    4. Ist der Raspi überlastet?
      maxpd @maxpd last edited by
      @maxpd So, um 10 uhr hat sich der Swap um 15,2% gefüllt (rote Linie) und hält den Wert momentan konstant. Der Log für diese eine Minute. Die Grüne Linie ist der freie Speicher. Mit 200mb angegeben, wobei ich im htop 400 sehe:
      2021-09-05 09:59:39.002  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
      2021-09-05 09:59:41.855  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 09:59:41.856  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 09:59:48.803  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 09:59:52.052  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632._info.mac" has to be type "number" but received type "string"
      2021-09-05 09:59:52.188  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 09:59:52.195  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 09:59:52.202  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 09:59:52.345  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2021-09-05 09:59:58.802  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 09:59:59.338  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
      2021-09-05 10:00:00.142  - info: host.iobroker instance system.adapter.coronavirus-statistics.0 started with pid 9065
      2021-09-05 10:00:01.924  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:01.925  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:01.962  - info: coronavirus-statistics.0 (9065) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.3.15
      2021-09-05 10:00:04.176  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9085
      2021-09-05 10:00:04.829  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.active_bright" has to be type "number" but received type "string"
      2021-09-05 10:00:04.831  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.ct" has to be type "number" but received type "string"
      2021-09-05 10:00:05.882  - info: daswetter.0 (9085) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.3.15
      2021-09-05 10:00:06.060  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.active_bright" has to be type "number" but received type "string"
      2021-09-05 10:00:06.061  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.ct" has to be type "number" but received type "string"
      2021-09-05 10:00:06.974  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821611698,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:07.148  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821611864,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:07.298  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612007,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:07.513  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612177,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:07.762  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612403,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:07.892  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612571,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:08.049  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612765,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:08.805  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 10:00:15.557  - info: host.iobroker instance system.adapter.ical.0 started with pid 9101
      2021-09-05 10:00:16.008  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2021-09-05 10:00:16.750  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612918,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:17.460  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613304,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:17.686  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613458,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:17.925  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613590,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:18.151  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613816,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:18.500  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614000,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:18.801  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 10:00:18.801  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614146,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:19.100  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614401,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:19.413  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614567,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:19.616  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
      2021-09-05 10:00:20.202  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615031,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:20.667  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615254,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:20.806  - info: ical.0 (9101) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.3.15
      2021-09-05 10:00:21.004  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615427,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:21.178  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616447,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:21.399  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616673,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:21.562  - info: ical.0 (9101) processing URL: Abfuhrtermine https://calendar.google.com/calendar/ical/gteg5rprkrdlshhholvk9ot354%40group.calendar.google.com/private-0251115518dfd8b3c71688e9dd691e07/basic.ics
      2021-09-05 10:00:21.715  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616919,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:21.893  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:21.894  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:21.968  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617130,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:22.155  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617402,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:22.510  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632._info.mac" has to be type "number" but received type "string"
      2021-09-05 10:00:22.662  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 10:00:22.671  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 10:00:22.678  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
      2021-09-05 10:00:22.745  - info: coronavirus-statistics.0 (9065) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2021-09-05 10:00:22.804  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617966,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:22.919  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618138,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:23.563  - info: host.iobroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-05 10:00:23.616  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618318,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:23.729  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618435,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:23.864  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618718,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:23.977  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618935,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.135  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619147,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.252  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619356,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.495  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619711,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.613  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619864,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.709  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620011,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.829  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620133,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:24.928  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620248,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:25.036  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620348,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:25.145  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620443,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:25.256  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620589,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2021-09-05 10:00:25.360  - info: daswetter.0 (9085) Terminated (NO_ERROR): Without reason
      2021-09-05 10:00:25.873  - info: daswetter.0 (9085) cleaned everything up...
