    4. Adapter Updates Fehler
      sigi234 Forum Testing Most Active @bob der 1. last edited by
      @bob-der-1
      Hast du vor dem Update mal den Adapter gestoppt?
        bob der 1. @sigi234 last edited by
        @sigi234
        Ja,das auch.
          Thomas Braun Most Active @bob der 1. last edited by
          @bob-der-1
          Hast du python installiert?
          Welche Version?
          python -v
          python3 -v
            bob der 1. @Thomas Braun last edited by
            bekomme folgende ausgabe
            bei python -v
            # installing zipimport hook
            import zipimport # builtin
            # installed zipimport hook
            # /usr/lib/python2.7/site.pyc matches /usr/lib/python2.7/site.py
            import site # precompiled from /usr/lib/python2.7/site.pyc
            # /usr/lib/python2.7/os.pyc matches /usr/lib/python2.7/os.py
            import os # precompiled from /usr/lib/python2.7/os.pyc
            import errno # builtin
            import posix # builtin
            # /usr/lib/python2.7/posixpath.pyc matches /usr/lib/python2.7/posixpath.py
            import posixpath # precompiled from /usr/lib/python2.7/posixpath.pyc
            # /usr/lib/python2.7/stat.pyc matches /usr/lib/python2.7/stat.py
            import stat # precompiled from /usr/lib/python2.7/stat.pyc
            # /usr/lib/python2.7/genericpath.pyc matches /usr/lib/python2.7/genericpath.py
            import genericpath # precompiled from /usr/lib/python2.7/genericpath.pyc
            # /usr/lib/python2.7/warnings.pyc matches /usr/lib/python2.7/warnings.py
            import warnings # precompiled from /usr/lib/python2.7/warnings.pyc
            # /usr/lib/python2.7/linecache.pyc matches /usr/lib/python2.7/linecache.py
            import linecache # precompiled from /usr/lib/python2.7/linecache.pyc
            # /usr/lib/python2.7/types.pyc matches /usr/lib/python2.7/types.py
            import types # precompiled from /usr/lib/python2.7/types.pyc
            # /usr/lib/python2.7/UserDict.pyc matches /usr/lib/python2.7/UserDict.py
            import UserDict # precompiled from /usr/lib/python2.7/UserDict.pyc
            # /usr/lib/python2.7/_abcoll.pyc matches /usr/lib/python2.7/_abcoll.py
            import _abcoll # precompiled from /usr/lib/python2.7/_abcoll.pyc
            # /usr/lib/python2.7/abc.pyc matches /usr/lib/python2.7/abc.py
            import abc # precompiled from /usr/lib/python2.7/abc.pyc
            # /usr/lib/python2.7/_weakrefset.pyc matches /usr/lib/python2.7/_weakrefset.py
            import _weakrefset # precompiled from /usr/lib/python2.7/_weakrefset.pyc
            import _weakref # builtin
            # /usr/lib/python2.7/copy_reg.pyc matches /usr/lib/python2.7/copy_reg.py
            import copy_reg # precompiled from /usr/lib/python2.7/copy_reg.pyc
            # /usr/lib/python2.7/traceback.pyc matches /usr/lib/python2.7/traceback.py
            import traceback # precompiled from /usr/lib/python2.7/traceback.pyc
            # /usr/lib/python2.7/sysconfig.pyc matches /usr/lib/python2.7/sysconfig.py
            import sysconfig # precompiled from /usr/lib/python2.7/sysconfig.pyc
            # /usr/lib/python2.7/re.pyc matches /usr/lib/python2.7/re.py
            import re # precompiled from /usr/lib/python2.7/re.pyc
            # /usr/lib/python2.7/sre_compile.pyc matches /usr/lib/python2.7/sre_compile.py
            import sre_compile # precompiled from /usr/lib/python2.7/sre_compile.pyc
            import _sre # builtin
            # /usr/lib/python2.7/sre_parse.pyc matches /usr/lib/python2.7/sre_parse.py
            import sre_parse # precompiled from /usr/lib/python2.7/sre_parse.pyc
            # /usr/lib/python2.7/sre_constants.pyc matches /usr/lib/python2.7/sre_constants.py
            import sre_constants # precompiled from /usr/lib/python2.7/sre_constants.pyc
            import _locale # builtin
            # /usr/lib/python2.7/_sysconfigdata.pyc matches /usr/lib/python2.7/_sysconfigdata.py
            import _sysconfigdata # precompiled from /usr/lib/python2.7/_sysconfigdata.pyc
            # /usr/lib/python2.7/plat-arm-linux-gnueabihf/_sysconfigdata_nd.pyc matches /usr/lib/python2.7/plat-arm-linux-gnueabihf/_sysconfigdata_nd.py
            import _sysconfigdata_nd # precompiled from /usr/lib/python2.7/plat-arm-linux-gnueabihf/_sysconfigdata_nd.pyc
            # /usr/lib/python2.7/sitecustomize.pyc matches /usr/lib/python2.7/sitecustomize.py
            import sitecustomize # precompiled from /usr/lib/python2.7/sitecustomize.pyc
            import encodings # directory /usr/lib/python2.7/encodings
            # /usr/lib/python2.7/encodings/__init__.pyc matches /usr/lib/python2.7/encodings/__init__.py
            import encodings # precompiled from /usr/lib/python2.7/encodings/__init__.pyc
            # /usr/lib/python2.7/codecs.pyc matches /usr/lib/python2.7/codecs.py
            import codecs # precompiled from /usr/lib/python2.7/codecs.pyc
            import _codecs # builtin
            # /usr/lib/python2.7/encodings/aliases.pyc matches /usr/lib/python2.7/encodings/aliases.py
            import encodings.aliases # precompiled from /usr/lib/python2.7/encodings/aliases.pyc
            # /usr/lib/python2.7/encodings/utf_8.pyc matches /usr/lib/python2.7/encodings/utf_8.py
            import encodings.utf_8 # precompiled from /usr/lib/python2.7/encodings/utf_8.pyc
            Python 2.7.16 (default, Oct 10 2019, 22:02:15)
            [GCC 8.3.0] on linux2
            Type "help", "copyright", "credits" or "license" for more information.
