    2. English
    3. ioBroker general
    4. [Gelöst] Adapters show invalid mode
      DBh last edited by
      Klar 😉
      pi@pi04:/opt/iobroker $ iobroker status
      Objects type: file
      States  type: file
      pi@pi04:/opt/iobroker $ iobroker update -i
      Used repository: default
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 5.1.23   , installed 5.1.23
      Adapter    "backitup"      : 2.1.17   , installed 2.1.17
      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
      Adapter    "heos"          : 1.8.6    , installed 1.8.6
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.15   , installed 3.3.15
      Adapter    "node-red"      : 2.4.0    , installed 2.4.0
      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "vis"           : 1.4.3    , installed 1.4.3
      Adapter    "web"           : 3.4.7    , installed 3.4.7
      pi@pi04:/opt/iobroker $ iobroker list adapters
      system.adapter.admin                   : admin          - v5.1.23
      system.adapter.backitup                : backitup       - v2.1.17
      system.adapter.discovery               : discovery      - v2.7.0
      system.adapter.heos                    : heos           - v1.8.6
      system.adapter.info                    : info           - v1.9.8
      system.adapter.javascript              : javascript     - v5.2.8
      system.adapter.node-red                : node-red       - v2.4.0
      system.adapter.shelly                  : shelly         - v4.0.7
      system.adapter.web                     : web            - v3.4.7
      pi@pi04:/opt/iobroker $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : pi04                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : pi04                                     -  enabled
      + system.adapter.discovery.0              : discovery             : pi04                                     -  enabled
        system.adapter.heos.0                   : heos                  : pi04                                     -  enabled
        system.adapter.info.0                   : info                  : pi04                                     -  enabled
      + system.adapter.javascript.0             : javascript            : pi04                                     -  enabled
      + system.adapter.node-red.0               : node-red              : pi04                                     -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : pi04                                     -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.web.0                    : web                   : pi04                                     -  enabled
      + system.adapter.web.1                    : web                   : pi04                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Thomas Braun paul53 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @DBh last edited by
        @dbh
        iobroker start info
        Und warum zwei Instanzen von web?
          DBh @Thomas Braun last edited by
          Habe ich, nachdem das Problem aufgetreten ist, nochmals installiert.
            @dbh
            Widerspricht dem KISS-Prinzip. Schmeiß den raus.
              paul53 @DBh last edited by paul53
              @dbh
              Was steht in den drei Objekten
              • system.adapter.heos.0
              • system.adapter.info.0
              • system.adapter.web.0
              unter "OBJEKTDATEN" hinter common.mode? Expertenmodus aktivieren!
                "_id": "system.adapter.web.0",
                "type": "instance",
                "common": {
                  "name": "web",
                  "version": "3.4.7",
                  "title": "WEB server",
                  "titleLang": {
                    "en": "WEB server",
                    "de": "WEB-Server",
                    "ru": "Веб сервер",
                    "pt": "Servidor web",
                    "nl": "Web Server",
                    "fr": "Serveur Web",
                    "it": "Server web",
                    "es": "Servidor web",
                    "pl": "Serwer internetowy",
                    "zh-cn": "Web服务器"
                  "desc": {
                    "en": "opens a webserver for other adapters",
                    "de": "Stellt webserver für 'ioBroker Adapter' zur Verfügung",
                    "ru": "Запускает веб сервер для 'ioBroker драйверов'",
                    "pt": "abre um servidor web para outros adaptadores",
                    "nl": "opent een webserver voor andere adapters",
                    "fr": "ouvre un serveur web pour d'autres adaptateurs",
                    "it": "apre un server web per altri adattatori",
                    "es": "abre un servidor web para otros adaptadores",
                    "pl": "otwiera serwer internetowy dla innych kart",
                    "zh-cn": "为其他适配器服务的web服务器"
                  "mode": "daemon",
                DBh @paul53 last edited by
                Bin leider noch nicht so fit, du hast wahrscheinlich eine Konsolenkommando gemein. In der Weboberfläche sehe ich die Objekte nicht.
                  @dbh sagte: In der Weboberfläche sehe ich die Objekte nicht.
