    2. English
    3. ioBroker general
    4. [Gelöst] Adapters show invalid mode
      Thomas Braun Most Active @DBh last edited by
      @dbh sagte in Adapters show invalid mode:
      curl -sL https://iobroker.net/install.sh | bash -
      is the only line that is necessary for a clean installation.
      What does your system reply to
      iobroker status
      iobroker update -i
      iobroker list adapters
      iobroker list instances
        DBh @Thomas Braun last edited by
        Hi Thomas,
        here the response to the commands:
        pi@pi04:/opt/iobroker $ iobroker status
        Objects type: file
        States type: file
        pi@pi04:/opt/iobroker $ iobroker update -i
        Used repository: default
        hash changed or no sources cached => force download of new sources
        update done
        Adapter "admin" : 5.1.23 , installed 5.1.23
        Adapter "backitup" : 2.1.17 , installed 2.1.17
        Adapter "discovery" : 2.7.0 , installed 2.7.0
        Adapter "heos" : 1.8.6 , installed 1.8.6
        Adapter "info" : 1.9.8 , installed 1.9.8
        Adapter "javascript" : 5.2.8 , installed 5.2.8
        Controller "js-controller" : 3.3.15 , installed 3.3.15
        Adapter "node-red" : 2.4.0 , installed 2.4.0
        Adapter "shelly" : 4.0.7 , installed 4.0.7
        Adapter "simple-api" : 2.6.1 , installed 2.6.1
        Adapter "socketio" : 3.1.4 , installed 3.1.4
        Adapter "vis" : 1.4.3 , installed 1.4.3
        Adapter "web" : 3.4.7 , installed 3.4.7
        pi@pi04:/opt/iobroker $ iobroker list adapters
        system.adapter.admin : admin - v5.1.23
        system.adapter.backitup : backitup - v2.1.17
        system.adapter.discovery : discovery - v2.7.0
        system.adapter.heos : heos - v1.8.6
        system.adapter.info : info - v1.9.8
        system.adapter.javascript : javascript - v5.2.8
        system.adapter.node-red : node-red - v2.4.0
        system.adapter.shelly : shelly - v4.0.7
        system.adapter.web : web - v3.4.7
        pi@pi04:/opt/iobroker $ iobroker list instances
        • system.adapter.admin.0 : admin : pi04 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.backitup.0 : backitup : pi04 - enabled
        • system.adapter.discovery.0 : discovery : pi04 - enabled
          system.adapter.heos.0 : heos : pi04 - enabled
          system.adapter.info.0 : info : pi04 - enabled
        • system.adapter.javascript.0 : javascript : pi04 - enabled
        • system.adapter.node-red.0 : node-red : pi04 - enabled, port: 1880, bind: 0.0.0.0
        • system.adapter.shelly.0 : shelly : pi04 - enabled, port: 1882, bind: 0.0.0.0
          system.adapter.web.0 : web : pi04 - enabled
        • system.adapter.web.1 : web : pi04 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • instance is alive
        Cheers
        Dieter
          Thomas Braun Most Active @DBh last edited by Thomas Braun
          @dbh
          Ich denke einem Dieter kann man auch deutsch antworten.
          Bitte Ausgaben aus der Konsole in CodeTags einbetten.
            DBh last edited by
            Klar 😉
            Objects type: file
            States  type: file
            update done
            + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
            + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
            + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
            + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
            + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            Thomas Braun paul53 2 Replies Last reply Reply Quote 0
              @dbh
              iobroker start info
              Und warum zwei Instanzen von web?
                Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
                  @dbh
                  Widerspricht dem KISS-Prinzip. Schmeiß den raus.
                    paul53 @DBh last edited by paul53
                    @dbh
                    Was steht in den drei Objekten
                    • system.adapter.heos.0
                    • system.adapter.info.0
                    • system.adapter.web.0
                    unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                      "_id": "system.adapter.web.0",
                      "type": "instance",
                      "common": {
                        "name": "web",
                        "version": "3.4.7",
                        "title": "WEB server",
                        "titleLang": {
                          "en": "WEB server",
                          "de": "WEB-Server",
                          "ru": "Веб сервер",
                          "pt": "Servidor web",
                          "nl": "Web Server",
                          "fr": "Serveur Web",
                          "it": "Server web",
                          "es": "Servidor web",
                          "pl": "Serwer internetowy",
                          "zh-cn": "Web服务器"
                        "desc": {
                          "en": "opens a webserver for other adapters",
                          "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                          "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                          "pt": "abre um servidor web para outros adaptadores",
                          "nl": "opent een webserver voor andere adapters",
                          "fr": "ouvre un serveur web pour d'autres adaptateurs",
                          "it": "apre un server web per altri adattatori",
                          "es": "abre un servidor web para otros adaptadores",
                          "pl": "otwiera serwer internetowy dla innych kart",
                          "zh-cn": "为其他适配器服务的web服务器"
                        "mode": "daemon",
                      DBh @paul53 last edited by
                      Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                        @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                        Unter "system" (rot).
                        Dann die Eigenschaften (Bleistift rechts).
                          Danke für die Unterstützung!
                            "type": "instance",
                            "protectedNative": [],
                            "encryptedNative": [],
                            "notifications": [],
                            "instanceObjects": [],
                            "objects": [],
                            "common": {
                              "name": "web",
                              "title": "ioBroker web Adapter",
                              "logLevel": "info",
                              "host": "pi04",
                              "enabled": true
                            "native": {},
                            "user": "system.user.admin",
                            "ts": 1631008143484
                            "type": "instance",
                            "objects": [],
                            "_id": "system.adapter.info.0",
                            "common": {
                              "name": "info",
                              "title": "Information page",
                              "logLevel": "info",
                              "host": "pi04",
                              "enabled": true
                            "native": {},
                            "ts": 1631009504485
                            "type": "meta",
                            "common": {
                              "name": "admin",
                              "type": "admin"
                            "from": "system.host.pi04.cli",
                            "ts": 1631003881490,
                            "native": {},
                            "_id": "heos.admin"
                            @dbh
                            Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                            Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                              @paul53 Danke, mache ich
                                @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                                  @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                                  Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                                    apollon77 last edited by
                                    Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                                    Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                                    Schlo 1 Reply Last reply Reply Quote 0
                                    • Schlo
                                      Schlo @apollon77 last edited by
                                      @apollon77
                                      Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                      Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                      Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                      Vielleicht hilft ja dieser Hinweis.
                                      OstfrieseUnterwegs 1 Reply Last reply Reply Quote 0
                                      • OstfrieseUnterwegs
                                        OstfrieseUnterwegs @Schlo last edited by
                                        @apollon77
                                        Ebenso: Komplett neu aufgesetzt. Erstkonfiguration mit dem Assistenten.
                                        Es gab drei Instanzen, die nicht gestartet sind: javascript, proxmox, lgtv. Der Fehler war invalid mode
                                        Weitere Instanzen konnten nicht konfiguriert werden. (tr-064, web, net-tools, ping) Fehlermeldung: File index.html not found
                                        'Upload' hat das Problem gelöst. Löschen der Instanz oder des Adapters war nicht nötig
                                          apollon77 @OstfrieseUnterwegs last edited by
                                          @ostfrieseunterwegs Legt bitte mal jemand im discovery adapter ein issue an? Danke!
                                            OstfrieseUnterwegs @apollon77 last edited by
                                            @apollon77
                                            schon da
                                            https://github.com/ioBroker/ioBroker.discovery/issues/176
                                            patrickbs96 created this issue in ioBroker/ioBroker.discovery
                                            closed Installing adapter doesn't work #176
                                            invalid mode
                                            3196