      2021-09-05 10:00:25.884  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      2021-09-05 10:00:26.996  - info: ical.0 (9101) Terminated (NO_ERROR): Without reason
      2021-09-05 10:00:27.521  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-09-05 10:00:28.803  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 10:00:34.833  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.active_bright" has to be type "number" but received type "string"
      2021-09-05 10:00:34.835  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.ct" has to be type "number" but received type "string"
      2021-09-05 10:00:36.050  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.active_bright" has to be type "number" but received type "string"
      2021-09-05 10:00:36.051  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.ct" has to be type "number" but received type "string"
      2021-09-05 10:00:36.570  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2021-09-05 10:00:38.804  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
      2021-09-05 10:00:39.856  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
      2021-09-05 10:00:41.860  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:41.861  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:47.699  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:47.699  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:47.703  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:47.703  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:48.725  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:48.726  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
      2021-09-05 10:00:48.728  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
      2021-09-05 10:00:48.728  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
        liv-in-sky @maxpd last edited by
        @maxpd ok - bin mir auch nicht sicher, ob wir da eine lösung brauchen - wenn der swap halt voll ist, wäre es schon gut, zu wissen, wer da vollschreibt
        was hast du den außer iobroker noch am laufen
        der befehl, der funktionieren sollte ist:
        for proc in /proc/*; do cat $proc/smaps 2>/dev/null ; done
        wenn die konsole schwarz bleibt, stimmt der awk befehl nicht - aber mit diesem befehl kannst du halt überprüfen, was im swap los ist
        wenn du ein bashscript machen kannst, ginge noch das http://hslomka.de/techno/?p=474
        der bash:
        #!/bin/bash
         THRESHOLD=2000
         for pid in `ls /proc`; do
           vmswap=`awk '/VmSwa/{print $2}' /proc/${pid}/status 2>/dev/null`;
           if [ ${vmswap} -gt ${THRESHOLD} ];then
             pName=`ps -ef|awk '$2=="'"${pid}"'" {print $8}'`;
             echo "PID ${pid}: ${vmswap} kB (${pName})";
           fi;
         done 2>/dev/null|sort -un -k3
        mit top geht es auch https://serverfault.com/questions/132084/system-swapping-how-do-i-figure-out-what-the-problem-is
          paul53 @maxpd last edited by paul53
          @maxpd sagte: um 10 uhr hat sich der Swap um 15,2% gefüllt
          Es starten drei scheduled Instanzen um 10:00 Uhr: coronavirus-statistics.0, ical.0 und daswetter.0. Sollte man vermeiden.
            liv-in-sky @paul53 last edited by
            finde ich einen nachteil im admin 5 - man sieht nicht mehr -"auf einem blick" , welche schedules man eingestellt hat - ist im admin 4 besser
              maxpd @liv-in-sky last edited by maxpd
              Da bin ich wieder.
              Pünktlich Nachts um 0 Uhr wurde der Swap geleert.
              An Tag 2 habe ich Coronavirus und das Wetter deaktiviert. Danach wurde der Swap nicht mehr ganz geleert, aber auch nicht mehr ganz voll. Der normale RAM zeigt seit dem auch weniger Bewegung, aber ist dennoch nicht "freier".
              An Tag 3 habe ich ICal deaktiviert. Keine große Veränderung.
              Ich hab damit das Gefühl, dass der SWAP nicht für die Trägheit verantwortlich ist. Heute um ~19 Uhr war wieder alles sehr langsam. Keine Auffälligkeiten in der Auslastung. Es ging um eine Abfrage von Werten aus dem Modbus Adapter. Die Werte waren fernab jeglicher Realität, respektive verzögert.
              @paul53 Schedules habe ich auf unterschiedliche Minuten gelegt und auch im Abstand reduziert.
              OliverIO Homoran 2 Replies Last reply Reply Quote 0
              • OliverIO
                OliverIO @maxpd last edited by
                @maxpd
                Der swap leert sich eigentlich nicht einfach so plötzlich.
                Wenn dann sind die Programme beendet worden die den Speicher belegen.
                Kannst du mal in Iobroker log und/oder ins syslog schauen ob zu dieser Uhrzeit da etwas steht?
                  Homoran Global Moderator Administrators @maxpd last edited by
                  @maxpd sagte in Ist der Raspi überlastet?:
                  was verstehst du darunter?
                  geht dann der SWAP auf 0?