            dlopen("/usr/lib/python2.7/lib-dynload/readline.arm-linux-gnueabihf.so", 2);
            import readline # dynamically loaded from /usr/lib/python2.7/lib-dynload/readline.arm-linux-gnueabihf.so
            Bei python 3
            import _frozen_importlib # frozen
            import _imp # builtin
            import '_thread' # <class '_frozen_importlib.BuiltinImporter'>
            import '_warnings' # <class '_frozen_importlib.BuiltinImporter'>
            import '_weakref' # <class '_frozen_importlib.BuiltinImporter'>
            import 'zipimport' # <class '_frozen_importlib.BuiltinImporter'>
            import '_frozen_importlib_external' # <class '_frozen_importlib.FrozenImporter'>
            import '_io' # <class '_frozen_importlib.BuiltinImporter'>
            import 'marshal' # <class '_frozen_importlib.BuiltinImporter'>
            import 'posix' # <class '_frozen_importlib.BuiltinImporter'>
            import _thread # previously loaded ('_thread')
            import _weakref # previously loaded ('_weakref')
            # /usr/lib/python3.7/encodings/__pycache__/__init__.cpython-37.pyc matches /usr/lib/python3.7/encodings/__init__.py
            # code object from '/usr/lib/python3.7/encodings/__pycache__/__init__.cpython-37.pyc'
            # /usr/lib/python3.7/__pycache__/codecs.cpython-37.pyc matches /usr/lib/python3.7/codecs.py
            # code object from '/usr/lib/python3.7/__pycache__/codecs.cpython-37.pyc'
            import '_codecs' # <class '_frozen_importlib.BuiltinImporter'>
            import 'codecs' # <_frozen_importlib_external.SourceFileLoader object at 0xb66bf630>
            # /usr/lib/python3.7/encodings/__pycache__/aliases.cpython-37.pyc matches /usr/lib/python3.7/encodings/aliases.py
            # code object from '/usr/lib/python3.7/encodings/__pycache__/aliases.cpython-37.pyc'
            import 'encodings.aliases' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d0190>
            import 'encodings' # <_frozen_importlib_external.SourceFileLoader object at 0xb66bf310>
            # /usr/lib/python3.7/encodings/__pycache__/utf_8.cpython-37.pyc matches /usr/lib/python3.7/encodings/utf_8.py
            # code object from '/usr/lib/python3.7/encodings/__pycache__/utf_8.cpython-37.pyc'
            import 'encodings.utf_8' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d4b10>
            import '_signal' # <class '_frozen_importlib.BuiltinImporter'>
            # /usr/lib/python3.7/encodings/__pycache__/latin_1.cpython-37.pyc matches /usr/lib/python3.7/encodings/latin_1.py
            # code object from '/usr/lib/python3.7/encodings/__pycache__/latin_1.cpython-37.pyc'
            import 'encodings.latin_1' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d8130>
            # /usr/lib/python3.7/__pycache__/io.cpython-37.pyc matches /usr/lib/python3.7/io.py
            # code object from '/usr/lib/python3.7/__pycache__/io.cpython-37.pyc'
            # /usr/lib/python3.7/__pycache__/abc.cpython-37.pyc matches /usr/lib/python3.7/abc.py
            # code object from '/usr/lib/python3.7/__pycache__/abc.cpython-37.pyc'
            import '_abc' # <class '_frozen_importlib.BuiltinImporter'>
            import 'abc' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d83b0>
            import 'io' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d8210>
            # /usr/lib/python3.7/__pycache__/site.cpython-37.pyc matches /usr/lib/python3.7/site.py
            # code object from '/usr/lib/python3.7/__pycache__/site.cpython-37.pyc'
            # /usr/lib/python3.7/__pycache__/os.cpython-37.pyc matches /usr/lib/python3.7/os.py
            # code object from '/usr/lib/python3.7/__pycache__/os.cpython-37.pyc'
            # /usr/lib/python3.7/__pycache__/stat.cpython-37.pyc matches /usr/lib/python3.7/stat.py
            # code object from '/usr/lib/python3.7/__pycache__/stat.cpython-37.pyc'
            import '_stat' # <class '_frozen_importlib.BuiltinImporter'>
            import 'stat' # <_frozen_importlib_external.SourceFileLoader object at 0xb66eae30>
            # /usr/lib/python3.7/__pycache__/posixpath.cpython-37.pyc matches /usr/lib/python3.7/posixpath.py
            # code object from '/usr/lib/python3.7/__pycache__/posixpath.cpython-37.pyc'
            # /usr/lib/python3.7/__pycache__/genericpath.cpython-37.pyc matches /usr/lib/python3.7/genericpath.py
            # code object from '/usr/lib/python3.7/__pycache__/genericpath.cpython-37.pyc'
