    4. [gelöst] Wert (JSON) an URL senden
      MCU @tofriedrich last edited by
      @tofriedrich Kommt wieder eine Warnung im LOG?
        tofriedrich @MCU last edited by
        @mcu
        12.9.2021, 01:28:01.071	[silly]: javascript.0 (27672) Objects user redis pmessage */cfg.o.script.js.Kamin_Set:{"common":{"name":"Kamin Set","expert":true,"engineType":"Blockly","engine":"system.adapter.javascript.0","source":"var result;\n\n\nexec('curl --data \"{\\'level\\':5}\" http://192.168.178.24/set_burn_level');\n\nconsole.log(result);\n\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","debug":false,"verbose":false,"enabled":true},"type":"script","from":"system.adapter.admin.0","user":"system.user.admin","ts":1631402881067,"_id":"script.js.Kamin_Set","acl":{"object":1636,"ownerGroup":"system.group.administrator"}}
        12.9.2021, 01:28:01.074	[info ]: javascript.0 (27672) Stop script script.js.Kamin_Set
        12.9.2021, 01:28:01.079	[info ]: javascript.0 (27672) Start javascript script.js.Kamin_Set
        12.9.2021, 01:28:01.090	[info ]: javascript.0 (27672) script.js.Kamin_Set: undefined
        12.9.2021, 01:28:01.090	[info ]: javascript.0 (27672) script.js.Kamin_Set: registered 0 subscriptions and 0 schedules
        12.9.2021, 01:28:02.948	[silly]: javascript.0 (27672) Objects user redis pmessage */cfg.o.script.js.Kamin_Set:{"common":{"name":"Kamin Set","expert":true,"engineType":"Blockly","engine":"system.adapter.javascript.0","source":"var result;\n\n\nexec('curl --data \"{\\'level\\':5}\" http://192.168.178.24/set_burn_level', async function (error, result, stderr) {\n    console.log(result);\n});\n\n//JTNDeG1sJTIweG1sbnMlM0QlMjJodHRwcyUzQSUyRiUyRmRldmVsb3BlcnMuZ29vZ2xlLmNvbSUyRmJsb2NrbHklMkZ4bWwlMjIlM0UlM0N2YXJpYWJsZXMlM0UlM0N2YXJpYWJsZSUyMGlkJTNEJTIybnM4R2t+N3ZSdiU0MCU1RWRhYSUyQkJEcHglMjIlM0VyZXN1bHQlM0MlMkZ2YXJpYWJsZSUzRSUzQyUyRnZhcmlhYmxlcyUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmV4ZWMlMjIlMjBpZCUzRCUyMk5ZSS0lM0IoJTYwbFIlN0NMLSUzQmNPJTJCWFg3SiUyMiUyMHglM0QlMjI4OCUyMiUyMHklM0QlMjIxODglMjIlM0UlM0NtdXRhdGlvbiUyMHhtbG5zJTNEJTIyaHR0cCUzQSUyRiUyRnd3dy53My5vcmclMkYxOTk5JTJGeGh0bWwlMjIlMjB3aXRoX3N0YXRlbWVudCUzRCUyMnRydWUlMjIlM0UlM0MlMkZtdXRhdGlvbiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfU1RBVEVNRU5UJTIyJTNFVFJVRSUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyTE9HJTIyJTNFJTNDJTJGZmllbGQlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJDT01NQU5EJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMi51dSU3RH44JTVELlRIRUNKOVZ2eE1PeiUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlRFWFQlMjIlM0VjdXJsJTIwLS1kYXRhJTIwJTIyJTdCJ2xldmVsJyUzQTUlN0QlMjIlMjBodHRwJTNBJTJGJTJGMTkyLjE2OC4xNzguMjQlMkZzZXRfYnVybl9sZXZlbCUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0NzdGF0ZW1lbnQlMjBuYW1lJTNEJTIyU1RBVEVNRU5UJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyZGVidWclMjIlMjBpZCUzRCUyMmhsJTQwX3FaQVJwXyU2MFRBTCU2ME1UeCU3Q2olMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJTZXZlcml0eSUyMiUzRWxvZyUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVEVYVCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjJsLSU1QiglM0FydX5kQSUyNCUyRlBfaSUzQTklM0RWLiUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlRFWFQlMjIlM0V0ZXN0JTNDJTJGZmllbGQlM0UlM0MlMkZzaGFkb3clM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjJobXolMjNBVXlEU3c1JTJDNnp6UUMlMkZ6ZSUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlZBUiUyMiUyMGlkJTNEJTIybnM4R2t+N3ZSdiU0MCU1RWRhYSUyQkJEcHglMjIlM0VyZXN1bHQlM0MlMkZmaWVsZCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnN0YXRlbWVudCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGeG1sJTNF","debug":false,"verbose":false,"enabled":true},"type":"script","from":"system.adapter.admin.0","user":"system.user.admin","ts":1631402882945,"_id":"script.js.Kamin_Set","acl":{"object":1636,"ownerGroup":"system.group.administrator"}}