                  Dann wäre das:
                  @oliverio sagte in Ist der Raspi überlastet?:
                  genau andersrum!
                  wenn SWAP -> 0, dann wird der Speicherfresser gestartet
                    maxpd @Homoran last edited by
                    @homoran Das sind die roten Graphen in meinem Screenshot. Um 0 Uhr geht der Swap von 100 auf 25%, wenn ich alle Scheduled Jobs an habe. Wenn ich alle Scheduled Jobs ausschalte geht er zurück auf 55%.
                    Habe noch Probleme in Flot nah ran zu zoomen um die exakten Sekunden rauszufinden, wann der Swap geleert wird. Sobald ich zoome verschwindet der Graph..
                      Homoran Global Moderator Administrators @maxpd last edited by Homoran
                      ah, das sind % genutzter SWAP??
                      und der geht einfach so auf 0%?
                      die Linie ist da unterbrochen!
                      und es ist nicht
                      sondern früher
                      scheduled jobs heben eigentlich keinerlei dauerhafte Auswirkung auf den Speicher, sondern nur dann, wenn der schedule startet
                      was ist denn die grüne Linie?
                      da schnellt irgendwas hoch.
                      (eine Legende wäre hilfreich)
                      kann es sein, dass dein RasPi da neu startet?
                      das kann verschiedene Gründe haben.
                      z.B. benötigt eine Linie mindestens zwei Punkte
                        Die Legende hatte ich oben mal schriftlich drin. Grün ist der freie RAM in mb. Swap ist belegt in MB, wobei es nur 100MB Swap gibt, sodass es gleichzeitig % sind.
                        Wenn die grüne Linie hochschnellt wird also RAM frei.
                        Ja die Linie ist unterbrochen. Kann aber noch nicht erfolgreich ran zoomen.
                        btw wo finde ich das System Log?
                        Ich habe keinen Neustart eingebaut, wüsste nicht wie ^^. Wie finde ich raus ob er neu startet?
                        Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @maxpd last edited by
                          Schau mit
                          uptime
                          wie lange der Server schon läuft.
                            maxpd @Thomas Braun last edited by
                            @thomas-braun Ok, also der selbe wert wie in htop
                            pi@iobroker:~ $ uptime
                             14:34:43 up 5 days,  6:20,  2 users,  load average: 0,10, 0,25, 0,22
                              @liv-in-sky dein befehl geht, aber ich glaube die putty Konsole kann nicht alles auflisten. Muss ich wohl noch andere Optionen ausprobieren, wenn das wirklich der sinnvolle Weg ist 🙂
                              KernelPageSize:        4 kB
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              ShmemPmdMapped:        0 kB
                              FilePmdMapped:         0 kB
                              Shared_Hugetlb:        0 kB
                              Private_Hugetlb:       0 kB
                              Swap:                748 kB
                              SwapPss:             748 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd wr mr mw me ac
                              b68a9000-b68b2000 r-xp 00000000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd ex mr mw me
                              b68b2000-b68c2000 ---p 00009000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b68c2000-b68c3000 r--p 00009000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr mw me ac
                              b68c3000-b68c4000 rw-p 0000a000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b68c4000-b68ca000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b68d4000-b6b4e000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6b4e000-b6d4e000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6d4e000-b6e86000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e86000-b6e96000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6e96000-b6e98000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  8 kB
                              SwapPss:               8 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e98000-b6e99000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e99000-b6e9c000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                 12 kB
                              SwapPss:              12 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e9c000-b6e9e000 r-xp 00000000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e9e000-b6ead000 ---p 00002000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6ead000-b6eae000 r--p 00001000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6eae000-b6eaf000 rw-p 00002000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6eaf000-b6ecd000 r-xp 00000000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ecd000-b6edd000 ---p 0001e000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6edd000-b6edf000 r--p 0001e000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  8 kB
                              SwapPss:               8 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6edf000-b6ee0000 rw-p 00020000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ee0000-b6ee4000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ee4000-b6ef3000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6ef3000-b6ef4000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ef4000-b6ef5000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ef5000-b6f15000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd ex mr mw me dw
                              b6f17000-b6f19000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f1c000-b6f23000 r--s 00000000 b3:02 12627      /usr/lib/arm-linux-gnueabihf/gc        onv/gconv-modules.cache
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr me ms
                              b6f23000-b6f25000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  8 kB
                              SwapPss:               8 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f25000-b6f26000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr mw me dw ac
                              b6f26000-b6f27000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  4 kB
                              SwapPss:               4 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd wr mr mw me dw ac
                              bee52000-bee73000 rw-p 00000000 00:00 0          [stack]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                 24 kB
                              SwapPss:              24 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd wr mr mw me gd ac
