                              2021-09-03 20:16:27.117	info	Starting Zigbee npm ...
                              zigbee.0
                              2021-09-03 20:16:26.892	info	starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
                              Und nachdem ich nun den Zigbee Adapter 1.6.1 deinstalliert, beide Systeme (Master und Slave) neugestartet und anschließend auf dem Slave wieder Zigbee 1.5.6 installiert habe, funktioniert der Adapter wieder 🤔
                              Hier noch einmal das Installationprotokoll zum Vergleich:
                              $ iobroker add zigbee auto --host ioslave01
                              npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                              ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                              ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                              ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                              ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                              In file included from ../../../nan/nan.h:56,
                              from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                              ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                              host.ioslave01 install adapter zigbee
                              host.ioslave01 object system.adapter.zigbee created/updated
                              host.ioslave01 create instance zigbee
                              host.ioslave01 object zigbee.0.info.groups created
                              host.ioslave01 object zigbee.0.info.pairingMessage created
                              host.ioslave01 object zigbee.0.info.pairingCountdown created
                              host.ioslave01 object zigbee.0.info.pairingMode created
                              host.ioslave01 object zigbee.0.info.connection created
                              host.ioslave01 object zigbee.0.info created
                              host.ioslave01 object zigbee.0.exclude.all created
                              host.ioslave01 object zigbee.0.exclude created
                              host.ioslave01 object system.adapter.zigbee.0.logLevel created
                              host.ioslave01 object system.adapter.zigbee.0.sigKill created
                              host.ioslave01 object system.adapter.zigbee.0.eventLoopLag created
                              host.ioslave01 object system.adapter.zigbee.0.outputCount created
                              host.ioslave01 object system.adapter.zigbee.0.inputCount created
                              host.ioslave01 object system.adapter.zigbee.0.uptime created
                              host.ioslave01 object system.adapter.zigbee.0.memRss created
                              host.ioslave01 object system.adapter.zigbee.0.memHeapTotal created
                              host.ioslave01 object system.adapter.zigbee.0.memHeapUsed created
                              host.ioslave01 object system.adapter.zigbee.0.cputime created
                              host.ioslave01 object system.adapter.zigbee.0.cpu created
                              host.ioslave01 object system.adapter.zigbee.0.compactMode created
                              host.ioslave01 object system.adapter.zigbee.0.connected created
                              host.ioslave01 object system.adapter.zigbee.0.alive created
                              host.ioslave01 Set default value of zigbee.0.info.groups:
                              host.ioslave01 Set default value of zigbee.0.info.pairingMessage:
                              host.ioslave01 Set default value of zigbee.0.info.pairingCountdown: 0
                              host.ioslave01 Set default value of zigbee.0.info.pairingMode: false
                              host.ioslave01 Set default value of zigbee.0.info.connection: false
                              host.ioslave01 Set default value of zigbee.0.exclude.all: []
                              host.ioslave01 object system.adapter.zigbee.0 created
                              Vielen Dank für eure Hilfe. Ich behalte das mal im Auge. Alle paar Monate neu flashen ist auf dauer auch anstrengend 😌
                                Josh @sauerstofff last edited by
                                Ich hatte gestern das gleiche Problem. Der Adapter auf einem der beiden Slaves bliebt gelb. Ich hatte vorher das node.js-Update gemacht. Da auch eine neue Kernelversion mit installiert wurde, musste der RPi neu gestartet werden.
                                Nachdem ich es nicht mehr geschafft hatte, den Adapter mittels Adapterneustart grün zu bekommen, habe ich den RPi nochmal neu gestartet und bin ins Bett gegangen. Heute morgen war er dann grün.
                                Nur so als Info, dass Du nicht alleine bist. 🙂
                                  @josh danke dir 😊
                                  Bei mir lief der Adapter gut ne Woche nicht. Neustarts hatten leider nicht funktioniert. Mal sehen wie lange es jetzt läuft 😌
                                  1675