        12.9.2021, 01:28:02.951	[info ]: javascript.0 (27672) Stop script script.js.Kamin_Set
        12.9.2021, 01:28:02.956	[info ]: javascript.0 (27672) Start javascript script.js.Kamin_Set
        12.9.2021, 01:28:02.970	[info ]: javascript.0 (27672) script.js.Kamin_Set: registered 0 subscriptions and 0 schedules
        12.9.2021, 01:28:03.023	[info ]: javascript.0 (27672) script.js.Kamin_Set: {"response":"OK"}
          @tofriedrich sagte in Wert (JSON) an URL senden:
          {"response":"OK"}
          Also hat er den jetzt durchgelassen?
          Ändere mal die 5 auf 2.
            @mcu burn_level bleibt auf 0
              @tofriedrich Dann versuchen wir die Alternative
              curl --data {'level':5} http://192.168.178.24/set_burn_level
                @mcu keine Veränderung
                  @tofriedrich Dann mit String
                  curl --data "{'level':'5'}" http://192.168.178.24/set_burn_level
                  oder
                  curl --data {'level':'5'} http://192.168.178.24/set_burn_level
                    tofriedrich @MCU last edited by tofriedrich
                    @mcu auch nicht. burn_level bleibt auf 0
                      @tofriedrich Bald gehen mir die Ideen aus:
                      curl --header "Content-Type: application/json  --data "{'level':'5'}" http://192.168.178.24/set_burn_level
                      oder
                      curl --header "Content-Type: application/json  --data {'level':'5'} http://192.168.178.24/set_burn_level
                        @mcu hier gibt der kein response ok mehr aus
                          @tofriedrich Dann muss es wieder raus.
                          curl -d "{'level':'5'}" http://192.168.178.24/set_burn_level
                            @mcu
                            javascript.0 (27672) Objects user redis pmessage */cfg.o.script.js.Kamin_Set:{"common":{"name":"Kamin Set","expert":true,"engineType":"Blockly","engine":"system.adapter.javascript.0","source":"var result;\n\n\nexec('curl -d \"{\\'level\\':\\'50\\'}\" http://192.168.178.24/set_burn_level', async function (error, result, stderr) {\n console.log(result);\n});\n\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","debug":false,"verbose":false,"enabled":true},"type":"script","from":"system.adapter.admin.0","user":"system.user.admin","ts":1631403883356,"_id":"script.js.Kamin_Set","acl":{"object":1636,"ownerGroup":"system.group.administrator"}}
                              @tofriedrich Kein "response:ok"
                                @mcu doch das ist dabei. Hatte es nur weggelassen weil die andere Meldung neu ist.
                                  MCU @tofriedrich last edited by MCU
                                  @tofriedrich Nee die war vorher auch schon da. Die Meldung kommt daher, weil dort noch eine sinnlose Funktion drin ist. Trigger ohne etwas auszuführen.
                                  curl -d "{'level':'5'}" -X POST http://192.168.178.24/set_burn_level
                                    @mcu keine Änderung… das komische ist, dass hurn_level auf 0 springt… egal welcher Wert vorher drin stand oder geschrieben wird.
                                      @tofriedrich Also da der burn_level auch als number zurück kommt nehmen wir weitherhin number:
                                      curl -d "{'level':3}" -X POST http://192.168.178.24/set_burn_level
                                        MCU @MCU last edited by
                                        @mcu Kann es sein,das man den Burn_Level nicht beliebig ändern darf?
                                          @mcu es gibt die Werte 0-5. Die bilden die Stufen vom Kamin ab. In der App selbst kann ich die Stufen einstellen.
                                            @tofriedrich Hat die App ein Passwort und Username? Muss man sich beim Kamin anmelden?
                                            4308