                              befdc000-befdd000 r-xp 00000000 00:00 0          [sigpage]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd ex mr mw me de
                              befdd000-befde000 r--p 00000000 00:00 0          [vvar]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr de
                              befde000-befdf000 r-xp 00000000 00:00 0          [vdso]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   0 kB
                              Shared_Clean:          4 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            4 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              ffff0000-ffff1000 r-xp 00000000 00:00 0          [vectors]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd ex mr me
                              00010000-00016000 r-xp 00000000 b3:02 687        /bin/cat
                              MMUPageSize:           4 kB
                              Rss:                  24 kB
                              Pss:                  24 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:        24 kB
                              Private_Dirty:         0 kB
                              Referenced:           24 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              00025000-00026000 r--p 00005000 b3:02 687        /bin/cat
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              00026000-00027000 rw-p 00006000 b3:02 687        /bin/cat
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              01735000-01756000 rw-p 00000000 00:00 0          [heap]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6951000-b6973000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6973000-b6bed000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                 172 kB
                              Pss:                  88 kB
                              Shared_Clean:        168 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         4 kB
                              Private_Dirty:         0 kB
                              Referenced:          172 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6bed000-b6ded000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                 248 kB
                              Pss:                 128 kB
                              Shared_Clean:        240 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         8 kB
                              Private_Dirty:         0 kB
                              Referenced:          248 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6ded000-b6f25000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                 712 kB
                              Pss:                  15 kB
                              Shared_Clean:        712 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:          712 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f25000-b6f35000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6f35000-b6f37000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f37000-b6f38000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f38000-b6f3b000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f3b000-b6f3f000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                  16 kB
                              Pss:                   0 kB
                              Shared_Clean:         16 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:           16 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f3f000-b6f4e000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6f4e000-b6f4f000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f4f000-b6f50000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f50000-b6f70000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                 128 kB
                              Pss:                   2 kB
                              Shared_Clean:        128 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:          128 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f7e000-b6f80000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f80000-b6f81000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f81000-b6f82000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              becae000-beccf000 rw-p 00000000 00:00 0          [stack]
                              MMUPageSize:           4 kB
                              Rss:                  12 kB
                              Pss:                  12 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:        12 kB
                              Referenced:           12 kB
                              Anonymous:            12 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              bee1e000-bee1f000 r-xp 00000000 00:00 0          [sigpage]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              bee1f000-bee20000 r--p 00000000 00:00 0          [vvar]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr de
                              bee20000-bee21000 r-xp 00000000 00:00 0          [vdso]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   0 kB
                              Shared_Clean:          4 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            4 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              MMUPageSize:           4 kB
                              Rss:                  24 kB
                              Pss:                  24 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Dirty:         0 kB
                              Referenced:           24 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              0161d000-0163e000 rw-p 00000000 00:00 0          [heap]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b698e000-b69b0000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b69b0000-b6c2a000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                 160 kB
                              Pss:                  88 kB
                              Shared_Clean:        144 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:        16 kB
                              Private_Dirty:         0 kB
                              Referenced:          160 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6c2a000-b6e2a000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                              MMUPageSize:           4 kB
                              Rss:                 188 kB
                              Pss:                 102 kB
                              Shared_Clean:        172 kB
                              Shared_Dirty:          0 kB
                              Private_Dirty:         0 kB