            import 'genericpath' # <_frozen_importlib_external.SourceFileLoader object at 0xb6672dd0>
            import 'posixpath' # <_frozen_importlib_external.SourceFileLoader object at 0xb66eaf30>
            # /usr/lib/python3.7/__pycache__/_collections_abc.cpython-37.pyc matches /usr/lib/python3.7/_collections_abc.py
            # code object from '/usr/lib/python3.7/__pycache__/_collections_abc.cpython-37.pyc'
            import '_collections_abc' # <_frozen_importlib_external.SourceFileLoader object at 0xb6679230>
            import 'os' # <_frozen_importlib_external.SourceFileLoader object at 0xb66e47d0>
            # /usr/lib/python3.7/__pycache__/_sitebuiltins.cpython-37.pyc matches /usr/lib/python3.7/_sitebuiltins.py
            # code object from '/usr/lib/python3.7/__pycache__/_sitebuiltins.cpython-37.pyc'
            import '_sitebuiltins' # <_frozen_importlib_external.SourceFileLoader object at 0xb66e4a50>
            # /usr/lib/python3.7/__pycache__/sitecustomize.cpython-37.pyc matches /usr/lib/python3.7/sitecustomize.py
            # code object from '/usr/lib/python3.7/__pycache__/sitecustomize.cpython-37.pyc'
            import 'sitecustomize' # <_frozen_importlib_external.SourceFileLoader object at 0xb668e5f0>
            import 'site' # <_frozen_importlib_external.SourceFileLoader object at 0xb66d8c50>
            Python 3.7.3 (default, Jan 22 2021, 20:04:44)
            # extension module 'readline' loaded from '/usr/lib/python3.7/lib-dynload/readline.cpython-37m-arm-linux-gnueabihf.so'
            # extension module 'readline' executed from '/usr/lib/python3.7/lib-dynload/readline.cpython-37m-arm-linux-gnueabihf.so'
            import 'readline' # <_frozen_importlib_external.ExtensionFileLoader object at 0xb668e850>
            import 'atexit' # <class '_frozen_importlib.BuiltinImporter'>
            # /usr/lib/python3.7/__pycache__/rlcompleter.cpython-37.pyc matches /usr/lib/python3.7/rlcompleter.py
            # code object from '/usr/lib/python3.7/__pycache__/rlcompleter.cpython-37.pyc'
            import 'rlcompleter' # <_frozen_importlib_external.SourceFileLoader object at 0xb668e930>
              @bob-der-1
              Die Meldungen sehen 'merkwürdig' aus.
              Normalerweise kommt da nur die Versionsnummer um's Eck.
                Was mich wundert auf dem Test Pi auch so ist....
                Habe den Clean installiert und nur das Backup eingespielt.
                  Thomas Braun Most Active @bob der 1. last edited by Thomas Braun
                  @bob-der-1
                  Mein Fehler. Das v muss groß sein:
                  python -V
                  python3 -V
                  Installier mal nach:
                  sudo apt install libffi-dev gcc-arm-linux-gnueabihf
                    bob der 1. @Thomas Braun last edited by bob der 1.
                    Unser Fehler:-)
                    pi@raspberrypi:~ $ python3 -V
                    Python 3.7.3
                    pi@raspberrypi:~ $ python -V
                    Python 2.7.16
                    pi@raspberrypi:~ $
                      @bob-der-1
                      Siehe Edit:
                      sudo apt install libffi-dev gcc-arm-linux-gnueabihf build-essential
                        @thomas-braun sagte in Adapter Updates Fehler:
                        Reading package lists... Done
                        Building dependency tree
                        Note, selecting 'gcc' instead of 'gcc-arm-linux-gnueabihf'
                        build-essential is already the newest version (12.6).
                        gcc is already the newest version (4:8.3.0-1+rpi2).
                        libffi-dev is already the newest version (3.2.1-9).
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          @bob-der-1
                          Kann sein das da sowas wie
                          sudo apt install python3-cffi
                          noch fehlt.
                            Wieder
                              @bob-der-1
                              War schon installiert?
                              Dann weiß ich auch nicht wo es da klemmt.
                                Dann danke
                                  bob der 1. @bob der 1. last edited by
                                  Frag mich einer was das war....
                                  Wie vom Zauberhand sind die Updates durch!!!
                                  481
