    4. Javascript Adapter Update auf v5.2.11 schlägt fehl
    • BBTown
      BBTown last edited by
      Bei mir schlägt das Update des Javascript Adapter von v5.2.10 auf v5.2.11 fehl und im Log habe ich interessante Fehlermeldungen
      javascript.0
      2021-09-12 00:03:41.982	error	axios-cookiejar-support@1.0.1 requires a peer of @types/tough-cookie@>=2.3.3 but none is installed. You must install peer dependencies yourself.
      javascript.0
      2021-09-12 00:03:39.548	error	deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      javascript.0
      2021-09-12 00:03:37.230	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.0
      2021-09-12 00:03:37.124	error	deprecated har-validator@5.1.5: this library is no longer supported
      2021-09-12 00:03:36.884	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.0
      2021-09-12 00:03:35.174	error	WARN axios-cookiejar-support@1.0.1 requires a peer of @types/tough-cookie@>=2.3.3 but none is installed. You must install peer dependencies yourself.
      javascript.0
      2021-09-12 00:03:32.003	error	WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      Bin ich damit alleine? 😎
      Ehrlich gesagt habe ich noch keine Idee was ich im einzelnen unternehmen sollte 🙃
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Thomas Braun Most Active @BBTown last edited by Thomas Braun
        @bbtown Nein, bist nicht alleine. Gibt ein Issue dazu.
        Wobei die Fehlermeldungen da andere bzw. nicht vorhanden sind
        sissiwup 1 Reply Last reply Reply Quote 1
        • sissiwup
          sissiwup @Thomas Braun last edited by
          bei mir sagt er immer "updated" nur die Version ist nicht neu ...
          BBTown Thomas Braun 2 Replies Last reply Reply Quote 1
          • BBTown
            BBTown @sissiwup last edited by
            @sissiwup es gibt eine neue Version (zumindest bereits auf github)
              Thomas Braun Most Active @sissiwup last edited by
              @sissiwup
              5.2.12 kommt wohl diese Nacht rüber. Einfach abwarten.
              adapter update fehler javascript adapter
