    3. Marktplatz
    4. [Verkauft] CC2652P Zigbee Stick
      Thomas Braun Most Active @sauerstofff last edited by
      @sauerm sagte in [Verkaufe] Neueste Entwicklung: CC2652P Zigbee Stick:
      Aber sollte so die Installation über die Konsole aussehen?
      Ja, so sieht das aus, wenn der serialport gebaut wird.
        sauerstofff @Thomas Braun last edited by
        @thomas-braun Ah, okay. Wieder was gelernt 😊
        Hast du denn noch eine Idee was man machen könnte? Ich finde schon keine neuen Suchergebnisse mehr bei Google 🙈
        Der Adapter startet immer noch nicht. Ich erhalte immer die selben Fehlermeldungen...
        zigbee.0
        2021-09-01 22:14:25.448	error	Error herdsman start
        zigbee.0
        2021-09-01 22:14:25.447	error	Failed to start Zigbee
        zigbee.0
        2021-09-01 22:14:25.445	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        zigbee.0
        2021-09-01 22:14:25.240	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        2021-09-01 22:14:25.181	info	Starting Zigbee npm ...
        zigbee.0
        2021-09-01 22:14:25.179	info	Try to reconnect. 1 attempts left
        zigbee.0
        2021-09-01 22:14:15.176	error	Error herdsman start
        zigbee.0
        2021-09-01 22:14:15.175	error	Failed to start Zigbee
        zigbee.0
        2021-09-01 22:14:15.173	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        zigbee.0
        2021-09-01 22:13:55.693	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        2021-09-01 22:13:55.077	info	Starting Zigbee npm ...
        zigbee.0
        2021-09-01 22:13:55.011	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
        zigbee.0
        2021-09-01 22:13:47.009	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        2021-09-01 22:13:47.006	info	terminating
        zigbee.0
        2021-09-01 22:13:47.005	warn	Failed to stop zigbee during startup
        zigbee.0
        2021-09-01 22:13:46.999	info	cleaned everything up...
        zigbee.0
        2021-09-01 22:13:46.996	info	Got terminate signal TERMINATE_YOURSELF
        zigbee.0
        2021-09-01 22:13:09.311	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
        zigbee.0
        2021-09-01 22:10:16.665	error	Error herdsman start
        zigbee.0
        2021-09-01 22:10:16.664	error	Failed to start Zigbee
        zigbee.0
        2021-09-01 22:10:16.662	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
        zigbee.0
        2021-09-01 22:10:16.486	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        2021-09-01 22:10:16.458	info	Starting Zigbee npm ...
        zigbee.0
        2021-09-01 22:10:16.456	info	Try to reconnect. 1 attempts left
        zigbee.0
        2021-09-01 22:10:06.453	error	Error herdsman start
        zigbee.0
        2021-09-01 22:10:06.452	error	Failed to start Zigbee
        zigbee.0
        2021-09-01 22:10:06.450	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
        zigbee.0
        2021-09-01 22:10:06.267	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        2021-09-01 22:10:05.708	info	Starting Zigbee npm ...
        zigbee.0
        2021-09-01 22:10:05.698	error	Serial port not selected! Go to settings page.
        zigbee.0
        2021-09-01 22:10:05.642	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
        zigbee.0
        2021-09-01 21:47:13.299	error	Cannot read property 'getEntries' of null
        zigbee.0
        2021-09-01 21:47:13.298	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0
        2021-09-01 21:47:13.295	error	unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0
        2021-09-01 21:47:13.294	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        2021-09-01 21:47:13.292	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        2021-09-01 21:47:13.290	info	terminating
        zigbee.0
        2021-09-01 21:47:13.289	warn	Failed to stop zigbee during startup
        zigbee.0
        2021-09-01 21:47:13.286	info	Zigbee: disabling joining new devices.
        zigbee.0
        2021-09-01 21:47:13.281	info	cleaned everything up...
        zigbee.0
        2021-09-01 21:47:13.278	info	Got terminate signal TERMINATE_YOURSELF
          @sauerm
          Mach mal einen eigenen Thread dafür auf.
          Hat ja mit dem Thema 'Verkaufe neueste Entwicklung... ' nix zu tun.
            @thomas-braun ja stimmt 😌
              Falls jemand Probleme hat die Firware für den CC2652P zu finden:
              Unter der Repository die auch oben verlinkt ist die FW "CC1352P2_CC2652P_launchpad_coordinator_[datum].zip" nehmen 🙂 👍
              E 1 Reply Last reply Reply Quote 2
                earl80 @sauerstofff last edited by
                @sauerm bleiben nach einem Update die Geräte erhalten, oder muss alles neu gemacht werden?
                D S 2 Replies Last reply Reply Quote 0
                  dimaiv @earl80 last edited by
                  @earl80 wenn der neueste Adapter 1.6.0 rund läuft, dann zu 99% ja.
                    arteck Developer Most Active @dimaiv last edited by
                    @dimaiv nimm den 1.6.1
                      sauerstofff @earl80 last edited by sauerstofff
                      @earl80 Also, ich musste meine Geräte neu pairen, aber die IDs waren alle noch vorhanden. Ich musste also die Skripte nicht anpassen. Nach dem erneuten pairen lief direkt wieder alles 🙂 👍
                      -> Allerdings hatte ich auch vergessen ein Backup vom Zigbee Adapter zu machen. Wenn man das einspielen kann, ist das natürlich noch besser 🙂
                      • N
                        nachon @sauerstofff last edited by
                        @sauerm
                        Ich habe auch gerade ein Firmware Update gemacht. Hat alles super geklappt.