                  Unter "system" (rot).
                  Dann die Eigenschaften (Bleistift rechts).
                    Danke für die Unterstützung!
                      "type": "instance",
                      "protectedNative": [],
                      "encryptedNative": [],
                      "notifications": [],
                      "instanceObjects": [],
                      "objects": [],
                      "common": {
                        "name": "web",
                        "title": "ioBroker web Adapter",
                        "logLevel": "info",
                        "host": "pi04",
                        "enabled": true
                      "native": {},
                      "user": "system.user.admin",
                      "ts": 1631008143484
                      "type": "instance",
                      "objects": [],
                      "_id": "system.adapter.info.0",
                      "common": {
                        "name": "info",
                        "title": "Information page",
                        "logLevel": "info",
                        "host": "pi04",
                        "enabled": true
                      "native": {},
                      "ts": 1631009504485
                      "type": "meta",
                      "common": {
                        "name": "admin",
                        "type": "admin"
                      "from": "system.host.pi04.cli",
                      "ts": 1631003881490,
                      "native": {},
                      "_id": "heos.admin"
                      @dbh
                      Da ist wohl beim Erstellen der Instanzen einiges schief gelaufen.
                      Lösche die Instanzen und erstelle sie neu. Falls es dann immer noch so aussieht, lösche die Adapter und installiere sie neu.
                        @paul53 Danke, mache ich
                          @paul53 Das Löschen und Neuanlegen der Instanzen hat gereicht. Läuft, besten Dank!
                            @dbh sagte: Löschen und Neuanlegen der Instanzen hat gereicht.
                            Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [Gelöst].
                              apollon77 last edited by
                              Seeehr interessant ... Kann mir das gerade nicht erklären so recht. Falls der nächste das Problem hat wäre interessnt bo auch ein "upload" des betroffenen Adapters das fixt und falls der Adapter neu installiert war das Install log.
                              Bzw Frage an die bisher betroffenen: Waren es neu installierte Adapter oder ist es "plötzlich aus heiteremHimmel" aufgetreten? Oder nach einem Update?
                              Schlo 1 Reply Last reply Reply Quote 0
                              • Schlo
                                Schlo @apollon77 last edited by
                                @apollon77
                                Ich hatte ein ähnliches Problem. Ich nutze das aktuelle Docker-Image von ioBroker und bei mir waren alle Instanzen außer Admin, Backup und Discovery fehlerhaft oder sind nicht (richtig) gestartet.
                                Löschen und über Adapter neu installieren hat es dann auch gefixt.
                                Die Fehler treten nur (aber immer nachvollziehbar) auf, wenn ich die Installation per Geräte und Dienste finden -> Letzten Scan verwenden -> Instanz auswählen und "Instanzen erstellen" starte. Was ich als Newbie natürlich erst mal so gemacht hatte.
                                Vielleicht hilft ja dieser Hinweis.
                                OstfrieseUnterwegs 1 Reply Last reply Reply Quote 0
                                • OstfrieseUnterwegs
                                  OstfrieseUnterwegs @Schlo last edited by
                                  @apollon77
                                  Ebenso: Komplett neu aufgesetzt. Erstkonfiguration mit dem Assistenten.
                                  Es gab drei Instanzen, die nicht gestartet sind: javascript, proxmox, lgtv. Der Fehler war invalid mode
                                  Weitere Instanzen konnten nicht konfiguriert werden. (tr-064, web, net-tools, ping) Fehlermeldung: File index.html not found
                                  'Upload' hat das Problem gelöst. Löschen der Instanz oder des Adapters war nicht nötig
                                    apollon77 @OstfrieseUnterwegs last edited by
                                    @ostfrieseunterwegs Legt bitte mal jemand im discovery adapter ein issue an? Danke!
                                      OstfrieseUnterwegs @apollon77 last edited by
                                      @apollon77
                                      schon da
                                      https://github.com/ioBroker/ioBroker.discovery/issues/176
                                      patrickbs96 created this issue in ioBroker/ioBroker.discovery
                                      closed Installing adapter doesn't work #176
                                      invalid mode
                                      3196