                              Referenced:          188 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6e2a000-b6f62000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                 784 kB
                              Pss:                  17 kB
                              Shared_Clean:        784 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:          784 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f62000-b6f72000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6f72000-b6f74000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f74000-b6f75000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f75000-b6f78000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f78000-b6f7c000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                  16 kB
                              Pss:                   0 kB
                              Shared_Clean:         16 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:           16 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f7c000-b6f8b000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: mr mw me
                              b6f8b000-b6f8c000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f8c000-b6f8d000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6f8d000-b6fad000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                 128 kB
                              Pss:                   2 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:          128 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6fbb000-b6fbd000 rw-p 00000000 00:00 0
                              MMUPageSize:           4 kB
                              Rss:                   8 kB
                              Pss:                   8 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         8 kB
                              Referenced:            8 kB
                              Anonymous:             8 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6fbd000-b6fbe000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              b6fbe000-b6fbf000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   4 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         4 kB
                              Referenced:            4 kB
                              Anonymous:             4 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              bed84000-beda5000 rw-p 00000000 00:00 0          [stack]
                              MMUPageSize:           4 kB
                              Rss:                  12 kB
                              Pss:                  12 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Referenced:           12 kB
                              Anonymous:            12 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              beddf000-bede0000 r-xp 00000000 00:00 0          [sigpage]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              bede0000-bede1000 r--p 00000000 00:00 0          [vvar]
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              VmFlags: rd mr de
                              bede1000-bede2000 r-xp 00000000 00:00 0          [vdso]
                              MMUPageSize:           4 kB
                              Rss:                   4 kB
                              Pss:                   0 kB
                              Shared_Clean:          4 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            4 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                              MMUPageSize:           4 kB
                              Rss:                   0 kB
                              Pss:                   0 kB
                              Shared_Clean:          0 kB
                              Shared_Dirty:          0 kB
                              Private_Clean:         0 kB
                              Private_Dirty:         0 kB
                              Referenced:            0 kB
                              Anonymous:             0 kB
                              LazyFree:              0 kB
                              AnonHugePages:         0 kB
                              FilePmdMapped:         0 kB
                              Swap:                  0 kB
                              SwapPss:               0 kB
                              Locked:                0 kB
                              THPeligible:    0
                                liv-in-sky @maxpd last edited by liv-in-sky
                                @maxpd
                                eigentlich nutze ich ja ein bash script - da sieht man das ziemlich deutlich
                                simple und schnell:
                                cd /usr/local/bin
                                nano seeSwap
                                • kopiere das rein
                                #!/bin/bash
                                THRESHOLD=2000
                                   fi;
                                drücke ctrl und die x-taste und speichere das ganze
                                anschliessend : chmod +x seeSwap
                                dann kannst du das aufrufen und bei mir sieht das so aus:
                                • OliverIO
                                  @maxpd
                                  Das syslog findest du unter /var/log/syslog
                                    @liv-in-sky kannst mir bitte auf die Sprünge helfen? 🙂
                                      @maxpd
                                      ls -l /usr/local/bin/seeSwap
                                        @thomas-braun dann bekomme ich nur das raus.
                                        pi@iobroker:~ $ ls -l /usr/local/bin/seeSwap
                                        -rw-r--r-- 1 root root 306 Sep 10 20:35 /usr/local/bin/seeSwap
                                        vllt hab ich das script falsch erstellt. unter dem link stehen dazu keine details. und bei liv-in-sky hab ich das "nano" nicht verstanden. ich bin einfach in den pfad, habe eine datei angelegt, das script reinkopiert und gespeichert.
                                          Thomas Braun Most Active @maxpd last edited by Thomas Braun
                                          @maxpd
                                          nano ist ein Editor auf Kommandozeile.
                                          sudo chmod +x /usr/local/bin/seeSwap
                                          Mit welchen Programmen? Irgendwelchem graphischem Kram? Das ist 'verboten' auf einem Server.
                                            @thomas-braun Mit WinSCP
                                            2390