                        Zigbee Adapter nutze ich allerdings den 1.5.6. Nach dem Firmware Update musste ich nichts neu anlernen. Einfach einstecken und starten und alles hat wieder funktioniert.
                          Ist das FW Update empfehlenswert? Was bringt es und was verpasse ich, wenn ich nicht update?
                            w00dy last edited by w00dy
                            Frage bzgl. neuem Zigbee-Standard "Matter/Thread"
                            Hallo.
                            Ich bin etwas verwirrt, was den neuen, im nächsten Jahr kommenden "Zigbee-Standard" (Chip/Matter/Thread) angeht.
                            Bevor ich den Stick kaufe würde mich interessieren, wie es mit der Kompatibilität des Sticks dazu aussieht. Hier wurde ja schon öfters danach gefragt, aber leider gab es dazu bisher noch keine Kommentare.
                            Ist der Stick nun Kompatibel zu Matter/Thread, bzw. ist die Kompatibilität in Form eines Updates via USB möglich?
                            Oder spielt der neue Standard keine Rolle?
                            Sonst würde ich mit dem Kauf lieber abwarten und schauen, was sich da im nächsten Jahr so tut.
                              dimaiv @w00dy last edited by
                              @w00dy sagte in [Verkaufe] Neueste Entwicklung: CC2652P Zigbee Stick:
                              Hallo.
                              Ich bin etwas verwirrt, was den neuen, im nächsten Jahr kommenden "Zigebee-Standard" (Chip/Matter/Thread) angeht.
                              Ja, der Stick ist laut TI mit Thread kompatibel.
                              Ja, sobald man passende Firmware hat, kann es via USB aufgespielt werden.
                              Ja, der neue Standard spielt noch keine Rolle.
                              P.S.: Bitte für weiteren Diskussionen eine neue Thema aufmachen.
                                Tobi 0 last edited by
                                Mein Stick lässt sich nicht flashen.
                                Nach längerem Suchen bin ich drauf gekommen dass beide Taster auf dem PCB nicht funktionieren (schalten nicht durch). Ich hab dann die Kontakte gebrückt und schon hats geklappt..
                                Also falls jemand ähnliche Probleme hat, dann mal die Taster prüfen..
                                D L 2 Replies Last reply Reply Quote 0
                                  dimaiv @Tobi 0 last edited by
                                  @tobi-0 alle Sticks werden von mir zusammen gebaut und geprüft und geflasht mit über die Taster, mehrmals.
                                  Nur ein Taster muss gedrückt werden...
                                    LarryXXL @Tobi 0 last edited by
                                    This post is deleted!
                                      dimaiv @LarryXXL last edited by
                                      • N
                                        nachon @dimaiv last edited by
                                        @dimaiv
                                        Hi, ich versuche gerade die letzte Firmware aufzuspielen habe aber leider kein Erfolg. Ich erhalte nur die Meldung "Failed".
                                        >Initiate access to target: COM3 using 2-pin cJTAG.
                                        >Reading file: C:/Users/LaKl/Downloads/Zigbee Firmware Update/Firmware/CC1352P2_CC2652P_launchpad_coordinator_20221102/CC1352P2_CC2652P_launchpad_coordinator_20221102.hex.
                                        >Unknown record type: 3.
                                        >Reset target ...
                                        >Reset of target successful.
                                        >No response from device. Device may not be in bootloader mode. Reset device and try again.
                                        If problem persists, check connection and baud rate.
                                        >Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again.
                                        >Failed to create device object.
                                        >Reset target ...
                                        >Reset target ...
                                        >ACK/NAK not received. Expected 0x00 0xCC or 0x00 0x33, received 0x42 0xF3.
                                        >Reset target ...
                                        >ACK/NAK not received. Expected 0x00 0xCC or 0x00 0x33, received 0x00 0xE1.
                                        >Reset target ...
                                        Kann mir wer helfen und mir sagen was ich falsch mache?
                                        Die Buttons habe ich mehrfach gedrückt. Leider ohne Erfolg.
                                        Besten Dank.
                                          dimaiv @nachon last edited by dimaiv
                                          @nachon
                                          Hi. Nach welche Anleitung machst du es? In meiner oben steht nix über mehrfache Tastendrücke...
                                          P.S.: melde dich bitte bei mir über PN oder Telegramm.
                                            Leviathan09 last edited by
                                            Hi @dimaiv,
                                            passt vllt nicht ganz hierein dennoch frage ich mal nach.
                                            Ich habe mir einen deiner Sticks gekauft und bräuchte nun eine neue (evtl. stärkere Antenne; die alte hat es beim Wohnungsumzug zerlegt)
                                            Eine WLAN-Antenne die ich hier noch rumliegen hatte geht leider nicht da der "Draht" im Anschluss fehlt.
                                            Kannst du mir vllt sagen nach was für einer Antenne ich suchen könnte? Oder hast du vllt einen Link zu einer passenden Antenne?
                                            Besten Dank
                                            81.1k
                                            cc2531 cc2538 cc2652 cc26x2r1 modkam modkamru slaesh ti board zigbee zigbee stick
                                            45
                                            155
                                            45763
