    4. [Gelöst] Zigbee Adapter lässt sich Update nicht installieren
    • frankthegreat
      frankthegreat @Thomas Braun last edited by
      Einige Adapter sind nicht aufm neuesten Stand...dürfte doch aber nix mit dem Zigbee Adapter zu tun haben.
      pi@raspberrypi:~ $ iobroker status
      Objects type: file
      States  type: file
      pi@raspberrypi:~ $ iobroker list adapters
      system.adapter.admin                   : admin          - v4.2.1
      system.adapter.alarm                   : alarm          - v2.0.1
      system.adapter.alexa2                  : alexa2         - v3.9.1
      system.adapter.backitup                : backitup       - v2.1.12
      system.adapter.echarts                 : echarts        - v0.4.14
      system.adapter.eventlist               : eventlist      - v0.4.2
      system.adapter.history                 : history        - v1.9.13
      system.adapter.info                    : info           - v1.9.8
      system.adapter.iqontrol                : iqontrol       - v1.8.0
      system.adapter.node-red                : node-red       - v2.3.0
      system.adapter.pushover                : pushover       - v2.0.3
      system.adapter.rpi2                    : rpi2           - v1.2.0
      system.adapter.senec                   : senec          - v1.3.1
      system.adapter.shelly                  : shelly         - v4.0.7
      system.adapter.simple-api              : simple-api     - v2.6.1
      system.adapter.socketio                : socketio       - v3.1.4
      system.adapter.sonoff                  : sonoff         - v2.4.0
      system.adapter.vis                     : vis            - v1.3.10
      system.adapter.web                     : web            - v3.4.1
      system.adapter.zigbee                  : zigbee         - v1.5.3
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
        system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
        system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
        system.adapter.info.0                   : info                  : raspberrypi                              - disabled
        system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              - disabled
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
        system.adapter.pushover.1               : pushover              : raspberrypi                              - disabled
        system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
        system.adapter.senec.0                  : senec                 : raspberrypi                              - disabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 192.168.2.33
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: stable
      hash changed or no sources cached => force download of new sources
      update done
      Cannot read or parse /opt/iobroker/node_modules/iobroker.js-controller/lib/../node_modules/iobroker.zigbee/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
      Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
      Adapter    "alarm"         : 2.0.2    , installed 2.0.1 [Updateable]
      Adapter    "alexa2"        : 3.9.3    , installed 3.9.1 [Updateable]
      Adapter    "backitup"      : 2.1.17   , installed 2.1.12 [Updateable]
      Adapter    "echarts"       : 0.4.13   , installed 0.4.14
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iqontrol"      : 1.8.2    , installed 1.8.0 [Updateable]
      Controller "js-controller" : 3.3.15   , installed 3.2.16 [Updateable]
      Adapter    "node-red"      : 2.4.0    , installed 2.3.0 [Updateable]
      Adapter    "pushover"      : 2.0.5    , installed 2.0.3 [Updateable]
      Adapter    "rpi2"          : 1.3.1    , installed 1.2.0 [Updateable]
      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.0 [Updateable]
      Adapter    "vis"           : 1.4.3    , installed 1.3.10 [Updateable]
      Adapter    "web"           : 3.4.7    , installed 3.4.1 [Updateable]
      pi@raspberrypi:~ $
        Thomas Braun Most Active @frankthegreat last edited by
        @frankthegreat
        Der fehlt ja auch in der Liste.
        Versuch mal
        iobroker upgrade iobroker.zigbee@1.5.6
          @frankthegreat
          Und zieh den anderen Kram auch auf was aktuelles!
          frankthegreat 1 Reply Last reply Reply Quote 0
          • frankthegreat
            Wie gesagt, der Zigbee will sich nicht installieren lassen...
            pi@raspberrypi:~ $ iobroker upgrade iobroker.zigbee@1.5.6
            Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
                at parse (<anonymous>)
                at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                at Module.load (internal/modules/cjs/loader.js:863:32)
                at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                at Module.require (internal/modules/cjs/loader.js:887:19)
                at require (internal/modules/cjs/helpers.js:74:18)
                at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:187:26
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2607:45)
                at processImmediate (internal/timers.js:463:21)
            pi@raspberrypi:~ $
              @frankthegreat
              Dann zieh zuerst den Rest hoch:
              iobroker stop
              iobroker update
              iobroker upgrade
              iobroker upgrade self
              iobroker start
              • frankthegreat
                Läuft...
                aber ich seh schon...das wird dauern.
                  @frankthegreat
                  Jetzt rächt sich deine nachlässige Systempflege.
                  frankthegreat 2 Replies Last reply Reply Quote 0
                  • frankthegreat
                    @thomas-braun sagte in Zigbee Adapter lässt sich Update nicht installieren:
                    @frankthegreat
                    ...ich gelobe Besserung 😇
                    • frankthegreat
                      So, alles auf dem neusten Stand... leider will der Zigbee immer noch nicht.
                          at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:368:27)
                          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:276:26
                          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2621:45)
                      pi@raspberrypi:~ $
                        @frankthegreat
                        cd /opt/iobroker
                        npm cache clear --force
                          @frankthegreat
                          Ansonsten: Schau was in der genannten Datei krumm ist:
                          • frankthegreat
                            Is durchgelaufen...leider keine Besserung.
                            pi@raspberrypi:/opt/iobroker $ iobroker upgrade iobroker.zigbee@1.5.6
                            • frankthegreat
                              Findet er nicht.
                              pi@raspberrypi:~ $ /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167
                              -bash: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json:: Datei oder Verzeichnis nicht gefunden
                              pi@raspberrypi:~ $
                              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                @frankthegreat
                                Du musst da schon mit einem pager oder editor ran.
                                more /opt/iobroker/node_modules/iobroker.zigbee/io-package.json
                                oder
                                nano /opt/iobroker/node_modules/iobroker.zigbee/io-package.json
                                • Glasfaser
                                  Glasfaser @frankthegreat last edited by
                                  @frankthegreat sagte in Zigbee Adapter lässt sich Update nicht installieren:
                                  Findet er nicht.
                                  pi@raspberrypi:~ $
                                  Ist der gleich Fehler wie hier :
                                  https://forum.iobroker.net/topic/47094/gelöst-zigbee-adapter-lässt-sich-nicht-inst
                                    Thomas Braun Most Active @Glasfaser last edited by
                                    @glasfaser
                                    Ah, den hatte ich nicht mehr präsent. Aber macht Sinn...
                                    • frankthegreat
                                      @glasfaser
                                      Hmm, jetzt bin ich verwirrt...was genau muß ich machen?
                                        Thomas Braun Most Active @frankthegreat last edited by Thomas Braun
                                        @frankthegreat
                                        Den Adapter mal an npm vorbei aus dem github ziehen.
                                        Bzw mal so versuchen:
                                        cd /opt/iobroker
                                        npm install iobroker.zigbee@1.5.6
                                        iobroker stop
                                        iobroker fix
                                        iobroker start
                                        • frankthegreat
                                          Über die Katze installieren?
                                            @frankthegreat
                                            Erstmal wie oben probieren.
                                            2157
